  3. MQTT/Ethernet Gateway using Leonardo(32u4), W5100, RFM69H, Hard SPI
6 Posts 3 Posters 3.3k Views 3 Watching
  • CarywinC
    CarywinC
    Carywin
    wrote on last edited by Carywin
    Hi Folks,
    I'm brand new at this MySensors thing, and I have struggled a lot trying to get a gateway going. I think I have mostly succeeded now though, so I thought I'd share how I got here and hopefully save others some trouble.
    I'm using Arduino Leonardo which is the Uno-like board that has the ATMega32u4 processor. It has a couple of differences from the '328 varieties that will trip you up if you're not careful (at least, they certainly tripped me up). The hardware SPI pins are on the ICSP header, and the interrupt pin for the radio triggers a different INT vector, for example.
    It's also a 5V chip, so I had to use a level converter for the radio module. I was lucky that my choice of prototyping shield for the Uno had a spot for SOIC-14 and so I populated it with TXS0104E and connected the radio through that. I connected the interrupt output from the radio module (DIO0) directly to the Atmel though.
    I had to use some tinned wire to extend the pins on the ICSP header so they would connect through the W5100 shield and into the prototyping shield that I mounted the radio on. I connected the RFM69 chip-select to pin 6 of the Arduino, and used 3, 5, 7 for the LEDs.
    I fumbled around for a long time before I realised that MySensors doesn't support the RFM69 module using SoftSPI. I think this should be made more clear on the Ethernet Gateway page. I ended up learning a lot about SPI and the W5100 Ethernet Shield, and came to the conclusion that the recent work on making SPI transactions atomic seems to have made sharing the SPI port possible. So I swapped out the RFM69 driver in the MySensors library with this one which includes the new SPI transaction features.
    My sketch is posted below and it's mostly the stock MQTT client gateway with the config set appropriately. The only other change was the RFM driver swap I mentioned above.
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define MY_RF69_IRQ_PIN 2
    #define MY_RF69_IRQ_NUM  1
    #define MY_RF69_SPI_CS 6
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "sensors-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "sensors-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "sensors"
    #define MY_IP_ADDRESS 192,168,1,30
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,254
    // MQTT broker ip address
    #define MY_CONTROLLER_IP_ADDRESS 192,168,1,10
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set LED blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 3 //3
    #define MY_DEFAULT_RX_LED_PIN  5 //5
    #define MY_DEFAULT_TX_LED_PIN  7 //7
    #include <Ethernet.h>
    G 1 Reply Last reply
      Is your gateway still working fine? Btw, nrf24 modules are 5V tolerant in the signal pins but require 3.3V max on the vcc
      • CarywinC
        CarywinC
        Carywin
        Yep, still running well. I have a few more sensors hanging off it now but I wouldn't say it's a stressful application, maybe 1-3 messages per 10 seconds.
        The NRF modules may be 5V tolerant, but I'm using the RFM69 radio at 433MHz and they're definitely not.
          wrote on last edited by gohan
          What level converter did you use?
          • CarywinC
            CarywinC
            Carywin
            TXS0104E
            • CarywinC Carywin
              Hi Folks,
               * LED purposes:
              G
              G
              gvorster
              wrote on last edited by gvorster
              @Carywin Thanks for the instructions!!
              I followed it and just got it working on a Leonardo clone. I am receiving messages from nodes on the Mosquitto broker on a Raspberry Pi.
              0;255;3;0;9;TSF:MSG:SEND,0-0-51-213,s=213,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:10280
              0;255;3;0;9;Sending message on topic: sensors-out/213/213/1/0/23
              0;255;3;0;9;TSF:MSG:READ,213-51-0,s=213,c=1,t=23,pt=2,l=2,sg=0:10281
              0;255;3;0;9;TSF:MSG:ACK REQ
              0;255;3;0;9;TSF:MSG:SEND,0-0-51-213,s=213,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:10281
              0;255;3;0;9;TSF:MSG:READ,207-51-0,s=207,c=1,t=23,pt=2,l=2,sg=0:21655
              0;255;3;0;9;TSF:MSG:SEND,0-0-51-207,s=207,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:21655
              0;255;3;0;9;Sending message on topic: sensors-out/207/207/1/0/23
              0;255;3;0;9;TSF:MSG:READ,213-51-0,s=213,c=1,t=23,pt=2,l=2,sg=0:10282
              mosquitto_sub -v -t 'sensors-out/#' -u XXXXXXX -P XXXXXXX
              sensors-out/0/255/0/0/18 2.1.1
              sensors-out/213/213/1/0/23 10217
              sensors-out/208/208/1/0/0 24.69
              sensors-out/213/213/1/0/23 10218
              sensors-out/213/213/1/0/23 10219
              sensors-out/213/213/1/0/23 10220
              sensors-out/213/213/1/0/23 10221
              sensors-out/213/213/1/0/23 10222
              sensors-out/213/213/1/0/23 10223
              sensors-out/213/213/1/0/23 10224
              I am using Mysensors 2.1.1. and didn't need to do anything on the nodes.
              Never worked with a Leonardo and spend a lot of time getting the serial port working on Win7. Also need to press reset everytime right before uploading a sketch.
              Also need to add:
                  while (!Serial) {;}
              otherwise Serial monitor shows nothing.
