  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 62.8k Views 21 Watching
  • G giran
    @pansen Thanks for answering.
    Even when I stopped the service
    or when I run
    ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020 --my-serial-baudrate=115200
    sudo make
    sudo ./bin/mysgw -d
    I still see failed logs.
    SdeWeb
    @giran Hi, how did you connect you NRF module on the Orange PI ?
    Is you use the GPIO, you should'nt use TTY stup for MuSensors.
    Look above my setup in this forum, if you use the GPIO.
    Regards.
    G 1 Reply Last reply
    • S SdeWeb
      Regards.
      G Offline
      G Offline
      giran
      wrote on last edited by giran
      #62
      @SdeWeb Just a minute ago everything worked )) With all steps I described, instead of the 1st one.
      I faced with issues when I installed Debian Jessie (https://www.armbian.com/orange-pi-zero/)
      but when I tried Ubuntu Xential - everything worked!
      By using this img time to time my OrangeZero stops to respond. I'll investigate this later.
      But for now I'm happy I set up MYS.
      Thanks everyone who was trying to help. And I believe someone would find this post useful, with trying another img.
      • M Offline
        M Offline
        marceloaqno
        Code Contributor
        #63
        Support for RFM69 has been added, check the build guide for more information.
        • awilnerA Offline
          awilnerA Offline
          awilner
          Hi, everyone
          I hope someone can help me, I'm lost trying to wrap my head around the proper pin numbers. I'm using a 433MHz RFM69 connected to an OrangePi PC with this configuration:
             OPI PC <-----------> RFM69
          17 / 3.3V <-----------> VCC
           19 / PC0 <-----------> MOSI
           21 / PC1 <-----------> MISO
           22 / PA2 <-----------> DI00
           23 / PC2 <-----------> SCK
           24 / PC3 <-----------> NSS
           25 / GND <-----------> GND
          Pin codes were taken from this picture:
          OrangePi pins
          I have the most recent version of the code in the development branch:
          fanta@orangepipc:~/MySensors$ git status
          On branch development
          Your branch is up-to-date with 'origin/development'.
          nothing to commit, working directory clean
          fanta@orangepipc:~/MySensors$ git log --pretty=format:'%h' -n 1
          ff0953d
          Although the OrangePi PC apparently does not use spidev0.0 for NAND flash like the Zero, I ended up changing the FEX. This is my current state:
          [product]
          version = "100"
          machine = "orangepi-pc"
          [platform]
          debug_mode = 1
          eraseflag = 1
          next_work = 2
          [target]
          boot_clock = 1008
          storage_type = -1
          [key_detect_en]
          keyen_flag = 0
          [fel_key]
          fel_key_max = 7
          fel_key_min = 2
          [card_boot]
          logical_start = 40960
          sprite_work_delay = 500
          sprite_err_delay = 200
          sprite_gpio0 = port:PL10<1><default><default><default>
          next_work = 3
          [box_start_os]
          used = 1
          start_type = 1
          irkey_used = 1
          pmukey_used = 1
          pmukey_num = 3
          led_power = 0
          led_state = 0
          [boot_init_gpio]
          used = 1
          gpio0 = port:PL10<1><default><default><1>
          gpio1 = port:PG11<1><default><default><1>
          [recovery_para]
          used = 1
          mode = 2
          recovery_key = port:PL04<0><default><default><default>
          [pm_para]
          standby_mode = 1
          [card0_boot_para]
          card_ctrl = 0
          card_high_speed = 1
          card_line = 4
          sdc_d1 = port:PF00<2><1><2><default>
          sdc_d0 = port:PF01<2><1><2><default>
          sdc_clk = port:PF02<2><1><2><default>
          sdc_cmd = port:PF03<2><1><2><default>
          sdc_d3 = port:PF04<2><1><2><default>
          sdc_d2 = port:PF05<2><1><2><default>
          [card2_boot_para]
          card_ctrl = 2
          card_high_speed = 1
          card_line = 8
          sdc_cmd = port:PC06<3><1><2><default>
          sdc_clk = port:PC05<3><1><2><default>
          sdc_d0 = port:PC08<3><1><2><default>
          sdc_d1 = port:PC09<3><1><2><default>
          sdc_d2 = port:PC10<3><1><2><default>
          sdc_d3 = port:PC11<3><1><2><default>
          sdc_d4 = port:PC12<3><1><2><default>
          sdc_d5 = port:PC13<3><1><2><default>
          sdc_d6 = port:PC14<3><1><2><default>
          sdc_d7 = port:PC15<3><1><2><default>
