  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 62.8k Views 21 Watching
  • S Offline
    SdeWeb
    Look here :
    https://linux-sunxi.org/Xunlong_Orange_Pi_One_%26_Lite
    Best.
    • T Tag
      @Reza
      try this:
      ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=3
      See this page for your header pinout: http://linux-sunxi.org/Orange_Pi_One#Orientation_of_the_GPIO_header
      the --my-rf24-cs-pin= is key to have it right on your system
      R Offline
      R Offline
      Reza
      @Tag my-rf24-cs-pin=3 . 3 is pin15 ? i do it. cs is connect to pin15 (GPIO3) and configre again .but dont work
      S T 2 Replies Last reply
      • R Reza
        SdeWeb
        wrote on last edited by SdeWeb
        #43
        @Reza Try to connect like mine, look above in this thread, then use my own ./configure setup.
        If it's not work, try to use the .fex file for your Orange PI download it here :
        http://linux-sunxi.org/Orange_Pi_One#Sunxi.2FLegacy_Kernel
        R 1 Reply Last reply
        • S SdeWeb
          R Offline
          R Offline
          Reza
          @SdeWeb said in 💬 Building a Orange Pi Gateway:
          sorry i cannot understand what is say in this link. thank you .perhaps other friend can found this for orange pi one or lite . i cannot understand really.
          • R Reza
            T Offline
            T Offline
            Tag
            wrote on last edited by Tag
            #45
            @Reza
            Did you also change the SPI channel?
            if you use the OPIzero pinout, SPI1 will be SPI0 on the OPI one......
            Your other option will be using a serial gateway: https://www.mysensors.org/build/serial_gateway
            This works for sure on the OPI One
            • T Tag
              @Reza
              R Offline
              R Offline
              Reza
              @Tag i change this but dont work, i am useing serial gateway now.but i want use a orangepi gateway:(
              S 1 Reply Last reply
              • R Reza
                SdeWeb
                @Reza
                Tell us how you connect your NRF24 module on your Orange PI.
                On this guide https://www.mysensors.org/build/orange do you followed the section "configure spidev" ?
                The main things are :
                1 - install sunxy-tools
                2 - install MySensors.git
                But the pinout of the GPIO on your Orange PI is different of the Orange PI zero explained here : https://www.mysensors.org/build/orange
                So you need to modify the script.bin file, with the command "bin2fex / fex2bin" as explained in the "configure spidev" chapter, if you fail to find the right configuration, try to use the .fex file that you can download here :
                If you have a Orange PI lite :
                https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepilite.fex
                Or if you have a Orange PI One :
                https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepione.fex
                then "fex2bin" the file you downloaded, to replace your own script.bin as described in the tuto at the chapter "configure spidev".
                I think that the pinout of your Orange PI is the same than mine, i got a Orange PI Plus 2E, so look my setup as explained above in this forum, then connect your NRF24 module like mine and use my "./configure" setup.
                If you succes your gateway setup, dont forget than the next step it's to install a controler to drive it, so you'll need to read guide about setup a controler : https://www.mysensors.org/controller
                Regards.
                • S SdeWeb
                  @Reza
                  Regards.
                  R Offline
                  R Offline
                  Reza
                  wrote on last edited by Reza
                  #48
                  @SdeWeb
                  this is my levels:
                  sudo apt-get update
                  sudo apt-get install sunxi-tools
                  bin2fex /boot/script.bin /tmp/orange.fex
                  nano /tmp/orange.fex
                  and replace
                  and save .
                  so:
                  sudo fex2bin /tmp/orange.fex /boot/script.bin
                  sudo reboot
                  root@orangepione:~# ls -l /dev/spidev*
                  crw------- 1 root root 153, 0 Mar 16 12:00 /dev/spidev0.0
                  sudo modprobe gpio-sunxi
                  echo "gpio-sunxi" >> /etc/modules
                  git clone https://github.com/mysensors/MySensors.git
                  cd MySensors
                  ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
                  ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                  make
                  sudo ./bin/mysgw -d
                  so i see :
                  mysgw: Starting gateway...
                  mysgw: Protocol version - 2.2.0-beta
                  mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.2.0-beta
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: !TSM:INIT:TSP FAIL
                  mysgw: TSM:FAIL:CNT=1
                  mysgw: TSM:FAIL:PDT
                  wiring is similar to zero...
                  • R Reza
                    @SdeWeb
                    this is my levels:
                    sudo apt-get update
                    and replace
                    and save .
                    so:
                    sudo reboot
                    cd MySensors
                    make
                    sudo ./bin/mysgw -d
                    so i see :
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: TSM:FAIL:PDT
                    SdeWeb
                    @Reza
                    Try to wire like mine and apply my configure setup, here is the copy/paste of the famous previous post from me :
                    I connected my NRF24L01 on OPI P2E like this :
                    NRF24L01 Port Name / (Pin N°) ----- OPI Port (Pin N°) / Name
                                          GND (1)  <-----------> (20) / GND
                                          VCC (2)  <-----------> (17) / 3.3V PWR
                                          CE (3)   <-----------> (22) / (PA2 / GPIO2)
                                          CSN (4)  <-----------> (24) / (PC3 / GPIO67)
                                          SCK (5)  <-----------> (23)
                                          MOSI (6) <-----------> (19) MOSI
                                          MISO (7) <-----------> (21) MISO
                                          IRQ (8)  <-----------> NC
                    So "MySensors" setup is :
                    ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
                    Then
                    ./bin/mysgw -d
                    Return :
                    root@orangepiplus2e:~/MySensors# ./bin/mysgw -d
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: TSM:INIT:TSP OK
                    mysgw: TSM:INIT:GW MODE
                    mysgw: MCO:REG:NOT NEEDED
                    mysgw: Listening for connections on 0.0.0.0:5003
                    mysgw: MCO:BGN:STP
                    mysgw: MCO:BGN:INIT OK,TSP=1
                    Best.
                    Seb.
                    • S SdeWeb
                      @Reza
                      Then
                      ./bin/mysgw -d
                      Return :
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: MCO:BGN:STP
                      Best.
                      Seb.
                      R Offline
                      R Offline
                      Reza
                      @SdeWeb
                      i do wiring true and do your levels... but there is same problem...
                      root@orangepione:~/MySensors# ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
                      [SECTION] Detecting target machine.
                        [OK] machine detected: SoC=H3, Type=unknown, CPU=armv7l.
                      [SECTION] Checking GPIO Sysfs.
                        [OK] /sys/class/gpio/export found
                      [SECTION] Detecting SPI driver.
                        [OK] SPI driver detected:SPIDEV.
                      [SECTION] Detecting init system.
                        [OK] init system detected: systemd.
                      [SECTION] Saving configuration.
                      [SECTION] Cleaning previous builds.
                      [OK] Finished.
                      root@orangepione:~/MySensors# ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                      [OK] Finished.
                      root@orangepione:~/MySensors# make
                      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                      g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                      g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                      g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                      g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                      g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                      g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                      g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                      g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                      g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                      g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                      g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                      g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                      g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                      examples_linux/mysgw.cpp:31:0: warning: "MY_RADIO_NRF24" redefined
                      <command-line>:0:0: note: this is the location of the previous definition
                      g++ -MT build/drivers/SPIDEV/SPI.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_SPIDEV -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/SPIDEV/SPI.cpp -o build/drivers/SPIDEV/SPI.o
                      g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/compatibility.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o  build/drivers/SPIDEV/SPI.o
                      root@orangepione:~/MySensors# sudo ./bin/mysgw -d
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:FAIL:RE-INIT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:CNT=2
                      mysgw: TSM:FAIL:PDT
                      • R Offline
                        R Offline
                        Reza
                        this is all my steps
                        root@orangepione:~# sudo apt-get update
                        Hit:1 http://ports.ubuntu.com xenial InRelease
                        Hit:2 http://apt.armbian.com xenial InRelease
                        Hit:3 http://ports.ubuntu.com xenial-security InRelease
                        Hit:4 http://ports.ubuntu.com xenial-updates InRelease
                        Hit:5 http://ports.ubuntu.com xenial-backports InRelease
                        Reading package lists... Done
                        root@orangepione:~# bin2fex /boot/script.bin /tmp/orange.fex
                        fexc-bin: /boot/script.bin: version: 1.2
                        fexc-bin: /boot/script.bin: size: 34704 (81 sections), header value: 34704
                        root@orangepione:~# nano /tmp/orange.fex
                        crw------- 1 root root 153, 0 Mar 19 11:17 /dev/spidev0.0
                        root@orangepione:~# sudo modprobe gpio-sunxi
                        root@orangepione:~# echo "gpio-sunxi" >> /etc/modules
                        root@orangepione:~# vncserver
                        New 'X' desktop is orangepione:1
                        Starting applications specified in /root/.vnc/xstartup
                        Log file is /root/.vnc/orangepione:1.log
                        root@orangepione:~# *** Error in `pasystray': corrupted double-linked list (not small): 0x01cdb908 ***
                        Cloning into 'MySensors'...
