  3. How to build a repeater
14 Posts 4 Posters 9.2k Views 3 Watching
  • S
    stingone
    Hello everyone.
    I cant find a clear solution how to build a repeater. i have a tempsensor on 40m distance from my gateway and want to build a repeater in between.
    Can anyone tell me what to do achieving this e.g. sample code etc..
    Thanks..
    ramoncarranzaR 1 Reply Last reply
    • scalzS
      scalzS
      Here it is https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes
      lot of great docs on main site though ;)
      S ramoncarranzaR 2 Replies Last reply
      • scalzS scalz
        stingone
        so do i need to use for each sensor a repeater? copy the sensor code and add the #define MY_REPEATER_FEATURE in the top of the code?
        • S stingone
          Hello everyone.
          Thanks..
          ramoncarranzaR
          ramoncarranzaR
          ramoncarranza
          @stingone hi, the mysensor master library comes with an example file to create a "RepeaterNode" I've built 4 of them using an Arduino nano and a radio module ( https://www.mysensors.org/build/connect_radio) they work very well for me.
          S 1 Reply Last reply
          • scalzS scalz
            ramoncarranzaR
            ramoncarranzaR
            ramoncarranza
            @scalz Thanks so much I was looking for something like this as well, thanks again
            • ramoncarranzaR ramoncarranza
              stingone
              @ramoncarranza
              So just using that example code is enough?
              • S stingone
                @ramoncarranza
                ramoncarranzaR
                ramoncarranzaR
                ramoncarranza
                @stingone yep all you have to do is upload it to your radio set-up and that's it, but you do waste a board and a radio unit, but in MY case is well worth it.
                  stingone
                  @ramoncarranza
                  Ok so no need to change any code in my original sensor? and will it send multiple values from more sensors if picked-up?
                  • ramoncarranzaR
                    ramoncarranzaR
                    ramoncarranza
                    no need to change anything on your original sensors and and yes it will relay signals from multiple sensors to your gateway/controller. Just our of curiosity, what controller are you using???
                    S 2 Replies Last reply
                      stingone
                      wrote on last edited by stingone
                      Using pimatic v9. on a raspberry pi 3. I already build a mysensors combined temp/ph sensor. But had to change the code in mysensors v2.0. I'm using lot of 433mhz over more then 25 devices.. but im now changing also towards mysensors :). so the mysensors is a little bit new to me.
                        stingone
                        Just build the repeater today..how can i see check if it is working properly??
                        Nevermind its working :):) just received the information on the repeater... great support thanks
                        • S
                          stingone
                          Now testing for few day's and i see that one of my sensors stops working after few minutes.. the one that is most close to the gateway... after resetting it sends af few minutes and then stops working again...
                          • S stingone
                            @stingone what does the serial debug output say?
                              stingone
                              TSM:UPL
                              TSP:PING:SEND (dest=0)
                              !TSP:MSG:SEND 6-6-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                              TSP:CHKUPL:FAIL (hops=255)
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              TSP:MSG:SEND 6-6-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                              !TSP:SEND:TNR
                              TSP:MSG:READ 5-5-6 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                              TSP:MSG:FPAR RES (ID=5, dist=1)
                              TSP:MSG:PAR OK (ID=5, dist=2)
                              !TSP:SEND:TNR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:CHKID:OK (ID=6)
                              TSM:UPL
                              !TSP:MSG:SEND 6-6-5-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              Init complete, id=6, parent=255, distance=255, registration=1
                              !TSP:SEND:TNR```
                              TSM:INIT
                              TSM:RADIO:OK
                              TSP:ASSIGNID:OK (ID=6)
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
