  3. ESP8266 Gateway runs DHCP, not static
11 Posts 5 Posters 4.0k Views 5 Watching
  • S
    Straydog
    Running an ESP8266(NodeMCU 1.0) gateway with MY_IP_ADDRESS uncommented and MY_RADIO_NRF24 commented out, without problem. I get the desired I.P. address.
    However, when I uncomment MY_RADIO_NRF24 it starts running DHCP.
    Any ideas?
    • S Straydog
      Any ideas?
      @Straydog which type of gateway are you using? mqtt? If that's the case it looks to me like the change in https://github.com/mysensors/MySensors/commit/dda9cefd93fd4a899ea1348e09e4fe2ce9b61ad4 also needs to be done at https://github.com/mysensors/MySensors/blob/dd9dff77ed1948db2b348bbdb82d0d3daa9e8e3a/core/MyGatewayTransportMQTTClient.cpp#L140
        @tekka was quick to submit a pull request for that fix, https://github.com/mysensors/MySensors/pull/772
        • S
          Straydog
          You're probable right. Running GatewayEsp8266 example but I seem to recall having had the same problem with the MQTTGateway. Will test and get back with you...Thanks
          And thanks for the quick response.
          • S
            Straydog
            Problem persists, running version "MySensors Library v2.2.0-beta" downloaded today.
              martim
              I have the same problem. I am not able to fix it. It seems that the order of Config and Begin are correct?!? I am also not sure why this changed if are remove the define for the radio. I am using the ethernet gateway.
              electrikE 1 Reply Last reply
              • M martim
                electrikE
                electrikE
                electrik
                @martim Did you read this thread?
                https://forum.mysensors.org/topic/9431/solved-esp8266-mysensors-2-2-0-problem-with-static-ip-configuration
                M 1 Reply Last reply
                • electrikE electrik
                  martim
                  @electrik Hi, Yes. I think so. I have create an empty sketch and upload this to the board and after that my original code. But without any improvement.
                  • M martim
                    @martim uploading an empty sketch does not clear the eeprom.
                    In the MySensors examples folder/menu, there is a ClearEeprom sketch. Upload that, run it (check serial monitor) and then upload your original sketch again.
                      martim
                      @mfalkvidd Thanks. I have cleared the eeprom with this and after that install the sketch again. Still DHCP.
                      This is the sketch:
                       * Version 1.0 - Henrik EKblad
                       * Contribution by Ivo Pullens (ESP8266 support)
                       * The EthernetGateway sends data received from sensors to the WiFi link.
                       * VERA CONFIGURATION:
                       * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
                       * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
                       * LED purposes:
                       * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
                       * nRF24L01+  ESP8266
                       * VCC        VCC
                       * CE         GPIO4
                       * CSN/CS     GPIO15
                       * SCK        GPIO14
                       * MISO       GPIO12
                       * MOSI       GPIO13
                       * GND        GND
                        * Inclusion mode button:
                      #define MY_BAUD_RATE 115200
                      //#define MY_RADIO_RFM95
                      #define MY_GATEWAY_ESP8266
                      #define MY_ESP8266_SSID "SID"
                      #define MY_ESP8266_PASSWORD "*********"
                      // Enable UDP communication
                      //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
                      #define MY_ESP8266_HOSTNAME "marcel-gateway"
                      #define MY_IP_ADDRESS 192,168,10,9
                      #define MY_IP_GATEWAY_ADDRESS 192,168,10,1
                      #define MY_PORT 5003
                      // Enable inclusion mode
                      // Set blinking period
                      //#define MY_DEFAULT_LED_BLINK_PERIOD 300
                      // Flash leds on rx/tx/err
                      // Led pins used if blinking feature is enabled above
                      #if defined(MY_USE_UDP)
                      #include <WiFiUdp.h>
                      #include <ESP8266WiFi.h>
                      This is the logging:
                      connected with CycloneIT, channel 5
                      dhcp client start...
                      ip:192.168.10.228,mask:255.255.255.0,gw:192.168.10.1
                      I am using MySensors 2.2.0 and Arduino 1.8.5 and download the latest boards from:
                      http://arduino.esp8266.com/stable/package_esp8266com_index.json
                      I am not sure what I am missing, maybe it is a simple thing in the sketch, if I comment out the #define MY_RADIO_NRF24 then it works???
                        As temporary workaround, you can reserve the ip you want assigned on the dhcp server configuration (I'd guess it is your wifi router)
