  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • mar.conteM mar.conte
    @user2684
    Hello, I have a simple pir hcr501 that normally does not send output to pin 3 (so low) but when there is movement becomes HIGH, then my CPU goes to sleep for 60 minutes; the hardware is well configured because this setup I used it with the official mysensors sketches for pir motion; I do not understand why the domoticz controller is always the pir HIGH and does not go into sleep the MCU, thanks
    U
    U
    user2684
    @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
    Ok, so you don't need any customization in NodeManager since this is meeting the default behavior (LOW by default and triggering on HIGH), sorry for the wrong advice. Let's have a look at the sensor's logs then to see why the node is waking up continuously.
    Thanks!
    mar.conteM 1 Reply Last reply
    • U user2684
      Thanks!
      mar.conteM
      mar.conteM
      mar.conte
      @user2684
      @gohan
      node
      0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
      40 MCO:BGN:BFR
      REG I=1 P=3 P=6 T=0
      NodeManager v1.4
      INT1 M=255
      INT2 M=255
      59 TSM:INIT
      135 TSF:WUR:MS=0
      155 TSM:INIT:TSP OK
      176 TSM:INIT:STATID=100
      202 TSF:SID:OK,ID=100
      225 TSM:FPAR
      370 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2244 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      2301 TSF:MSG:FPAR OK,ID=0,D=1
      2447 TSM:FPAR:OK
      2463 TSM:ID
      2478 TSM:ID:OK
      2492 TSM:UPL
      2639 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
      3678 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      3737 TSF:MSG:PONG RECV,HP=1
      3768 TSM:UPL:OK
      3784 TSM:READY:ID=100,PAR=0,DIS=1
      3883 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      4003 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      4202 !TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
      4415 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=NACK:0
      6733 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=2,st=NACK:NodeManagerTemplate
      6928 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=OK:1.0
      RADIO OK
      PRES I=200, T=23
      7137 !TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
      PRES I=201, T=30
      7321 TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=OK:
      BATT V=3.25 P=93
      SEND D=0 I=201 C=0 T=38 S= I=0 F=3.25
      7469 !MCO:SND:NODE NOT REG
      7587 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:93
      PRES I=1 T=6
      7794 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
      READY
      7868 MCO:REG:REQ
      7933 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
      9019 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      9078 MCO:PIM:NODE REG=1
      9105 MCO:BGN:STP
      MY I=100 M=1
      9123 MCO:BGN:INIT OK,TSP=1
      THER I=1 V=354.00 T=40.05
       M=1
      SEND D=0 I=1 C=0 T=0 S= N=0 F=40.05
      9224 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.05
      SLEEP 3600s
      9316 MCO:SLP:MS=3600000,SMS=1,I1=255,M1=255,I2=255,M2=255
      9527 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:287
      9607 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      9666 !TSF:MSG:LEN,0!=8
      10108 MCO:SLP:TPD```
      Gateway
      0;255;3;0;9;TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;TSF:MSG:BC
      0;255;3;0;9;TSF:MSG:FPAR REQ,ID=100
      0;255;3;0;9;TSF:PNG:SEND,TO=0
      0;255;3;0;9;TSF:CKU:OK
      0;255;3;0;9;TSF:MSG:GWL OK
      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
      0;255;3;0;9;TSF:MSG:PINGED,ID=100,HP=1
      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/0/0/17
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=19,sg=0:NodeManagerTemplate
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/11
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=200,c=0,t=23,pt=0,l=0,sg=0:
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/200/0/0/23
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=0,pt=1,l=1,sg=0:85
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/0
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:36.72
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/1/1/0/0
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=22,pt=5,l=4,sg=0:286
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/22
      0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/0/3/0/18
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/22
      M.C.
      U 1 Reply Last reply
        @user2684
        @gohan
        node
        40 MCO:BGN:BFR
        REG I=1 P=3 P=6 T=0
        NodeManager v1.4
        INT1 M=255
        INT2 M=255
        59 TSM:INIT
        135 TSF:WUR:MS=0
        155 TSM:INIT:TSP OK
        225 TSM:FPAR
        2447 TSM:FPAR:OK
        2463 TSM:ID
        2478 TSM:ID:OK
        2492 TSM:UPL
        3768 TSM:UPL:OK
        RADIO OK
        PRES I=200, T=23
        PRES I=201, T=30
        BATT V=3.25 P=93
        PRES I=1 T=6
        READY
        7868 MCO:REG:REQ
        9105 MCO:BGN:STP
        MY I=100 M=1
         M=1
        SLEEP 3600s
        Gateway
        U
        U
        user2684
        @mar.conte there is something strange with this node. First of all the node is still presenting the temperature and not the motion sensor. Then I see a lot of failures during transmit but also while receiving (!TSF:MSG:LEN,0!=8). Are you sure you don't have something like two nodes with the same id?
        • U user2684
          mar.conteM
          mar.conteM
          mar.conte
          wrote on last edited by mar.conte
          #84
          @user2684
          hi, I noticed that the zero node has a child called S_Arduino_Repeater with an id equal to 255 child node, called 100 S_Arduino_Node, what do you recommend?
          smotion now appears I had mistakenly entered analog 0 on a wire that went to +Power
          M.C.
