  3. Communication problem (maybe)
30 Posts 5 Posters 13.5k Views 3 Watching
  • N
    N
    niccodemi
    @Hausner yes, arduino and relay share ground. I use this node solely as relay (not repeater) and still have issues.
    • H
      H
      Hausner
      I have now converted the 3 temp sensors to mains power and removed the sleep function, but the problem is still the same :(
      I even let the temp nodes be repeaters! I looks like the GW can't SEND to the nodes, receiving is just fine. I'm getting "spammed" with temp readings atm.
      I have already tried with a CAP on the GW radio, but still out of luck :(
      Somehow this tells me, that mysensors is not for me :(
      • H
        H
        Hausner
        UPDATE:
        I was getting a bit frustrated with the relay node not working, so as a last resort, i decided to reset all the nodes. Starting with the temp nodes and the relay at the end.
        And I'll be damned! The system has now been running 3-4 hours with only a single hickup! (a relay failed on first request)
        So this tells me, that if you only have "1-way send" battery nodes in the mesh eg. temp sensors, then the "intelligent" mesh works fine, but as soon as you introduce main powered "recieve" nodes to the setup, it starts to fail (big time!). So pgo, you were right! I have just seen the same as you.
        At the temp sensors, I have removed the sleep command. The only problem now is that i'm getting flooded with temp readings! Anyone know of a simple solution to only have reading every 1 min without killing the radio?
        • daulagariD
          daulagariD
          daulagari
          Good observation but what is the difference between the "1-way send" battery nodes and the main powered "receive" nodes? Is it that the main powered nodes do send more often messages and therefore the network gets flooded?
          I am not sure how this is related to "i decided to reset all the nodes. Starting with the temp nodes and the relay at the end."
          On:
          In there sketch there is:
          float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
          if (lastTemperature[i] != temperature && temperature != -127.00) {
            gw.send(msg.setSensor(i).set(temperature,1));
          Right?
          Is the temperature changing every minute??
          • H
            H
            Hausner
            @daulagari
            By 1-way node I mean a reporting node. It only reports a temperature, nothing else. So therefore 1 way traffic TO the GW/controller.
            A relay node on the other hand has to receive also, else you can't flip on/off the relays.
            This is roughly 1 minute worth of controller log:
             2014-11-13 04:49:27 - Helena_temp_LastUpdate state updated to 2014-11-13T04:49:27
             2014-11-13 04:49:28 - Temperature_GF_Helena state updated to 26.7
             2014-11-13 04:49:28 - Helena_temp_LastUpdate state updated to 2014-11-13T04:49:28
             2014-11-13 04:49:29 - Temperature_GF_Helena state updated to 26.6
             2014-11-13 04:49:29 - Helena_temp_LastUpdate state updated to 2014-11-13T04:49:29
             2014-11-13 04:49:30 - Temperature_GF_Helena state updated to 26.7
             2014-11-13 04:49:30 - Helena_temp_LastUpdate state updated to 2014-11-13T04:49:30
             2014-11-13 04:49:39 - Temperature_GF_Helena state updated to 26.6
             2014-11-13 04:49:39 - Helena_temp_LastUpdate state updated to 2014-11-13T04:49:39
             2014-11-13 04:50:07 - Temperature_GF_Living state updated to 24.3
             2014-11-13 04:50:07 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:07
             2014-11-13 04:50:08 - Temperature_GF_Living state updated to 24.2
             2014-11-13 04:50:08 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:08
             2014-11-13 04:50:12 - Temperature_GF_Living state updated to 24.3
             2014-11-13 04:50:12 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:12
             2014-11-13 04:50:14 - Temperature_GF_Living state updated to 24.2
             2014-11-13 04:50:14 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:14
             2014-11-13 04:50:15 - Temperature_GF_Helena state updated to 26.7
             2014-11-13 04:50:15 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:15
             2014-11-13 04:50:16 - Temperature_GF_Helena state updated to 26.6
             2014-11-13 04:50:16 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:16
             2014-11-13 04:50:16 - Temperature_GF_Living state updated to 24.3
             2014-11-13 04:50:16 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:16
             2014-11-13 04:50:16 - Temperature_GF_Living state updated to 24.2
             2014-11-13 04:50:18 - Temperature_GF_Living state updated to 24.3
             2014-11-13 04:50:18 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:18
             2014-11-13 04:50:19 - Temperature_GF_Helena state updated to 26.7
             2014-11-13 04:50:19 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:19
             2014-11-13 04:50:20 - Temperature_GF_Helena state updated to 26.6
             2014-11-13 04:50:20 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:20
             2014-11-13 04:50:20 - Temperature_GF_Living state updated to 24.2
             2014-11-13 04:50:20 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:20
             2014-11-13 04:50:20 - Temperature_GF_Helena state updated to 26.7
             2014-11-13 04:50:20 - Temperature_GF_Living state updated to 24.3
             2014-11-13 04:50:22 - Temperature_GF_Helena state updated to 26.6
             2014-11-13 04:50:22 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:22
             2014-11-13 04:50:23 - Temperature_GF_Living state updated to 24.2
             2014-11-13 04:50:23 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:23
             2014-11-13 04:50:24 - Temperature_GF_Living state updated to 24.3
             2014-11-13 04:50:24 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:24
             2014-11-13 04:50:26 - Temperature_GF_Helena state updated to 26.7
             2014-11-13 04:50:26 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:26
             2014-11-13 04:50:26 - Temperature_GF_Living state updated to 24.2
             2014-11-13 04:50:26 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:26
             2014-11-13 04:50:27 - Temperature_GF_Living state updated to 24.3
             2014-11-13 04:50:27 - Living_temp_LastUpdate state updated to 2014-11-13T04:50:27
             2014-11-13 04:50:29 - Temperature_GF_Helena state updated to 26.6
             2014-11-13 04:50:29 - Helena_temp_LastUpdate state updated to 2014-11-13T04:50:29
            As you can see i'm getting way more than 1 reading a second. I think this is happening because of the rounding up/down of the temperature readings.
            pgoP 1 Reply Last reply
              wrote on last edited by hek
              Please post your sketch code. And to which pins you have connected sensors.