                        remote: Counting objects: 13985, done.
                        remote: Compressing objects: 100% (45/45), done.
                        remote: Total 13985 (delta 8), reused 0 (delta 0), pack-reused 13940
                        Receiving objects: 100% (13985/13985), 9.70 MiB | 181.00 KiB/s, done.
                        Resolving deltas: 100% (8436/8436), done.
                        Checking connectivity... done.
                        root@orangepione:~# cd MySensors
                        [OK] Finished.
                        [OK] Finished.
                        mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: TSM:FAIL:PDT
                        mysgw: TSM:INIT
                        mysgw: TSM:FAIL:PDT
                        mysgw: TSM:INIT
                        mysgw: TSM:FAIL:CNT=3
                        mysgw: TSM:FAIL:PDT
                        • P Offline
                          P Offline
                          pansen
                          Can you post a picture of your wiring?
                          Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                          • R Reza
                            [OK] Finished.
                            [OK] Finished.
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: TSM:FAIL:PDT
                            mysgw: TSM:INIT
                            mysgw: TSM:FAIL:PDT
                            mysgw: TSM:INIT
                            mysgw: TSM:FAIL:PDT
                            SdeWeb
                            @Reza Hello,
                            Did you modifying the .Fex file before applying the 'configure' setup ?
                            What did you do with nano ?
                            Regards.
                            • P pansen
                              R Offline
                              R Offline
                              Reza
                              #54
                              @pansen
                              red is 3.3
                              brown is GND
                              green is CE
                              orange is SCK
                              yellow is MISO
                              violet is CS
                              blue is MOSI
                              IRQ is empty
                              • S SdeWeb
                                @Reza Hello,
                                Regards.
                                R Offline
                                R Offline
                                Reza
                                #55
                                @SdeWeb
                                yes. use:
                                sudo nano /tmp/orange.fex
                                and remove all line and copy , paste your link and save this.
                                now orange.fex is:
                                [product]
                                version = "100"
                                machine = "Xunlong Orange Pi One"
                                [platform]
                                debug_mode = 1
                                eraseflag = 1
                                next_work = 2
                                [target]
                                boot_clock = 1008
                                storage_type = -1
                                [key_detect_en]
                                keyen_flag = 0
                                [fel_key]
                                fel_key_max = 7
                                fel_key_min = 2
                                [card_boot]
                                logical_start = 40960
                                sprite_work_delay = 500
                                sprite_err_delay = 200
                                sprite_gpio0 = port:PL10<1><default><default><default>
                                next_work = 3
                                [box_start_os]
                                used = 1
                                start_type = 1
                                irkey_used = 1
                                pmukey_used = 1
                                pmukey_num = 3
                                led_power = 0
                                led_state = 0
                                [boot_init_gpio]
                                used = 1
                                gpio0 = port:PL10<1><default><default><1>
                                gpio1 = port:PG11<1><default><default><1>
                                [recovery_para]
                                used = 1
                                mode = 2
                                recovery_key = port:PL04<0><default><default><default>
                                [pm_para]
                                standby_mode = 1
                                [card0_boot_para]
                                card_ctrl = 0
                                card_high_speed = 1
                                card_line = 4
                                sdc_d1 = port:PF00<2><1><2><default>
                                sdc_d0 = port:PF01<2><1><2><default>
                                sdc_clk = port:PF02<2><1><2><default>
                                sdc_cmd = port:PF03<2><1><2><default>
                                sdc_d3 = port:PF04<2><1><2><default>
                                sdc_d2 = port:PF05<2><1><2><default>
                                [card2_boot_para]
                                card_ctrl = 2
                                card_high_speed = 1
                                card_line = 8
                                sdc_cmd = port:PC06<3><1><2><default>
                                sdc_clk = port:PC05<3><1><2><default>
                                sdc_d0 = port:PC08<3><1><2><default>
                                sdc_d1 = port:PC09<3><1><2><default>
                                sdc_d2 = port:PC10<3><1><2><default>
                                sdc_d3 = port:PC11<3><1><2><default>
                                sdc_d4 = port:PC12<3><1><2><default>
                                sdc_d5 = port:PC13<3><1><2><default>
                                sdc_d6 = port:PC14<3><1><2><default>
                                sdc_d7 = port:PC15<3><1><2><default>
                                sdc_2xmode = 1
                                sdc_ddrmode = 1
                                [twi_para]
                                twi_port = 0
                                twi_scl = port:PA11<2><default><default><default>
                                twi_sda = port:PA12<2><default><default><default>
                                [uart_para]
                                uart_debug_port = 0
                                uart_debug_tx = port:PA04<2><1><default><default>
                                uart_debug_rx = port:PA05<2><1><default><default>
                                [force_uart_para]
                                force_uart_port = 0
                                force_uart_tx = port:PF02<3><1><default><default>
                                force_uart_rx = port:PF04<3><1><default><default>
                                [jtag_para]
                                jtag_enable = 0
                                jtag_ms = port:PA00<3><default><default><default>
                                jtag_ck = port:PA01<3><default><default><default>
                                jtag_do = port:PA02<3><default><default><default>
                                jtag_di = port:PA03<3><default><default><default>
                                [clock]
                                pll_video = 297
                                pll_ve = 402
                                pll_periph0 = 600
                                pll_gpu = 576
                                pll_periph1 = 600
                                pll_de = 864
                                [dram_para]
                                dram_clk = 624
                                dram_type = 3
                                dram_zq = 0x3b3bfb
                                dram_odt_en = 1
                                dram_para1 = 283377664
                                dram_para2 = 0
                                dram_mr0 = 6208
                                dram_mr1 = 64
                                dram_mr2 = 24
                                dram_mr3 = 2
                                dram_tpr0 = 0x48a192
                                dram_tpr1 = 0x1c2418d
                                dram_tpr2 = 0x76051
                                dram_tpr3 = 0x0
                                dram_tpr4 = 0x0
                                dram_tpr5 = 0x0
                                dram_tpr6 = 0x64
                                dram_tpr7 = 0x0
                                dram_tpr8 = 0x0
                                dram_tpr9 = 0x0
                                dram_tpr10 = 0x0
                                dram_tpr11 = 0x6aaa0000
                                dram_tpr12 = 0x7979
                                dram_tpr13 = 0x800800
                                [wakeup_src_para]
                                cpu_en = 0
                                cpu_freq = 48
                                pll_ratio = 273
                                dram_selfresh_en = 1
                                dram_freq = 36
                                wakeup_src0 =
                                wakeup_src_wl = port:PG10<4><default><default><0>
                                wakeup_src_bt = port:PL03<6><default><default><0>
                                [twi0]
                                twi_used = 1
                                [twi1]
                                twi_used = 1
                                twi_scl = port:PA18<3><default><default><default>
                                twi_sda = port:PA19<3><default><default><default>
                                [twi2]
                                twi_used = 0
                                twi_scl = port:PE12<3><default><default><default>
                                twi_sda = port:PE13<3><default><default><default>
                                [uart0]
                                uart_used = 1
                                uart_port = 0
                                uart_type = 2
                                uart_tx = port:PA04<2><1><default><default>
                                uart_rx = port:PA05<2><1><default><default>
                                [uart1]
                                uart_used = 0
                                uart_port = 1
                                uart_type = 4
                                uart_tx = port:PG06<2><1><default><default>
                                uart_rx = port:PG07<2><1><default><default>
                                uart_rts = port:PG08<2><1><default><default>
                                uart_cts = port:PG09<2><1><default><default>
                                [uart2]
                                uart_used = 0
                                uart_port = 2
                                uart_type = 4
                                uart_tx = port:PA00<2><1><default><default>
                                uart_rx = port:PA01<2><1><default><default>
                                uart_rts = port:PA02<2><1><default><default>
                                uart_cts = port:PA03<2><1><default><default>
                                [uart3]
                                uart_used = 0
                                uart_port = 3
                                uart_type = 4
                                uart_tx = port:PA13<3><1><default><default>
                                uart_rx = port:PA14<3><1><default><default>
