  3. 💬 NodeManager
💬 NodeManager
contest2017arduinonewbiemysensorsbattery sensor
196 Posts 42 Posters 113.5k Views 41 Watching
  • V vikasjee
    @user2684, Sorry, couldn't revert to your query earlier as i was away building a small library.
    Expanding onto my earlier post on the requested Power Management feature -
    A simple switch will complete a circuit whenever its switched ON. This allows for placing the switch on the ground return wire too. So only a single GND-ON (Switched ON) will complete the circuit (without requiring an additional Vcc-ON switch).
    Now, with a developer configured #DEFINE GND_ON_POWER =1 may be checked in NodeManager's PowerManagement functions to DigitalWrite(Digital_GND_ON_Pin, LOW)
    for a switchON effect.
    Additionally, To provide an extra current to a sensor (i.e. more than a ~10mA-20mA, a max safe current provided by an Arduino pin) an external power source (other than Arduino +5V0 OR +3V3) may be provided by that external power source (of course with with a common ground wire between Arduino and that powersource to complete the circuit.)
    Also, with the current 2Wire PowerOn methodology, the VccPowerOn switch can provide only one positive voltage (that provided by Arduino Vcc, say +5V0) but not +3V3 (say) to the sensors. If some attached sensors require the other voltage (+3V3), then, this 2Wire PowerOn method will not help. Whereas, a single GND_On power methodology will still switch the circuit thus managing the Power to those sensors too.
    [PS: Signal Voltage Levels will still need to be managed by the developer attaching those sensors to the node]
    I think this simple feature will add on to the power of the PowerManagement functions.
    Hope this clears some air ? Open to suggestions...
    U
    U
    user2684
    @vikasjee thanks all clear now! I'll track this with https://github.com/mysensors/NodeManager/issues/224. Thanks again for the detailed explanation!
    • U
      U
      user2684
      Hello all, just to let you know when compiling against the latest version of the mysensors 2.2.0-beta library, NodeManager will crash on startup, just after presenting the mysensors logo. Thanks @gohan for pointing this out! Root cause is still unknown but when MY_DEBUG is defined, the crash doesn't take place (https://github.com/mysensors/NodeManager/issues/223)
      V 1 Reply Last reply
      • U user2684
        V
        V
        vikasjee
        @user2684, Can we have a quick hot fix?
        U 1 Reply Last reply
        • V vikasjee
          U
          U
          user2684
          @vikasjee sure, as soon as I'll be able to understand the reason why it crashes when MY_DEBUG is not defined :-( if somebody from the core team has any hit, would be really appreciated!
          • Sergio RiusS
            Sergio RiusS
            Sergio Rius
            wrote on last edited by Sergio Rius
            #125
            I'm afraid that issue 223 is not a NodeManager failure. I can reproduce it in a new sketch without using NodeManager.
            Other issue with MySensors are, NRF24 doesn't link with controller.
            If MY_DEBUG_VERBOSE_RF24 is defined, it automagically works.
            • Sergio RiusS Sergio Rius
              V
              V
              vikasjee
              @Sergio-Rius, with RF24_VERBOSE on, the system crashes in 40-50 seconds especially if you're connected to the serial monitor or if your serial gateway has this #DEFINE on.
              Sergio RiusS 1 Reply Last reply
              • V vikasjee
                Sergio RiusS
                Sergio RiusS
                Sergio Rius
                Still more strange, suddenly started to work properly on 2/3 of my testing nodes. That killed me.
                What about the gateways you are using? And the controllers?
                • F
                  F
                  FredRoot
                  I'm having trouble with the motion sample code. I have changed the setSleepHours(1) command to setSleepMinutes(1). I understand that the sensor will send a hart beat every 1 min. This is working fine for the hart beat, but evertime the hart beat is send the sensor sends a Trigger messages as well even though the sensor is not triggered. I thought that maybe there is a power dip and that it might cause the PIR (RS501) to send a interrupt, but I have removed the setSleepMinutes command and replaced it with a setBatteryReportHours(1) command. This command is send correctly and the sensor only sends the trigger command when the PIR is triggered. Did anyone have a similar issue?