          sdc_2xmode = 1
          sdc_ddrmode = 1
          [twi_para]
          twi_port = 0
          twi_scl = port:PA11<2><default><default><default>
          twi_sda = port:PA12<2><default><default><default>
          [uart_para]
          uart_debug_port = 0
          uart_debug_tx = port:PA04<2><1><default><default>
          uart_debug_rx = port:PA05<2><1><default><default>
          [force_uart_para]
          force_uart_port = 0
          force_uart_tx = port:PF02<3><1><default><default>
          force_uart_rx = port:PF04<3><1><default><default>
          [jtag_para]
          jtag_enable = 0
          jtag_ms = port:PA00<3><default><default><default>
          jtag_ck = port:PA01<3><default><default><default>
          jtag_do = port:PA02<3><default><default><default>
          jtag_di = port:PA03<3><default><default><default>
          [clock]
          pll_video = 297
          pll_ve = 402
          pll_periph0 = 600
          pll_gpu = 576
          pll_periph1 = 600
          pll_de = 864
          [dram_para]
          dram_clk = 624
          dram_type = 3
          dram_zq = 0x3b3bfb
          dram_odt_en = 1
          dram_para1 = 283377664
          dram_para2 = 0
          dram_mr0 = 6208
          dram_mr1 = 64
          dram_mr2 = 24
          dram_mr3 = 2
          dram_tpr0 = 0x48a192
          dram_tpr1 = 0x1c2418d
          dram_tpr2 = 0x76051
          dram_tpr3 = 0x0
          dram_tpr4 = 0x0
          dram_tpr5 = 0x0
          dram_tpr6 = 0x64
          dram_tpr7 = 0x0
          dram_tpr8 = 0x0
          dram_tpr9 = 0x0
          dram_tpr10 = 0x0
          dram_tpr11 = 0x6aaa0000
          dram_tpr12 = 0x7979
          dram_tpr13 = 0x800800
          [wakeup_src_para]
          cpu_en = 0
          cpu_freq = 48
          pll_ratio = 273
          dram_selfresh_en = 1
          dram_freq = 36
          wakeup_src0 =
          wakeup_src_wl = port:PG10<4><default><default><0>
          wakeup_src_bt = port:PL03<6><default><default><0>
          [twi0]
          twi_used = 1
          [twi1]
          twi_used = 1
          twi_scl = port:PA18<3><default><default><default>
          twi_sda = port:PA19<3><default><default><default>
          [twi2]
          twi_used = 0
          twi_scl = port:PE12<3><default><default><default>
          twi_sda = port:PE13<3><default><default><default>
          [uart0]
          uart_used = 1
          uart_port = 0
          uart_type = 2
          uart_tx = port:PA04<2><1><default><default>
          uart_rx = port:PA05<2><1><default><default>
          [uart1]
          uart_used = 0
          uart_port = 1
          uart_type = 4
          uart_tx = port:PG06<2><1><default><default>
          uart_rx = port:PG07<2><1><default><default>
          uart_rts = port:PG08<2><1><default><default>
          uart_cts = port:PG09<2><1><default><default>
          [uart2]
          uart_used = 0
          uart_port = 2
          uart_type = 4
          uart_tx = port:PA00<2><1><default><default>
          uart_rx = port:PA01<2><1><default><default>
          uart_rts = port:PA02<2><1><default><default>
          uart_cts = port:PA03<2><1><default><default>
          [uart3]
          uart_used = 0
          uart_port = 3
          uart_type = 4
          uart_tx = port:PA13<3><1><default><default>
          uart_rx = port:PA14<3><1><default><default>
          uart_rts = port:PA15<3><1><default><default>
          uart_cts = port:PA16<3><1><default><default>
          [spi0]
          spi_used = 1
          spi_cs_bitmap = 1
          spi_mosi = port:PC00<3><default><default><default>
          spi_miso = port:PC01<3><default><default><default>
          spi_sclk = port:PC02<3><default><default><default>
          spi_cs0 = port:PC03<3><1><default><default>
          [spi1]
          spi_used = 1
          spi_cs_bitmap = 1
          spi_cs0 = port:PA13<2><1><default><default>
          spi_sclk = port:PA14<2><default><default><default>
          spi_mosi = port:PA15<2><default><default><default>
          spi_miso = port:PA16<2><default><default><default>
          [spi_devices]
          spi_dev_num = 2
          [spi_board0]
          modalias = "spidev"
          max_speed_hz = 33000000
          bus_num = 0
          chip_select = 0
          mode = 0
          full_duplex = 1
          manual_cs = 0
          [spi_board1]
          modalias = "spidev"
          bus_num = 1
          chip_select = 0
          mode = 0
          full_duplex = 1
          manual_cs = 0
          [gpio_para]
          gpio_used = 1
          gpio_num = 20
