  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • R Reza
    @Tag
    Could you setup my sensors gateway on orange pi one? if you can please help me to build this . thank you
    Tag
    wrote on last edited by Tag
    #41
    @Reza
    Unfortunately the mysgw software does not run native on the OPI systems at this moment.The only option today is to add an arduino to the USB port running i.e the serial gateway sketch (if you do not want to use the USB port, an other option would be using an UART trough the GPIO header, you data will show up on i.e. /dev/ttyS1 if UART 1 is used)
    step 2 will be to install controller software.
    (i tested MyController on the OPI and that works like a charm, and looks pretty cool!)
    See this link on how to build a serial gateway on the arduino. Using this setup you can follow the RaspberryPI tutorials.
    Hopefully mysgw will run soon on the OrangePI systems! think this is work in progress......
      marceloaqno
      Code Contributor
      #42
      I'm trying to add support for Orange Pi to MySensors, this is the work-in-progress repository:
      https://github.com/marceloaqno/MySensors/tree/spidev
      It would be great if someone could test and submit results from the configure and make commands:
      git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
      cd marceloaqno-spidev
      git checkout spidev
      ./configure
      make
      T 2 Replies Last reply
      • M marceloaqno
        git checkout spidev
        ./configure
        make
        Tag
        @marceloaqno
        Hi!, really appreciate your hard work on this!!, below are the results,
        (I was not able to execute the 1st command :( but... tried something else..
        root@orangepizero:~# git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
        Cloning into 'marceloaqno-spidev'...
        remote: Counting objects: 13834, done.
        remote: Compressing objects: 100% (26/26), done.
        remote: Total 13834 (delta 2), reused 0 (delta 0), pack-reused 13808
        Receiving objects: 100% (13834/13834), 9.67 MiB | 3.16 MiB/s, done.
        Resolving deltas: 100% (8289/8289), done.
        Checking connectivity... done.
        root@orangepizero:~# cd marceloaqno-spidev
        root@orangepizero:~/marceloaqno-spidev# git checkout spidev
        Branch spidev set up to track remote branch spidev from origin.
        Switched to a new branch 'spidev'
        root@orangepizero:~/marceloaqno-spidev# ./configure
        [SECTION] Detecting target machine.
        [OK] machine detected: SoC=H3, Type=unknown, CPU=armv7l.
        [SECTION] Detecting SPI driver.
        [OK] SPI driver detected:SPIDEV.
        [SECTION] Detecting init system.
        [OK] init system detected: systemd.
        [SECTION] Saving configuration.
        [SECTION] Cleaning previous builds.
        [OK] Finished.
        root@orangepizero:~/marceloaqno-spidev# make
        gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
        g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
        g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
        g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
        g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
        g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
        g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
        g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
        g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
        g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
        g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
        g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
        g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
        /tmp/ccVhf8xP.s: Assembler messages:
        /tmp/ccVhf8xP.s:14808: Warning: IT blocks containing 32-bit Thumb instructions are deprecated in ARMv8
        g++ -MT build/drivers/SPIDEV/SPI.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/SPIDEV/SPI.cpp -o build/drivers/SPIDEV/SPI.o
        g++ -pthread -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/compatibility.o build/drivers/Linux/interrupt.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/SPIDEV/SPI.o
        root@orangepizero:~/marceloaqno-spidev# ll bin
        total 640
        -rwxr-xr-x 1 root root 654544 Jan 7 22:48 mysgw
        Seems we have a binary!!
        :D
        • M marceloaqno
          git checkout spidev
          ./configure
          make
          Tag
          #44
          @marceloaqno
          Just hooked up a radio to the GPIO header. (used this link for the model 1 RPI https://www.mysensors.org/build/raspberry and attached the interrupt pin also to pin 15)
          This is the result i get
          root@orangepizero:~/marceloaqno-spidev/bin# mysgw
          mysgw: Starting gateway...
