  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • pentti12P pentti12
    Here is the serial monitor printout from MySensors W5100 Gateway. I think that this listing is OK, but still there is no actual temperature nor humidity values at control screen of OH2 .
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.201
    0;255;3;0;9;TSP:SANCHK:OK
    0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.6
    0;255;3;0;9;TSP:MSG:READ 9-9-0 s=10,c=1,t=1,pt=7,l=5,sg=0:37.9
    0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.7
    0;255;3;0;9;TSP:MSG:READ 9-9-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=9)
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-9-9 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
    0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
    0;255;3;0;9;TSP:MSG:READ 9-9-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSP:MSG:PINGED (ID=9, hops=1)
    0;255;3;0;9;TSP:MSG:SEND 0-0-9-9 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
    0;255;3;0;9;TSP:MSG:READ 9-9-0 s=10,c=1,t=1,pt=7,l=5,sg=0:38.0
    The problem must be on OpenHAB2 side. What to do next?
    jogantJ
    jogantJ
    jogant
    @pentti12
    you are right, your serial log looks ok. So at least your mysensors network is up and running. In the moment the gateway receives an update from a sensor you should also see an incoming message in OH log. If this is not the case there might be something wrong with your binding config. You know https://github.com/tobof/openhab2-addons/wiki? There are valuable hints. Only difference to my setup is that I'm using mysensors 2.0.1 beta. No idea whether this makes any difference. Besides that I have no further idea. Sorry.
    • pentti12P
      pentti12P
      pentti12
      I see from OH2 event log:
      2016-11-22 06:17:43.911 [hingStatusInfoChangedEvent] - 'mysensors:bridge-eth:19d1e911' changed from UNINITIALIZED to INITIALIZING
      2016-11-22 06:17:43.937 [hingStatusInfoChangedEvent] - 'mysensors:bridge-eth:19d1e911' changed from INITIALIZING to ONLINE
      2016-11-22 06:19:49.491 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_battery' received command REFRESH
      2016-11-22 06:20:05.658 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_temp' received command REFRESH
      2016-11-22 06:21:08.469 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_battery' received command REFRESH
      And from OH2 log:
      2016-11-22 06:11:11.125 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
      2016-11-22 06:11:11.194 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
      2016-11-22 06:11:11.251 [ERROR] [rs.protocol.ip.MySensorsIpConnection] - Error while trying to connect InputStreamReader
      2016-11-22 06:11:11.255 [ERROR] [rs.protocol.ip.MySensorsIpConnection] - Something went wrong!
      2016-11-22 06:11:11.322 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
      2016-11-22 06:12:08.388 [INFO ] [ome.io.rest.core.thing.ThingResource] - Received HTTP PUT request for update configuration at 'things/mysensors:bridge-eth:gateway/config' for an unmanaged thing 'mysensors:bridge-eth:gateway'.
      2016-11-22 06:12:32.535 [INFO ] [ome.io.rest.core.thing.ThingResource] - Received HTTP PUT request for update at 'things/mysensors:bridge-eth:gateway' for an unmanaged thing 'mysensors:bridge-eth:gateway'.
      2016-11-22 06:12:51.983 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
      2016-11-22 06:12:51.990 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
      2016-11-22 06:12:52.016 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
      2016-11-22 06:12:52.072 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
      2016-11-22 06:14:46.978 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
      2016-11-22 06:14:46.986 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
      2016-11-22 06:14:47.045 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
      So there are some problems at least on test.things file:
      Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.1.201", tcpPort=5003, sendDelay=200, imperial=false ] {
      /** define things connected to that bridge here */
      humidity hum01 [ nodeId="9", childId="10" ]
      temperature temp01 [ nodeId="9", childId="11" ]
      Any advice?
      jogantJ 1 Reply Last reply
        And from OH2 log:
        Any advice?
        jogantJ
        jogantJ
        jogant
        @pentti12
        ahh, try to leave out thing definition in config file and let OH discover things. After discovery remember to restart mysensors binding like @TimO explained. Then link discovered things to items and see if that works.
