  3. Sending sensor data from raspberry via NRF24L01+ to arduino
33 Posts 4 Posters 10.4k Views 3 Watching
  • LaMB95L Offline
    LaMB95L Offline
    LaMB95
    I have been looking at instructions to set up a communication system where I can send my Arduino data to a Raspberry Pi via a NRF24L01+.
    I have used this link: https://www.youtube.com/watch?v=_68f-yp63ds&lc=z12wivkbyr3uzleri04ccblr3wflyntwpgk
    While everything run there is no data sent or received.
    If anyone could give me an advice or correction or even provide me with a new insturction link it would help !
    I am planning to send ultrasonic data or a HMC5883L data to the pi.
    • LaMB95L LaMB95
      @LaMB95 welcome to the MySensors community!
      Doing that with MySensors is fairly easy. Create a gateway, either directly attached to the raspberry pi gpio pins (https://www.mysensors.org/build/raspberry ) or using a serial gateway (https://www.mysensors.org/build/serial_gateway )
      An example for sending data from a ultrasound distance sensor is available at https://www.mysensors.org/build/distance
      Be aware that using MySensors is VERY different from the instructions provided in the video you linked. You might want to start reading the getting started guide, https://www.mysensors.org/about
      • LaMB95L Offline
        LaMB95L Offline
        LaMB95
        Thank you so much for getting back to me!
        When you mean serial gateway is it something where the Arduino is directly connected to the pi?
        I wasn't sure which code to implement on the Arduino to send the sensor data.
        What I need is a code from the Arduino to send the data from an ultrasonic sensor to a database (or something) on the pi using the NRF modules.
        • LaMB95L LaMB95
          @LaMB95 You might want to start reading the getting started guide, https://www.mysensors.org/about
          • LaMB95L Offline
            LaMB95L Offline
            LaMB95
            I have been working on the installation of the libraries.
            I have Added them to the Arduino ide software but when I run the gateway serial code it shows that
            fatal error: MySensors.h: No such file or directory
            compilation terminated.
            What is causing this?
            PS I am using a Macbook
            mfalkviddM LaMB95L 2 Replies Last reply
            • LaMB95L LaMB95
              @LaMB95 seems like the MySensors library isn't installed. Did you follow the instructions on https://www.mysensors.org/about/arduino#installing-the-sensor-libraries ? If so, did you get any error messages?
                I'm doing a project very similar to yours. Mysensors library can be installed from library manager in arduino ide, just like many other libraries.
                • LaMB95L LaMB95
                  LaMB95L Offline
                  LaMB95L Offline
                  LaMB95
                  wrote on last edited by LaMB95
                  @mfalkvidd @gohan
                  Just resolved the issue !
                  Apparently my Arduino Ide wasnt updated to the lastest version which explains why I never found the Library Manager :P
                  • LaMB95L LaMB95
                    @mfalkvidd @gohan
                    Great that you found the problem @LaMB95, thanks for reporting back. It might help someone else in the future if they have the same problem :)
                    LaMB95L 1 Reply Last reply
                      LaMB95L Offline
                      LaMB95L Offline
                      LaMB95
                      @mfalkvidd
                      Thanks !
                      However I am still facing some issues trying to set up a gateway with the raspberry pi,
                      Do you know who could help me with that ?
                      • LaMB95L LaMB95
                        @mfalkvidd
                        Thanks !
                        @LaMB95 just create a new thread describing what you have done, what result you got and what result you expected and we'll help.
                        • H Offline
                          H Offline
                          hugo_pn
                          wrote on last edited by hugo_pn
                          I'm having problems exactly the same as @LaMB95
                          The MySensors library is installed, at least is says so doing as shown in the link @mfalkvidd sent.
                          This is my error:
                          DallasTemperatureSensor.ino:36:25: fatal error: MySensors.h: No such file or directory
                          Compilation terminated.
                          LaMB95L gohanG 2 Replies Last reply
                          • H hugo_pn
                            This is my error:
                            LaMB95L Offline
                            LaMB95L Offline
                            LaMB95
                            @hugo_pn
                            Okay could you check what version of Arduino IDE you have now ?
                            If there is a newer version upgrade to that.
                            My issue was that I could not find the library manager in the version I had.
                            Hope it helps !
                            • H hugo_pn
                              This is my error:
                              @hugo_pn
                              You don't have the mysensors library installed
                              • H Offline
                                H Offline
                                hugo_pn
                                Hi all,
                                @LaMB95
                                I'll have to get back to you later on that.
                                @gohan
                                The software says it's installed. Is there a way to uninstall and install again?
                                gohanG 1 Reply Last reply
                                • H hugo_pn
                                  Hi all,
                                  @LaMB95
                                  @gohan
                                  @hugo_pn
                                  from library manager you can install, remove, update the libraries. You can try to remove from the Arduino IDE and try to copy the library manually where you have all the libraries
                                  • H Offline
                                    H Offline
                                    hugo_pn
                                    Hi all,
                                    Sorry for the delay, my IDE is 1.6.5 going to try and update.
                                    Thanks in advance.
                                    cheers
                                    • H Offline
                                      H Offline
                                      hugo_pn
                                      Got it working, IDE updated and everything working.
                                      My temperature already getting values.
                                      Going to try and attached another DS18B20 as shown in the example.
                                      Don´t really know what is going to show up.
                                        Just change the node ID and you shouldn't have any problem
                                          LaMB95L Offline
                                          LaMB95L Offline
                                          LaMB95
                                          @gohan
                                          I am facing an issue while sending data from an Arduino pro mini 5V to an arduino UNO. Receiving a lot of garbage from the Pro mini.
                                          Any idea why ?
