  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • JonnyDev13J JonnyDev13
    Can I suggest updated sourceforge to say that the code has been moved to github, and leaving little else there? That way it's easier to update everything in the same place. I was browsing on sourceforge for a while and wondering "Why isn't this on github instead?" It wasn't even until I came back and started skimming this thread that I realized it was moved to github.
    U
    U
    user2684
    @JonnyDev13 said in NodeManager: plugin for a rapid development of battery-powered sensors:
    Good advice thanks! I've changed the website link on Sourceforge as well as added a note in the description and redirected the "Support" link.
    JonnyDev13J 1 Reply Last reply
    • U user2684
      @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
      I have a problem, my node is in sleep for 60 minutes and hourly reads the battery voltage but when you wake the pir is high and in addition to the high volts sends me even then the controller sends me a pir pir movement false; how can I avoid it?
      So you are saying when the node wakes up not from the pir interrupt at the end of the sleeping cycle to report battery level, is it also reporting a V_TRIPPED with payload 0? Thanks
      mar.conteM
      mar.conteM
      mar.conte
      @user2684
      Yes of course but payload =1 pir movimento detect
      M.C.
        What's the problem if it reports no motion?
        mar.conteM 1 Reply Last reply
        • U user2684
          JonnyDev13J
          JonnyDev13J
          JonnyDev13
          @user2684 Looks great!
            mar.conteM
            mar.conteM
            mar.conte
            @gohan
            The problem is that motion report whenever sleep goes to wake to send me the battery status every 60 minutes ,then every 60 minutes sends me battery status and motion pir
            M.C.
              Ok, but is it causing any problem?
                mar.conteM
                mar.conteM
                mar.conte
                @gohan
                Definitely, if I put a pir sensor to monitor a security access I will never know if I had an intrusion if I have a false alarm
                M.C.
                  if it reports "no motion" it is not a false alarm. The important thing is it must report when there is "motion"
                  U 1 Reply Last reply
                    U
                    U
                    user2684
                    @gohan said in NodeManager: plugin for a rapid development of battery-powered sensors:
                    Agree with what @gohan says. But I'll look into this anyway @mar-conte, reporting no motion when waking up should not happen even if it is a minor issue (https://github.com/mysensors/NodeManager/issues/71). What should not happen at all is reporting motion (payload 1) but as far as I've understood this is the case.
                    • U user2684
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @user2684
                      So with version 1.5 do I solve my problem too?
                      M.C.
                      • mar.conteM
                        mar.conteM
                        mar.conte
                        wrote on last edited by mar.conte
                        #111
                        I noticed that the battery report if set to one hour does not happen every hour ...
                        M.C.
                        • mar.conteM mar.conte
                          @user2684
                          U
                          U
                          user2684
                          I'll look into it by then. Feel free to follow the github issue to see how it will evolve. Thanks!
                            U
                            U
                            user2684
                            More details please :-) Does not happen at all, it is not regular, happens every other hour, etc. what is the case?
                            Thanks!
                            • U user2684
                              Thanks!
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @user2684
                              It happens even if i put 6 hours or every 3 hours so in the specified hours it is not regular the report sometimes jumps some report
                              M.C.
                                @user2684
                                U
                                U
                                user2684
                                Ok, I'd probably need both MySensors and NodeManagers's logs to troubleshoot this, just to ensure there is no failure in sending out the messages as I've seen in the other logs you have previously shared.
                                Thanks!
                                • U user2684
                                  Thanks!
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  @user2684
                                  Ok Tanks
                                  M.C.
                                  • mar.conteM
                                    mar.conteM
                                    mar.conte
                                    Then solved the problem of the accuracy of the battery report: basically I did not realize that the sleep wait time started from the last pir movement then if i put an hour of sleep and during this active time the pir time resumes; The communication problems I solved them by letting antenna from rfm69 so every hour the battery report does not even send pir moviment
                                    ....Very strange my rfm69 modules communicate better without an antenna even at a distance of 10 meters with a wall
                                    M.C.
                                      There is a risk of damaging the radio module if you don't use an antenna. Also a wrong tuned antenna will make transmitting more difficult.
                                        mar.conteM
                                        mar.conteM
                                        mar.conte
                                        @gohan
                                        Ok Tanks, but the 86 mm wire for 868 what is Ideal diameter and thread type for simple antenna no dipole e non ground ant?
                                        M.C.
                                          wrote on last edited by gohan
                                          #120
                                          Found in another forum
                                          433 1/4 wave = 164.7mm
                                          433 1/2 wave = 329.4mm
                                          433 full wave = 692.7mm
                                          868 1/4 wave = 82.2mm
                                          868 1/2 wave = 164.3mm
                                          868 full wave = 345.5mm
                                          915 1/4 wave = 77.9mm
                                          915 1/2 wave = 155.9mm
                                          915 full wave = 327.8mm
                                          Try shortening a little bit. What kind of wire are you using?
                                          mar.conteM 2 Replies Last reply
