MySensors Ethernet Gateway goes to OFFLINE state
@TimO Good news! I finally got it to work; I have been using the dev, 2.1.0, and decided to try master, 2.0.0 and it came right up! I did notice one thing though that you may be interested in: if I start the ethGateway after OH2 is up, or turn it off and back on, the binding does not reconnect. Not sure if there is anything you can do about that.
One other change to mention (before changing to v2.0.0): I found a note from hek about the node id of gateway local sensors will always be 0; I changed that in my things file and in my sketch.16:34:59.286 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;12.5 16:34:59.291 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2016-12-10T16:34:59.289-0500 16:34:59.300 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2016-12-10T16:34:59.297-0500 16:34:59.333 [INFO ] [marthome.event.ItemStateChangedEvent] - bTemp changed from 12.8 to 12.5 16:34:59.354 [INFO ] [marthome.event.ItemStateChangedEvent] - bTempF changed from 55.04 to 54.50 16:34:59.365 [INFO ] [marthome.event.ItemStateChangedEvent] - bTempC_F changed from 12.8 °C / 55.0 °F to 12.5 °C / 54.5 °F 16:34:59.490 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped 16:34:59.583 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;0;1;0;1;34.1 16:34:59.593 [INFO ] [marthome.event.ItemStateChangedEvent] - bHum changed from 34.2 to 34.1@hek I could be wrong, or maybe something has changed configuration wise but as you can see from above posts, dev branch v2.1.0, the radioless ethernet (ESP8266) gateway with local temp & hum sensors was not sending local sensor data. When I switched back to master v2.0.0 it started sending.
@carlyler
The issue with the oh2 binding is known. You have to restart oh2 or just the binding through oh console and binding:restart
Maybe an update of the binding may help but I didn't try yet. -
@pentti12 I've pushed a new version of the binding to github, please try it out and let me know if it helps.
@TimO
yesterday I tried the new binding with OH2 b4 and I have exactly the faulty behavior as described before. The gateway goes in online state but none of the mysensor node items goes online. They remain uninitialized. I restored the older binding and everything works well again. As it is the same behavior that @pentti12 describes I think it has to with the binding itself.@pentti12 : please try attached binding as that works for me. 0_1482134888619_org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
it is an older snapshot from November, 7th.
Good luck -
@TimO
Good luck -
@jogant you're right, as stated in the wiki the current binding version is only working together with the current snapshot release. I had no luck while trying to create a binding that is backward compatible.
now I tried the new combination of a recent OH2 snapshot as of 2016-12-21 with the recent mysensors binding. I had to restart the gateway and every single node but then everything works well. The nodes were found in the inbox and could be acknowledged as new things. Values are transmitted regularly and my relay node follows the switch items as desired. So no glitch at the moment.
Well done @TimO.
