!TSM:FPAR:FAIL node and gateway communication problems?
I don't know what I am missing, but I am trying to get a node on an Ardunio Pro Mini, running the Door/Window sketch to send data using a NRF24L01+ card to an Arduino Mega gateway using the same card.
I have soldered a 4.7micro ferad condenser on both of them... I have tried running the Pro Mini on batteries - still to no avail.
I have no controller as it is right now - is this necessary?
The gateway seems to startup properly, gives no error messages... it concludes with0;255;3;0;9;MC0;BGN:INIT OK, TSP=1I have turned off registration in MyConfig.h to ease the setup, but nothing helped.
The node gives the following errors:
3675664 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 3677673 !TSM:FPAR:NO REPLY 3677675 TSM:FPAR 3677775 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 3679787 !TSM:FPAR:FAIL 3679789 TSM:FAIL:CNT=7 3679791 TSM:FAIL:PDTIf anyone have any suggestions I will be more than happy!
Will try with bigger capacitors in a few hours...
Greetings,
Robert -
I have hooked up the Arduino Pro mini with the sensor to a laboratory power supply, which should be very precise. No change in the log...
0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0 4 TSM:INIT 4 TSF:WUR:MS=0 12 TSM:INIT:TSP OK 14 TSF:SID:OK,ID=3 16 TSM:FPAR 114 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2123 !TSM:FPAR:NO REPLY 2125 TSM:FPAR 2226 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 4235 !TSM:FPAR:NO REPLY 4237 TSM:FPAR 4337 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 6346 !TSM:FPAR:NO REPLY 6348 TSM:FPAR 6449 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 8458 !TSM:FPAR:FAIL 8460 TSM:FAIL:CNT=1 8462 TSM:FAIL:PDT 18466 TSM:FAIL:RE-INITWill try with a larger capacitor, even though I don't think it will do much difference, when I use this power supply...
@agtig could you post the debug log from your gateway?
Edit: sorry, I see that you already did.@mfalkvidd Kind of... Here is the log of the gateway in full length ;-)
0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0 0;255;3;0;9;TSM:INIT 0;255;3;0;9;TSF:WUR:MS=0 0;255;3;0;9;TSM:INIT:TSP OK 0;255;3;0;9;TSM:INIT:GW MODE 0;255;3;0;9;TSM:READY:ID=0,PAR=0,DIS=0 0;255;3;0;9;MCO:REG:NOT NEEDED 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.1.0 0;255;3;0;9;MCO:BGN:STP 0;255;3;0;9;MCO:BGN:INIT OK,TSP=1If this helps... I will try using the older version of the sketch for both the sensor and the gateway...
Now I downgraded to version 2.0, but the same problem remains.
It seems that the problem resides with the sensor?
At least it is the sensor that complains...
Or is my problem that I am trying to run this without a controller?TSM:PDT TSM:INIT TSM:RADIO:OK TSP:ASSIGNID:OK (ID=254) TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSM:FPAR:FAIL !TSM:FAILURE -
did you try https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
According with this flowchart, you can try to change radio on node. -
I am joining discussione as I have same problem. Here is the sensor node running on a Mega2560 with sketch MotionSensor from Mysensors examples
0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0 3 TSM:INIT 4 TSF:WUR:MS=0 11 TSM:INIT:TSP OK 13 TSM:INIT:STATID=2 14 TSF:SID:OK,ID=2 16 TSM:FPAR 1615 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 3623 !TSM:FPAR:NO REPLY 3625 TSM:FPAR 5225 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 7232 !TSM:FPAR:NO REPLY 7234 TSM:FPAR 8834 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 10841 !TSM:FPAR:NO REPLY 10843 TSM:FPAR 12442 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 14449 !TSM:FPAR:FAIL 14450 TSM:FAIL:CNT=1 14452 TSM:FAIL:PDT 24455 TSM:FAIL:RE-INITThis is gateway running on a UNO with sketch Serial Gateway from MySensors examples
0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0 0;255;3;0;9;TSM:INIT 0;255;3;0;9;TSF:WUR:MS=0 0;255;3;0;9;TSM:INIT:TSP OK 0;255;3;0;9;TSM:INIT:GW MODE 0;255;3;0;9;TSM:READY:ID=0,PAR=0,DIS=0 0;255;3;0;9;MCO:REG:NOT NEEDED 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.1.0 0;255;3;0;9;MCO:BGN:STP 0;255;3;0;9;MCO:BGN:INIT OK,TSP=1 0;255;3;0;9;TSF:SAN:OKI tried with both a power regulator for NRF24 and with a 10uF on both sides.
Hi all,
are you with Arduino IDE 1.8.0 ?
If yes did you try to downgrade the AVR version of Arduino 1.8.0 ?
Check the last two posts in this thread: https://forum.mysensors.org/topic/4801/building-an-ethernet-gateway/15I'm not sure it will solve the problem but not bad to try.
Hi all,
@David Well, I just saw an update to the boards had been released, so first I tried updating that, but resulting in the same error.
Then I downgraded the boards to version 1.6.11 as recommended in the thread you linked to, but still resulting in the same error.But thanks for the tip... Well, am really scratching my head on this problem.
Can anyone verify that a controller is not needed for the communication between the sensor and the gateway to work?
<>Can anyone verify that a controller is not needed for the communication between the sensor and the gateway to work?
A controller is needed for dynamic id assignment. Since you are using static id a controller is not requored. The node should find its parent (= the gateway unless you have repeater(s)) anyway.
@mfalkvidd Should both the gateway and the sensor have static id's? (different of course)
I just found this other forum post, which might be the answer to my issues: https://forum.mysensors.org/topic/5671/loosing-my-mind-sensor-not-talking-to-esp-gw-latest-2-2-0-beta/2
I too have bought the radios with a blob instead of an IC.
I too have ordered different radios - the ones that are recommended here in the shop.
Had just hoped to be able to figure out how to get the ones I have to work. If anyone have any other ideas, or would like me to post some code, please let me know. I am running pretty standard from the example, only added MY_NODE_ID in the top... -
i got the new NRF24 modules and it looks they are working. it looks like they are clones but at least I am not getting errors on startup like the others. For reference on the chip the code is 1609AH
PS I did some tests on range with RF24_PA_MAX but I can get maximum 6-7 meters on same floor with 2 walls. Not as much as I would have expected.