          mysgw: Protocol version - 2.2.0-beta
          mysgw: Could not open /sys/class/gpio/gpio10/direction
          Illegal instruction
          M 2 Replies Last reply
          • T Tag
            @marceloaqno
            Illegal instruction
            marceloaqno
            Code Contributor
            #45
            @Tag Great! The mapping of the physical GPIO number in OrangePi is not ready yet, so you need to figure out the correct value for the CE and CSN pins by adding this to the examples_linux/mysgw.cpp or MyConfig.h
            #define MY_RF24_CE_PIN X
            #define MY_RF24_CS_PIN Y
            This is the best pinout image I've found that could help:
            https://oshlab.com/orange-pi-zero-pinout/
            This may also give you some hint:
            cat /sys/kernel/debug/gpio
            M 1 Reply Last reply
            • M marceloaqno
              marceloaqno
              Code Contributor
              #46
              @Tag Maybe this one can help too:
              http://orange314.com/WiringOP
              • M marceloaqno
                marceloaqno
                Code Contributor
                @Tag also, please don't set the interrupt pin for now.
                • T Tag
                  @marceloaqno
                  Illegal instruction
                  marceloaqno
                  Code Contributor
                  @Tag I found more information on the wiki page about the gpio pins:
                  http://linux-sunxi.org/GPIO
                  It seems that there is a calculation to be made to know which number to use :scream:
                  • T
                    Tag
                    #49
                    @marceloaqno
                    Hi!!, many thanks for the info!! really helpful!
                    Made some progress. first I created this table based on this page: http://linux-sunxi.org/GPIO
                    Pin - Num - Name - Calculated value A=1 ((1-1)*32 + Pin)
                    CE / 22 / PA02 / 2
                    SCK / 23 / PA14 / 14
                    MISO / 21 / PA16 / 16
                    CSN / 24 / PA13 / 13
                    MOSI / 19 / PA15 / 15
                    Now it is important that you know which kernel is used on your systems the 4.x architecture is different compared to the 3.x arch...
                    If the 4.x kernel is used you need to use the calculated value for the GPIO pin numbering, i could not test that since I am using the 3.x kernel, so this is what i did:
                    1. load the GPIO kernel module:
                    modprobe gpio-sunxi
                    1. Create the GPIO device files since these were not available on my system by default.
                    for A in 1 2 3 4 5 6 7 8 9 10 11 12; do echo "$A" > /sys/class/gpio/export ; done
                    This created the following entries in /sys/class/gpio
                    root@orangepizero:~/marceloaqno-spidev/bin# ls -l /sys/class/gpio
                    total 0
                    --w------- 1 root root 4096 Jan  8 07:39 export
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio1 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio1
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio11 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio11
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio12 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio12
                    lrwxrwxrwx 1 root root    0 Jan  8 07:32 gpio13 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio13
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio2 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio2
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio3 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio3
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio4 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio4
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio5 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio5
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio6 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio6
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio7 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio7
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio8 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio8
                    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio9 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio9
                    lrwxrwxrwx 1 root root    0 Jan  1  1970 gpiochip0 -> ../../devices/platform/sunxi-pinctrl/gpio/gpiochip0
                    --w------- 1 root root 4096 Jan  1  1970 unexport
                    Modified mysgw.cpp to use:
                    #define MY_RF24_CE_PIN 2
                    #define MY_RF24_CS_PIN 13
                    And did a clean build:
                    make clean
                    ./configure
                    make
                    Now some thing has changed! :)
                    root@orangepizero:~/marceloaqno-spidev/bin# ./mysgw -d
                    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.2.0-beta
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: !TSM:INIT:TSP FAIL
                    mysgw: TSM:FAIL:CNT=1
                    mysgw: TSM:FAIL:PDT
                    Will do some more testing with an LED today see if the GPIO pin numbering that was created is okay,
                    will keep you posted!:
                    • T
                      Tag
                      #50
                      @marceloaqno
                      Did some testing,
                      Setup the GPIO pins:
                      modprobe gpio-sunxi
                      for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
                      done
                      (The device files that are created by the commands above do not survive a reboot, so remember to execute the above commands after each reboot!)
