  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 38.5k Views 6 Watching
  • pentti12P pentti12
    Openhab2 detected things automatically, I don't use my own. Here is the sensor node monitor listing:
    B´AÚXStarting sensor (RNNNA-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=9)
    TSM:FPAR
    TSP:MSG:SEND 9-9-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSP:MSG:READ 0-0-9 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=9)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-9 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
    !TSP:MSG:SEND 9-9-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
    TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
    TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=ok:My Bedroom
    TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
    TSP:MSG:SEND 9-9-0-0 s=10,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 9-9-0-0 s=11,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 9-9-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    Request registration...
    TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    TSP:MSG:READ 0-0-9 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=9, parent=0, distance=1, registration=1
    !TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:21.8
    T: 21.80
    TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=1,st=ok:24.2
    H: 24.20
    TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:24.6
    H: 24.60
    TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.9
    T: 21.90
    TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:25.4
    H: 25.40
    TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.0
    T: 22.00
    !TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=fail:25.3
    H: 25.30
    It is operating normally and it send both temperature and humidity values.
    J Offline
    J Offline
    jogant
    @pentti12
    everytime you see a SEND message in the node debug log, you should also see a READ message in your gateway. And than you should also see a SEND message to the controller and a message coming in in your openhab binding.
    So would you mind start logging all three stages of the message at the same time as I showed several posts before? If you don't see incoming messages in the binding log there is something wrong with your ethernet connection. Otherwise it's only guessing whats wrong.
    • pentti12P Offline
      pentti12P Offline
      pentti12
      Before I set up full logging environment, I wonder why I cannot get connection when I enter following command on the terminal window of OH2 server (Pine64):
      telnet localhost 5003
      unable to connect to remote host
      J 1 Reply Last reply
      • JicJ Offline
        JicJ Offline
        Jic
        I didn't see in your node log an ip assignament. Are your sketch configured to Ethernet Gateway?
        I think you should use some parameters:
        #define MY_IP_ADDRESS 192,168,178,87
        #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
        I am not sure how to use Ethernet Gateway, perhaps this example help you
        https://github.com/mysensors/MySensors/blob/development/examples/GatewayW5100MQTTClient/GatewayW5100MQTTClient.ino
        • pentti12P Offline
          pentti12P Offline
          pentti12
          I am not using the MQTT gateway, I am using standard GatewayW5100.ino, which has correct IP-settings:
          #define MY_IP_ADDRESS 192,168,1,201 // If this is disabled, DHCP is used to retrieve address
          #define MY_PORT 5003
          #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 185
          // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
          And MySensors Ethernet Gateway is detected by Advanced IP Scanner and I can ping it and so on..
          JicJ 1 Reply Last reply
            J Offline
            J Offline
            jogant
            @pentti12
            the gateway is the server. You should succeed with telnet <ip_of_mysensors_gw> 5003
              JicJ Offline
              JicJ Offline
              Jic
              @pentti12
              Can you start manually your gateway with -d option to see the log?
              You should see there if your gateway its receiving messages. If you are receiving message then, the problem should be in the OH2
              • JicJ Jic
                @pentti12
                J Offline
                J Offline
                jogant
                @Jic
                what do you mean with "start gateway manually -d option"? My gateway is a standalone device, ethernet connector on one side, nrf24 on the other, arduino in the middle connecting the other two parts.
                • pentti12P Offline
                  pentti12P Offline
                  pentti12
                  Wait a minute! I think that from the original GatewayW5100 sketch there were missing the IP Gateway and subnet addresses!
                  So I will recompile sketch and test again.
                    J Offline
                    J Offline
                    jogant
                    wrote on last edited by jogant
                    #49
                    @pentti12
                    slowly my image gets complete. Online/Offline status is resolved by OH2 binding via polling during initialization. Value updates are sent spontaneous by the gateway via callback, afair. So the gateway needs to know the address and mask of the controller to send values.