          gpio_pin_1 = port:PA06<1><default><default><0>
          gpio_pin_2 = port:PA13<1><default><default><0>
          gpio_pin_3 = port:PA14<1><default><default><0>
          gpio_pin_4 = port:PA01<1><default><default><0>
          gpio_pin_5 = port:PD14<1><default><default><0>
          gpio_pin_6 = port:PA00<1><default><default><0>
          gpio_pin_7 = port:PA03<1><default><default><0>
          gpio_pin_8 = port:PC04<1><default><default><0>
          gpio_pin_9 = port:PC07<1><default><default><0>
          gpio_pin_10 = port:PA02<1><default><default><0>
          gpio_pin_11 = port:PA21<1><default><default><0>
          gpio_pin_12 = port:PA07<1><default><default><0>
          gpio_pin_13 = port:PA08<1><default><default><0>
          gpio_pin_14 = port:PG08<1><default><default><0>
          gpio_pin_15 = port:PA09<1><default><default><0>
          gpio_pin_16 = port:PA10<1><default><default><0>
          gpio_pin_17 = port:PG09<1><default><default><0>
          gpio_pin_18 = port:PG06<1><default><default><0>
          gpio_pin_19 = port:PG07<1><default><default><0>
          gpio_pin_20 = port:PC03<1><default><default><0>
          [leds_para]
          leds_used = 1
          green_led = port:PL10<1><default><default><1>
          green_led_active_low = 0
          red_led = port:PA15<1><default><default><0>
          red_led_active_low = 0
          [ths_para]
          ths_used = 1
          ths_trip1_count = 6
          ths_trip1_0 = 75
          ths_trip1_1 = 80
          ths_trip1_2 = 85
          ths_trip1_3 = 90
          ths_trip1_4 = 95
          ths_trip1_5 = 105
          ths_trip1_6 = 0
          ths_trip1_7 = 0
          ths_trip1_0_min = 0
          ths_trip1_0_max = 1
          ths_trip1_1_min = 1
          ths_trip1_1_max = 2
          ths_trip1_2_min = 2
          ths_trip1_2_max = 3
          ths_trip1_3_min = 3
          ths_trip1_3_max = 4
          ths_trip1_4_min = 4
          ths_trip1_4_max = 8
          ths_trip1_5_min = 8
          ths_trip1_5_max = 8
          ths_trip1_6_min = 0
          ths_trip1_6_max = 0
          ths_trip2_count = 1
          ths_trip2_0 = 105
          [cooler_table]
          cooler_count = 9
          cooler0 = "1296000 4 4294967295 0"
          cooler1 = "1200000 4 4294967295 0"
          cooler2 = "1008000 4 4294967295 0"
          cooler3 = "816000 4 4294967295 0"
          cooler4 = "648000 4 4294967295 0"
          cooler5 = "480000 4 4294967295 0"
          cooler6 = "480000 3 4294967295 0"
          cooler7 = "480000 2 4294967295 0"
          cooler8 = "480000 1 4294967295 0"
          [nand0_para]
          nand_support_2ch = 0
          nand0_used = 0
          nand0_we = port:PC00<2><default><default><default>
          nand0_ale = port:PC01<2><default><default><default>
          nand0_cle = port:PC02<2><default><default><default>
          nand0_ce1 = port:PC03<2><default><default><default>
          nand0_ce0 = port:PC04<2><default><default><default>
          nand0_nre = port:PC05<2><default><default><default>
          nand0_rb0 = port:PC06<2><default><default><default>
          nand0_rb1 = port:PC07<2><default><default><default>
          nand0_d0 = port:PC08<2><default><default><default>
          nand0_d1 = port:PC09<2><default><default><default>
          nand0_d2 = port:PC10<2><default><default><default>
          nand0_d3 = port:PC11<2><default><default><default>
          nand0_d4 = port:PC12<2><default><default><default>
          nand0_d5 = port:PC13<2><default><default><default>
          nand0_d6 = port:PC14<2><default><default><default>
          nand0_d7 = port:PC15<2><default><default><default>
          nand0_ndqs = port:PC16<2><default><default><default>
          [boot_disp]
          advert_disp = 0
          auto_hpd = 1
          output_type = 4
          hdmi_channel = 0
          hdmi_mode = 4
          cvbs_channel = 1
          cvbs_mode = 11
          output_full = 1
          hdmi_mode_check = 1
          [disp_init]
          disp_init_enable = 1
          disp_mode = 0
          screen0_output_type = 3
          screen0_output_mode = 5
          screen1_output_type = 3
          screen1_output_mode = 5
          fb0_format = 0
          fb0_width = 0
          fb0_height = 0
          fb1_format = 0
          fb1_width = 0
          fb1_height = 0
          [hdmi_para]
          hdmi_used = 1
          hdmi_power = "vcc-hdmi-18"
          [tv_para]
          tv_used = 0
          tv_dac_used = 1
          tv_dac_src0 = 0
          [pwm0_para]
          pwm_used = 0
          pwm_positive = port:PA05<3><0><default><default>
          [gmac0]
          gmac_used = 2
