  3. Newbe error question: #error No forward link or gateway feature activated
9 Posts 3 Posters 3.2k Views 3 Watching
    A Former User
    I'm very new to this. Trying to construct the dimmable mirror. I added the libraries and tried to verify the code. I did change #include <MySensor.h> to #include <MySensors.h> because an error message said couldn't find MySensor. Now it get this error message and not sure what means:
    C:\Users\Documents\Arduino\libraries\MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
      Did you use the following example?
      https://www.mysensors.org/build/dimmer
        A Former User
        No, I used https://forum.mysensors.org/topic/936/backlit-dimmable-led-mirror-with-motion-sensor/2
        I tried the code from that example and had no issues.
          A Former User
          Sorry, had no issues when I tried https://www.mysensors.org/build/dimmer
          • ? A Former User
            is for MySensors 1.x. It won't work with 2.x unless it is converted.
              A Former User
              Where do I go to find out what need to be done and how to convert it?
                https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                  A Former User
                  Thanks, got it working. There still is a error message:
                  In function 'void loop()':
                  warning: comparison is always false due to limited range of data type [-Wtype-limits]
                       fadeLevel = fadeLevel < 0 ? 0 : fadeLevel;
                  Not to worry??
                    Nothing to worry about.