                  Attached is the sensor debug output when the setSleepMinutes command is used:
                  40 MCO:BGN:BFR
                  REG I=1 P=3 P=1 T=16
                  NodeManager v1.6
                  LIB V=2.1.1 R=N T=N A=A S=- B=-
                  INT P=3 M=1
                  INT P=2 M=255
                  96 TSM:INIT
                  176 TSF:WUR:MS=0
                  198 TSM:INIT:TSP OK
                  219 TSM:INIT:STATID=3
                  243 TSF:SID:OK,ID=3
                  264 TSM:FPAR
                  313 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  385 TSF:MSG:READ,0-0-3,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  440 TSF:MSG:FPAR OK,ID=0,D=1
                  2387 TSM:FPAR:OK
                  2404 TSM:ID
                  2418 TSM:ID:OK
                  2433 TSM:UPL
                  2449 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  2521 TSF:MSG:READ,0-0-3,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  2578 TSF:MSG:PONG RECV,HP=1
                  2607 TSM:UPL:OK
                  2625 TSM:READY:ID=3,PAR=0,DIS=1
                  2660 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  2734 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  2797 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                  2875 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  2945 TSF:MSG:READ,0-0-3,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  RADIO OK
                  3004 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:NodeManager
                  3096 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                  PRES I=200, T=23
                  3170 TSF:MSG:SEND,3-3-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=OK:
                  PRES I=201, T=30
                  3260 TSF:MSG:SEND,3-3-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                  BATT V=3.30 P=100
                  SEND D=0 I=201 C=0 T=38 S= I=0 F=3.30
                  3418 !MCO:SND:NODE NOT REG
                  3506 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:100
                  PRES I=1 T=1
                  3579 TSF:MSG:SEND,3-3-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                  READY
                  3659 MCO:REG:REQ
                  3688 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  3760 TSF:MSG:READ,0-0-3,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  3817 MCO:PIM:NODE REG=1
                  3842 MCO:BGN:STP
                  MY I=3 M=1
                  3860 MCO:BGN:INIT OK,TSP=1
                  SLEEP 60s
                  3901 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                  3971 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:127
                  4544 MCO:SLP:TPD
                  4560 MCO:SLP:WUP=1
                  INT P=3, M=1
                  AWAKE
                  SWITCH I=1 P=3 V=1
                  SEND D=0 I=1 C=0 T=16 S= I=1 F=0.00
                  4597 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                  SLEEP 60s
                  4732 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                  4800 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:956
                  5376 MCO:SLP:TPD
                  5392 MCO:SLP:WUP=1
                  INT P=3, M=1
                  AWAKE
                  SWITCH I=1 P=3 V=0
                  SEND D=0 I=1 C=1 T=16 S= I=0 F=0.00
                  5429 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                  SLEEP 60s
                  5564 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                  5632 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:1787
                  6207 MCO:SLP:TPD
                  6223 MCO:SLP:WUP=-1
                  AWAKE
                  SLEEP 60s
                  6246 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                  6322 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2478
                  6897 MCO:SLP:TPD
                  6914 MCO:SLP:WUP=1
                  INT P=3, M=1
                  AWAKE
                  SWITCH I=1 P=3 V=1
                  SEND D=0 I=1 C=1 T=16 S= I=1 F=0.00
                  6950 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                  SLEEP 60s
                  7086 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                  7153 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:3309
                  7729 MCO:SLP:TPD
                  7745 MCO:SLP:WUP=1
                  INT P=3, M=1
                  AWAKE
                  SWITCH I=1 P=3 V=0
                  7782 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                  SLEEP 60s
                  7917 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                  7985 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:4141
                  8560 MCO:SLP:TPD
                  8577 MCO:SLP:WUP=-1
                  AWAKE
                  SLEEP 60s
                  8599 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                  8675 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:4831
                  9252 MCO:SLP:TPD
                  9269 MCO:SLP:WUP=1
                  INT P=3, M=1
                  AWAKE
                  SWITCH I=1 P=3 V=1
                  9306 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                  SLEEP 60s
                  9441 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                  9508 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:5664
                  10084 MCO:SLP:TPD
                  10102 MCO:SLP:WUP=1
                  INT P=3, M=1
                  AWAKE
                  SWITCH I=1 P=3 V=0
                  10139 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                  SLEEP 60s
                  10274 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                  10344 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:6500
                  10921 MCO:SLP:TPD
                  • F FredRoot
                    40 MCO:BGN:BFR
                    NodeManager v1.6
                    INT P=3 M=1
                    INT P=2 M=255
                    96 TSM:INIT
                    176 TSF:WUR:MS=0
