MySensors Hvac device
Hi All,
i Successfully created a hvac node and connected it to HASS, i can see that the climate device on HASS has the option to get the current temperature from the device.
Does any one knows if the MySensors Havc platform supports sending temperature? if i send V_TEMP message from that node will it be shown in HASS in the climate device as current temp?
Hi All,
Yes, the platform supports reporting current temperature using V_TEMP. The documentation doesn't mention this and needs updating:
https://home-assistant.io/components/climate.mysensors/PR for this is welcome.
@martinhjelmare cool, thanks i will try to PR this later.
Great! I haven't seen a PR for this. Did you make one?