          gmac_power1 =
          [csi0]
          vip_used = 1
          vip_mode = 0
          vip_dev_qty = 1
          vip_define_sensor_list = 0
          vip_csi_pck = port:PE00<2><default><default><default>
          vip_csi_mck = port:PE01<2><default><default><default>
          vip_csi_hsync = port:PE02<2><default><default><default>
          vip_csi_vsync = port:PE03<2><default><default><default>
          vip_csi_d0 = port:PE04<2><default><default><default>
          vip_csi_d1 = port:PE05<2><default><default><default>
          vip_csi_d2 = port:PE06<2><default><default><default>
          vip_csi_d3 = port:PE07<2><default><default><default>
          vip_csi_d4 = port:PE08<2><default><default><default>
          vip_csi_d5 = port:PE09<2><default><default><default>
          vip_csi_d6 = port:PE10<2><default><default><default>
          vip_csi_d7 = port:PE11<2><default><default><default>
          vip_csi_sck = port:PE12<2><default><default><default>
          vip_csi_sda = port:PE13<2><default><default><default>
          vip_dev0_mname = "gc2035"
          vip_dev0_pos = "front"
          vip_dev0_lane = 1
          vip_dev0_twi_id = 2
          vip_dev0_twi_addr = 120
          vip_dev0_isp_used = 0
          vip_dev0_fmt = 0
          vip_dev0_stby_mode = 0
          vip_dev0_vflip = 1
          vip_dev0_hflip = 1
          vip_dev0_iovdd = ""
          vip_dev0_iovdd_vol = 2800000
          vip_dev0_avdd = ""
          vip_dev0_avdd_vol = 2800000
          vip_dev0_dvdd = ""
          vip_dev0_dvdd_vol = 1800000
          vip_dev0_afvdd = ""
          vip_dev0_afvdd_vol = 2800000
          vip_dev0_power_en = port:PA17<1><default><default><1>
          vip_dev0_reset = port:PE14<1><default><default><1>
          vip_dev0_pwdn = port:PE15<1><default><default><0>
          vip_dev0_flash_en =
          vip_dev0_flash_mode =
          vip_dev0_af_pwdn =
          vip_dev0_act_used = 0
          vip_dev0_act_name = "ad5820_act"
          vip_dev0_act_slave = 24
          vip_dev1_mname = ""
          vip_dev1_pos = "rear"
          vip_dev1_lane = 1
          vip_dev1_twi_id = 0
          vip_dev1_twi_addr =
          vip_dev1_isp_used = 0
          vip_dev1_fmt = 1
          vip_dev1_stby_mode = 0
          vip_dev1_vflip = 0
          vip_dev1_hflip = 0
          vip_dev1_iovdd = ""
          vip_dev1_iovdd_vol = 2800000
          vip_dev1_avdd = ""
          vip_dev1_avdd_vol = 2800000
          vip_dev1_dvdd = ""
          vip_dev1_dvdd_vol = 1500000
          vip_dev1_afvdd = ""
          vip_dev1_afvdd_vol = 2800000
          vip_dev1_power_en =
          vip_dev1_reset =
          vip_dev1_pwdn =
          vip_dev1_flash_en =
          vip_dev1_flash_mode =
          vip_dev1_af_pwdn =
          [tvout_para]
          tvout_used =
          tvout_channel_num =
          tv_en =
          [tvin_para]
          tvin_used =
          tvin_channel_num =
          [di_para]
          di_used = 1
          [mmc0_para]
          sdc_used = 1
          sdc_detmode = 3
          sdc_buswidth = 4
          sdc_det = port:PF06<0><1><2><default>
          sdc_use_wp = 0
          sdc_wp =
          sdc_isio = 0
          sdc_regulator = "none"
          sdc_power_supply = "none"
          [mmc1_para]
          sdc_used = 1
          sdc_detmode = 4
          sdc_buswidth = 4
          sdc_clk = port:PG00<2><1><3><default>
          sdc_cmd = port:PG01<2><1><3><default>
          sdc_d0 = port:PG02<2><1><3><default>
          sdc_d1 = port:PG03<2><1><3><default>
          sdc_d2 = port:PG04<2><1><3><default>
          sdc_d3 = port:PG05<2><1><3><default>
          sdc_det =
          sdc_use_wp = 0
          sdc_wp =
          sdc_isio = 1
          sdc_2xmode = 1
          sdc_ddrmode = 1
          [mmc2_para]
          sdc_used = 0
          sdc_detmode = 3
          sdc_buswidth = 8
          emmc_rst = port:PC16<3><1><2><default>
          sdc_det =
          sdc_use_wp = 0
          sdc_wp =
          sdc_isio = 0
          sdc_2xmode = 1
          sdc_ddrmode = 1
          [smc_para]
          smc_used = 0
          smc_rst = port:PA09<2><default><default><default>
          smc_vppen = port:PA20<3><default><default><default>
          smc_vppp = port:PA21<3><default><default><default>
          smc_det = port:PA10<2><default><default><default>
          smc_vccen = port:PA06<2><default><default><default>
          smc_sck = port:PA07<2><default><default><default>
          smc_sda = port:PA08<2><default><default><default>
          [usbc0]
          usb_used = 1
          usb_port_type = 2
          usb_detect_type = 0