        Are you shure about your sonsor IDs? Usually they are numbered starting with 0.
        • pentti12P
          pentti12P
          pentti12
          No success!
          I ended up to the same situation, no real values of temperature nor humidity.
          OH2 cannot search things automatically. I added them manually after I configured the MySensors Gateway.
          jogantJ T 2 Replies Last reply
            No success!
            jogantJ
            jogantJ
            jogant
            @pentti12
            here you see a snippet from my log while in DEBUG mode for mysensors binding:
            10:57:19.269 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            10:57:29.271 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            10:57:39.273 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            10:57:39.820 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_EG_WZ_R_signal changed from -50 to -51
            10:57:42.145 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;21;0
            10:57:42.171 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2016-11-22T10:57:42.169+0100
            10:57:42.174 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2016-11-22T10:57:42.172+0100
            10:57:49.274 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            10:57:50.476 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_UG_Ki_Li_signal changed from -61 to -60
            10:57:59.276 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            10:57:59.465 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_UG_SZ_signal changed from -68 to -67
            10:58:09.278 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            10:58:19.280 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            10:58:29.282 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            10:58:30.810 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;23;80
            10:58:30.817 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.815+0100
            10:58:30.824 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.822+0100
            10:58:30.833 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.831+0100
            10:58:30.837 [INFO ] [marthome.event.ItemStateChangedEvent] - Lightlevel changed from 81 to 80
            10:58:39.284 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            Here is the mysensors part my default.things
            Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.96.9", tcpPort=5003, sendDelay=200 ] {
            0_1479809074466_upload-a4b1d17f-3056-4c44-9f95-13fbeccae68b
            0_1479809140350_upload-320df1cc-3f4d-4893-8a5e-dc44d0045cba
            and the mysensors part of my items:
            /* mysensors Licht/Temp/Hum */
            Number Lightlevel "Helligkeit [%.0f %%]" <sun> (gLicht)                         { channel="mysensors:light-level:gateway:Light_level_1_0:light-level" }
            Number mySensors1Hum "Luftfeuchte [%.1f %%]" <water>                            { channel="mysensors:humidity:gateway:Humidity_1_1:hum" }
            Number mySensors1Temp "Temperatur [%.1f °C]" <temperature>                      { channel="mysensors:temperature:gateway:Temperature_1_2:temp" }
            Maybe this is of any help as I don't have an idea what's wrong with your config.
              No success!
              TimO
              Hi @pentti12 !
              Stop searching, there is a bug in the binding. I'm working on it. ;-)
              • pentti12P
                pentti12P
                pentti12
                OK, TimO!
                I will wait for the new version until I continue!
                Pentti
                T 1 Reply Last reply
                • T TimO
                  Hi @pentti12 !
                  jogantJ
                  jogantJ
                  jogant
                  @TimO
                  funny that it works for me :smiley:
                  • jogantJ jogant
                    @TimO
                    TimO
                    @jogant Sadly it works fine in my devolpment and test environment, too. ;-)
                    If you are using a OH2 snapshot that is older than 11 days there is a chance that it still works but it's not predictable.
                    • T TimO
                      jogantJ
                      jogantJ
                      jogant
                      @TimO
                      ok, I'm using OH2 b4, that is definitely older than 11 days.
                        OK, TimO!
                        Pentti
                        TimO
                        @pentti12 I've pushed a new version of the binding to github, please try it out and let me know if it helps.
                        • pentti12P
                          pentti12P
                          pentti12
                          Now I got only MySensors Ethernet Gateway into ONLINE state. The Humidity and Temperature Sensors (Things) stay UNINITIALIZED state.
                            TimO
                            @pentti12 Have you deleted the things and newly discovered them? When the binding changes the mapdb (where discovered devices are stored) isn't updated as well. That's why I'm using the *.things files instead. If you try to remove the items errors could occure, this is another hint that this is the problem. After restart of OH2 the things should disappear.
                            Another way to do this is:
                            1. stop OH2
                            2. rm /var/lib/openhab2/mapdb/*
                            3. start OH2
                            But this will delete all discovered things (not only MySensors)!
