  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
  • NeverDieN NeverDie
    @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
    @NeverDie Thanks for heads-up. I'll keep it in mind
    I found an interesting cap -
    https://www.digikey.co.uk/product-detail/en/vishay-bc-components/MAL219691204E3/4705PHBK-ND/5015889
    Its voltage is very close to the solar panel so I think it may be connected directly via diode (0.7v drop = 6 - 0.7 = 5.3V vs 5.6V max rating)
    I've tried that cap already, and I wouldn't recommend it. It has a fairly high ESR.
    alexsh1A
    alexsh1A
    alexsh1
    @NeverDie Given that you have been tinkering with it for a while, what caps can you recommend? With what ESR?
    This cap has got 2.4 Ohm @ 1kHz - I think it is low?!
    NeverDieN 1 Reply Last reply
    • alexsh1A alexsh1
      NeverDieN
      NeverDieN
      Perky explains it better than I can: https://lowpowerlab.com/forum/projects/a-solar-supercap-powered-moteino/msg18120/#msg18120
      • C ceech
        @alexsh1 @NeverDie You can substitute the MAX8887 with MIC5365.
        This whole thing got me so intrigued that I'm going to make a board myself. With charger, super capacitors and DC-DC converter. I'll use MIC5365 and for DC-DC conversion TPS610986. It has loads of options. And the whole thing will cost less than 10 bucks. I've made a schematic
        NeverDieN
        NeverDieN
        @ceech said in How best to find the "best" small solar panel of a particular size?:
        TPS610986
        1.5 mm x 1.5 mm WSON Package
        Not sure how easy that will be to solder?
        alexsh1A 1 Reply Last reply
          TPS610986
          alexsh1A
          alexsh1A
          alexsh1
          @NeverDie You need to get SMD rework station or oven.
          This is extremely difficult to get done by even an iron with a fine tip.
          C 1 Reply Last reply
          • alexsh1A alexsh1
            C
            C
            ceech
            @alexsh1 @NeverDie Yes, they will be soldered in the oven.
            • C ceech
              NeverDieN
              NeverDieN
              @ceech
              Well, I may end up buying it from ceech then. Even properly aligning it onto the solder pads becomes difficult. I really struggled with the BQ25504. Not saying it can't be done, but just that it requires a lot more skill.
                @ceech
                alexsh1A
                alexsh1A
                alexsh1
                @NeverDie and a strong magnifying glass :-)
                • C
                  C
                  ceech
                  Those are the boards BTW
                  • C ceech
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @ceech it is very small. Excellent. Let us know when it is ready
                    • C
                      C
                      ceech
                      And if it is too tall, still, only two capacitors can be installed in horizontal position, or even just one.
                      • C ceech
                        alexsh1A
                        alexsh1A
                        alexsh1
                        #151
                        @ceech How about a flat supercap like this:
                        https://www.digikey.co.uk/product-detail/en/vishay-bc-components/MAL219691252E3/4699PHBK-ND/5015883
                        There is no need to have two in my view unless you want to raise voltage. One flat to make the board compact may be enough.
                        • C
                          C
                          ceech
                          Flat ones are nice. Nice package. High internal resistance, therefore low current. The double cell 15F flat capacitor can only supply 70mA.
                          • NeverDieN
                            NeverDieN
                            This is great. :+1: Maybe more people will start playing with this stuff if they can buy inexpensive pre-made boards from ceech. The more, the merrier. :)
                            • C ceech
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @ceech said iThe double cell 15F flat capacitor can only supply 70mA.
                              It should be enough if not using nrf24l01+ pa lna or rfm69HW. In this case perhaps, it would be better to have 150mA at least to cover those transmitters?
                              I like the size - It is really flat.
                              • alexsh1A alexsh1
                                NeverDieN
                                NeverDieN
                                If you start to get choosy, that's when it's time to start making your own boards. It's easier than you might think. Otherwise, you just have to accept that the off-the-shelf stuff will never be exactly what you want.
                                It's really too bad there isn't more of a universal PCB format that's easily edited, so you can simply start with a board that's close to what you want and just customize it a bit (the way one might with, say, software). For instance, even just changing LDO's--unless the new LDO has exactly the same land pattern--can necessitate redoing the board. No problem if you're the original designer, but it's a PITA if you aren't.
                                • NeverDieN
                                  NeverDieN
                                  #156
                                  I received the Chinese supercaps today. My "el cheapo" component tester is, I guess, too cheap, because it can't identify them:
                                  So, if anyone has suggestions for a good capacitor tester, let me know.
                                  However, I did plug the first one into my solar node after charging it ,and, so far it's not holding it's charge very well at all. I'll try the green one next.
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @NeverDie I just watched this video:
                                    https://youtu.be/EKRZEc-4SBo
                                    Is this what you have been looking?
                                    • alexsh1A alexsh1
                                      NeverDieN
                                      NeverDieN
                                      #158
                                      @alexsh1
                                      I like Julien's videos, butI'd find something that's faster and more automated to be preferable, as well as something that can measure ESR too.
                                      • NeverDieN
                                        NeverDieN
                                        #159
                                        Well, so far the green supercap isn't holding its charge any better. I'll leave it in-circuit for two or three days, though, and see if that improves. It's encouraging that the rate of voltage decrease is decreasing. Some supercaps apparently improve their ability to retain charge if they are forced to hold a charge long enough, though I have no idea why that is. For instance, some capacitor leakage test protocols call for holding a capacitor at its rated voltage for 72 hours before running the leakage test.
                                        alexsh1A NeverDieN 2 Replies Last reply
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #160
                                          @NeverDie you are right - Nick Gammon states exactly the same that overtime leakage "improves". A new cap has to be broken in before leakage is measured.
                                          ESR measurement - I have no idea if it is possible to measure it and how. I think right now we are going down deep into the physics in order to do that
