  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 62.8k Views 21 Watching
  • 8 Offline
    8 Offline
    8667
    This should be in the wiki
    root@pi0:~/MySensors# ./configure --help
    configure script for MySensors gateway.
    Options:
    Help:
        -h, --help                  print this message
    SPI driver options:
        --spi-driver=[BCM|SPIDEV]
        --spi-spidev-device=<DEVICE>
                                    Device path. [/dev/spidev0.0]
    Building options:
        --soc=[BCM2835|BCM2836|BCM2837|AM33XX|A10|A13|A20|H3]
                                    SoC type to be used. [configure autodetected]
        --cpu-flags=<CPUFLAGS>      CPU defining/optimizing flags to be used. [configure autodetected]
        --extra-cflags=<CFLAGS>     Extra C flags passed to C compilation. []
        --extra-cxxflags=<CXXFLAGS> Extra C++ flags passed to C++ compilation. []
        --extra-ldflags=<LDFLAGS>   Extra C flags passed to linking. []
        --c_compiler=<CC>           C compiler. [arm-linux-gnueabihf-gcc][gcc]
        --cxx_compiler=<CXX>        C++ compiler. [arm-linux-gnueabihf-g++][g++]
        --build-dir=<DIR>           Compiler directory to store object files. [build]
        --bin-dir=<DIR>             Compiler directory to store binary files. [bin]
        --arduino-lib-dir=<DIR>     Arduino library directory.
        --no-clean                  Don't clean previous build artifacts.
    Installation options:
        --prefix=<PREFIX>           Installation prefix path. [/usr/local]
        --gateway-dir=<DIR>         Gateway files installation directory. [PREFIX/bin]
    MySensors options:
        --my-debug=[enable|disable] Enables or disables MySensors core debugging. [enable]
        --my-config-file=<FILE>     Config file path. [/etc/mysensors.dat]
        --my-gateway=[none|ethernet|serial|mqtt]
                                    Set the protocol used to communicate with the controller.
                                    [ethernet]
        --my-node-id=<ID>           Disable gateway feature and run as a node with the specified id.
        --my-controller-url-address=<URL>
                                    Controller or MQTT broker url.
        --my-controller-ip-address=<IP>
                                    Controller or MQTT broker ip.
        --my-port=<PORT>            The port to keep open on gateway mode.
                                    If gateway is set to mqtt, it sets the broker port.
        --my-serial-port=<PORT>     Serial port. [/dev/ttyACM0]
        --my-serial-baudrate=<BAUD> Serial baud rate. [115200]
        --my-serial-is-pty          Set the serial port to be a pseudo terminal. Use this if you want
                                    to connect to a controller running on the same device.
        --my-serial-pty=<NAME>      Symlink name for the PTY device. [/dev/ttyMySensorsGateway]
        --my-serial-groupname=<GROUP>
                                    Grant access to the specified system group for the serial device.
        --my-mqtt-client-id=<ID>    MQTT client id.
        --my-mqtt-user=<UID>        MQTT user id.
        --my-mqtt-password=<PASS>   MQTT password.
        --my-mqtt-publish-topic-prefix=<PREFIX>
                                    MQTT publish topic prefix.
        --my-mqtt-subscribe-topic-prefix=<PREFIX>
                                    MQTT subscribe topic prefix.
        --my-transport=[none|nrf24|rs485|rfm95|rfm69]
                                    Set the transport to be used to communicate with other nodes.
                                    [nrf24]
        --my-rf24-channel=<0-125>   RF channel for the sensor net. [76]
        --my-rf24-pa-level=[RF24_PA_MAX|RF24_PA_LOW]
                                    RF24 PA level. [RF24_PA_MAX]
        --my-rf24-ce-pin=<PIN>      Pin number to use for rf24 Chip-Enable.
        --my-rf24-cs-pin=<PIN>      Pin number to use for rf24 Chip-Select.
        --my-rf24-irq-pin=<PIN>     Pin number connected to nRF24L01 IRQ pin.
        --my-rf24-encryption-enabled
                                    Enables RF24 encryption.
                                    All nodes and gateway must have this enabled, and all must be
                                    personalized with the same AES key
        --my-rx-message-buffer-size=<SIZE>
                                    Buffer size for incoming messages when using rf24 interrupts. [20]
        --my-rfm69-frequency=[315|433|868|915]
                                    RFM69 Module Frequency. [868]
        --my-is-rfm69hw             Enable high-powered rfm69hw.
        --my-rfm69-irq-pin=<PIN>    Pin number connected to RFM69 IRQ pin.
        --my-rfm69-cs-pin=<PIN>     Pin number to use for RFM69 Chip-Select.
        --my-rs485-serial-port=<PORT>
                                    RS485 serial port. You must provide a port.
        --my-rs485-baudrate=<BAUD>  RS485 baudrate. [9600]
        --my-rs485-de-pin=<PIN>     Pin number connected to RS485 driver enable pin.