                            • pentti12P
                              pentti12P
                              pentti12
                              I removed mapdb and things disappeared. I started OH2 again, but I got only MySensors Ethernet Gateway into ONLINE state after adding them manually The Humidity and Temperature Sensors (Things) stay UNINITIALIZED state.
                                TimO
                                @pentti12 What does the log say?
                                JicJ 1 Reply Last reply
                                • T TimO
                                  JicJ
                                  JicJ
                                  Jic
                                  @TimO I have exactly the same problem.
                                  My event.log is:
                                  2016-11-22 20:45:24.043 [temChannelLinkRemovedEvent] - Link 'mysensors_door_gateway_door01_armed => mysensors:door:gateway:door01:armed' has been removed.
                                  2016-11-22 20:54:35.089 [ItemChannelLinkAddedEvent ] - Link 'door01_tripped-mysensors:door:gateway:door01:tripped' has been added.
                                  2016-11-22 20:54:35.097 [ItemChannelLinkAddedEvent ] - Link 'door01_lastupdate-mysensors:door:gateway:door01:lastupdate' has been added.
                                  2016-11-22 20:54:35.671 [ThingAddedEvent           ] - Thing 'mysensors:bridge-ser:gateway' has been added.
                                  2016-11-22 20:54:35.682 [ThingAddedEvent           ] - Thing 'mysensors:door:gateway:door01' has been added.
                                  2016-11-22 20:54:36.702 [hingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from UNINITIALIZED to INITIALIZING
                                  2016-11-22 20:54:36.713 [hingStatusInfoChangedEvent] - 'mysensors:door:gateway:door01' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
                                  2016-11-22 20:54:40.191 [hingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from INITIALIZING to ONLINE
                                  2016-11-22 20:54:40.262 [hingStatusInfoChangedEvent] - 'mysensors:door:gateway:door01' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                                  2016-11-22 20:54:40.462 [hingStatusInfoChangedEvent] - 'mysensors:door:gateway:door01' changed from INITIALIZING to OFFLINE
                                  And my openhab.log is:
                                  2016-11-22 20:58:10.295 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                  2016-11-22 20:58:11.254 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;4;1;0;16;1
                                  2016-11-22 20:58:16.264 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;0;23
                                  2016-11-22 20:58:20.297 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                  2016-11-22 20:58:21.279 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;4;1;0;16;0
                                  2016-11-22 20:58:26.295 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;0;23
                                  2016-11-22 20:58:30.300 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                  2016-11-22 20:58:31.319 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;4;1;0;16;1
                                  I have downloaded your last binding, and the last version of MySensors. Thanks
                                  • pentti12P
                                    pentti12P
                                    pentti12
                                    Event log:
                                    2016-11-22 18:57:07.915 [hingStatusInfoChangedEvent] - 'mysensors:humidity:dd0f7b9e' changed from UNINITIALIZED to INITIALIZING
                                    2016-11-22 18:57:07.928 [hingStatusInfoChangedEvent] - 'mysensors:humidity:dd0f7b9e' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                                    And Openhba log:
                                    2016-11-22 18:57:07.924 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'mysensors:humidity:dd0f7b9e': java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                                    java.util.concurrent.ExecutionException: java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                                    at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_101]
                                    at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_101]
                                    at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                                    at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                                    at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                                    at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:761)[103:org.eclipse.smarthome.core.thing:0.9.0.201611102032]
                                    at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_101]
                                    at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_101]
                                    at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_101]
                                    at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_101]
                                    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
                                    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
                                    at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
                                    Caused by: java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                                    at org.openhab.binding.mysensors.internal.handler.MySensorsThingHandler.getBridgeHandler(MySensorsThingHandler.java:284)
                                    at org.openhab.binding.mysensors.internal.handler.MySensorsThingHandler.initialize(MySensorsThingHandler.java:74)
                                    at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:764)
                                    at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)
                                    at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)
                                    ... 3 more
                                    • pentti12P
                                      pentti12P
                                      pentti12
                                      Update:
                                      I started from the scratch. I installed debian MATE and OH2-offline snapshot. I put the org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar into addons folder. I started openhab2 and after a while I got MySensors Ethernet Gateway and Temperature and Humidity Sensors ONLINE state.