                    198 TSM:INIT:TSP OK
                    243 TSF:SID:OK,ID=3
                    264 TSM:FPAR
                    2387 TSM:FPAR:OK
                    2404 TSM:ID
                    2418 TSM:ID:OK
                    2433 TSM:UPL
                    2607 TSM:UPL:OK
                    RADIO OK
                    PRES I=200, T=23
                    PRES I=201, T=30
                    BATT V=3.30 P=100
                    PRES I=1 T=1
                    READY
                    3659 MCO:REG:REQ
                    3842 MCO:BGN:STP
                    MY I=3 M=1
                    SLEEP 60s
                    4544 MCO:SLP:TPD
                    4560 MCO:SLP:WUP=1
                    INT P=3, M=1
                    AWAKE
                    SWITCH I=1 P=3 V=1
                    SLEEP 60s
                    5376 MCO:SLP:TPD
                    5392 MCO:SLP:WUP=1
                    INT P=3, M=1
                    AWAKE
                    SWITCH I=1 P=3 V=0
                    SLEEP 60s
                    6207 MCO:SLP:TPD
                    6223 MCO:SLP:WUP=-1
                    AWAKE
                    SLEEP 60s
                    6897 MCO:SLP:TPD
                    6914 MCO:SLP:WUP=1
                    INT P=3, M=1
                    AWAKE
                    SWITCH I=1 P=3 V=1
                    SLEEP 60s
                    7729 MCO:SLP:TPD
                    7745 MCO:SLP:WUP=1
                    INT P=3, M=1
                    AWAKE
                    SWITCH I=1 P=3 V=0
                    SLEEP 60s
                    8560 MCO:SLP:TPD
                    8577 MCO:SLP:WUP=-1
                    AWAKE
                    SLEEP 60s
                    9252 MCO:SLP:TPD
                    9269 MCO:SLP:WUP=1
                    INT P=3, M=1
                    AWAKE
                    SWITCH I=1 P=3 V=1
                    SLEEP 60s
                    10084 MCO:SLP:TPD
                    10102 MCO:SLP:WUP=1
                    INT P=3, M=1
                    AWAKE
                    SWITCH I=1 P=3 V=0
                    SLEEP 60s
                    10921 MCO:SLP:TPD
                    U
                    U
                    user2684
                    @FredRoot this is weird, from the logs looks like there is kind of a floating interrupt (alternatively 1 and 0). The strange thing is that the interrupt is coming from the call to mysensors' sleep() function which is returning a positive number corresponding to the interrupt linked to pin 3 instead of a negative value like it should after a sleeping cycle. Anybody else experiencing this behavior with NodeManager v1.6? thanks
                      mvader
                      wrote on last edited by mvader
                      #130
                      @user2684 can you add support for the Si7021 sensor as found in sensebender micro?
                      https://www.mysensors.org/hardware/micro
                      also, 2nd question.
                      how do i register a sensor that is onboard?
                      you ask for a child id and pin that it's on. but if it's an onboard sensor. how do you make that work? just omit the pin?
                      • M mvader
                        also, 2nd question.
                        U
                        U
                        user2684
                        @mvader for question #1, I've added it to the existing issue https://github.com/mysensors/NodeManager/issues/221. For question #2, for sensors using i2c the pin is not required despite within the code nodemanager will set a random pin (have a look at SensorSHT21 for example)
                        M 1 Reply Last reply
                        • U user2684
                          mvader
                          @user2684 said in 💬 NodeManager:
                          great.. thank you!
                          • U
                            U
                            user2684
                            After a few months working behind the scene, NodeManager got kind of a full review in terms of architecture and usability. The code should be now simpler to understand for new users, the memory utilization has been optimized and the overall user experience has been improved.
                            The looooong list of things that have been changed are detailed on https://github.com/mysensors/NodeManager/pull/229.
                            Please note this is only available in the development branch (https://github.com/mysensors/NodeManager/tree/development) and will be generally available only when NodeManager's v1.7 will be released (it will take I guess still a few months).
                            Since this change was blocking other pending changes, I hope now the development will be faster and feel free to submit your PRs now that the new architecture has been finalized.
                            As always, any feedback is more than welcome.
                            • R
                              R
                              reinhold
                              @user2684 Thanks a lot for the architecture change, which makes a lot of sense conceptually.
                              Unfortunately, it appears to use more memory than before. I'm working on an air quality board with eight MQ sensors, an MH-Z19 CO2 sensor and a Plantower PMSA003 particulate matter sensor. In previous development versions (1.7-dev, before today), the eight MQ sensors and the MH-Z19 worked fine, but now after your big merge of #229 the sketch appears to run out of memory after adding the child of the sixth MQ sensor. Do you see any chance to optimize for memory?
                              Old sketch (using a previous development version of NodeManager, without the PMSA003; 155 bytes left after all nine sensors are fully initialized): https://github.com/open-tools/NodeManager_GasSensor/tree/master/NodeManager_GasSensor
                              New sketch (using the latest version of NodeManager, plus a PMSA003): https://github.com/kainhofer/NodeManager/tree/GasSensor
                              That sketch runs out of memory with the sixth MQ sensor (I added debug output with free memory at a lot of spots). Of course, I have commented out the PMSA003 completely to have a correct comparison.
