  3. [Solved]Radio Error on Sensor
17 Posts 3 Posters 4.5k Views 3 Watching
    martim
    wrote on last edited by tekka
    I am a starter. I build my gateway and this seems to work! No error messages and when I attach a local sensor and I can see this information on the controller (Homey). But when I create a sensor device I get and error in the logging which I do not understand. I spend the whole day but I cannot find the issue. Tried different nrf24l01 radio modules but no change.
    See logging below. What could be wrong?
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    tekkaT 1 Reply Last reply
    • M martim
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      tekkaT
      tekkaT
      tekka
      @martim This is a common power-related issue. Try adding a larger cap on your radio(s) (>=10uF)
        martim
        I tried this already but no differences (tried 4,7 uF until 47uF). Below I have the start log where something is about an CHKID fail:
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        TSP:MSG:PAR OK (ID=0, dist=1)
        TSM:FPAR:OK
        TSM:ID
        TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
        TSM:ID
        TSM:ID
        TSM:ID
        !TSM:CHKID:FAIL (ID=255)
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE```
        • M martim
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR:OK
          TSM:ID
          TSM:ID
          TSM:ID
          TSM:ID
          !TSM:FAILURE
          TSM:PDT
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE```
          tekkaT
          tekkaT
          tekka
          @martim That looks already better:
          (1) make sure to add a large cap on both, GW and node
          (2) your controller software does not appear to assign IDs (hence the CHKID:FAIL) - set a static ID using:
          #define NODE_ID 123
          M 1 Reply Last reply
          • tekkaT tekka
            #define NODE_ID 123
            martim
            @tekka
            Thanks for helping!
            I already have this in my code. This is the code for my Node:
            #define MY_BAUD_RATE 115200
            // Enable debug prints
            #define OPEN 1
            #define CLOSE 0
            #define NODE_ID 123
            MyMessage msg(NODE_ID, V_TRIPPED);
            uint8_t value = OPEN;
            void presentation() {
              sendSketchInfo("Dummy sensor", "1.0");
               present(NODE_ID, S_DOOR);
                value = value == OPEN ? CLOSE : OPEN;
                send(msg.set(value));
                sleep(10000);
            and it still gives this message? Can this be an error in the Gateway?
            • M martim
              @tekka
              Thanks for helping!
              #define OPEN 1
              #define CLOSE 0
              #define NODE_ID 123
                  sleep(10000);
              @martim
              #define NODE_ID 123
              must be done before
                @martim
                #define NODE_ID 123
                must be done before
                martim
                @mfalkvidd said:
                @martim
                #define NODE_ID 123
                must be done before
                thanks. But still same error!?!
                • M martim
                  @mfalkvidd said:
                  @martim
                  #define NODE_ID 123
                  must be done before
                  @martim and you followed tekka's recommendation on adding capacitors?
                    martim
                    wrote on last edited by martim
                    @mfalkvidd
                    Yes I did. 47uF
                    • M martim
                      @mfalkvidd
                      Yes I did. 47uF
                      tekkaT
                      tekkaT
                      tekka
                      @martim Please post the full debug log from your GW and node.
                        martim
                        GW:
                        0;255;3;0;9;TSM:INIT
                        0;255;3;0;9;TSM:RADIO:OK
                        0;255;3;0;9;TSM:GW MODE
                        0;255;3;0;9;TSM:READY
                        scandone
                        f 0, scandone
                        state: 0 -> 2 (b0)
                        state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        aid 11
                        cnt
                        connected with CycloneIT, channel 11
                        dhcp client start...
                        ...ip:192.168.10.218,mask:255.255.255.0,gw:192.168.10.1
                        .IP: 192.168.10.218
                        pm open,type:2 0
                        0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;TSP:MSG:BC
                        0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
                        0;255;3;0;9;TSP:CHKUPL:OK
                        0;255;3;0;9;TSP:MSG:GWL OK
                        0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
                        0;255;3;0;9;TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                        0;255;3;0;9;TSP:SANCHK:OK
                        Node:
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:ID
                        TSM:ID
                        TSM:ID
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:ID
                        TSM:ID
                        TSM:ID
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:ID
                        TSM:ID
                        TSM:ID
                        !TSM:FAILURE
                        TSM:PDT
                        • M martim
                          GW:
                          scandone
                          f 0, scandone
                          state: 0 -> 2 (b0)
                          state: 2 -> 3 (0)
                          state: 3 -> 5 (10)
                          add 0
                          aid 11
                          cnt
                          .IP: 192.168.10.218
                          pm open,type:2 0
                          Node:
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:ID
                          TSM:ID
                          TSM:ID
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:ID
                          TSM:ID
                          TSM:ID
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:ID
                          TSM:ID
                          TSM:ID
                          !TSM:FAILURE
                          TSM:PDT
                          @martim the node is still requesting an ID. Are you sure you moved the #define NODE_ID 123 ?
                            martim
                            My Sensor code:
                               The MySensors Arduino library handles the wireless radio link and protocol
                               between your home built sensors/actuators and HA controller of choice.
                               The sensors forms a self healing radio network with optional repeaters. Each
                               repeater and gateway builds a routing tables in EEPROM which keeps track of the
                               network topology allowing messages to be routed to nodes.
                               Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
                               Copyright (C) 2013-2015 Sensnology AB
                               Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
                               Documentation: http://www.mysensors.org
                               Support Forum: http://forum.mysensors.org
                               This program is free software; you can redistribute it and/or
                               modify it under the terms of the GNU General Public License
                               version 2 as published by the Free Software Foundation.
                               REVISION HISTORY
                               Version 1.0 - Henrik EKblad
                               DESCRIPTION
                               This sketch provides an example how to implement a distance sensor using HC-SR04
                               http://www.mysensors.org/build/distance
                            #define OPEN 1
                            #define CLOSE 0
                            #define NODE_ID 123
                                sleep(10000);
                            • M martim
                              My Sensor code:
                                 REVISION HISTORY
                                 DESCRIPTION
                              #define OPEN 1
                              #define CLOSE 0
                              #define NODE_ID 123
                                  sleep(10000);
                              tekkaT
                              tekkaT
                              tekka
                              @martim uupps, my bad - should be MY_NODE_ID instead of NODE_ID
                              • tekkaT tekka
                                martim
                                @tekka
                                That was indeed the trick :joy: :thumbsup: This is really awesome.
                                Final question. The Node register know with the GW if I am correct. And when I change a port how fast is this send to the gateway?
                                I would like to connect a doorbell and use an interrupt when someone is pressing on the doorbell.
                                • M martim
                                  @tekka
                                  @martim the current code sleeps 10 seconds. So it might take up to 10 seconds before a press is registered. The sleep can be modified to wake on interrupt instead. See https://www.mysensors.org/download/sensor_api_20#sleeping for general i formation about the sleep function and https://www.mysensors.org/build/motion for an example that wakes on interrupt.
                                    martim
                                    @mfalkvidd
                                    Thanks! Some study to do :)