          usb_id_gpio = port:PG12<0><1><default><default>
          usb_det_vbus_gpio = port:PG12<0><1><default><default>
          usb_drv_vbus_gpio = port:PL02<1><0><default><0>
          usb_host_init_state = 1
          usb_restrict_gpio =
          usb_restric_flag = 0
          usb_restric_voltage = 3550000
          usb_restric_capacity = 5
          usb_regulator_io = "nocare"
          usb_regulator_vol = 0
          usb_not_suspend = 0
          [usbc1]
          usb_used = 1
          usb_drv_vbus_gpio =
          usb_restrict_gpio =
          usb_not_suspend = 0
          [usbc2]
          usb_used = 1
          usb_drv_vbus_gpio =
          usb_restrict_gpio =
          usb_not_suspend = 0
          [usbc3]
          usb_used = 1
          usb_drv_vbus_gpio =
          usb_restrict_gpio =
          usb_not_suspend = 0
          [usb_feature]
          vendor_id = 6353
          mass_storage_id = 1
          adb_id = 2
          manufacturer_name = "USB Developer"
          product_name = "Android"
          serial_number = "20080411"
          [msc_feature]
          vendor_name = "USB 2.0"
          product_name = "USB Flash Driver"
          release = 100
          luns = 3
          [serial_feature]
          serial_unique = 0
          [module_para]
          module_num = 7
          module_power0 = "vcc-wifi-33"
          module_power0_vol = 0
          module_power1 =
          module_power1_vol =
          module_power2 =
          module_power2_vol =
          module_power3 =
          module_power3_vol =
          chip_en =
          lpo_use_apclk =
          [wifi_para]
          wifi_used = 0
          wifi_sdc_id = 1
          wifi_usbc_id = 5
          wifi_usbc_type = 1
          wl_reg_on = port:PL07<1><default><default><0>
          wl_host_wake = port:PG10<0><default><default><0>
          wl_host_wake_invert = 0
          [bt_para]
          bt_used = 0
          bt_uart_id = 1
          bt_rst_n =
          bt_wake =
          bt_host_wake =
          bt_host_wake_invert = 0
          [pcm0]
          daudio_used = 0
          daudio_master = 4
          daudio_select = 1
          audio_format = 1
          signal_inversion = 1
          mclk_fs = 128
          sample_resolution = 16
          slot_width_select = 32
          pcm_lrck_period = 32
          pcm_lrckr_period = 1
          msb_lsb_first = 0
          sign_extend = 0
          slot_index = 0
          slot_width = 32
          frame_width = 0
          tx_data_mode = 0
          rx_data_mode = 0
          i2s_mclk = port:PA18<2><1><default><default>
          i2s_bclk = port:PA19<2><1><default><default>
          i2s_dout0 = port:PA20<2><1><default><default>
          i2s_din = port:PA21<2><1><default><default>
          [pcm1]
          daudio_used = 0
          daudio_master = 4
          daudio_select = 1
          audio_format = 1
          mclk_fs = 128
          msb_lsb_first = 0
          sign_extend = 0
          slot_index = 0
          slot_width = 32
          frame_width = 0
          tx_data_mode = 0
          rx_data_mode = 0
          i2s_mclk = port:PG10<2><1><default><default>
          i2s_bclk = port:PG11<2><1><default><default>
          i2s_dout0 = port:PG12<2><1><default><default>
          i2s_din = port:PG13<2><1><default><default>
          [audio0]
          audio_used = 1
          lineout_vol = 31
          cap_vol = 5
          audio_hp_ldo = "none"
          adcagc_used = 0
          adcdrc_used = 0
          dacdrc_used = 0
          adchpf_used = 0
          dachpf_used = 0
          audio_pa_ctrl = port:PA16<1><default><default><0>
          [spdif0]
          spdif_used = 0
          spdif_dout = port:PA17<2><1><default><default>
          [audiohub]
          hub_used = 0
          codec_used = 1
          spdif_used = 1
          hdmi_used = 1
          [s_cir0]
          ir_used = 1
          ir_rx = port:PL11<2><1><default><default>
          ir_power_key_code0 = 87
          ir_addr_code0 = 40704
          ir_power_key_code1 = 26
          ir_addr_code1 = 64260
          ir_power_key_code2 = 20
          ir_addr_code2 = 32640
          ir_power_key_code3 = 21
          ir_addr_code3 = 32640
          ir_power_key_code4 = 11
          ir_addr_code4 = 63240
          ir_power_key_code5 = 3
          ir_addr_code5 = 239
          ir_power_key_code6 = 159
          ir_addr_code6 = 19635
          ir_power_key_code7 = 10
          ir_addr_code7 = 30536
          ir_power_key_code8 = 69
          ir_addr_code8 = 48386
          ir_power_key_code9 = 77
          ir_addr_code9 = 56865
          ir_power_key_code10 = 24
          ir_addr_code10 = 65025