                              FWIW, the sketch is for this board: https://github.com/open-tools/NodeManager_GasSensor/blob/master/images/IMAG2267.jpg
                              Nca78N mfalkviddM U 3 Replies Last reply
                              • R reinhold
                                Nca78N
                                Nca78N
                                @reinhold if you have high memory requirement, what about switching to a more modern architecture like stm32f103c8t6 on the famous "blue pill" boards ? It has 20k or RAM (10 times what you have on Arduino) and 64k of flash and it's supported by MySensors, in addition to be very cheap (2$/board). You will need voltage converter between 3.3V of the board and 5V of your sensors but that's not a big deal in exchange of the possibility to expand your board with more sensors in the future.
                                R 1 Reply Last reply
                                • R reinhold
                                  @reinhold not sure how much this applies to NodeManager, but there are some recomendations for reducing memory footprint at https://www.mysensors.org/apidocs-beta/group__memorysavings.html
                                  • Nca78N Nca78
                                    R
                                    R
                                    reinhold
                                    @nca78 Thanks for the suggestion to use the blue pill STM32 boards. I haven't thought of it (I only looked at the ESP8266, but that has only one ADC). I have a few lying around here, but never got around to trying them, as I first need to burn the bootloader. It looks quite promising, but the boards are huge, so I'll need to enlarge my PCB...
                                    The need for a 5V->3.3V regulator is no issue, as the NRF24 already needs 3.3V. The 5V analog level of the MQ sensors will need some converter (the analog ADC inputs are marked as non-5V-tolerant...), but then in turn I can get rid of the voltage dividers for the PMSA003. The larger issue seems to be the connection of the nrf24, which takes away 4 ADC pins, so there are only 6 ADC pins left, while I have 8 analog sensors :(
                                    Still, for now I have the PCBs with the ProMini, so I'll try to strip down the Sensor or SensorMQ classes for my own use.
                                    • R
                                      R
                                      reinhold
                                      @nca78 Two more things popped up with the latest development version of NodeManager:
                                      • In NodeManager.ino: function void before(): The sample code to set the child id of a child is sht.children.get(1)->child_id = 5, but that does not work, because at that point the children are not yet even generated. They are created by the node.before(); call at the very end of the function... So, currently this will not assign any new child ID and the default IDs will be used. I have not checked in detail whether calling node.before() at the beginning of the before() function and then assigning child_id to the children will solve the issue. From a quick look at the code, it might work...
                                      • I'm trying to implement an OLED display, where the node would wake up every 5 seconds, take a measurement and display it on the OLED. But the report interval to the MySensors gateway should only be 10 minutes. I thought that
                                        node.setSleepSeconds(5); node.setReportIntervalMinutes(10); would be the correct way to setup NodeManager to take measurements every 5 seconds, but only report it every 10 minutes to the network. Unfortunately, Sensor::loop(MyMessage* message) seems to immediately return without measurement if the reporting timer has not elapsed. Somehow I don't understand that logic. Why have different sleep and reporting intervals when measurements will only be taken at reporting intervals anyway? I would expect measurements to be taken with the sleep intervals (e.g. to calculate an average over the whole reporting interval) and report back to the network using report intervals.
                                      • R reinhold
                                        U
                                        U
                                        user2684
                                        @reinhold thanks for reporting this issue. One of the main objectives of the new architecture was to reduce the memory footprint so if this is not the case, there is definitely something to fix. I've noticed in your sketch you are using the remote configuration sensor, that one is huge in terms of memory, if not strictly required I'd comment it out (BTW very nice project!). In PR #229 I've also uploaded a spreadsheet with all tests I run for realizing what was using the memory the most. Anyway, there is still a lot of room for improvement looks like :)
                                        Thanks @mfalkvidd , I'll give the directives you pointed out a try!
                                        • R reinhold
                                          U
                                          U
                                          user2684
                                          @reinhold you're right, assigning the child_id before calling node.before() does not work. The way to go would be to have all the methods being called before node.before() and the child_id assigned just after. Not very intuitive, I probably need to find a completely different and a better way to do so, probably by creating the Child in the constructor instead (reopening https://github.com/mysensors/NodeManager/issues/198 for this).
                                          Regarding setSleep and setReportInterval, measurement are driven only by setReportInterval. Those are different because there are situations (e.g. relays, motion sensors) when you have nothing to report but you want the capture the heartbeat from sleep(). What you are looking for is something I never considered which is actually a pretty nice idea (taking measurements over a given time period and than reporting at the end). I've created https://github.com/mysensors/NodeManager/issues/243 for this. With the new architecture, since keeping already track of the average within Child, should not be so difficult even if would probably require an additional Timer. Thanks!