            @user2684
            U
            U
            user2684
            The node 0 is the gateway which presents itself as S_ARDUINO_REPEATER, the child id 255 is the broadcast address, the node id 100 is instead you node. This is all correct (with or without NodeManager). Glad to hear the motion sensor is now showing up. Is it still trigger continuously?
            • U user2684
              mar.conteM
              mar.conteM
              mar.conte
              @user2684
              Yes trig again!!!
              M.C.
                @user2684
                Yes trig again!!!
                U
                U
                user2684
                Yes trig again!!!
                Ok, if triggers continuously, please share the logs of the node now that has been fixed so we can have a look.
                Thanks!
                • U user2684
                  Yes trig again!!!
                  Thanks!
                  mar.conteM
                  mar.conteM
                  mar.conte
                  wrote on last edited by gohan
                  #88
                  @user2684
                  NODE OUTPUT
                  40 MCO:BGN:BFR
                  REG I=1 P=3 P=1 T=16
                  NodeManager v1.4
                  INT1 M=3
                  INT2 M=255
                  59 TSM:INIT
                  135 TSF:WUR:MS=0
                  153 TSM:INIT:TSP OK
                  200 TSF:SID:OK,ID=100
                  223 TSM:FPAR
                  368 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  641 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  698 TSF:MSG:FPAR OK,ID=0,D=1
                  2445 TSM:FPAR:OK
                  2461 TSM:ID
                  2476 TSM:ID:OK
                  2490 TSM:UPL
                  2512 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  2633 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  2693 TSF:MSG:PONG RECV,HP=1
                  2721 TSM:UPL:OK
                  2738 TSM:READY:ID=100,PAR=0,DIS=1
                  2785 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  2904 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  3018 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                  3229 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
                  5316 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=1,st=OK:NodeManagerTemplate
                  5541 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.0
                  RADIO OK
                  PRES I=200, T=23
                  5715 TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=1,st=OK:
                  PRES I=201, T=30
                  5922 !TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=NACK:
                  BATT V=3.21 P=86
                  SEND D=0 I=201 C=0 T=38 S= I=0 F=3.21
                  6072 !MCO:SND:NODE NOT REG
                  6164 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:86
                  PRES I=1 T=1
                  6371 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
                  READY
                  6445 MCO:REG:REQ
                  6531 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                  6619 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  6678 MCO:PIM:NODE REG=1
                  6705 MCO:BGN:STP
                  MY I=100 M=1
                  6723 MCO:BGN:INIT OK,TSP=1
                  SWITCH I=1 P=3 V=1
                  SEND D=0 I=1 C=0 T=16 S= N=1 F=0.00
                  6817 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                  SLEEP 3600s
                  6897 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                  7104 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:264
                  7684 MCO:SLP:TPD
                  7700 MCO:SLP:WUP=1
                  WAKE P=3, M=3
                  AWAKE
                  SWITCH I=1 P=3 V=1
                  SEND D=0 I=1 C=1 T=16 S= N=1 F=0.00
                  7786 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                  SLEEP 3600s
                  7876 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                  8087 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:1243
                  8667 MCO:SLP:TPD
                  8683 MCO:SLP:WUP=1
                  WAKE P=3, M=3
                  AWAKE
                  SWITCH I=1 P=3 V=1
                  8757 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                  SLEEP 3600s
                  8859 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                  8982 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2226
                  9562 MCO:SLP:TPD
                  9578 MCO:SLP:WUP=1
                  WAKE P=3, M=3
                  AWAKE
                  SWITCH I=1 P=3 V=1
                  9621 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                  SLEEP 3600s
                  9754 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                  9961 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:3121
                  10541 MCO:SLP:TPD
                  Tanks
                  M.C.
                    @user2684
                    NODE OUTPUT
                    40 MCO:BGN:BFR
                    NodeManager v1.4
                    INT1 M=3
                    INT2 M=255
                    59 TSM:INIT
                    135 TSF:WUR:MS=0
                    153 TSM:INIT:TSP OK
                    223 TSM:FPAR
                    2445 TSM:FPAR:OK
                    2461 TSM:ID
                    2476 TSM:ID:OK
                    2490 TSM:UPL
                    2721 TSM:UPL:OK
                    RADIO OK
                    PRES I=200, T=23
                    PRES I=201, T=30
                    BATT V=3.21 P=86
                    PRES I=1 T=1
                    READY
                    6445 MCO:REG:REQ
                    6705 MCO:BGN:STP
                    MY I=100 M=1
                    SWITCH I=1 P=3 V=1
                    SLEEP 3600s
                    7684 MCO:SLP:TPD
                    7700 MCO:SLP:WUP=1
                    WAKE P=3, M=3
                    AWAKE
                    SWITCH I=1 P=3 V=1
                    SLEEP 3600s
                    8667 MCO:SLP:TPD
                    8683 MCO:SLP:WUP=1
                    WAKE P=3, M=3
                    AWAKE
                    SWITCH I=1 P=3 V=1
                    SLEEP 3600s
                    9562 MCO:SLP:TPD
                    9578 MCO:SLP:WUP=1
                    WAKE P=3, M=3
                    AWAKE
                    SWITCH I=1 P=3 V=1
                    SLEEP 3600s
                    10541 MCO:SLP:TPD
                    Tanks
                    U
                    U
                    user2684
                    @mar.conte ok, this looks better, the node is presenting correctly and I see the sensor triggering continuously. You still have a lot of radio failures while sending but this is another story and it is not related to the issue but keep in mind you are losing a few messages.
