  3. !TSM:FPAR:FAIL node and gateway communication problems?
31 Posts 9 Posters 22.1k Views 8 Watching
  • agtigA
    agtigA
    agtig
    I don't know what I am missing, but I am trying to get a node on an Ardunio Pro Mini, running the Door/Window sketch to send data using a NRF24L01+ card to an Arduino Mega gateway using the same card.
    I have soldered a 4.7micro ferad condenser on both of them... I have tried running the Pro Mini on batteries - still to no avail.
    I have no controller as it is right now - is this necessary?
    The gateway seems to startup properly, gives no error messages... it concludes with
    0;255;3;0;9;MC0;BGN:INIT OK, TSP=1
    I have turned off registration in MyConfig.h to ease the setup, but nothing helped.
    The node gives the following errors:
    3675664 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    3677673 !TSM:FPAR:NO REPLY
    3677675 TSM:FPAR
    3677775 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    3679787 !TSM:FPAR:FAIL
    3679789 TSM:FAIL:CNT=7
    3679791 TSM:FAIL:PDT
    If anyone have any suggestions I will be more than happy!
    Will try with bigger capacitors in a few hours...
    Greetings,
    Robert
    • F
      F
      Fabien
      Wich controller you use ? Node ID attribution is coming from controller, not gateway.
      agtigA 1 Reply Last reply
      • F Fabien
        agtigA
        agtigA
        agtig
        @Fabien I am not using a controller. Can it run alone, or can I set up the Arduino Mega gateway as a controller as well?
        • agtigA
          agtigA
          agtig
          I have hooked up the Arduino Pro mini with the sensor to a laboratory power supply, which should be very precise. No change in the log...
          0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
          4 TSM:INIT
          4 TSF:WUR:MS=0
          12 TSM:INIT:TSP OK
          14 TSF:SID:OK,ID=3
          16 TSM:FPAR
          114 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2123 !TSM:FPAR:NO REPLY
          2125 TSM:FPAR
          2226 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4235 !TSM:FPAR:NO REPLY
          4237 TSM:FPAR
          4337 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          6346 !TSM:FPAR:NO REPLY
          6348 TSM:FPAR
          6449 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          8458 !TSM:FPAR:FAIL
          8460 TSM:FAIL:CNT=1
          8462 TSM:FAIL:PDT
          18466 TSM:FAIL:RE-INIT
          Will try with a larger capacitor, even though I don't think it will do much difference, when I use this power supply...
          • agtigA
            agtigA
            agtig
            Tried with a ceramic 47 micro farad condenser to no avail...
            • agtigA agtig
              @agtig could you post the debug log from your gateway?
              Edit: sorry, I see that you already did.
                agtigA
                agtigA
                agtig
                @mfalkvidd Kind of... Here is the log of the gateway in full length ;-)
                0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSF:WUR:MS=0
                0;255;3;0;9;TSM:INIT:TSP OK
                0;255;3;0;9;TSM:INIT:GW MODE
                0;255;0;0;18;2.1.0
                0;255;3;0;9;MCO:BGN:STP
                If this helps... I will try using the older version of the sketch for both the sensor and the gateway...
                • agtigA
                  agtigA
                  agtig
                  Now I downgraded to version 2.0, but the same problem remains.
                  It seems that the problem resides with the sensor?
                  At least it is the sensor that complains...
                  Or is my problem that I am trying to run this without a controller?
                  TSM:PDT
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=254)
                  TSM:FPAR
                  TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  • F
                    F
                    Fabien
                    did you try https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
                    According with this flowchart, you can try to change radio on node.
                    • agtigA
                      agtigA
                      agtig
                      I have now rewired all the cables, and made it neat, plus changed the radio, but nothing helps...
                      I still get a:
                      !TSM:FFPAR:FAIL
                      !TSM:FAILURE
                        I am joining discussione as I have same problem. Here is the sensor node running on a Mega2560 with sketch MotionSensor from Mysensors examples
                        3 TSM:INIT
                        4 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        13 TSM:INIT:STATID=2
                        14 TSF:SID:OK,ID=2
                        16 TSM:FPAR
                        1615 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        3623 !TSM:FPAR:NO REPLY
                        3625 TSM:FPAR
                        5225 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        7232 !TSM:FPAR:NO REPLY
                        7234 TSM:FPAR
                        8834 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        10841 !TSM:FPAR:NO REPLY
                        10843 TSM:FPAR
                        12442 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        14449 !TSM:FPAR:FAIL
                        14450 TSM:FAIL:CNT=1
                        14452 TSM:FAIL:PDT
                        24455 TSM:FAIL:RE-INIT
                        This is gateway running on a UNO with sketch Serial Gateway from MySensors examples
                        0;255;0;0;18;2.1.0
                        0;255;3;0;9;TSF:SAN:OK
                        I tried with both a power regulator for NRF24 and with a 10uF on both sides.
                        • D
                          D
                          David
                          wrote on last edited by David
                          Hi all,
                          are you with Arduino IDE 1.8.0 ?
                          If yes did you try to downgrade the AVR version of Arduino 1.8.0 ?
                          Check the last two posts in this thread: https://forum.mysensors.org/topic/4801/building-an-ethernet-gateway/15
                          I'm not sure it will solve the problem but not bad to try.
                          • D David
                            Hi all,
                            agtigA
                            agtigA
                            agtig
                            @David Well, I just saw an update to the boards had been released, so first I tried updating that, but resulting in the same error.
                            Then I downgraded the boards to version 1.6.11 as recommended in the thread you linked to, but still resulting in the same error.
                            But thanks for the tip... Well, am really scratching my head on this problem.
                            Can anyone verify that a controller is not needed for the communication between the sensor and the gateway to work?
                            • agtigA
                              agtigA
                              agtig
                              It seems to me that the sensor is trying to find a parent, but fails?
                              • agtigA agtig
                                A controller is needed for dynamic id assignment. Since you are using static id a controller is not requored. The node should find its parent (= the gateway unless you have repeater(s)) anyway.
                                  agtigA
                                  agtigA
                                  agtig
                                  @mfalkvidd Should both the gateway and the sensor have static id's? (different of course)
                                  • agtigA agtig
                                    @agtig a gateway always has the static id 0. So yes they will both have static id to work without a controller.
                                    • agtigA
                                      agtigA
                                      agtig
                                      I just found this other forum post, which might be the answer to my issues: https://forum.mysensors.org/topic/5671/loosing-my-mind-sensor-not-talking-to-esp-gw-latest-2-2-0-beta/2
                                      I too have bought the radios with a blob instead of an IC.
                                      I too have ordered different radios - the ones that are recommended here in the shop.
                                      Had just hoped to be able to figure out how to get the ones I have to work. If anyone have any other ideas, or would like me to post some code, please let me know. I am running pretty standard from the example, only added MY_NODE_ID in the top...
                                        I sent back my radios with blob and ordered other with IC: according to users' feedback they are working.
                                          wrote on last edited by gohan
                                          i got the new NRF24 modules and it looks they are working. it looks like they are clones but at least I am not getting errors on startup like the others. For reference on the chip the code is 1609AH
                                          PS I did some tests on range with RF24_PA_MAX but I can get maximum 6-7 meters on same floor with 2 walls. Not as much as I would have expected.
                                          xelnahaX T 2 Replies Last reply