                    • pentti12P Offline
                      pentti12P Offline
                      pentti12
                      No help after new sketch loaded into GatewayW5100. OH2 log informs the same result:
                      14:49:09.484 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                      I will take a break - to be continued on next day...
                        J Offline
                        J Offline
                        jogant
                        @pentti12
                        "connection skipped" message occurs frequently, usually every 10 seconds. That is normal and ok. But you should see messages from the gateway everytime the sensor nodes send updates, except the value is the same as before.
                        • pentti12P Offline
                          pentti12P Offline
                          pentti12
                          I connected my laptop into Ethernet Gateway. Here is a sample of monitoring listing:
                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.4
                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:21.9
                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.5
                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.0
                          0;255;3;0;9;TSP:SANCHK:OK
                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.6
                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.7
                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:21.8
                          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.8
                          So I think that this is OK, when I have only one sensor node alive.
                          But still, how I shall modify my Arduino Gateway sketch in order to get OH2 server show temperature and humidity values?
                            JicJ Offline
                            JicJ Offline
                            Jic
                            @pentti12
                            Could be permission problem?
                            Can you connect your gateway on rpi and execute
                            ls -l /dev/tty*
                            I think you are using a ethernet gateway skecth, normaly it's should be mounted in /dev/ttyACM0
                            Have you already execute
                            sudo usermod -a -G dialout openhab
                            Be sure that you have the las binding
                            https://github.com/tobof/openhab2-addons/blob/MySensors/addons/binding/org.openhab.binding.mysensors/target/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                            and your openhab2 is updated.
                            • pentti12P Offline
                              pentti12P Offline
                              pentti12
                              I am running the Ethernet GatewayW5100 software on Arduino UNO. I don't have rpi, I have installed OH2 on Pine64. It is running debian Jessie and it is uptodate. Also the latest mysensors binding is in use. So what to next?
                                JicJ Offline
                                JicJ Offline
                                Jic
                                wrote on last edited by Jic
                                #55
                                @pentti12 I am confused.
                                Don't you need to connect your Ethernet GatewayW5100 by USB into your pine64?
                                • pentti12P Offline
                                  pentti12P Offline
                                  pentti12
                                  OK, now Gateway is connected via USB into Pine64 and it is shown as /dev/ttyUSB0.
                                    JicJ Offline
                                    JicJ Offline
                                    Jic
                                    @pentti12 said:
                                    /dev/ttyUSB0
                                    Now, you need to configure your binding in your OH2?
                                    https://github.com/tobof/openhab2-addons/wiki/Configuration
                                    • pentti12P Offline
                                      pentti12P Offline
                                      pentti12
                                      I added into demo.things following line:
                                      Bridge mysensors:bridge-ser:gateway [ serialPort="dev/ttyUSB0", sendDelay=200 ] {
                                      In OH2 MySensor Serial Gateway stays OFFLINE state now. And also the Philips HUE things went OFFLINE state even if they have their own Bridge.
                                      Looks bad!
                                        Looks bad!
                                        JicJ Offline
                                        JicJ Offline
                                        Jic
                                        @pentti12 This configuration is for a Serial Gateway connected to GPIO, I think.
                                        You should use this one
                                        Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ] {
                                             /** define things connected to that bridge here */
                                        But at this point I am really confused, I don't know how Ethernet Gateway works. I am not sure when I can help you.
                                        Do you need configure you ESSID and password of your WIFI in your sketch? or the ethernet Gateway geneate their own network?
                                        • pentti12P Offline
                                          pentti12P Offline
                                          pentti12
                                          Now I am confused, why I should bridge Ethernet Gateway, if I have USB-connection to MySensors Gateway only?
                                          I tried to use Ethernet Gateway connected into my local IP-network without success, so I think that I will end this work to this point. There seems no good instructions available what is missing or wrong on the MySensors openhab binding..
