  3. Max6675 Thermocouple project
2 Posts 1 Posters 2.8k Views 1 Watching
    Mr_sensor
    wrote on last edited by Mr_sensor
    Hi, just started to explore the MySensors possibilities. The first project I'm building is a High temperature MAX6675 Thermocouple which send data to the MQTT broker.
    So I ordered some parts and started building the gateway with an arduino uno and Ethernet shield. Than connected the Max6675 and gave it a go!
    Although the set-up seems to be quit simple I can not get any temperature read from the sensor?
    If I connect it like some of the samples I found I end up with this:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGA--,VER=2.1.1
    IP: 192.168.0.87
    0;255;3;0;9;MCO:BGN:STP
    MAX6675 test
    0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
    IP: 192.168.0.87
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/255/0/0/17
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/255/3/0/11
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/255/3/0/12
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/10/0/0/6
    Deg C = nan	 Deg F = nan
    I used this example for the wiring: link to max6675-temp-module-wiring
    Also had a look at the post about the max6675 here on the forum. After trying several combinations I run out of ideas. So maybe one of you can point me in the right direction to get this finally working :)
    This is the sketch I ended up after changing it several times.
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    //#define MY_RADIO_NRF24
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    #define MY_MQTT_USER ""
    #define MY_MQTT_PASSWORD ""
    #define MY_IP_ADDRESS 192,168,0,87
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,1
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 36
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <Ethernet.h>
    // Sample Arduino MAX6675 Arduino Sketch
    #include "max6675.h"
    #define MY_NODE_ID 10
    #define CHILD_ID_TEMP 10
    #define TEMP_SENSOR_DIGITAL_PIN 8
    int thermoSO = 8;
    int thermoCS = 9;
    int thermoSCLK = 10;
    MAX6675 thermo(thermoSCLK, thermoCS, thermoSO);
    int vccPin = 3;
    int gndPin = 2;
    MyMessage msg(CHILD_ID_TEMP, S_TEMP);
    void presentation()  {
      sendSketchInfo("Temp Sensor", "0.1");
      Serial.begin(115200);
    // use Arduino pins
      pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
      pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
      Serial.println("MAX6675 test");
      // give the MAX a little time to settle
      delay(500);
      // basic readout test
       Serial.print("Deg C = ");
       Serial.print(thermo.readCelsius());
       Serial.print("\t Deg F = ");
       Serial.println(thermo.readFahrenheit());
       delay(500);
      Mr_sensor
      Any ideas on this any one? How to troubleshoot this? Would be nice to get this working. Thanks
      W.