        --my-rs485-max-msg-length=<LENGTH>
                                    The maximum message length used for RS485. [40]
        --my-leds-err-pin=<PIN>     Error LED pin.
        --my-leds-rx-pin=<PIN>      Receive LED pin.
        --my-leds-tx-pin=<PIN>      Transmit LED pin.
        --my-leds-blinking-inverse  Inverse the blinking feature.
        --my-signing=[none|software|password]
                                    Message signing. [none]
        --my-signing-debug          Enable signing related debug.
        --my-signing-request-signatures
                                    Enable signature request from nodes that in turn requested
                                    gateway signature.
        --my-signing-weak_security  Enable this to permit downgrade of security preferences and
                                    relaxed gateway signing requirements.
        --my-signing-password=<PASSWORD>
                                    If you are using password as the signature type, set your password here.
    root@pi0:~/MySensors# sudo ./bin/mysgw -h
    mysgw: Config file /etc/mysensors.dat does not exist, creating new config file.
    Usage: mysgw [options]
    Options:
      -h, --help                 Display a short summary of all program options.
      -d, --debug                Enable debug.
      -b, --background           Run as a background process.
      --gen-soft-hmac-key        Generate and print a soft hmac key.
      --gen-soft-serial-key      Generate and print a soft serial key.
      --gen-aes-key              Generate and print an aes encryption key.
      --print-soft-hmac-key      Print the soft hmac key from the config file.
      --print-soft-serial-key    Print the soft serial key from the config file.
      --print-aes-key            Print the aes encryption key from the config file.
      --set-soft-hmac-key        Write a soft hmac key to the config file.
      --set-soft-serial-key      Write a soft serial key to the config file.
      --set-aes-key              Write an aes encryption key to the config file.
    A mfalkviddM 2 Replies Last reply
    • 8 8667
      Options:
      Help:
      SPI driver options:
      Building options:
      MySensors options:
                                      [ethernet]
                                      [nrf24]
                                      gateway signature.
      Options:
      A Offline
      A Offline
      Anticimex
      @8667 if there is no option for the whitelist, you should still be able to set it using the same #define as mentioned in the signing documentation. The implementation is shared.
      It makes sense to keep it like that since the list could be quite long.
      • 8 8667
        Options:
        Help:
        SPI driver options:
        Building options:
        MySensors options:
                                        [ethernet]
                                        [nrf24]
                                        gateway signature.
        Options:
        #83
        @8667 a first try of making the help text available online is now available at https://ci.mysensors.org/job/MySensors/job/MySensors/job/PR-952/12/Doxygen_HTML/group__RaspberryPiGateway.html
        If/when the pull request is accepted, a link can be added on the build page.
        • Ricardo RibeiroR Offline
          Ricardo Ribeiro
          Hello! I followed instructions by SdeWeb on my Orange Pi Lite with Armbian, and gateway is working fine, I can see debug messages from other node. But when I try to add a serial port in node-red I can't find the gateway one. Can you help me?
            Ricardo Ribeiro
            FYI i configure like this:
            ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB10 --my-serial-baudrate=115200
            • 8 Offline
              8 Offline
              8667
              NOTE for Armbian and Orange Pi Zero.
              Set static IP address or the device will lose connection on next DHCP request. I use only the LAN and was having problems for few days.
              • 8 8667
                @8667 I didn't know it was possibe to set ip address for the Pi gateway. How did you do that?
                • S Offline
                  SdeWeb
                  wrote on last edited by SdeWeb
                  #88
                  You should set your gateway as a ethernet / network gateway. By default, it run on port 5003 (ex : [gwipadresse]:5003.
                  If you controler is hosted on the same machine that the gateway, then you can call the ip adresse : 127.0.0.1:5003. (the localhost adress) whatever the real IP adresse of your PI.
                  if you got a good router on u'r network, that it running DHCP server and give IP adresses of your devices on the network, then you can define static IP adresse for the MAC adresse of your PI.
                  Regards.
                    Ricardo Ribeiro
                    I had to use spidev0.0 and not spidev1.0:
                    opilite@orangepilite:~/MySensors$ sudo ./bin/mysgw -d
                    mysgw: Starting gateway...
                    mysgw: Protocol version - 2.2.0-beta
                    mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-beta
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: TSM:INIT:TSP OK
                    mysgw: TSM:INIT:GW MODE
                    mysgw: MCO:REG:NOT NEEDED
                    mysgw: MCO:BGN:STP
                    mysgw: MCO:BGN:INIT OK,TSP=1
                    opilite@orangepilite:~/MySensors$ ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                      Ricardo Ribeiro
                      With mqtt gateway I got further ahead:
                      opilite@orangepilite:~/MySensors$ ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=my_mqtt_gateway
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: MCO:BGN:STP
                      mysgw: Attempting MQTT connection...
                      mysgw: connected to 127.0.0.1
                      mysgw: MQTT connected
                      mysgw: Sending message on topic: mysensors-out/0/255/0/0/18
                      mysensors-out/0/255/0/0/18 : msg.payload : string[10]
                      "2.2.0-beta"
                        Ricardo Ribeiro
                        Ok, now I load a sketch into an arduino nanowith nrf24l01+ and this is all I got:
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        mysgw: TSF:MSG:BC
                        mysgw: TSF:MSG:FPAR REQ,ID=255
                        mysgw: TSF:CKU:OK,FCTRL
                        mysgw: TSF:MSG:GWL OK
                        mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                        mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
                        mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
                        mysgw: TSF:MSG:BC
                        mysgw: TSF:PNG:SEND,TO=0
                        mysgw: TSF:CKU:OK
                        Stuck again.