                                uart_rts = port:PA15<3><1><default><default>
                                uart_cts = port:PA16<3><1><default><default>
                                [spi0]
                                spi_used = 1
                                spi_cs_bitmap = 1
                                spi_mosi = port:PC00<3><default><default><default>
                                spi_miso = port:PC01<3><default><default><default>
                                spi_sclk = port:PC02<3><default><default><default>
                                spi_cs0 = port:PC03<3><1><default><default>
                                [spi1]
                                spi_used = 0
                                spi_cs_bitmap = 1
                                spi_cs0 = port:PA13<2><1><default><default>
                                spi_sclk = port:PA14<2><default><default><default>
                                spi_mosi = port:PA15<2><default><default><default>
                                spi_miso = port:PA16<2><default><default><default>
                                [spi_devices]
                                spi_dev_num = 1
                                [spi_board0]
                                modalias = "spidev"
                                max_speed_hz = 33000000
                                bus_num = 0
                                chip_select = 0
                                mode = 0
                                full_duplex = 1
                                manual_cs = 0
                                ; NOTE: This section is necessary only for "gpio_sunxi" driver
                                ; which is obsolete for H3 boards
                                [gpio_para]
                                gpio_used = 0
                                gpio_num = 0
                                ;[led_assign]
                                ;normal_led = "gpio_pin_2"
                                ;standby_led = "gpio_pin_1"
                                [leds_para]
                                leds_used = 1
                                green_led = port:PL10<1><default><default><1>
                                green_led_active_low = 0
                                red_led = port:PA15<1><default><default><0>
                                red_led_active_low = 0
                                [ths_para]
                                ths_used = 1
                                ths_trip1_count = 6
                                ths_trip1_0 = 75
                                ths_trip1_1 = 80
                                ths_trip1_2 = 85
                                ths_trip1_3 = 90
                                ths_trip1_4 = 95
                                ths_trip1_5 = 105
                                ths_trip1_6 = 0
                                ths_trip1_7 = 0
                                ths_trip1_0_min = 0
                                ths_trip1_0_max = 1
                                ths_trip1_1_min = 1
                                ths_trip1_1_max = 2
                                ths_trip1_2_min = 2
                                ths_trip1_2_max = 3
                                ths_trip1_3_min = 3
                                ths_trip1_3_max = 4
                                ths_trip1_4_min = 4
                                ths_trip1_4_max = 5
                                ths_trip1_5_min = 5
                                ths_trip1_5_max = 7
                                ths_trip1_6_min = 0
                                ths_trip1_6_max = 0
                                ths_trip2_count = 1
                                ths_trip2_0 = 105
                                [cooler_table]
                                cooler_count = 8
                                cooler0 = "1200000 4 4294967295 0"
                                cooler1 = "912000 4 4294967295 0"
                                cooler2 = "768000 4 4294967295 0"
                                cooler3 = "648000 4 4294967295 0"
                                cooler4 = "480000 4 4294967295 0"
                                cooler5 = "480000 3 4294967295 0"
                                cooler6 = "480000 2 4294967295 0"
                                cooler7 = "480000 1 4294967295 0"
                                [nand0_para]
                                nand_support_2ch = 0
                                nand0_used = 0
                                nand0_we = port:PC00<2><default><default><default>
                                nand0_ale = port:PC01<2><default><default><default>
                                nand0_cle = port:PC02<2><default><default><default>
                                nand0_ce1 = port:PC03<2><default><default><default>
                                nand0_ce0 = port:PC04<2><default><default><default>
                                nand0_nre = port:PC05<2><default><default><default>
                                nand0_rb0 = port:PC06<2><default><default><default>
                                nand0_rb1 = port:PC07<2><default><default><default>
                                nand0_d0 = port:PC08<2><default><default><default>
                                nand0_d1 = port:PC09<2><default><default><default>
                                nand0_d2 = port:PC10<2><default><default><default>
                                nand0_d3 = port:PC11<2><default><default><default>
                                nand0_d4 = port:PC12<2><default><default><default>
                                nand0_d5 = port:PC13<2><default><default><default>
                                nand0_d6 = port:PC14<2><default><default><default>
                                nand0_d7 = port:PC15<2><default><default><default>
                                nand0_ndqs = port:PC16<2><default><default><default>
                                [boot_disp]
                                advert_disp = 0
                                auto_hpd = 1
                                output_type = 4
                                hdmi_channel = 0
                                hdmi_mode = 4
                                cvbs_channel = 1
                                cvbs_mode = 11
                                output_full = 1
                                hdmi_mode_check = 1
                                [disp_init]
                                disp_init_enable = 1
                                disp_mode = 0
                                screen0_output_type = 3
                                screen0_output_mode = 5
                                screen1_output_type = 3
                                screen1_output_mode = 5
                                fb0_format = 0
                                fb0_width = 0
                                fb0_height = 0
                                fb1_format = 0
                                fb1_width = 0
                                fb1_height = 0
                                [hdmi_para]
                                hdmi_used = 1
                                hdmi_power = "vcc-hdmi-18"
                                [tv_para]
                                tv_used = 0
                                tv_dac_used = 1
                                tv_dac_src0 = 0
                                [pwm0_para]
                                pwm_used = 0
                                pwm_positive = port:PA05<3><0><default><default>
                                ;       If set gamc_phy to use = 2
                                [gmac0]
                                gmac_used = 2
                                gmac_power1 =
                                [csi0]
                                vip_used = 1
                                vip_mode = 0
                                vip_dev_qty = 1
                                vip_define_sensor_list = 0
                                vip_csi_pck = port:PE00<2><default><default><default>
                                vip_csi_mck = port:PE01<2><default><default><default>
                                vip_csi_hsync = port:PE02<2><default><default><default>
                                vip_csi_vsync = port:PE03<2><default><default><default>
                                vip_csi_d0 = port:PE04<2><default><default><default>
                                vip_csi_d1 = port:PE05<2><default><default><default>
                                vip_csi_d2 = port:PE06<2><default><default><default>
                                vip_csi_d3 = port:PE07<2><default><default><default>
                                vip_csi_d4 = port:PE08<2><default><default><default>
                                vip_csi_d5 = port:PE09<2><default><default><default>
                                vip_csi_d6 = port:PE10<2><default><default><default>
                                vip_csi_d7 = port:PE11<2><default><default><default>
                                vip_csi_sck = port:PE12<2><default><default><default>
                                vip_csi_sda = port:PE13<2><default><default><default>
                                vip_dev0_mname = "gc2035"
                                vip_dev0_pos = "front"
                                vip_dev0_lane = 1
                                vip_dev0_twi_id = 2
                                vip_dev0_twi_addr = 120
                                vip_dev0_isp_used = 0
                                vip_dev0_fmt = 0
                                vip_dev0_stby_mode = 0
                                vip_dev0_vflip = 1
                                vip_dev0_hflip = 1
                                vip_dev0_iovdd = ""
                                vip_dev0_iovdd_vol = 2800000
                                vip_dev0_avdd = ""
                                vip_dev0_avdd_vol = 2800000
                                vip_dev0_dvdd = ""
                                vip_dev0_dvdd_vol = 1800000
                                vip_dev0_afvdd = ""
                                vip_dev0_afvdd_vol = 2800000
                                vip_dev0_power_en = port:PA17<1><default><default><1>
                                vip_dev0_reset = port:PE14<1><default><default><1>
                                vip_dev0_pwdn = port:PE15<1><default><default><0>
                                vip_dev0_flash_en =
                                vip_dev0_flash_mode =
                                vip_dev0_af_pwdn =
                                vip_dev0_act_used = 0
                                vip_dev0_act_name = "ad5820_act"
                                vip_dev0_act_slave = 24
                                vip_dev1_mname = ""
                                vip_dev1_pos = "rear"
                                vip_dev1_lane = 1
                                vip_dev1_twi_id = 0
                                vip_dev1_twi_addr =
                                vip_dev1_isp_used = 0
                                vip_dev1_fmt = 1
                                vip_dev1_stby_mode = 0
                                vip_dev1_vflip = 0
                                vip_dev1_hflip = 0
                                vip_dev1_iovdd = ""
                                vip_dev1_iovdd_vol = 2800000
                                vip_dev1_avdd = ""
                                vip_dev1_avdd_vol = 2800000
                                vip_dev1_dvdd = ""
                                vip_dev1_dvdd_vol = 1500000
                                vip_dev1_afvdd = ""
                                vip_dev1_afvdd_vol = 2800000
                                vip_dev1_power_en =
                                vip_dev1_reset =
                                vip_dev1_pwdn =
                                vip_dev1_flash_en =
