  3. Sending Sensor data to Cloud with GSM module
8 Posts 3 Posters 6.2k Views 2 Watching
  • E Offline
    E Offline
    esawyja
    Hi all,
    Any ideas on how to do this please, I have a serial gateway running with a GSM module and a "button pressed" sensor. When I press the button I can see this below on the serial monitor.
    0;255;0;0;18;2.1.1
    Serial Setup Complete!
    Serial Setup to A6 Complete!
    10;3;1;0;16;0
    10;3;1;0;16;1
    Without using a controller, how can I "capture" the sensor data and send it to my server in the cloud via the GSM module? I can get the communication with the GSM module working, its just the capture of the MySensors data that I have no idea of how to do...
    Any ideas will be appreciated..
    • E esawyja
      Hi all,
      0;255;0;0;18;2.1.1
      10;3;1;0;16;0
      10;3;1;0;16;1
      @esawyja maybe you can modify the mqtt gateway? It is built for sending data directly to a server. The MySensors example mqtt sketches assume that the gateway has ethernet or wifi connection, but it should be possible to make it work with a gsm connection.
      • E Offline
        E Offline
        esawyja
        Thanks @mfalkvidd , Let me read up on that a bit
        gohanG 1 Reply Last reply
        • E esawyja
          @esawyja there are multiple examples over internet and youtube on how to connect gsm modules to arduino and get internet IP connection. Also adafruit has some examples on gsm and mqtt.
          • E Offline
            E Offline
            esawyja
            wrote on last edited by esawyja
            I've read about MQTT, but I'm afraid it is above my pay grade :-) Is there no way of capturing the data what gets displayed on the serial port of the gateway, or rather, what does MySensors use as the serial port, all I need is some kind of trap what will say if I receive this
            10;3;1;0;16;0 for example,
            initialize the GSM module and post the sensor value using curl or something, could someone point me in the right direction please, my head is spinning
              I think investing some time on learning how mqtt works, is going to make it simpler to manage it later on because mqtt was born to be used for applications like this one.
              • E Offline
                E Offline
                esawyja
                Ok in a effort to learn MQTT, what I did is the following, I used my RFM69 sensor (that did work on a Serial Gateway, see the values received above) and with that to build a MQTT gateway, I used an Arduino Mega with a W5100 Ethernet Shield and connected the RFM69 radio to the Mega, using the pinouts of the RFM69 & Arduino page and also included a level converter on the NSS, SCK MOSI and MISO pins
                Radio is powered by 3.3V and I uploaded this sketch below to the Mega
                 * Version 1.0 - Henrik Ekblad
                 * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
                 * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
                 * LED purposes:
                 * nRF24L01+  ESP8266
                 * VCC        VCC
                 * CE         GPIO4
                 * CSN/CS     GPIO15
                 * SCK        GPIO14
                 * MISO       GPIO12
                 * MOSI       GPIO13
                  * Inclusion mode button:
                //#define MY_RADIO_NRF24
                #define MY_RADIO_RFM69  // Define for using RFM69 radio
                #define MY_IS_RFM69HW
                // Set MQTT client id
                //#define MY_W5100_SPI_EN 4
                // radio on the same spi bus.
                #define MY_SOFTSPI
                #ifndef MY_RF24_CE_PIN
                #define MY_RF24_CE_PIN 5
                #ifndef MY_RF24_CS_PIN
                #define MY_RF24_CS_PIN 6
                #define MY_IP_ADDRESS 192,168,1,88
                #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
                #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 9
                #define MY_PORT 1883
                #define MY_GATEWAY_W5100
                // Enable inclusion mode
                // Set blinking period
                // Flash leds on rx/tx/err
                #include <Ethernet.h>
                I then installed MQTT on a raspberry PI on IP 192.168.1.9, from the Mega's serial port, it looks to me that the radio initializes OK and the Mega is connected to my LAN with IP 192.168.1.88, see below
                0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.1
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSF:WUR:MS=0
                0;255;3;0;9;TSM:INIT:TSP OK
                0;255;3;0;9;TSM:INIT:GW MODE
                IP: 192.168.1.88
                0;255;3;0;9;MCO:BGN:STP
                IP: 192.168.1.88
                0;255;3;0;9;MQTT connected
                0;255;3;0;9;Sending message on topic: mygateway1-out/0/255/0/0/18
                But when I activate the sensor, I don''t see anything as I did before on the Mega and also nothing in the MQTT server logs or subscription
                root@raspberrypi:~# mosquitto_sub -v -t 'mygateway1-out/#'
                mygateway1-out/0/255/0/0/18 2.1.1
                and the log
                root@raspberrypi:~# kill -9 28003
                root@raspberrypi:~# /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf &
                [1] 29149
                root@raspberrypi:~# tail -f /var/log/mosquitto/mosquitto.log
                1490722311: New client connected from 192.168.1.88 as mysensors-1 (c1, k15).
                1490722482: Client mysensors-1 has exceeded timeout, disconnecting.
                1490722482: Socket error on client mysensors-1, disconnecting.
                1490722739: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
                1490722757: Socket error on client mosqsub/28798-raspberry, disconnecting.
                1490722980: mosquitto version 1.4.11 (build date Mon, 20 Feb 2017 22:49:47 +0000) starting
                1490722980: Config loaded from /etc/mosquitto/mosquitto.conf.
                1490722980: Opening ipv4 listen socket on port 1883.
                1490722980: Opening ipv6 listen socket on port 1883.
                1490722984: New connection from ::1 on port 1883.
                1490722984: New client connected from ::1 as mosqsub/29150-raspberry (c1, k60).
                1490723068: New connection from 192.168.1.88 on port 1883.
                1490723068: New client connected from 192.168.1.88 as mysensors-1 (c1, k15).
                1490723375: Client mysensors-1 has exceeded timeout, disconnecting.
                1490723375: Socket error on client mysensors-1, disconnecting.
                1490723398: New connection from 192.168.1.88 on port 1883.
                Any ideas please, must the Mega get a NODE_ID? I seem to recall I could only get sensor data on the serial gateway after a assigned a NODE_ID to the sensor, any advice please would be appreciated
                Regards
                  Being gateway you don't need node ID