          ir_power_key_code11 = 87
          ir_addr_code11 = 65280
          ir_power_key_code12 = 77
          ir_addr_code12 = 65344
          [cir]
          ir_used = 1
          ir_tx = port:PH07<2><default><default><default>
          [dvfs_table]
          pmuic_type = 2
          pmu_gpio0 = port:PL06<1><1><2><1>
          pmu_level0 = 11300
          pmu_level1 = 1100
          extremity_freq = 1296000000
          max_freq = 1200000000
          min_freq = 480000000
          LV_count = 7
          LV1_freq = 1296000000
          LV1_volt = 1320
          LV2_freq = 1200000000
          LV2_volt = 1240
          LV3_freq = 1104000000
          LV3_volt = 1180
          LV4_freq = 1008000000
          LV4_volt = 1140
          LV5_freq = 960000000
          LV5_volt = 1080
          LV6_freq = 816000000
          LV6_volt = 1020
          LV7_freq = 480000000
          LV7_volt = 980
          [gpu_dvfs_table]
          G_LV_count = 3
          G_LV0_freq = 312000000
          G_LV0_volt = 1200000
          G_LV1_freq = 384000000
          G_LV1_volt = 1200000
          G_LV2_freq = 456000000
          G_LV2_volt = 1200000
          [Vdevice]
          Vdevice_used = 0
          Vdevice_0 = port:PH10<5><1><2><default>
          Vdevice_1 = port:PH11<5><1><2><default>
          [s_uart0]
          s_uart_used = 0
          s_uart_tx = port:PL02<2><default><default><default>
          s_uart_rx = port:PL03<2><default><default><default>
          [s_rsb0]
          s_rsb_used = 1
          s_rsb_sck = port:PL00<2><1><2><default>
          s_rsb_sda = port:PL01<2><1><2><default>
          [s_jtag0]
          s_jtag_used = 0
          s_jtag_tms = port:PL04<2><1><2><default>
          s_jtag_tck = port:PL05<2><1><2><default>
          s_jtag_tdo = port:PL06<2><1><2><default>
          s_jtag_tdi = port:PL07<2><1><2><default>
          [s_powchk]
          s_powchk_used = -2147483648
          s_power_reg = 0
          s_system_power = 50
          [sim0]
          scr_used = 0
          scr_vccen = port:PA06<2><default><default><default>
          scr_slk = port:PA07<2><default><default><default>
          scr_sda = port:PA08<2><default><default><default>
          scr_rst = port:PA09<2><default><default><default>
          scr_det = port:PA10<2><default><default><default>
          [ts0]
          tsc_used = 0
          tsc_clk = port:PE00<3><default><default><default>
          tsc_err = port:PE01<3><default><default><default>
          tsc_sync = port:PE02<3><default><default><default>
          tsc_dvld = port:PE03<3><default><default><default>
          tsc_d0 = port:PE04<3><default><default><default>
          tsc_d1 = port:PE05<3><default><default><default>
          tsc_d2 = port:PE06<3><default><default><default>
          tsc_d3 = port:PE07<3><default><default><default>
          tsc_d4 = port:PE08<3><default><default><default>
          tsc_d5 = port:PE09<3><default><default><default>
          tsc_d6 = port:PE10<3><default><default><default>
          tsc_d7 = port:PE11<3><default><default><default>
          [gpio_power_key]
          key_used = 1
          key_io = port:PL03<6><default><default><0>
          [key_para]
          key_used = 0
          key_cnt = 5
          key1_vol = 222
          key2_vol = 444
          key3_vol = 666
          key4_vol = 857
          key5_vol = 2000
          [d7s_para]
          d7s_used = 0
          din_gpio = port:PD00<1><default><default><1>
          clk_gpio = port:PD01<1><default><default><1>
          stb_gpio = port:PD02<1><default><default><1>
          [mali_para]
          mali_used = 1
          mali_clkdiv = 1
          mali_extreme_freq = 600
          mali_extreme_vol = 1400
          [w1_para]
          w1_used = 1
          gpio = 20
          [corekeeper]
          corekeeper_enabled = 1
          Note that I added a line to the gpio section in one of my attempts to make this work, in order to map PA2 to GPIO20 (or at least that was what I was trying to accomplish).
          I'm trying to compile an MQTT gateway, so my configure line is:
          ./configure --spi-spidev-device=/dev/spidev0.0 --my-rfm69-irq-pin=10 --my-rfm69-cs-pin=20 --my-transport=rfm69 --my-rfm69-frequency=433 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --extra-cxxflags="-DMY_DEBUG_VERBOSE_RFM69"
          And here is the core of my problem - which values to use for IRQ pin and CS pin. If I use 10 for IRQ. I compile with no problems, but when I run
          sudo bin/mysgw -d
          I get:
          fanta@orangepipc:~/MySensors$ sudo bin/mysgw -d
          mysgw: Starting gateway...