              • H
                H
                Hausner
                wrote on last edited by Hausner
                Temperatur sensor
                 // Example sketch showing how to send in OneWire temperature readings
                 #include <OneWire.h>
                 int numSensors=0;
                 boolean receivedConfig = false;
                 boolean metric = true;
                 MyMessage msg(0,V_TEMP);
                 //int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
                 //int oldBatteryPcnt = 0;
                   // Startup OneWire
                   sensors.begin();
                   // Startup and initialize MySensors library. Set callback for incoming messages.
                   gw.begin();
                   gw.sendSketchInfo("Temperature Sensor", "1.0");
                      gw.present(i, S_TEMP);
                   //analogReference(INTERNAL);
                   // Process incoming messages (like config from server)
                   float temperature = static_cast<float>(static_cast<int>  ((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                // get the battery Voltage
                //int sensorValue = analogRead(BATTERY_SENSE_PIN);
                //Serial.println(sensorValue);
                //float batteryV = sensorValue * 0.004106;
                //int batteryPcnt = sensorValue / 10;
                 //Serial.print("Battery Voltage: ");
                   //Serial.print(batteryV);
                   //Serial.println(" V");
                   //Serial.print("Battery percent: ");
                   //Serial.print(batteryPcnt);
                   //Serial.println(" %");
                   //if (oldBatteryPcnt != batteryPcnt) {
                   // Power up radio after sleep
                   //gw.sendBatteryLevel(batteryPcnt);
                   //oldBatteryPcnt = batteryPcnt;
                   //gw.sleep(SLEEP_TIME);
                The temp sensor has been build according to this: http://mysensors.org/build/temp
                1 small exception though. I have used 5v->3.3v aparters for the radios, but that shouldn't matter.
                10Pcs-lot-Socket-Adapter-Plate-Board-For-8Pin-NRF24L01-Wireless-Transceive-Module-51-Free-Shipping.jpg
                hekH 1 Reply Last reply
                • H Hausner
                  Temperatur sensor
                   int numSensors=0;
                     // Startup OneWire
                     sensors.begin();
                     gw.begin();
                  Why did you comment away this line?
                    H
                    H
                    Hausner
                    @hek
                    Because it looks like that the sleep function is messing with the repeater function. With sleep enabled, almost all messages to the relay actuator node gets lost.
                      #22
                      Hmm.. shouldn't affect transmissions. When you removed this line you will get several hundreds of temp readings per second. It is a very big chance a few of them differs which means they will send it to gateway.
                      You could try adding:
                      gw.powerUp();
                      delay(10)
                      Just before gw.send() to add a small some additional delay after radio powers up.
                      If you want to keep node awake another option is to use millis() keep track of send frequency. See here:
                      https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/TimeAwareSensor/TimeAwareSensor.ino#L47
                        gw.powerUp();
                        delay(10)
                        H
                        H
                        Hausner
                        @hek said:
                        delay(10)
                        I assume that is milliseconds, but does that mean that the radio will be powered on during that delay, and will the node repeat incoming messages during that?
                        If so, I think a much bigger delay would be better, like 30000 or even more.
                          This node isn't configured to be a repeater. So no, it won't.
                          • H
                            H
                            Hausner
                            #25
                            It isn't??
                            hmm... now i'm puzzled!
                            Cause this is 2 temp nodes
                            0;0;3;0;9;read: 24-23-0 s=0,c=1,t=0,pt=7,l=5:23.8
                            My relay actuator is 22
                            • N
                              N
                              niccodemi
                              @Hausner do you have any issues with relay node if you are NOT using it also as repeater?
                              • H Hausner
                                @hek said:
                                delay(10)
                                Yes, thats is actually a third option like you say. Just add a delay(30000) at the end of loop(). (If this node just acts a as a temp sensor and nothing else).
                                • H Hausner
                                  @daulagari
                                  pgoP
                                  pgoP
                                  pgo
                                  @Hausner I send the temp changes only if change is > 1 deg C and light changes only > +/- 40 lux, have this in main loop:
                                      // Only send data if temperature has changed more then 1 degC and no error
                                      if (int(lastTemperature[i]) != int(temperature) && temperature != -127.00) { //added integer
                                    // Read lux from TEMT6000
                                    float lightLevel = analogRead(LIGHT_SENSOR_ANALOG_PIN) * 9.765625;  // 1000/1024
                                    if (int(lightLevel - lastLightLevel) > 40 || int(lastLightLevel - lightLevel) > 40) {
                                        gw.send(msg.setSensor(CHILD_ID_LIGHT).set(int(lightLevel),1));
                                        lastLightLevel = lightLevel;
                                    //gw.sleep(SLEEP_TIME); //no sleep for relays!!!!
                                  Hope this helps, Pego
                                  • daulagariD
                                    daulagariD
                                    daulagari
                                    Yes, clear, if you do not want this you need to change the if to something like:
                                    if (abs(lastTemperature[i] - temperature) >= 0.5 && temperature != -127.00) {
                                    • daulagariD daulagari
                                      H
                                      H
                                      Hausner
                                      @daulagari
                                      Thank you. I'm gonna try with this
                                      if (abs(lastTemperature[i] - temperature) >= 0.2 && temperature != -127.00) {
