  3. Can't find the right documentation... Reading receive messages
4 Posts 2 Posters 1.2k Views 2 Watching
  • A
    A
    Alain Mizreh
    First of all, I would like to say thank you for MySensors.
    It seems to be doing all the things I expected for a longtime, and I have been trying to do it all by myself before...
    So, I am new to MySensors, not to Arduino / ESP8266, etc...
    I have been able to make a Gateway & a Sensor talk together.
    I have been able to connect to my io.adafruit.com MQTT server, as well...
    I am using the "void receive(MyMessage &msg)" routine to read incoming messages from my Sensor (a DHT22 based one).
    But I cannot figure out how to get the data from it !
    The variable I use doesn't seem to be a String, and I am pretty sure I coud get something like : MyNode = MyMessage.NODE_ID... but I can't find the explanation of how to read incoming messages...
    Hint : I am a hardware engineer from 1985, and I developed my programming skills very late...
    Here is the bit of code I use :
      String MyMessage;
      int MsgLen = MyMessage.length();
      String Humid = MyMessage.substring(12, MsgLen);
      Serial.println(MsgLen);
      Serial.println (Humid);
    The result is that MsgLen (Length of MyMessage) = 0. So to me this is not a String...
    Thanks for your help,
    Regards,
    Alain
    • A Alain Mizreh
        String MyMessage;
      Regards,
      Alain
      @Alain-Mizreh welcome to the MySensors community!
      msg is an object, which contains lots of stuff. msg.getString(char* buffer) is probably what you are looking for.
      Information about the MyMessage object is available at https://www.mysensors.org/download/sensor_api_20#message-manipulation. You might need to scroll inside the "code" box though, the get functions might not fit on the screen.
      A 1 Reply Last reply
        A
        A
        Alain Mizreh
        @mfalkvidd , Thanks for your reply !
        Would there be some code example to illustrate ?
        I am bad at manipulating variables, and I don't get it...
        The link you gave me is very detailed, however, I don't understand what I should do with all the variables described... Create one local variable for every field ?
        Thanks a lot,
        Regards,
        Alain
        • A Alain Mizreh
          Thanks a lot,
          Regards,
          Alain
          @Alain-Mizreh only create a variable for the data you are using. If you use a string, get a string.