                      Hooked up an led between ground and i.e. pin 22, this pin is linked to GPIO2
                      Then:
                      echo out > /sys/class/gpio/gpio2/direction
                      echo 1 > /sys/class/gpio/gpio2/value
                      echo 0 > /sys/class/gpio/gpio2/value
                      And eureka!! Led went on and off :D
                      Did this for all GPIO ports used by mysgw, below is the verified pin / GPIO table
                      Pin#  -  GPIO / NRF24
                      22 - GPIO2   / CE
                      23 - GPIO14  / SCK
                      21 - GPIO16  / MISO
                      24 - GPIO13  / CSN
                      19 - GPIO15  / MOSI
                      Tested all pins and led went on and off on all
                      How i connected the radio: https://www.mysensors.org/build/raspberry (see the Pi1 part)
                      How to setup GPIO: http://linux-sunxi.org/GPIO (3.x kernel part, and added pin 13/14/15/16)
                      Pinout for the OPI Zero: https://i1.wp.com/oshlab.com/wp-content/uploads/2016/11/Orange-Pi-Zero-Pinout-banner2.jpg?fit=1200%2C628&ssl=1 (carefully look at the pin numbering!)
                      Maybe it is usefull, I rebuild mysgw with NRF24 radio debugging enabled, this is the output I get:
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: RF24:write register, reg=0, value=14
                      mysgw: RF24:write register, reg=3, value=3
                      mysgw: RF24:write register, reg=4, value=95
                      mysgw: RF24:write register, reg=5, value=76
                      mysgw: RF24:write register, reg=6, value=39
                      mysgw: RF24:write register, reg=16, value=115
                      mysgw: RF24:write register, reg=29, value=6
                      mysgw: RF24:read register, reg=6, value=0
                      mysgw: RF24:read register, reg=5, value=0
                      mysgw: !RF24:INIT:SANCHK FAIL
                      mysgw: TSM:FAIL:PDT
                      mysgw: RF24:write register, reg=0, value=12
                      mysgw: RF24:PD
                      ^Cmysgw: Received SIGINT
                      keeps looping, until ctrl-c is given.
                      • T Tag
                        @marceloaqno
                        CE / 22 / PA02 / 2
                        modprobe gpio-sunxi
                        total 0
                        make clean
                        ./configure
                        make
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: TSM:FAIL:PDT
                        mihai.aldea
                        CE / 22 / PA02 / 482
                        SCK / 23 / PA14 / 494
                        MISO / 21 / PA16 / 496
                        CSN / 24 / PA13 / 493
                        MOSI / 19 / PA15 / 495
                        Are you sure this is correct?
                        The formula is: (position of letter in alphabet - 1) * 32 + pin number
                        For PA02 for instance the correct value is:
                        PA02 = (1 - 1) * 32 + 02 = 2
                        Actually you don't need to use the formula at all with the PA ports, all you have to do is use the trailing number.
                        T 1 Reply Last reply
                        • M mihai.aldea
                          Tag
                          @mihai.aldea
                          You are right, took the letter P, which is 16.... but is should have been A.... (for the 4.x kernel)
                          Updated the table!,
                          Thx!!
                          • R
                            R
                            Reza
                            wrote on last edited by Reza
                            #53
                            i have problem in build gateway on orangepi one
                            root@OrangePI:~/marceloaqno-spidev# make
                            Makefile:16: Makefile.inc: No such file or directory
                            [Running configure]
                            [OK] Finished.
                            gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                            g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                            g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                            g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                            g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                            g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                            g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                            g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                            g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                            g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                            drivers/Linux/interrupt.cpp: In function ‘void* interruptHandler(void*)’:
                            drivers/Linux/interrupt.cpp:107:26: warning: ignoring return value of ‘ssize_t read(int, void*, size_t)’, declared with attribute warn_unused_result [-Wunused-result]
                               (void)read (fd, &c, 1) ;
                            g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                            g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                            g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                            In file included from ./MySensors.h:294:0,
                                             from examples_linux/mysgw.cpp:74:
                            ./drivers/RF24/RF24.cpp:39:11: error: Not supported on this platform.
                              hwDigitalWrite(MY_RF24_CS_PIN, level);
                            ./drivers/RF24/RF24.cpp:44:11: error: Not supported on this platform.
                              hwDigitalWrite(MY_RF24_CE_PIN, level);
                            ./drivers/RF24/RF24.cpp:388:11: error: Not supported on this platform.
                              hwPinMode(MY_RF24_CE_PIN,OUTPUT);
                            ./drivers/RF24/RF24.cpp:389:11: error: Not supported on this platform.