                                vip_dev1_flash_mode =
                                vip_dev1_af_pwdn =
                                [tvout_para]
                                tvout_used = 0
                                tvout_channel_num =
                                tv_en = 0
                                [tvin_para]
                                tvin_used = 0
                                tvin_channel_num =
                                [di_para]
                                di_used = 1
                                [mmc0_para]
                                sdc_used = 1
                                sdc_detmode = 3
                                sdc_buswidth = 4
                                sdc_det = port:PF06<0><1><2><default>
                                sdc_use_wp = 0
                                sdc_wp =
                                sdc_isio = 0
                                sdc_regulator = "none"
                                sdc_power_supply = "none"
                                [mmc1_para]
                                sdc_used = 1
                                sdc_detmode = 4
                                sdc_buswidth = 4
                                sdc_clk = port:PG00<2><1><3><default>
                                sdc_cmd = port:PG01<2><1><3><default>
                                sdc_d0 = port:PG02<2><1><3><default>
                                sdc_d1 = port:PG03<2><1><3><default>
                                sdc_d2 = port:PG04<2><1><3><default>
                                sdc_d3 = port:PG05<2><1><3><default>
                                sdc_det =
                                sdc_use_wp = 0
                                sdc_wp =
                                sdc_isio = 1
                                sdc_2xmode = 1
                                sdc_ddrmode = 1
                                [mmc2_para]
                                sdc_used = 0
                                sdc_detmode = 3
                                sdc_buswidth = 8
                                emmc_rst = port:PC16<3><1><2><default>
                                sdc_det =
                                sdc_use_wp = 0
                                sdc_wp =
                                sdc_isio = 0
                                sdc_2xmode = 1
                                sdc_ddrmode = 1
                                [smc_para]
                                smc_used = 0
                                smc_rst = port:PA09<2><default><default><default>
                                smc_vppen = port:PA20<3><default><default><default>
                                smc_vppp = port:PA21<3><default><default><default>
                                smc_det = port:PA10<2><default><default><default>
                                smc_vccen = port:PA06<2><default><default><default>
                                smc_sck = port:PA07<2><default><default><default>
                                smc_sda = port:PA08<2><default><default><default>
                                [usbc0]
                                usb_used = 1
                                usb_port_type = 2
                                usb_detect_type = 0
                                usb_id_gpio = port:PG12<0><1><default><default>
                                usb_det_vbus_gpio = port:PG12<0><1><default><default>
                                usb_drv_vbus_gpio = port:PL02<1><0><default><0>
                                usb_host_init_state = 1
                                usb_restrict_gpio =
                                usb_restric_flag = 0
                                usb_restric_voltage = 3550000
                                usb_restric_capacity = 5
                                usb_regulator_io = "nocare"
                                usb_regulator_vol = 0
                                usb_not_suspend = 0
                                [usbc1]
                                usb_used = 1
                                usb_drv_vbus_gpio =
                                usb_restrict_gpio =
                                usb_not_suspend = 0
                                [usbc2]
                                usb_used = 1
                                usb_drv_vbus_gpio =
                                usb_restrict_gpio =
                                usb_not_suspend = 0
                                [usbc3]
                                usb_used = 1
                                usb_drv_vbus_gpio =
                                usb_restrict_gpio =
                                usb_not_suspend = 0
                                [usb_feature]
                                vendor_id = 6353
                                mass_storage_id = 1
                                adb_id = 2
                                manufacturer_name = "USB Developer"
                                product_name = "Android"
                                serial_number = "20080411"
                                [msc_feature]
                                vendor_name = "USB 2.0"
                                product_name = "USB Flash Driver"
                                release = 100
                                luns = 3
                                [serial_feature]
                                serial_unique = 0
                                [module_para]
                                module_num = 7
                                module_power0 = "vcc-wifi-33"
                                module_power0_vol = 0
                                module_power1 =
                                module_power1_vol =
                                module_power2 =
                                module_power2_vol =
                                module_power3 =
                                module_power3_vol =
                                chip_en =
                                lpo_use_apclk =
                                [wifi_para]
                                wifi_used = 0
                                wifi_sdc_id = 1
                                wifi_usbc_id = 5
                                wifi_usbc_type = 1
                                wl_reg_on = port:PL07<1><default><default><0>
                                wl_host_wake = port:PG10<0><default><default><0>
                                wl_host_wake_invert = 0
                                [bt_para]
                                bt_used = 0
                                bt_uart_id = 1
                                bt_rst_n =
                                bt_wake =
                                bt_host_wake =
                                bt_host_wake_invert = 0
                                [pcm0]
                                daudio_used = 0
                                daudio_master = 4
                                daudio_select = 1
                                audio_format = 1
                                signal_inversion = 1
                                mclk_fs = 128
                                sample_resolution = 16
                                slot_width_select = 32
                                pcm_lrck_period = 32
                                pcm_lrckr_period = 1
                                msb_lsb_first = 0
                                sign_extend = 0
                                slot_index = 0
                                slot_width = 32
                                frame_width = 0
                                tx_data_mode = 0
                                rx_data_mode = 0
                                i2s_mclk = port:PA18<2><1><default><default>
                                i2s_bclk = port:PA19<2><1><default><default>
                                i2s_dout0 = port:PA20<2><1><default><default>
                                i2s_din = port:PA21<2><1><default><default>
                                [pcm1]
                                daudio_used = 0
                                daudio_master = 4
                                daudio_select = 1
                                audio_format = 1
                                mclk_fs = 128
                                msb_lsb_first = 0
                                sign_extend = 0
                                slot_index = 0
                                slot_width = 32
                                frame_width = 0
                                tx_data_mode = 0
                                rx_data_mode = 0
                                i2s_mclk = port:PG10<2><1><default><default>
                                i2s_bclk = port:PG11<2><1><default><default>
                                i2s_dout0 = port:PG12<2><1><default><default>
                                i2s_din = port:PG13<2><1><default><default>
                                [audio0]
                                audio_used = 1
                                lineout_vol = 31
                                cap_vol = 5
                                audio_hp_ldo = "none"
                                adcagc_used = 0
                                adcdrc_used = 0
                                dacdrc_used = 0
                                adchpf_used = 0
                                dachpf_used = 0
                                audio_pa_ctrl = port:PA16<1><default><default><0>
                                [spdif0]
                                spdif_used = 0
                                spdif_dout = port:PA17<2><1><default><default>
                                [audiohub]
                                hub_used = 0
                                codec_used = 1
                                spdif_used = 1
                                hdmi_used = 1
                                [s_cir0]
                                ir_used = 0
                                ir_rx = port:PL11<2><1><default><default>
                                ir_power_key_code0 = 87
                                ir_addr_code0 = 40704
                                ir_power_key_code1 = 26
                                ir_addr_code1 = 64260
                                ir_power_key_code2 = 20
                                ir_addr_code2 = 32640
                                ir_power_key_code3 = 21
                                ir_addr_code3 = 32640
                                ir_power_key_code4 = 11
                                ir_addr_code4 = 63240
                                ir_power_key_code5 = 3
                                ir_addr_code5 = 239
                                ir_power_key_code6 = 159
                                ir_addr_code6 = 19635
                                ir_power_key_code7 = 10
                                ir_addr_code7 = 30536
                                ir_power_key_code8 = 69
                                ir_addr_code8 = 48386
                                ir_power_key_code9 = 77
                                ir_addr_code9 = 56865
                                ir_power_key_code10 = 24
                                ir_addr_code10 = 65025
                                ir_power_key_code11 = 87
                                ir_addr_code11 = 65280
                                ir_power_key_code12 = 77
                                ir_addr_code12 = 65344
                                [cir]
                                ir_used = 1
                                ir_tx = port:PH07<2><default><default><default>
                                ; dvfs voltage-frequency table configuration
                                ; pmuic_type:0:none, 1:gpio, 2:i2c
                                ; pmu_gpio0: gpio config.
                                ; pmu_levelx: 0~9999: voltage(mV), 10000~90000:gpio0 state. voltage form high to low.
