  3. MQ135 AirQuality Sensor migrate sketch to MySensors 2.0
3 Posts 2 Posters 2.7k Views 2 Watching
    A Former User
    hello,
    i would like to build a MQ135 AirQuality Sensor. The sketch i have found from empierre ist not compatible with the 2.0 libery. I don`t know what i musst change on this sketch. Can anyone help me?
      Arduino MQ135
      connect the sensor as follows :
      A H A   >>> 5V
      B       >>> A0
      H       >>> GND
      B       >>> 10K ohm >>> GND
      Contribution: epierre
      Based on David Gironi http://davidegironi.blogspot.fr/2014/01/cheap-co2-meter-using-mq135-sensor-with.html
      http://skylink.dl.sourceforge.net/project/davidegironi/avr-lib/avr_lib_mq135_01.zip
    #include <Wire.h>
    #define CHILD_ID_AIQ 0
    #define AIQ_SENSOR_ANALOG_PIN 0
    #define MQ135_DEFAULTPPM 399 //default ppm of CO2 for calibration
    #define MQ135_DEFAULTRO 68550 //default Ro for MQ135_DEFAULTPPM ppm of CO2
    #define MQ135_SCALINGFACTOR 116.6020682 //CO2 gas value
    #define MQ135_EXPONENT -2.769034857 //CO2 gas value
    #define MQ135_MAXRSRO 2.428 //for CO2
    #define MQ135_MINRSRO 0.358 //for CO2
    unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in seconds)
    //VARIABLES
    float mq135_ro = 10000.0;    // this has to be tuned 10K Ohm
    int val = 0;                 // variable to store the value coming from the sensor
    float valAIQ =0.0;
    float lastAIQ =0.0;
    MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
      gw.begin();
      gw.sendSketchInfo("AIQ Sensor MQ135", "1.0");
      gw.present(CHILD_ID_AIQ, S_AIR_QUALITY);
     * get the calibrated ro based upon read resistance, and a know ppm
    long mq135_getro(long resvalue, double ppm) {
    return (long)(resvalue * exp( log(MQ135_SCALINGFACTOR/ppm) / MQ135_EXPONENT ));
     * get the ppm concentration
    double mq135_getppm(long resvalue, long ro) {
    double ret = 0;
    double validinterval = 0;
    validinterval = resvalue/(double)ro;
    if(validinterval<MQ135_MAXRSRO && validinterval>MQ135_MINRSRO) {
    ret = (double)MQ135_SCALINGFACTOR * pow( ((double)resvalue/ro), MQ135_EXPONENT);
    return ret;
      uint16_t valr = analogRead(AIQ_SENSOR_ANALOG_PIN);// Get AIQ value
      Serial.println(val);
      uint16_t val =  ((float)22000*(1023-valr)/valr);
      //during clean air calibration, read the Ro value and replace MQ135_DEFAULTRO value with it, you can even deactivate following function call.
      mq135_ro = mq135_getro(val, MQ135_DEFAULTPPM);
      //convert to ppm (using default ro)
      valAIQ = mq135_getppm(val, MQ135_DEFAULTRO);
      Serial.print ( "Val / Ro / value:");
      Serial.print ( val);
      Serial.print ( " / ");
      Serial.print ( mq135_ro);
      Serial.print ( valAIQ);
      if (valAIQ != lastAIQ) {
          gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ)));
          lastAIQ = ceil(valAIQ);
      // Power down the radio.  Note that the radio will get powered back up
      // on the next write() call.
      gw.sleep(SLEEP_TIME); //sleep for: sleepTime
    /*****************************  MQGetPercentage **********************************
    Input:   rs_ro_ratio - Rs divided by Ro
             pcurve      - pointer to the curve of the target gas
    Output:  ppm of the target gas
    Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
             of the line could be derived if y(rs_ro_ratio) is provided. As it is a
             logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
             value.
    int  MQGetPercentage(float rs_ro_ratio, float ro, float *pcurve)
      return (double)(pcurve[0] * pow(((double)rs_ro_ratio/ro), pcurve[1]));
    Boots33B 1 Reply Last reply
    • ? A Former User
      hello,
        Arduino MQ135
        A H A   >>> 5V
        B       >>> A0
        H       >>> GND
      #include <Wire.h>
      //VARIABLES
      float valAIQ =0.0;
      float lastAIQ =0.0;
        gw.begin();
      double ret = 0;
      return ret;
               value.
      Boots33B
      Boots33B
      Boots33
      @scaleoblack
      Try this
        Arduino MQ135
        A H A   >>> 5V
        B       >>> A0
        H       >>> GND
      // Enable debug prints
      // #include <SPI.h>
      //#include <MySensor.h>
      #include <Wire.h>
      //VARIABLES
      float valAIQ =0.0;
      float lastAIQ =0.0;
      // MySensor gw;
      //  gw.begin();
       // gw.sendSketchInfo("AIQ Sensor MQ135", "1.0");
      //  gw.present(CHILD_ID_AIQ, S_AIR_QUALITY);
      double ret = 0;
      return ret;
          //  gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ)));
        //gw.sleep(SLEEP_TIME); //sleep for: sleepTime
               value.
        A Former User
        thank you. it works:)