                                      But still I cannot see any temperature nor humidity values from my sensors!
                                      Here is the Karaf Log after I pressed MySensorsGateway Reset button:
                                      08:35:40.194 [ERROR] [otocol.MySensorsNetworkSanityChecker] - Retry period expired, gateway is down. Disconneting bridge...
                                      08:35:40.196 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Request disconnection flag setted to: true
                                      08:35:44.213 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Connection request disconnection...
                                      08:35:44.215 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Request disconnection flag setted to: false
                                      08:35:44.217 [INFO ] [otocol.MySensorsNetworkSanityChecker] - Network Sanity Checker thread stopped
                                      08:35:44.223 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                                      08:35:44.227 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                                      08:35:44.241 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
                                      08:35:44.244 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                                      08:35:44.246 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
                                      08:35:44.261 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to OFFLINE for device: mysensors:humidity:a825a6a7
                                      08:35:44.263 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.201:5003]
                                      08:35:44.267 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to OFFLINE for device: mysensors:temperature:43712fbc
                                      08:35:44.295 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Skipping I_VERSION connection test, not recommended...
                                      08:35:44.305 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:43712fbc' changed from ONLINE to OFFLINE
                                      08:35:44.305 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:a825a6a7
                                      08:35:44.313 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:43712fbc
                                      08:35:44.325 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                                      08:35:44.349 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:d18f7f4c' changed from ONLINE to OFFLINE
                                      08:35:44.354 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a825a6a7' changed from ONLINE to OFFLINE
                                      08:35:44.361 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:d18f7f4c' changed from OFFLINE to ONLINE
                                      08:35:44.373 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a825a6a7' changed from OFFLINE to ONLINE
                                      08:35:44.392 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:43712fbc' changed from OFFLINE to ONLINE
                                      08:35:54.341 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                      So what to do next?
                                      • JicJ
                                        JicJ
                                        Jic
                                        I think that your sensor will be online also when your node are switched off. I am working with SerialGateway not with ethernet, so I am not sure.
                                        Can you send us your .things and your .items? Have you write or automatically discover them?
                                        And output from your node?
                                        Keep the sensor connected to your computer and enable the Serial Monitor in the Arduino IDE. Tools>Serial Monitor.
                                        • pentti12P
                                          pentti12P
                                          pentti12
                                          Openhab2 detected things automatically, I don't use my own. Here is the sensor node monitor listing:
                                          B´AÚXStarting sensor (RNNNA-, 2.0.0)
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSP:ASSIGNID:OK (ID=9)
                                          TSM:FPAR
                                          TSP:MSG:SEND 9-9-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSP:MSG:READ 0-0-9 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          TSP:MSG:PAR OK (ID=0, dist=1)
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:CHKID:OK (ID=9)
                                          TSM:UPL
                                          TSP:PING:SEND (dest=0)
                                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                          TSP:MSG:READ 0-0-9 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          TSP:MSG:PONG RECV (hops=1)
                                          TSP:CHKUPL:OK
                                          TSM:UPL:OK
                                          TSM:READY
                                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                          !TSP:MSG:SEND 9-9-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=ok:My Bedroom
                                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                                          TSP:MSG:SEND 9-9-0-0 s=10,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:SEND 9-9-0-0 s=11,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:SEND 9-9-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                          Request registration...
                                          TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                          TSP:MSG:READ 0-0-9 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                          Node registration=1
                                          Init complete, id=9, parent=0, distance=1, registration=1
                                          !TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:21.8
                                          T: 21.80
                                          TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=1,st=ok:24.2
                                          H: 24.20
                                          TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:24.6
                                          H: 24.60
                                          TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.9
                                          T: 21.90
                                          TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:25.4
                                          H: 25.40
                                          TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.0
                                          T: 22.00
                                          !TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=fail:25.3
                                          H: 25.30
                                          It is operating normally and it send both temperature and humidity values.