                                ; extremity_freq(Hz): cpu extremity frequency when run benckmark or demo apk
                                ;                     1536MHz@1500mV with radiator, 1296MHz@1340mV without radiator
                                ; max_freq: cpu maximum frequency, based on Hz, can not be more than 1200MHz
                                ; min_freq: cpu minimum frequency, based on Hz, can not be less than 60MHz
                                ; LV_count: count of LV_freq/LV_volt, must be < 16
                                ; LV1: core vdd is 1.50v if cpu frequency is (1296Mhz,  1536Mhz]
                                ; LV2: core vdd is 1.34v if cpu frequency is (1200Mhz,  1296Mhz]
                                ; LV3: core vdd is 1.32v if cpu frequency is (1008Mhz,  1200Mhz]
                                ; LV4: core vdd is 1.20v if cpu frequency is (816Mhz,   1008Mhz]
                                ; LV5: core vdd is 1.10v if cpu frequency is (648Mhz,    816Mhz]
                                ; LV6: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                                ; LV7: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                                ; LV8: core vdd is 1.04v if cpu frequency is (0Mhz,      648Mhz]
                                [dvfs_table]
                                pmuic_type = 1
                                pmu_gpio0 = port:PL06<1><1><2><1>
                                pmu_level0 = 11300
                                pmu_level1 = 1100
                                max_freq = 1200000000
                                min_freq = 480000000
                                LV_count = 5
                                LV1_freq = 1200000000
                                LV1_volt = 1300
                                LV2_freq = 1008000000
                                LV2_volt = 1300
                                LV3_freq = 912000000
                                LV3_volt = 1100
                                LV4_freq = 648000000
                                LV4_volt = 1100
                                LV5_freq = 480000000
                                LV5_volt = 1100
                                [gpu_dvfs_table]
                                G_LV_count = 3
                                G_LV0_freq = 312000000
                                G_LV0_volt = 1200000
                                G_LV1_freq = 384000000
                                G_LV1_volt = 1200000
                                G_LV2_freq = 456000000
                                G_LV2_volt = 1200000
                                [Vdevice]
                                Vdevice_used = 0
                                Vdevice_0 = port:PH10<5><1><2><default>
                                Vdevice_1 = port:PH11<5><1><2><default>
                                [s_uart0]
                                s_uart_used = 0
                                s_uart_tx = port:PL02<2><default><default><default>
                                s_uart_rx = port:PL03<2><default><default><default>
                                [s_rsb0]
                                s_rsb_used = 1
                                s_rsb_sck = port:PL00<2><1><2><default>
                                s_rsb_sda = port:PL01<2><1><2><default>
                                [s_jtag0]
                                s_jtag_used = 0
                                s_jtag_tms = port:PL04<2><1><2><default>
                                s_jtag_tck = port:PL05<2><1><2><default>
                                s_jtag_tdo = port:PL06<2><1><2><default>
                                s_jtag_tdi = port:PL07<2><1><2><default>
                                [s_powchk]
                                s_powchk_used = -2147483648
                                s_power_reg = 0
                                s_system_power = 50
                                [sim0]
                                scr_used = 0
                                scr_vccen = port:PA06<2><default><default><default>
                                scr_slk = port:PA07<2><default><default><default>
                                scr_sda = port:PA08<2><default><default><default>
                                scr_rst = port:PA09<2><default><default><default>
                                scr_det = port:PA10<2><default><default><default>
                                [ts0]
                                tsc_used = 0
                                tsc_clk = port:PE00<3><default><default><default>
                                tsc_err = port:PE01<3><default><default><default>
                                tsc_sync = port:PE02<3><default><default><default>
                                tsc_dvld = port:PE03<3><default><default><default>
                                tsc_d0 = port:PE04<3><default><default><default>
                                tsc_d1 = port:PE05<3><default><default><default>
                                tsc_d2 = port:PE06<3><default><default><default>
                                tsc_d3 = port:PE07<3><default><default><default>
                                tsc_d4 = port:PE08<3><default><default><default>
                                tsc_d5 = port:PE09<3><default><default><default>
                                tsc_d6 = port:PE10<3><default><default><default>
                                tsc_d7 = port:PE11<3><default><default><default>
                                [gpio_power_key]
                                key_used = 1
                                key_io = port:PL03<6><default><default><0>
                                [key_para]
                                key_used = 0
                                key_cnt = 5
                                key1_vol = 222
                                key2_vol = 444
                                key3_vol = 666
                                key4_vol = 857
                                key5_vol = 2000
                                [d7s_para]
                                d7s_used = 0
                                din_gpio = port:PD00<1><default><default><1>
                                clk_gpio = port:PD01<1><default><default><1>
                                stb_gpio = port:PD02<1><default><default><1>
                                ;mali parameters
                                [mali_para]
                                mali_used = 1
                                mali_clkdiv = 1
                                mali_extreme_freq = 600
                                mali_extreme_vol = 1400
                                ;1wire parameters (default - PA20)
                                [w1_para]
                                w1_used = 1
                                gpio = 20
                                [corekeeper]
                                corekeeper_enabled = 1
                                • R Reza
                                  @SdeWeb
                                  yes. use:
                                  now orange.fex is:
                                  [product]
                                  version = "100"
                                  [platform]
                                  debug_mode = 1
                                  eraseflag = 1
                                  next_work = 2
                                  [target]
                                  boot_clock = 1008
                                  storage_type = -1
                                  [key_detect_en]
                                  keyen_flag = 0
                                  [fel_key]
                                  fel_key_max = 7
                                  fel_key_min = 2
                                  [card_boot]
                                  next_work = 3
                                  [box_start_os]
                                  used = 1
                                  start_type = 1
                                  irkey_used = 1
                                  pmukey_used = 1
                                  pmukey_num = 3
                                  led_power = 0
                                  led_state = 0
                                  [boot_init_gpio]
                                  used = 1
                                  [recovery_para]
                                  used = 1
                                  mode = 2
                                  [pm_para]
                                  standby_mode = 1
                                  [card0_boot_para]
                                  card_ctrl = 0
                                  card_high_speed = 1
                                  card_line = 4
                                  [card2_boot_para]
                                  card_ctrl = 2
                                  card_high_speed = 1
                                  card_line = 8
                                  sdc_2xmode = 1
                                  sdc_ddrmode = 1
                                  [twi_para]
                                  twi_port = 0
                                  [uart_para]
                                  uart_debug_port = 0
                                  [force_uart_para]
                                  force_uart_port = 0
                                  [jtag_para]
                                  jtag_enable = 0
                                  [clock]
                                  pll_video = 297
                                  pll_ve = 402
                                  pll_periph0 = 600
                                  pll_gpu = 576
                                  pll_periph1 = 600
                                  pll_de = 864
                                  [dram_para]
                                  dram_clk = 624
                                  dram_type = 3
                                  dram_zq = 0x3b3bfb
                                  dram_odt_en = 1
                                  dram_para2 = 0
                                  dram_mr0 = 6208
                                  dram_mr1 = 64
                                  dram_mr2 = 24
                                  dram_mr3 = 2
                                  dram_tpr2 = 0x76051
                                  dram_tpr3 = 0x0
                                  dram_tpr4 = 0x0
                                  dram_tpr5 = 0x0
                                  dram_tpr6 = 0x64
                                  dram_tpr7 = 0x0
                                  dram_tpr8 = 0x0
                                  dram_tpr9 = 0x0
                                  dram_tpr10 = 0x0
                                  dram_tpr12 = 0x7979
                                  [wakeup_src_para]
                                  cpu_en = 0
                                  cpu_freq = 48
                                  pll_ratio = 273
                                  dram_freq = 36
                                  wakeup_src0 =
                                  [twi0]
                                  twi_used = 1
                                  [twi1]
                                  twi_used = 1
                                  [twi2]
                                  twi_used = 0
                                  [uart0]
                                  uart_used = 1
                                  uart_port = 0
                                  uart_type = 2
                                  [uart1]
                                  uart_used = 0
                                  uart_port = 1
                                  uart_type = 4
                                  [uart2]
                                  uart_used = 0
                                  uart_port = 2
                                  uart_type = 4
                                  [uart3]
                                  uart_used = 0
                                  uart_port = 3
                                  uart_type = 4
                                  [spi0]
                                  spi_used = 1
                                  spi_cs_bitmap = 1
                                  [spi1]
                                  spi_used = 0
                                  spi_cs_bitmap = 1
                                  [spi_devices]
                                  spi_dev_num = 1
                                  [spi_board0]
                                  modalias = "spidev"
                                  bus_num = 0
                                  chip_select = 0
                                  mode = 0
                                  full_duplex = 1
                                  manual_cs = 0
                                  [gpio_para]
                                  gpio_used = 0
                                  gpio_num = 0
                                  ;[led_assign]
                                  [leds_para]
                                  leds_used = 1
                                  [ths_para]
                                  ths_used = 1
                                  ths_trip1_count = 6
                                  ths_trip1_0 = 75
                                  ths_trip1_1 = 80
                                  ths_trip1_2 = 85
