  3. OpenHAB
  4. MQTT batterylevel reporting
3 Posts 2 Posters 4.0k Views 1 Watching
  • H
    H
    Hausner
    Hi
    I've migrated from serial to mqtt. With the serial connection I got the sensors to report the batterylevel, but I can't get it to work with the MQTT GW.
    I've seen, that there's a "default" battery reporting line in MySensor.h
         void sendBatteryLevel(uint8_t level, bool ack);
    But how do I adapt that to mqtt?
    Can I just add the line at the end of the default temperature sensor loop?
    • bjornhallbergB
      bjornhallbergB
      bjornhallberg
      Because I'm lazy at soldering I only have one battery board so far that actually reports battery level, but for me the battery is coming through as
      MyMQTT/4/255/50 92
      Or whatever, "92" being the payload. I went into MyMQTT.cpp and changed the pertinent line to
      char V_50[] PROGMEM = "BATTERY_LEVEL";
      So it looks a bit prettier and easier to catch in Python. As for actually using that value with some controller / HA software that is another matter. I myself save it as a "user variable" in Domoticz (since many of the dummy sensors in Domoticz can't have a battery level apparently). That way I can have a long list all in one place of all battery levels and can sort it.
      What sort of controller do you use?
      • H
        H
        Hausner
        wrote on last edited by Hausner
        I'm using OpenHab as controller.
        It worked pretty good when i had a raspberry as a serial gateway reporting to Openhab, but now I've switched to a MQTT gateway on an UNO. That works fine for a few temp sensors, but i'm having serious trouble getting a 8-channel relay node to work. It works for about 1-2 hours then it stops responding :( Then i have to powercycle it, to get it running again.
        Currently the temp sensors report this:
        0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1:81
        for a battery reading (81%).
