Communication problem (maybe)
Hmm.. shouldn't affect transmissions. When you removed this line you will get several hundreds of temp readings per second. It is a very big chance a few of them differs which means they will send it to gateway.
You could try adding:
gw.powerUp();
delay(10)
Just before gw.send() to add a small some additional delay after radio powers up.If you want to keep node awake another option is to use millis() keep track of send frequency. See here:
https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/TimeAwareSensor/TimeAwareSensor.ino#L47 -
gw.powerUp();
delay(10)
@hek said:
delay(10)
I assume that is milliseconds, but does that mean that the radio will be powered on during that delay, and will the node repeat incoming messages during that?
If so, I think a much bigger delay would be better, like 30000 or even more.
By 1-way node I mean a reporting node. It only reports a temperature, nothing else. So therefore 1 way traffic TO the GW/controller.
A relay node on the other hand has to receive also, else you can't flip on/off the relays.
This is roughly 1 minute worth of controller log:
2014-11-13 04:49:27 - Helena_temp_LastUpdate state updated to 2014-11-13T04:49:27 2014-11-13 04:49:28 - Temperature_GF_Helena state updated to 26.7 2014-11-13 04:49:28 - Helena_temp_LastUpdate state updated to 2014-11-13T04:49:28 2014-11-13 04:49:29 - Temperature_GF_Helena state updated to 26.6 2014-11-13 04:49:29 - Helena_temp_LastUpdate state updated to 2014-11-13T04:49:29 2014-11-13 04:49:30 - Temperature_GF_Helena state updated to 26.7 2014-11-13 04:49:30 - Helena_temp_LastUpdate state updated to 2014-11-13T04:49:30 2014-11-13 04:49:39 - Temperature_GF_Helena state updated to 26.6 2014-11-13 04:49:39 - Helena_temp_LastUpdate state updated to 2014-11-13T04:49:39 2014-11-13 04:50:07 - Temperature_GF_Living state updated to 24.3 2014-11-13 04:50:07 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:07 2014-11-13 04:50:08 - Temperature_GF_Living state updated to 24.2 2014-11-13 04:50:08 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:08 2014-11-13 04:50:12 - Temperature_GF_Living state updated to 24.3 2014-11-13 04:50:12 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:12 2014-11-13 04:50:14 - Temperature_GF_Living state updated to 24.2 2014-11-13 04:50:14 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:14 2014-11-13 04:50:15 - Temperature_GF_Helena state updated to 26.7 2014-11-13 04:50:15 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:15 2014-11-13 04:50:16 - Temperature_GF_Helena state updated to 26.6 2014-11-13 04:50:16 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:16 2014-11-13 04:50:16 - Temperature_GF_Living state updated to 24.3 2014-11-13 04:50:16 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:16 2014-11-13 04:50:16 - Temperature_GF_Living state updated to 24.2 2014-11-13 04:50:16 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:16 2014-11-13 04:50:18 - Temperature_GF_Living state updated to 24.3 2014-11-13 04:50:18 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:18 2014-11-13 04:50:19 - Temperature_GF_Helena state updated to 26.7 2014-11-13 04:50:19 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:19 2014-11-13 04:50:20 - Temperature_GF_Helena state updated to 26.6 2014-11-13 04:50:20 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:20 2014-11-13 04:50:20 - Temperature_GF_Living state updated to 24.2 2014-11-13 04:50:20 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:20 2014-11-13 04:50:20 - Temperature_GF_Helena state updated to 26.7 2014-11-13 04:50:20 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:20 2014-11-13 04:50:20 - Temperature_GF_Living state updated to 24.3 2014-11-13 04:50:20 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:20 2014-11-13 04:50:22 - Temperature_GF_Helena state updated to 26.6 2014-11-13 04:50:22 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:22 2014-11-13 04:50:23 - Temperature_GF_Living state updated to 24.2 2014-11-13 04:50:23 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:23 2014-11-13 04:50:24 - Temperature_GF_Living state updated to 24.3 2014-11-13 04:50:24 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:24 2014-11-13 04:50:26 - Temperature_GF_Helena state updated to 26.7 2014-11-13 04:50:26 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:26 2014-11-13 04:50:26 - Temperature_GF_Living state updated to 24.2 2014-11-13 04:50:26 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:26 2014-11-13 04:50:27 - Temperature_GF_Living state updated to 24.3 2014-11-13 04:50:27 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:27 2014-11-13 04:50:29 - Temperature_GF_Helena state updated to 26.6 2014-11-13 04:50:29 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:29As you can see i'm getting way more than 1 reading a second. I think this is happening because of the rounding up/down of the temperature readings.
@Hausner I send the temp changes only if change is > 1 deg C and light changes only > +/- 40 lux, have this in main loop:
void loop() { // Process incoming messages (like config from server) gw.process(); // Fetch temperatures from Dallas sensors sensors.requestTemperatures(); // Read temperatures and send them to controller for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) { // Fetch and round temperature to one decimal float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.; // Only send data if temperature has changed more then 1 degC and no error if (int(lastTemperature[i]) != int(temperature) && temperature != -127.00) { //added integer // Send in the new temperature gw.send(msg.setSensor(i).set(temperature,1)); lastTemperature[i]=temperature; } } // Read lux from TEMT6000 float lightLevel = analogRead(LIGHT_SENSOR_ANALOG_PIN) * 9.765625; // 1000/1024 if (int(lightLevel - lastLightLevel) > 40 || int(lastLightLevel - lightLevel) > 40) { gw.send(msg.setSensor(CHILD_ID_LIGHT).set(int(lightLevel),1)); lastLightLevel = lightLevel; } //gw.sleep(SLEEP_TIME); //no sleep for relays!!!! }Hope this helps, Pego
Yes, clear, if you do not want this you need to change the if to something like:
if (abs(lastTemperature[i] - temperature) >= 0.5 && temperature != -127.00) { -
if (abs(lastTemperature[i] - temperature) >= 0.5 && temperature != -127.00) {Thank you. I'm gonna try with this
if (abs(lastTemperature[i] - temperature) >= 0.2 && temperature != -127.00) {