                                  ths_trip1_3 = 90
                                  ths_trip1_4 = 95
                                  ths_trip1_5 = 105
                                  ths_trip1_6 = 0
                                  ths_trip1_7 = 0
                                  ths_trip1_0_min = 0
                                  ths_trip1_0_max = 1
                                  ths_trip1_1_min = 1
                                  ths_trip1_1_max = 2
                                  ths_trip1_2_min = 2
                                  ths_trip1_2_max = 3
                                  ths_trip1_3_min = 3
                                  ths_trip1_3_max = 4
                                  ths_trip1_4_min = 4
                                  ths_trip1_4_max = 5
                                  ths_trip1_5_min = 5
                                  ths_trip1_5_max = 7
                                  ths_trip1_6_min = 0
                                  ths_trip1_6_max = 0
                                  ths_trip2_count = 1
                                  ths_trip2_0 = 105
                                  [cooler_table]
                                  cooler_count = 8
                                  [nand0_para]
                                  nand0_used = 0
                                  [boot_disp]
                                  advert_disp = 0
                                  auto_hpd = 1
                                  output_type = 4
                                  hdmi_channel = 0
                                  hdmi_mode = 4
                                  cvbs_channel = 1
                                  cvbs_mode = 11
                                  output_full = 1
                                  hdmi_mode_check = 1
                                  [disp_init]
                                  disp_mode = 0
                                  fb0_format = 0
                                  fb0_width = 0
                                  fb0_height = 0
                                  fb1_format = 0
                                  fb1_width = 0
                                  fb1_height = 0
                                  [hdmi_para]
                                  hdmi_used = 1
                                  [tv_para]
                                  tv_used = 0
                                  tv_dac_used = 1
                                  tv_dac_src0 = 0
                                  [pwm0_para]
                                  pwm_used = 0
                                  [gmac0]
                                  gmac_used = 2
                                  gmac_power1 =
                                  [csi0]
                                  vip_used = 1
                                  vip_mode = 0
                                  vip_dev_qty = 1
                                  vip_dev0_lane = 1
                                  vip_dev0_twi_id = 2
                                  vip_dev0_fmt = 0
                                  vip_dev0_vflip = 1
                                  vip_dev0_hflip = 1
                                  vip_dev0_iovdd = ""
                                  vip_dev0_avdd = ""
                                  vip_dev0_dvdd = ""
                                  vip_dev0_afvdd = ""
                                  vip_dev0_flash_en =
                                  vip_dev0_af_pwdn =
                                  vip_dev1_mname = ""
                                  vip_dev1_lane = 1
                                  vip_dev1_twi_id = 0
                                  vip_dev1_twi_addr =
                                  vip_dev1_fmt = 1
                                  vip_dev1_vflip = 0
                                  vip_dev1_hflip = 0
                                  vip_dev1_iovdd = ""
                                  vip_dev1_avdd = ""
                                  vip_dev1_dvdd = ""
                                  vip_dev1_afvdd = ""
                                  vip_dev1_power_en =
                                  vip_dev1_reset =
                                  vip_dev1_pwdn =
                                  vip_dev1_flash_en =
                                  vip_dev1_af_pwdn =
                                  [tvout_para]
                                  tvout_used = 0
                                  tvout_channel_num =
                                  tv_en = 0
                                  [tvin_para]
                                  tvin_used = 0
                                  tvin_channel_num =
                                  [di_para]
                                  di_used = 1
                                  [mmc0_para]
                                  sdc_used = 1
                                  sdc_detmode = 3
                                  sdc_buswidth = 4
                                  sdc_use_wp = 0
                                  sdc_wp =
                                  sdc_isio = 0
                                  [mmc1_para]
                                  sdc_used = 1
                                  sdc_detmode = 4
                                  sdc_buswidth = 4
                                  sdc_det =
                                  sdc_use_wp = 0
                                  sdc_wp =
                                  sdc_isio = 1
                                  sdc_2xmode = 1
                                  sdc_ddrmode = 1
                                  [mmc2_para]
                                  sdc_used = 0
                                  sdc_detmode = 3
                                  sdc_buswidth = 8
                                  sdc_det =
                                  sdc_use_wp = 0
                                  sdc_wp =
                                  sdc_isio = 0
                                  sdc_2xmode = 1
                                  sdc_ddrmode = 1
                                  [smc_para]
                                  smc_used = 0
                                  [usbc0]
                                  usb_used = 1
                                  usb_port_type = 2
                                  usb_detect_type = 0
                                  usb_restrict_gpio =
                                  usb_not_suspend = 0
                                  [usbc1]
                                  usb_used = 1
                                  usb_drv_vbus_gpio =
                                  usb_restrict_gpio =
                                  usb_not_suspend = 0
                                  [usbc2]
                                  usb_used = 1
                                  usb_drv_vbus_gpio =
                                  usb_restrict_gpio =
                                  usb_not_suspend = 0
                                  [usbc3]
                                  usb_used = 1
                                  usb_drv_vbus_gpio =
                                  usb_restrict_gpio =
                                  usb_not_suspend = 0
                                  [usb_feature]
                                  vendor_id = 6353
                                  mass_storage_id = 1
                                  adb_id = 2
                                  [msc_feature]
                                  release = 100
                                  luns = 3
                                  [serial_feature]
                                  serial_unique = 0
                                  [module_para]
                                  module_num = 7
                                  module_power1 =
                                  module_power1_vol =
                                  module_power2 =
                                  module_power2_vol =
                                  module_power3 =
                                  module_power3_vol =
                                  chip_en =
                                  lpo_use_apclk =
                                  [wifi_para]
                                  wifi_used = 0
                                  wifi_sdc_id = 1
                                  wifi_usbc_id = 5
                                  wifi_usbc_type = 1
                                  [bt_para]
                                  bt_used = 0
                                  bt_uart_id = 1
                                  bt_rst_n =
                                  bt_wake =
                                  bt_host_wake =
                                  [pcm0]
                                  daudio_used = 0
                                  daudio_master = 4
                                  daudio_select = 1
                                  audio_format = 1
                                  mclk_fs = 128
                                  msb_lsb_first = 0
                                  sign_extend = 0
                                  slot_index = 0
                                  slot_width = 32
                                  frame_width = 0
                                  tx_data_mode = 0
                                  rx_data_mode = 0
                                  [pcm1]
                                  daudio_used = 0
                                  daudio_master = 4
                                  daudio_select = 1
                                  audio_format = 1
                                  mclk_fs = 128
                                  msb_lsb_first = 0
                                  sign_extend = 0
                                  slot_index = 0
                                  slot_width = 32
                                  frame_width = 0
                                  tx_data_mode = 0
                                  rx_data_mode = 0
                                  [audio0]
                                  audio_used = 1
                                  lineout_vol = 31
                                  cap_vol = 5
                                  adcagc_used = 0
                                  adcdrc_used = 0
                                  dacdrc_used = 0
                                  adchpf_used = 0
                                  dachpf_used = 0
                                  [spdif0]
                                  spdif_used = 0
                                  [audiohub]
                                  hub_used = 0
                                  codec_used = 1
                                  spdif_used = 1
                                  hdmi_used = 1
                                  [s_cir0]
                                  ir_used = 0
                                  ir_addr_code5 = 239
                                  [cir]
                                  ir_used = 1
                                  [dvfs_table]
                                  pmuic_type = 1
                                  pmu_level0 = 11300
                                  pmu_level1 = 1100
                                  LV_count = 5
                                  LV1_volt = 1300
                                  LV2_volt = 1300
                                  LV3_volt = 1100
                                  LV4_volt = 1100
                                  LV5_volt = 1100
                                  [gpu_dvfs_table]
                                  G_LV_count = 3
                                  [Vdevice]
                                  Vdevice_used = 0
                                  [s_uart0]
                                  s_uart_used = 0
                                  [s_rsb0]
                                  s_rsb_used = 1
                                  [s_jtag0]
                                  s_jtag_used = 0
                                  [s_powchk]
                                  s_power_reg = 0
                                  s_system_power = 50
                                  [sim0]
                                  scr_used = 0
                                  [ts0]
                                  tsc_used = 0
                                  [gpio_power_key]
                                  key_used = 1
                                  [key_para]
                                  key_used = 0
                                  key_cnt = 5
                                  key1_vol = 222
                                  key2_vol = 444
                                  key3_vol = 666
                                  key4_vol = 857
                                  key5_vol = 2000
                                  [d7s_para]
                                  d7s_used = 0
                                  ;mali parameters
                                  [mali_para]
                                  mali_used = 1
                                  mali_clkdiv = 1
                                  [w1_para]
                                  w1_used = 1
                                  gpio = 20
                                  [corekeeper]
                                  SdeWeb
                                  @Reza
                                  Hello, it seems when i read your previous post, that you forgot to reverse your custom .fex file in the system.