                        • Ricardo RibeiroR Ricardo Ribeiro
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: MCO:BGN:STP
                          mysgw: TSF:MSG:BC
                          mysgw: TSF:MSG:BC
                          mysgw: TSF:CKU:OK
                          Stuck again.
                          #92
                          @Ricardo-Ribeiro that looks normal. Is this different from what you expected? If so, how does it differ?
                          • 8 Offline
                            8 Offline
                            8667
                            Had anyone succeeded using signing+encryption on OrangePi MQTT gateway? I managed to make Arduino gateway and it worked but I can not replicate the same thing with Pi. What file should be edited to enter the keys? and the whitelist?
                            • P Offline
                              P Offline
                              pii
                              #94
                              Am getting this error:
                              ERROR Could not open /sys/class/gpio/gpio24/direction
                              My config is:
                              ./configure --spi-spidev-device=/dev/spidev1.0 --my-node-id=1 --my-transport=rfm95 --my-rfm95-cs-pin=13 --my-rfm95-irq-pin=10 --my-rfm69-frequency=915E6
                              Whole output is:
                              root@ttn-gateway:~/MySensors# sudo ./bin/mysgw
                              May 23 09:37:31 INFO  Starting gateway...
                              May 23 09:37:31 INFO  Protocol version - 2.3.0-alpha
                               __  __       ____
                                      |___/                      2.3.0-alpha
                              May 23 09:37:31 DEBUG MCO:BGN:INIT NODE,CP=RLNNL---,VER=2.3.0-alpha
                              May 23 09:37:31 DEBUG TSM:INIT
                              May 23 09:37:31 DEBUG TSF:WUR:MS=0
                              May 23 09:37:42 ERROR Could not open /sys/class/gpio/gpio24/direction
                              P 1 Reply Last reply
                              • P pii
                                My config is:
                                Whole output is:
                                 __  __       ____
                                        |___/                      2.3.0-alpha
                                P Offline
                                P Offline
                                pansen
                                @pii
                                • Does /sys/class/gpio/gpio24/direction exists?
                                • Does /sys/class/gpio/gpio24 exists?
                                • Can you write to them using echo?
                                Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                                P 2 Replies Last reply
                                • P pansen
                                  @pii
                                  P Offline
                                  P Offline
                                  pii
                                  @pansen No.... nothing... /sys/class/gpio/gpio24doesn't exist.
                                  even "echo "24" > /sys/class/gpio/export doesn't work.
                                  But, yes otherwise if I try the same with 13 i.e "echo "13" > /sys/class/gpio/export Then a directory is created and then /sys/class/gpio/gpio24/direction do exist.
                                  • P pansen
                                    @pii
                                    P Offline
                                    P Offline
                                    pii
                                    @pansen Thank you sooooooo much for your reply.!!! By the way, What I actually have to do is "Make an MQTT based LoRa(RA-02) receiver gateway on OrangePi Zero". And I'm stuck since whole week :'( of course spent time trying code without solid base. :/
                                    Yes, yet I'm trying to first set up a LoRa receiver(not MQTT, not gateway)
                                    • M Offline
                                      M Offline
                                      marceloaqno
                                      Code Contributor
                                      @pii --my-rfm95-cs-pin and --my-rfm95-irq-pin options are not currently supported by the configure script.
                                      Until we fix this, could you please try adding the following to your examples_linux/mysgw.cpp (before the #include <MySensors.h>)
                                      #define MY_RFM95_CS_PIN 13
                                      #define MY_RFM95_IRQ_PIN 10
                                      #define MY_RFM95_FREQUENCY RFM95_915MHZ
                                      and run the make command again.
                                      • M marceloaqno
                                        P Offline
                                        P Offline
                                        pii
                                        @marceloaqno said in 💬 Building a Orange Pi Gateway:
                                        Thank you sooo much. I just did this. But, Now got a new error.
                                         ERROR Could not open /sys/class/gpio/gpio10/direction
                                        and when I tried to export pin 10 it says:
                                        :/sys/class/gpio# echo '10' > export
                                        -bash: echo: write error: Device or resource busy
                                        Though yes still I'm able to export/unexport pin 13(just for testing)
                                        M 1 Reply Last reply
                                        • vladikomsV Offline
                                          vladikomsV Offline
                                          vladikoms
                                          @pii Try my library for Orange Pi Zero and Semtech SX1278 radio (RA-02 module)