                              hwPinMode(MY_RF24_CS_PIN,OUTPUT);
                            ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
                             LOCAL void RF24_csn(const bool level)
                            ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
                             LOCAL void RF24_ce(const bool level)
                            ./drivers/RF24/RF24.cpp: In function ‘uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)’:
                            ./drivers/RF24/RF24.cpp:56:11: error: ‘LOW’ was not declared in this scope
                              RF24_csn(LOW);
                            ./drivers/RF24/RF24.cpp:99:11: error: ‘HIGH’ was not declared in this scope
                              RF24_csn(HIGH);
                            ./drivers/RF24/RF24.cpp: In function ‘void RF24_startListening()’:
                            ./drivers/RF24/RF24.cpp:235:10: error: ‘HIGH’ was not declared in this scope
                              RF24_ce(HIGH);
                            ./drivers/RF24/RF24.cpp: In function ‘void RF24_stopListening()’:
                            ./drivers/RF24/RF24.cpp:241:10: error: ‘LOW’ was not declared in this scope
                              RF24_ce(LOW);
                            ./drivers/RF24/RF24.cpp: In function ‘void RF24_powerDown()’:
                            ./drivers/RF24/RF24.cpp:251:10: error: ‘LOW’ was not declared in this scope
                              RF24_ce(LOW);
                            ./drivers/RF24/RF24.cpp: In function ‘bool RF24_sendMessage(uint8_t, const void*, uint8_t)’:
                            ./drivers/RF24/RF24.cpp:269:10: error: ‘HIGH’ was not declared in this scope
                              RF24_ce(HIGH);
                            ./drivers/RF24/RF24.cpp:276:10: error: ‘LOW’ was not declared in this scope
                              RF24_ce(LOW);
                            ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
                            ./drivers/RF24/RF24.cpp:395:10: error: ‘LOW’ was not declared in this scope
                              RF24_ce(LOW);
                            ./drivers/RF24/RF24.cpp:396:11: error: ‘HIGH’ was not declared in this scope
                              RF24_csn(HIGH);
                            Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
                            make: *** [build/examples_linux/mysgw.o] Error 1
                            i want build a gateway with orangepi one with channel 0 . what am i do ? thank you
                            • R Reza
                              [Running configure]
                              [OK] Finished.
                                RF24_csn(LOW);
                                RF24_csn(HIGH);
                                RF24_ce(HIGH);
                                RF24_ce(LOW);
                                RF24_ce(LOW);
                                RF24_ce(HIGH);
                                RF24_ce(LOW);
                                RF24_ce(LOW);
                                RF24_csn(HIGH);
                              marceloaqno
                              Code Contributor
                              @Reza You need to run:
                              modprobe gpio-sunxi
                              so that /sys/class/gpio/export is created.
                              • T Tag
                                @mihai.aldea
                                Updated the table!,
                                Thx!!
                                marceloaqno
                                Code Contributor
                                #55
                                @Tag Does the TMRh20 works in the way your radio is currently connected?
                                • M marceloaqno
                                  Tag
                                  #56
                                  @marceloaqno
                                  The library compiled, but unfortunately i cannot get the examples for linux working.
                                  need to edit i.e. gettingstarted.cpp with the correct pin setting, have tried a lot, but either it says that the radio is not connected, and if used with incorrect settings it will not compile at all....
                                  Maybe someone following this thread who has experince with this lib?
                                  if there is any progress from my side will keep you posted...