          mysgw: Protocol version - 2.2.0-beta
          mysgw: MCO:BGN:INIT GW,CP=RPNG----,VER=2.2.0-beta
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: RFM69:INIT
          mysgw: RFM69:INIT:PIN,CS=20,IQP=10,IQN=2
          mysgw: RFM69:PTX:LEVEL=5 dBm
          mysgw: Could not open /sys/class/gpio/gpio10/direction
          I have already tried enabling GPIO10:
          fanta@orangepipc:~/MySensors$ echo "10" |sudo tee /sys/class/gpio/export
          tee: /sys/class/gpio/export: Device or resource busy
          My gpio readall outputs this:
          fanta@orangepipc:~/MySensors$ gpio readall
           +-----+-----+----------+------+---+-Orange Pi+---+---+------+---------+-----+--+
           | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
           |     |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |     |
           |  12 |   8 |    SDA.0 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
           |  11 |   9 |    SCL.0 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
           |   6 |   7 |   GPIO.7 |  OUT | 0 |  7 || 8  | 0 | OUT  | TxD3     | 15  | 13  |
           |     |     |       0v |      |   |  9 || 10 | 0 | OUT  | RxD3     | 16  | 14  |
           |   1 |   0 |     RxD2 |  OUT | 0 | 11 || 12 | 0 | OUT  | GPIO.1   | 1   | 110 |
           |   0 |   2 |     TxD2 |  OUT | 0 | 13 || 14 |   |      | 0v       |     |     |
           |   3 |   3 |     CTS2 |  OUT | 0 | 15 || 16 | 0 | OUT  | GPIO.4   | 4   | 68  |
           |     |     |     3.3v |      |   | 17 || 18 | 0 | OUT  | GPIO.5   | 5   | 71  |
           |  64 |  12 |     MOSI | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
           |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | OUT  | RTS2     | 6   | 2   |
           |  66 |  14 |     SCLK | ALT4 | 0 | 23 || 24 | 0 | OUT  | CE0      | 10  | 67  |
           |     |     |       0v |      |   | 25 || 26 | 0 | OUT  | GPIO.11  | 11  | 21  |
           |  19 |  30 |    SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1    | 31  | 18  |
           |   7 |  21 |  GPIO.21 |  OUT | 0 | 29 || 30 |   |      | 0v       |     |     |
           |   8 |  22 |  GPIO.22 |  OUT | 0 | 31 || 32 | 0 | OUT  | RTS1     | 26  | 200 |
           |   9 |  23 |  GPIO.23 |  OUT | 0 | 33 || 34 |   |      | 0v       |     |     |
           |  10 |  24 |  GPIO.24 |  OUT | 0 | 35 || 36 | 0 | OUT  | CTS1     | 27  | 201 |
           |  20 |  25 |  GPIO.25 |  OUT | 1 | 37 || 38 | 0 | OUT  | TxD1     | 28  | 198 |
           |     |     |       0v |      |   | 39 || 40 | 0 | OUT  | RxD1     | 29  | 199 |
           +-----+-----+----------+------+---+-Orange Pi+---+------+----------+-----+-----+
          So I tried --my-rfm69-irq-pin=2 --my-rfm69-cs-pin=67 as well, but I run into the same problem with pin 2.
          Can anyone help me find out which pin numbers to use?
          Thanks in advance!
          • P Offline
            P Offline
            pansen
            @awilner I am in a hurry right now so I cannot go through what you wrote in detail, but maybe my post about pin numbering can help you: https://forum.mysensors.org/post/58309 It is related to an OPi Plus2e using nrf24 but the numbering formulas should still be valid.
            Good luck!
            Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
            awilnerA 1 Reply Last reply
            • P pansen
              Good luck!
              awilnerA Offline
              awilnerA Offline
              awilner
              @pansen , Thank you so much!!! I managed to find two pins that didn't give me this error, PA11 and PA12, and now at least the chip configuration and communication apparently works.
              • 8 Offline
                8 Offline
                8667
                I wanted to build MQTT client gateway with whitelisting and encryption + 3 LEDs with Arduino UNO and Ethernet shield but it does not have enough memory.
                Before going to Arduino MEGA I found this and I think this will be a better way to do it. Smaller, cheaper..just not sure if it has all the options. Can someone confirm? Whitelisting will be easier then reflashing Arduino all the time too.
                I plan to use Orange Pi Zero H2+ Quad Core 256MB
                • P Offline
                  P Offline
                  pansen
                  If your conditions are
                  • 3 LEDs: yes through GPIO
                  • Ethernet: yes (d'uh)
                  • beefy enough for software encryption: I guess? For an IoT-low data rate scenario for sure
                  I'm running armbian on my Orange Pi and setting up mosquitto is a breeze. But you don't need a broker right? Don't forget you need an SD card on top and more power.
                  • 8 Offline
                    8 Offline
                    8667
                    Thanks, I already have a broker and OpenHAB. Want this gateway to act as a client....maybe it will even support SSL MQTT. And encryption with
                    #define MY_RF24_ENABLE_ENCRYPTION is wanted.
                    In the article, there is no list of all available configurations...yea adding SD card does not make it cheaper
                    • P Offline
                      P Offline
                      pansen
                      i'm sorry, i do not have experience with encryption. essentially it depends on the code you want to write, since on the pi you are kind of limited to scripting, whereas microcontroller code is closer to hardware. also, if you need things like an adc or spi you're better of with a microcontroller. if it's just about some LEDs lighting up..
                      • 8 8667
                        @8667 said in 💬 Building a Orange Pi Gateway:
                        From the article:
                        For a complete list of configuration parameters, run:
                        ./configure --help
                        Did you miss this or is there something I'm not understanding?