                                  In fact, after modifying the .fex in nano, you must do "fex2bin" your .fex file to replace in the system the script.bin file.
                                  If you didn't to that, your .fex file is not used, is useless until you "fex2bin" it.
                                  Your pinout seems OK, a option is to use Pin 17 (3.3V) an Pin 20 (GND) to powering your NRF module.
                                  Regards.
                                  Seb.
                                  • S SdeWeb
                                    @Reza
                                    Regards.
                                    Seb.
                                    R Offline
                                    R Offline
                                    Reza
                                    @SdeWeb sorry i am worng in typing.but i do all steps but there is problem for me.
                                    pin 1 and 6 is 3.3v and gnd .what is defference between 1 & 17 and 6 & 20?
                                    this is all steps that i was follow:
                                    Hit:2 http://ports.ubuntu.com xenial-security InRelease
                                    Hit:3 http://apt.armbian.com xenial InRelease
                                    root@orangepione:~# sudo apt-get install sunxi-tools
                                    Building dependency tree
                                    Reading state information... Done
                                    sunxi-tools is already the newest version (1.4.2-1~armbian5.25+1).
                                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                    and in orange.fex :
                                    [product]
                                    version = "100"
                                    [platform]
                                    debug_mode = 1
                                    eraseflag = 1
                                    next_work = 2
                                    [target]
                                    boot_clock = 1008
                                    storage_type = -1
                                    [key_detect_en]
                                    keyen_flag = 0
                                    [fel_key]
                                    fel_key_max = 7
                                    fel_key_min = 2
                                    [card_boot]
                                    next_work = 3
                                    [box_start_os]
                                    used = 1
                                    start_type = 1
                                    irkey_used = 1
                                    pmukey_used = 1
                                    pmukey_num = 3
                                    led_power = 0
                                    led_state = 0
                                    [boot_init_gpio]
                                    used = 1
                                    [recovery_para]
                                    used = 1
                                    mode = 2
                                    [pm_para]
                                    standby_mode = 1
                                    [card0_boot_para]
                                    card_ctrl = 0
                                    card_high_speed = 1
                                    card_line = 4
                                    [card2_boot_para]
                                    card_ctrl = 2
                                    card_high_speed = 1
                                    card_line = 8
                                    sdc_2xmode = 1
                                    sdc_ddrmode = 1
                                    [twi_para]
                                    twi_port = 0
                                    [uart_para]
                                    uart_debug_port = 0
                                    [force_uart_para]
                                    force_uart_port = 0
                                    [jtag_para]
                                    jtag_enable = 0
                                    [clock]
                                    pll_video = 297
                                    pll_ve = 402
                                    pll_periph0 = 600
                                    pll_gpu = 576
                                    pll_periph1 = 600
                                    pll_de = 864
                                    [dram_para]
                                    dram_clk = 624
                                    dram_type = 3
                                    dram_zq = 0x3b3bfb
                                    dram_odt_en = 1
                                    dram_para2 = 0
                                    dram_mr0 = 6208
                                    dram_mr1 = 64
                                    dram_mr2 = 24
                                    dram_mr3 = 2
                                    dram_tpr2 = 0x76051
                                    dram_tpr3 = 0x0
                                    dram_tpr4 = 0x0
                                    dram_tpr5 = 0x0
                                    dram_tpr6 = 0x64
                                    dram_tpr7 = 0x0
                                    dram_tpr8 = 0x0
                                    dram_tpr9 = 0x0
                                    dram_tpr10 = 0x0
                                    dram_tpr12 = 0x7979
                                    [wakeup_src_para]
                                    cpu_en = 0
                                    cpu_freq = 48
                                    pll_ratio = 273
                                    dram_freq = 36
                                    wakeup_src0 =
                                    [twi0]
                                    twi_used = 1
                                    [twi1]
                                    twi_used = 1
                                    [twi2]
                                    twi_used = 0
                                    [uart0]
                                    uart_used = 1
                                    uart_port = 0
                                    uart_type = 2
                                    [uart1]
                                    uart_used = 0
                                    uart_port = 1
                                    uart_type = 4
                                    [uart2]
                                    uart_used = 0
                                    uart_port = 2
                                    uart_type = 4
                                    [uart3]
                                    uart_used = 0
                                    uart_port = 3
                                    uart_type = 4
                                    [spi0]
                                    spi_used = 1
                                    spi_cs_bitmap = 1
                                    [spi1]
                                    spi_used = 0
                                    spi_cs_bitmap = 1
                                    [spi_devices]
                                    spi_dev_num = 1
                                    [spi_board0]
                                    modalias = "spidev"
                                    bus_num = 0
                                    chip_select = 0
                                    mode = 0
                                    full_duplex = 1
                                    manual_cs = 0
                                    [gpio_para]
                                    gpio_used = 0
                                    gpio_num = 0
                                    ;[led_assign]
                                    [leds_para]
                                    leds_used = 1
                                    [ths_para]
                                    ths_used = 1
                                    ths_trip1_count = 6
                                    ths_trip1_0 = 75
                                    ths_trip1_1 = 80
                                    ths_trip1_2 = 85
                                    ths_trip1_3 = 90
                                    ths_trip1_4 = 95
                                    ths_trip1_5 = 105
                                    ths_trip1_6 = 0
                                    ths_trip1_7 = 0
                                    ths_trip1_0_min = 0
                                    ths_trip1_0_max = 1
                                    ths_trip1_1_min = 1
                                    ths_trip1_1_max = 2
                                    ths_trip1_2_min = 2
                                    ths_trip1_2_max = 3
                                    ths_trip1_3_min = 3
                                    ths_trip1_3_max = 4
                                    ths_trip1_4_min = 4
                                    ths_trip1_4_max = 5
                                    ths_trip1_5_min = 5
                                    ths_trip1_5_max = 7
                                    ths_trip1_6_min = 0
                                    ths_trip1_6_max = 0
                                    ths_trip2_count = 1
                                    ths_trip2_0 = 105
                                    [cooler_table]
                                    cooler_count = 8
                                    [nand0_para]
                                    nand0_used = 0
                                    [boot_disp]
                                    advert_disp = 0
                                    auto_hpd = 1
                                    output_type = 4
                                    hdmi_channel = 0
                                    hdmi_mode = 4
                                    cvbs_channel = 1
                                    cvbs_mode = 11
                                    output_full = 1
                                    hdmi_mode_check = 1
                                    [disp_init]
                                    disp_mode = 0
                                    fb0_format = 0
                                    fb0_width = 0
                                    fb0_height = 0
                                    fb1_format = 0
                                    fb1_width = 0
                                    fb1_height = 0
                                    [hdmi_para]
                                    hdmi_used = 1
                                    [tv_para]
                                    tv_used = 0
                                    tv_dac_used = 1
                                    tv_dac_src0 = 0
                                    [pwm0_para]
                                    pwm_used = 0
                                    [gmac0]
                                    gmac_used = 2
                                    gmac_power1 =
                                    [csi0]
                                    vip_used = 1
                                    vip_mode = 0
                                    vip_dev_qty = 1
                                    vip_dev0_lane = 1
                                    vip_dev0_twi_id = 2
                                    vip_dev0_fmt = 0
                                    vip_dev0_vflip = 1
                                    vip_dev0_hflip = 1
                                    vip_dev0_iovdd = ""
                                    vip_dev0_avdd = ""
                                    vip_dev0_dvdd = ""
                                    vip_dev0_afvdd = ""
                                    vip_dev0_flash_en =
                                    vip_dev0_af_pwdn =
                                    vip_dev1_mname = ""
                                    vip_dev1_lane = 1
                                    vip_dev1_twi_id = 0
                                    vip_dev1_twi_addr =
                                    vip_dev1_fmt = 1
                                    vip_dev1_vflip = 0
                                    vip_dev1_hflip = 0
                                    vip_dev1_iovdd = ""
                                    vip_dev1_avdd = ""
                                    vip_dev1_dvdd = ""
                                    vip_dev1_afvdd = ""
                                    vip_dev1_power_en =
                                    vip_dev1_reset =
                                    vip_dev1_pwdn =
                                    vip_dev1_flash_en =
                                    vip_dev1_af_pwdn =
                                    [tvout_para]
                                    tvout_used = 0
                                    tvout_channel_num =
                                    tv_en = 0
                                    [tvin_para]
                                    tvin_used = 0
                                    tvin_channel_num =