                                    mihai.aldea
                                    wrote on last edited by mihai.aldea
                                    #57
                                    If you used this wiring scheme:
                                    nRF24L01 | Orange Pi
                                    _________|________________
                                    VCC      | VCC3V3-EXT
                                    GND      | GND
                                    CSN      | SPI0_CS0 (SPI-CE0)
                                    CE       | PA7 (IO-7)
                                    MOSI     | SPI0_MOSI (SPI-MOSI)
                                    SCK      | SPI0_CLK (SPI-CLK)
                                    MISO     | SPI0_MISO (SPI-MISO)
                                    Then you should initialize the radio with:
                                    RF24 radio(7,0);
                                    Worked for me:
                                    root@opi-pc-1:~/RF24-master/examples_linux# ./gettingstarted
                                    RF24/examples/GettingStarted/
                                    STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                                    RX_ADDR_P0-1	 = 0x65646f4e32 0x65646f4e31
                                    RX_ADDR_P2-5	 = 0xc3 0xc4 0xc5 0xc6
                                    TX_ADDR		 = 0x65646f4e32
                                    RX_PW_P0-6	 = 0x20 0x20 0x00 0x00 0x00 0x00
                                    EN_AA		 = 0x3f
                                    EN_RXADDR	 = 0x02
                                    RF_CH		 = 0x4c
                                    RF_SETUP	 = 0x07
                                    CONFIG		 = 0x0e
                                    DYNPD/FEATURE	 = 0x00 0x00
                                    Data Rate	 = 1MBPS
                                    Model		 = nRF24L01+
                                    CRC Length	 = 16 bits
                                    PA Power	 = PA_MAX
                                     ************ Role Setup ***********
                                    Choose a role: Enter 0 for pong_back, 1 for ping_out (CTRL+C to exit)
                                    M T 2 Replies Last reply
                                    • M mihai.aldea
                                      VCC      | VCC3V3-EXT
                                      GND      | GND
                                      CE       | PA7 (IO-7)
                                      RF24 radio(7,0);
                                      Worked for me:
                                      EN_AA		 = 0x3f
                                      EN_RXADDR	 = 0x02
                                      RF_CH		 = 0x4c
                                      RF_SETUP	 = 0x07
                                      CONFIG		 = 0x0e
                                      Data Rate	 = 1MBPS
                                      Model		 = nRF24L01+
                                      PA Power	 = PA_MAX
                                      marceloaqno
                                      Code Contributor
                                      @mihai.aldea Could you try the repo I'm working on (https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev) adding your settings to the examples_linux/mysgw.cpp?
                                      #define MY_RF24_CE_PIN 7
                                      #define MY_RF24_CS_PIN 0
                                      • M mihai.aldea
                                        VCC      | VCC3V3-EXT
                                        GND      | GND
                                        CE       | PA7 (IO-7)
                                        RF24 radio(7,0);
                                        Worked for me:
                                        EN_AA		 = 0x3f
                                        EN_RXADDR	 = 0x02
                                        RF_CH		 = 0x4c
                                        RF_SETUP	 = 0x07
                                        CONFIG		 = 0x0e
                                        Data Rate	 = 1MBPS
                                        Model		 = nRF24L01+
                                        PA Power	 = PA_MAX
                                        Tag
                                        #59
                                        @mihai.aldea
                                        Hmmm.... checked the docs again and guess what. the 26 pin header on the OPI Zero has SPI1.... instead of SPI0
                                        Expansion Port
                                        The Orange Pi Zero has a 26-pin, 0.1" unpopulated connector with several low-speed interfaces.
                                        2x13 Header
                                        1	3.3V	           2	5V
                                        3	TWI0_SDA / PA12	   4	5V
                                        5	TWI0_SCK / PA11	   6	GND
                                        7	PWM1 / PA06	       8	UART1_TX / PG06
                                        9	GND	               10	UART1_RX / PG07
                                        11	UART2_RX / PA01	   12	SIM_CLK/PA_EINT7 / PA07
                                        13	UART2_TX / PA00	   14	GND
                                        15	UART2_CTS / PA03   16	TWI1-SDA / PA19
                                        17	3.3V	           18	TWI1-SCK / PA18
                                        19	SPI1_MOSI / PA15   20	GND
                                        21	SPI1_MISO / PA16   22	UART2_RTS / PA02
                                        23	SPI1_CLK / PA14    24	SPI1_CS / PA13
                                        25	GND	               26	SIM_DET/PA_EINT10 / PA10
                                        From http://linux-sunxi.org/Xunlong_Orange_Pi_Zero
                                        If i look at /dev I only see spi0, which is most probably used for the onboard flash...
                                        root@orangepizero:/# ll /dev | grep -i spi
                                        crw------- 1 root root    153,   0 Jan  8 11:12 spidev0.0
                                        So now i need to figure out a way to get SPI1 up and running
                                        • M marceloaqno
                                          mihai.aldea
                                          @marceloaqno Here's the output:
                                          ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                                          In file included from ./drivers/RF24/RF24.cpp:23:0,
                                                           from ./MySensors.h:294,
                                                           from examples_linux/mysgw.cpp:77:
                                          ./drivers/RF24/RF24.h:52:17: fatal error: SPI.h: No such file or directory
                                          compilation terminated.
                                          Makefile:98: recipe for target 'build/examples_linux/mysgw.o' failed