                        • B Offline
                          B Offline
                          BAsavaraj004
                          Please help me to solve this error
                          • B BAsavaraj004
                            @BAsavaraj004 could you describe what you did when you got that error?
                            • B Offline
                              B Offline
                              BAsavaraj004
                              @mfalkvidd
                              When I executed sudo ./bin/mysgw -d this command after that i'm facing error like :
                              mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: Could not open /sys/class/gpio/gpio24/direction
                              I followed all the steps provide in the site but still I am getting error.
                              • B BAsavaraj004
                                @mfalkvidd
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                @BAsavaraj004 thanks. Earlier posts indicate that the "Could not open" error could be caused by a problem with the pin mapping. I don't have an OrangePi myself so I don't know the details but maybe these posts can help:
                                https://forum.mysensors.org/post/69656
                                https://forum.mysensors.org/post/60943
                                https://forum.mysensors.org/post/56374
                                • S SdeWeb
                                  Well done finally i used the dedicated .fex file for Orange Pi Plus 2E here :
                                  https://linux-sunxi.org/Xunlong_Orange_Pi_Plus_2E#Expansion_Port
                                  at this point :
                                  https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepiplus2e.fex
                                  Read the .fex file in a text editor, u'll see important things about "gpio_config" for H3 cpu :
                                  ; NOTE: This section is necessary only for "gpio_sunxi" driver
                                  ; which is obsolete for H3 boards
                                  [gpio_para]
                                  gpio_used = 0
                                  gpio_num = 0
                                  I connected my NRF24L01 on OPI P2E like this :
                                  NRF24L01 Port Name / (Pin N°) ----- OPI Port (Pin N°) / Name
                                                        GND (1)  <-----------> (20) / GND
                                                        VCC (2)  <-----------> (17) / 3.3V PWR
                                                        CE (3)   <-----------> (22) / (PA2 / GPIO2)
                                                        CSN (4)  <-----------> (24) / (PC3 / GPIO67)
                                                        SCK (5)  <-----------> (23)
                                                        MOSI (6) <-----------> (19) MOSI
                                                        MISO (7) <-----------> (21) MISO
                                                        IRQ (8)  <-----------> NC
                                  So "MySensors" setup is :
                                  ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
                                  Then
                                  ./bin/mysgw -d
                                  Return :
                                  root@orangepiplus2e:~/MySensors# ./bin/mysgw -d
                                  mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.2.0-beta
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: TSM:INIT:TSP OK
                                  mysgw: TSM:INIT:GW MODE
                                  mysgw: MCO:REG:NOT NEEDED
                                  mysgw: Listening for connections on 0.0.0.0:5003
                                  mysgw: MCO:BGN:STP
                                  mysgw: MCO:BGN:INIT OK,TSP=1
                                  Best.
                                  Seb.
                                  E Offline
                                  E Offline
                                  ElDuderino
                                  wrote on last edited by ElDuderino
                                  #76
                                  @SdeWeb said in 💬 Building a Orange Pi Gateway:
                                  at this point :
                                  [gpio_para]
                                  gpio_used = 0
                                  gpio_num = 0
                                  Then
                                  ./bin/mysgw -d
                                  Return :
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: MCO:BGN:STP
                                  Best.
                                  Seb.
                                  This worked great on my Orange Pi Lite.
                                  I was trying to follow the tutorial at Building a Orange Pi Gateway and I tried all sorts of things that didn't work.
                                  IMO the main tutorial should have this as instruction to building a gateway with Orange Pi Lite/Plus.
                                  Thanks!!
                                  ( Sorry for quoting the entire original post, but this will help anyone searching for help with their Orange Pi Lite)
                                  • 8 Offline
                                    8 Offline
                                    8667
                                    I got the OrangeZero and was building the configuration command... can someone provide me more detailed instructions about using higher security?
                                    1. Is it possible to use SSL for the connecting to the broker?
                                    2. How whitelisting works with Pi? I moved away of Arduino as I do not want to recompile it everytime I need to include new node. So far I have
                                    -my-signing-request-signatures --my-signing-debug --my-signing=password --my-signing-password=SOMETHING --my-rf24-encryption-enabled
                                    but this will not allow me to exclude stolen nodes right?
                                    • 8 8667
                                      A Offline
                                      A Offline
                                      Anticimex
                                      @8667 no, it won't. As it is for the moment, whitelisting works no different compared to Arduino based devices. You will have to recompile your GW if you add new nodes as you will need to add their serials to the whitelist in the GW.
                                      8 1 Reply Last reply
                                      • A Anticimex
                                        8 Offline
                                        8 Offline
                                        8667
                                        @Anticimex said in 💬 Building a Orange Pi Gateway:
                                        So how personalization works on the orange and how to pass the list of serials?
                                        • 8 8667
                                          A Offline
                                          A Offline
                                          Anticimex
                                          @8667 not sure. I have not been involved in the rPi port. I suggest you pass --help to the configure command. It should give a list of options.