                                    [di_para]
                                    di_used = 1
                                    [mmc0_para]
                                    sdc_used = 1
                                    sdc_detmode = 3
                                    sdc_buswidth = 4
                                    sdc_use_wp = 0
                                    sdc_wp =
                                    sdc_isio = 0
                                    [mmc1_para]
                                    sdc_used = 1
                                    sdc_detmode = 4
                                    sdc_buswidth = 4
                                    sdc_det =
                                    sdc_use_wp = 0
                                    sdc_wp =
                                    sdc_isio = 1
                                    sdc_2xmode = 1
                                    sdc_ddrmode = 1
                                    [mmc2_para]
                                    sdc_used = 0
                                    sdc_detmode = 3
                                    sdc_buswidth = 8
                                    sdc_det =
                                    sdc_use_wp = 0
                                    sdc_wp =
                                    sdc_isio = 0
                                    sdc_2xmode = 1
                                    sdc_ddrmode = 1
                                    [smc_para]
                                    smc_used = 0
                                    [usbc0]
                                    usb_used = 1
                                    usb_port_type = 2
                                    usb_detect_type = 0
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usbc1]
                                    usb_used = 1
                                    usb_drv_vbus_gpio =
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usbc2]
                                    usb_used = 1
                                    usb_drv_vbus_gpio =
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usbc3]
                                    usb_used = 1
                                    usb_drv_vbus_gpio =
                                    usb_restrict_gpio =
                                    usb_not_suspend = 0
                                    [usb_feature]
                                    vendor_id = 6353
                                    mass_storage_id = 1
                                    adb_id = 2
                                    [msc_feature]
                                    release = 100
                                    luns = 3
                                    [serial_feature]
                                    serial_unique = 0
                                    [module_para]
                                    module_num = 7
                                    module_power1 =
                                    module_power1_vol =
                                    module_power2 =
                                    module_power2_vol =
                                    module_power3 =
                                    module_power3_vol =
                                    chip_en =
                                    lpo_use_apclk =
                                    [wifi_para]
                                    wifi_used = 0
                                    wifi_sdc_id = 1
                                    wifi_usbc_id = 5
                                    wifi_usbc_type = 1
                                    [bt_para]
                                    bt_used = 0
                                    bt_uart_id = 1
                                    bt_rst_n =
                                    bt_wake =
                                    bt_host_wake =
                                    [pcm0]
                                    daudio_used = 0
                                    daudio_master = 4
                                    daudio_select = 1
                                    audio_format = 1
                                    mclk_fs = 128
                                    msb_lsb_first = 0
                                    sign_extend = 0
                                    slot_index = 0
                                    slot_width = 32
                                    frame_width = 0
                                    tx_data_mode = 0
                                    rx_data_mode = 0
                                    [pcm1]
                                    daudio_used = 0
                                    daudio_master = 4
                                    daudio_select = 1
                                    audio_format = 1
                                    mclk_fs = 128
                                    msb_lsb_first = 0
                                    sign_extend = 0
                                    slot_index = 0
                                    slot_width = 32
                                    frame_width = 0
                                    tx_data_mode = 0
                                    rx_data_mode = 0
                                    [audio0]
                                    audio_used = 1
                                    lineout_vol = 31
                                    cap_vol = 5
                                    adcagc_used = 0
                                    adcdrc_used = 0
                                    dacdrc_used = 0
                                    adchpf_used = 0
                                    dachpf_used = 0
                                    [spdif0]
                                    spdif_used = 0
                                    [audiohub]
                                    hub_used = 0
                                    codec_used = 1
                                    spdif_used = 1
                                    hdmi_used = 1
                                    [s_cir0]
                                    ir_used = 0
                                    ir_addr_code5 = 239
                                    [cir]
                                    ir_used = 1
                                    [dvfs_table]
                                    pmuic_type = 1
                                    pmu_level0 = 11300
                                    pmu_level1 = 1100
                                    LV_count = 5
                                    LV1_volt = 1300
                                    LV2_volt = 1300
                                    LV3_volt = 1100
                                    LV4_volt = 1100
                                    LV5_volt = 1100
                                    [gpu_dvfs_table]
                                    G_LV_count = 3
                                    [Vdevice]
                                    Vdevice_used = 0
                                    [s_uart0]
                                    s_uart_used = 0
                                    [s_rsb0]
                                    s_rsb_used = 1
                                    [s_jtag0]
                                    s_jtag_used = 0
                                    [s_powchk]
                                    s_power_reg = 0
                                    s_system_power = 50
                                    [sim0]
                                    scr_used = 0
                                    [ts0]
                                    tsc_used = 0
                                    [gpio_power_key]
                                    key_used = 1
                                    [key_para]
                                    key_used = 0
                                    key_cnt = 5
                                    key1_vol = 222
                                    key2_vol = 444
                                    key3_vol = 666
                                    key4_vol = 857
                                    key5_vol = 2000
                                    [d7s_para]
                                    d7s_used = 0
                                    ;mali parameters
                                    [mali_para]
                                    mali_used = 1
                                    mali_clkdiv = 1
                                    [w1_para]
                                    w1_used = 1
                                    gpio = 20
                                    [corekeeper]
                                    then:
                                    root@orangepione:~# sudo fex2bin /tmp/orange.fex /boot/script.bin
                                    root@orangepione:~# sudo reboot
                                    then:
                                    crw------- 1 root root 153, 0 Mar 19 22:57 /dev/spidev0.0
                                    then:
                                    root@orangepione:~# git clone https://github.com/mysensors/MySensors.git
                                    Receiving objects: 100% (13985/13985), 9.70 MiB | 310.00 KiB/s, done.
                                    [OK] Finished.
                                    [OK] Finished.
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:PDT
                                    ^Z
                                    [1]+  Stopped                 sudo ./bin/mysgw -d
                                    also i change 3.3v and gnd to 17 and 20 but . . . :(
                                    • G Offline
                                      G Offline
                                      giran
                                      wrote on last edited by giran
                                      #58
                                      Hi all
                                      I have problems with Orange zero to make it work as a MYS gateway.
                                      What is done:
                                      1. take Debian img from https://www.armbian.com/orange-pi-zero/
                                      2. added /dev/spidev1.0 using instructions from here: https://www.mysensors.org/build/orange
                                        So I actually see spidev1.0 in ls -l /dev/spidev*
                                      3. wired everything up as is described here: https://www.mysensors.org/build/orange
                                        So everything is connected to the spi1 pins.
                                        I used nrf24 with a capacitor and without - same result
                                      4. ran commands
                                      cd MySensors
                                      ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020 --my-serial-baudrate=115200
                                      sudo make
                                      sudo make install
                                      sudo systemctl enable mysgw.service
                                      sudo systemctl start mysgw.service
                                      sudo ./bin/mysgw -d
                                      And I see failed logs
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: TSM:FAIL:PDT
                                      mysgw: TSM:INIT
                                      Has anyone set it up for Zero?
                                      What am I doing wrong?
                                      Thanks in advance!
                                      P 1 Reply Last reply
                                      • G giran
                                        Hi all
                                        What is done:
                                        4. ran commands
                                        cd MySensors
                                        sudo make
                                        sudo make install
                                        sudo ./bin/mysgw -d
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        Thanks in advance!
                                        P Offline
                                        P Offline
                                        pansen
                                        @giran hi i don't think you can run the service and the binary standalone at the same time since hardware access is exclusive. Try to stop the service and then run the binary again.
                                        G 1 Reply Last reply
                                        • P pansen
                                          G Offline
                                          G Offline
                                          giran
                                          #60
                                          @pansen Thanks for answering.
                                          Even when I stopped the service
                                          or when I run
                                          sudo make
                                          sudo ./bin/mysgw -d
                                          I still see failed logs.