                    Now, if I look at the digital read of the pin waking up the board (V=):
                    SWITCH I=1 P=3 V=1
                    This is HIGH so the board correctly wakes up. Since the signal apparently stays high, the board goes in and out of sleep so looks like an expected behavior. The are a couple of functions available to prevent this (setTriggerTime() and setDebounce()) but before giving direction I'd ask you to measure the voltage at pin 3 with a multimeter because it looks like the motion sensor goes HIGH and stay HIGH for a long time. If we know this timeframe, we can adjust the settings accordingly. Btw you should have the same behavior with the example sketch at https://www.mysensors.org/build/motion.
                    mar.conteM 2 Replies Last reply
                    • U user2684
                      SWITCH I=1 P=3 V=1
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @user2684
                      ok, I will check first the voltage of the pir and even the power of the MCU, it seems to me that the rfm69 module does not communicate with each other (node-gateway), it seems strange because with the sketch of links that you suggested it all works well ! thanks anyway I'll do my tests and let you know soon ...
                      M.C.
                      • mar.conteM
                        mar.conteM
                        mar.conte
                        #91
                        I wanted to know what are the connections to monitor the batteries of my sensor, do I connect the battery V+ to the analog pin A0?
                        M.C.
                          U
                          U
                          user2684
                          If you are connecting the arduino directly to the battery (e.g. no step-up-down), then you don't need any connection since NodeManager is able to sense and measure the input vcc (and according to my measures it is very accurate). In case instead you need to use the method here https://www.mysensors.org/build/battery, you need the following:
                          nodeManager.setBatteryInternalVcc(false);
                          nodeManager.setBatteryPin(A0);
                          You can even customize the default 0.003363075 voltage per bit with setBatteryVoltsPerBit()
                          • U user2684
                            mar.conteM
                            mar.conteM
                            mar.conte
                            @user2684
                            THEN MY NODE WILL BE CONNECTED TO A BATTERY 3.6 VOLT AA 2600 MAH, SO I DO NOT RIGHT CONNECTIONS? BUT I HAVE TO CHANGE OTHER PARAMETERS TO BEING 3.6?
                            TANKS
                            M.C.
                              @user2684
                              TANKS
                              U
                              U
                              user2684
                              TANKS
                              If directly connected to the battery you don't need any other connection. To set minimum and maximum voltage to have an accurate battery percentage level calculated you need to use e.g.:
                              nodeManager.setBatteryMin(2.7);
                              nodeManager.setBatteryMax(3.6);
                              So the percentage will be calculated between the two values.
                              • U user2684
                                TANKS
                                mar.conteM
                                mar.conteM
                                mar.conte
                                @user2684
                                Much easy INFINITE THANKS AND CONGRATULATIONS
                                M.C.
                                • U user2684
                                  SWITCH I=1 P=3 V=1
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  #96
                                  @user2684
                                  Solved
                                  I solved it by putting settriggertime (5000) setdebounce (50); also solved the supply problems because if power is ftdi with the sensor was always high, with batteries the pir is stable and works well
                                  thanks for the support
                                  This is my reprap printed house for my project
                                  M.C.
                                    @user2684
                                    Solved
                                    U
                                    U
                                    user2684
                                    @mar.conte great to hear it is working now! For anybody else interested in these parameters, setDebounce() will set a debounce interval, e.g. the value of the input is checked after the interval from the wakeup so to avoid false positives, while seTriggerTime() ignore any input after the pir has triggered to avoid the sensor to trigger continuously. Btw, very nice and clean packaging!
                                    T 1 Reply Last reply
                                    • mar.conteM
                                      mar.conteM
                                      mar.conte
                                      I have a problem, my node is in sleep for 60 minutes and hourly reads the battery voltage but when you wake the pir is high and in addition to the high volts sends me even then the controller sends me a pir pir movement false; how can I avoid it?
                                      M.C.
                                      • JonnyDev13J
                                        JonnyDev13J
                                        JonnyDev13
                                        Can I suggest updated sourceforge to say that the code has been moved to github, and leaving little else there? That way it's easier to update everything in the same place. I was browsing on sourceforge for a while and wondering "Why isn't this on github instead?" It wasn't even until I came back and started skimming this thread that I realized it was moved to github.
                                          U
                                          U
                                          user2684
                                          So you are saying when the node wakes up not from the pir interrupt at the end of the sleeping cycle to report battery level, is it also reporting a V_TRIPPED with payload 0? Thanks
