  3. Heatpump Sketch Help
7 Posts 3 Posters 2.8k Views 2 Watching
  • SGiS Offline
    SGiS Offline
    SGi
    I need some help converting the Heatpump sketch example to 2.0 and also isolating to just the Mitsubishi model as i have no need or memory for all the models.... i guess my biggest issue is where in the sketch is the model actually defined?
    Link to sketch that i need converting below:
    https://www.mysensors.org/build/heatpump
    Cheers
    Scott
    S 1 Reply Last reply
    • SGiS SGi
      Cheers
      Scott
      @SGi - check this out: https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
      In the sketch it looks like you just define which you want to use:
      Just remove/erase the ones you dont want.
      #include <FujitsuHeatpumpIR.h>
      #include <PanasonicCKPHeatpumpIR.h>
      #include <PanasonicHeatpumpIR.h>
      #include <CarrierHeatpumpIR.h>
      #include <MideaHeatpumpIR.h>
      #include <MitsubishiHeatpumpIR.h>
      #include <SamsungHeatpumpIR.h>
      #include <SharpHeatpumpIR.h>
      #include <DaikinHeatpumpIR.h>```
      • SGiS Offline
        SGiS Offline
        SGi
        Ok, i have managed to get a heatpump IR sketch working somewhat. I can see the node in 'hardware' and even the children but they do not appear in 'devices'... is there something fundamentally wrong in my sketch?
        I am using Domoticz and a RPI controller.
        0_1485842430447_upload-0a99d4c1-0ede-4128-a926-481cb0270315
        #define POWER_ID 0
        #define MODE_ID 1
        #define FAN_ID 2
        #define TEMP_ID 3
        #define VDIR_ID 4
        #define HDIR_ID 5
        MyMessage powerMsg(POWER_ID, V_STATUS);
        MyMessage modeMsg(MODE_ID, V_HVAC_FLOW_STATE);
        MyMessage fanMsg(FAN_ID, V_PERCENTAGE);
        MyMessage tempMsg(TEMP_ID, V_TEMP);
        MyMessage vdirMsg(VDIR_ID, V_VAR1);
        MyMessage hdirMsg(HDIR_ID, V_VAR2);
        IRSenderPWM irSender(3);       // IR led on Arduino digital pin 3, using Arduino PWM
        HeatpumpIR *heatpumpIR = new MitsubishiFDHeatpumpIR();
        //Some global variables to hold the states
        int POWER_STATE;
        int TEMP_STATE;
        int FAN_STATE;
        int MODE_STATE;
          // begin(incomingMessage, AUTO, false);
          sendSketchInfo("Heatpump", "1.0");
          present(POWER_ID, S_BINARY);
          present(MODE_ID, S_HVAC);
          present(FAN_ID, S_HVAC);
          present(TEMP_ID, S_HVAC);
          present(VDIR_ID, S_CUSTOM);
          present(HDIR_ID, S_CUSTOM);
          // Load our values on start
          POWER_STATE = loadState(POWER_ID);
          TEMP_STATE = loadState(TEMP_ID);
          FAN_STATE = loadState(FAN_ID);
          MODE_STATE = loadState(MODE_ID);
          sendHeatpumpCommand();
        void handlePowerMessage(bool newState) {
          if (newState) {
            POWER_STATE = POWER_ON;
          else {
            POWER_STATE = POWER_OFF;
          saveState(POWER_ID, newState);
        void handleModeMessge(int newMode) {
          switch(newMode) {
            case 0:
              MODE_STATE = MODE_HEAT; break;
            case 1:
              MODE_STATE = MODE_COOL; break;
            case 2:
              MODE_STATE = MODE_AUTO; break;
            case 3:
              MODE_STATE = MODE_FAN; break;
             case 4:
              MODE_STATE = MODE_DRY; break;
          MODE_STATE = newMode;
          saveState(MODE_ID, newMode);
        void handleFanMessage(int newFan) {
          if (newFan > 5) newFan=5;
          switch(newFan) {
            case 0:
              FAN_STATE = FAN_AUTO; break;
            case 1:
              FAN_STATE = FAN_1; break;
            case 2:
              FAN_STATE = FAN_2; break;
            case 3:
              FAN_STATE = FAN_3; break;
            case 4:
              FAN_STATE = FAN_4; break;
            case 5:
              FAN_STATE = FAN_5; break;
            default:
          FAN_STATE = newFan;
          saveState(FAN_ID, newFan);
        void handleTempMessage(int newTemp) {
          TEMP_STATE = newTemp;
          saveState(TEMP_ID, newTemp);
        void sendHeatpumpCommand() {
          Serial.println("Power = " + (String)POWER_STATE);
          Serial.println("Mode = " + (String)MODE_STATE);
          Serial.println("Fan = " + (String)FAN_STATE);
          Serial.println("Temp = " + (String)TEMP_STATE);
          heatpumpIR->send(irSender, POWER_STATE, MODE_STATE, FAN_STATE, TEMP_STATE, VDIR_AUTO, HDIR_AUTO);
          if (message.isAck()) {
           Serial.print(message.sensor);
           switch(message.sensor) {
            case POWER_ID: {
              bool newState = message.getBool();
              handlePowerMessage(newState);
              break;
            case MODE_ID: {
              int newMode = message.getInt();
              handleModeMessge(newMode);
              break;
            case FAN_ID: {
              int newFan = message.getInt();
              handleFanMessage(newFan);
              break;
            case TEMP_ID: {
              int newTemp = message.getInt();
              handleTempMessage(newTemp);
              break;
        • SGiS SGi
          #define POWER_ID 0
          #define MODE_ID 1
          #define FAN_ID 2
          #define TEMP_ID 3
          #define VDIR_ID 4
          #define HDIR_ID 5
          int POWER_STATE;
          int TEMP_STATE;
          int FAN_STATE;
          int MODE_STATE;
            if (newState) {
            else {
            switch(newMode) {
              case 0:
              case 1:
              case 2:
              case 3:
               case 4:
            switch(newFan) {
              case 0:
              case 1:
              case 2:
              case 3:
              case 4:
              case 5:
              default:
            FAN_STATE = newFan;
              case POWER_ID: {
                break;
              case MODE_ID: {
                break;
              case FAN_ID: {
                break;
              case TEMP_ID: {
                break;
          @SGi - you will not see any device before first value is sent. Make sure you send status or something on startup.
          SGiS 1 Reply Last reply
          • S sundberg84
            SGiS Offline
            SGiS Offline
            SGi
            @sundberg84 Ok thanks, i thought the following part of the code in Presentation() was doing that?
              sendHeatpumpCommand();```
            • SGiS SGi
              @SGi - not sure, but I think that is load the saved state from EEPROM.
              You should have some sort of send(value);
              • M Offline
                M Offline
                moskovskiy82
                I can see the topic is quite old but myabe a complete sensor 2.1 example?
                I can see that this code for openhab is quite popular. But i'm facing an issue constructing the proper MQTT topic
                As on my set up all my control messages look like
                      topic: "mys-in/41/2/1/0/2"
                      payload: "0"
                So wonder which ones to use with this sketch?
