  3. Relay not reacting first 3 seconds
4 Posts 2 Posters 1.5k Views 2 Watching
  • derksuhD Offline
    derksuhD Offline
    derksuh
    Hello all,
    I have the following sketch working with a pimatic installation. When i switch on the relay nothing happens
    when i keep switching it on and off than after 2 or 3 times it starts reacting. But every time i wait a couple of seconds
    i have to switch it on and off a couple of times before it reacts. This is th epimatic log output if i switch it on the first time.
    debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSF:MSG:LEN,2!=7
    19:53:48debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSF:MSG:READ,25-12-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    19:45:45debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;MCO:BGN:INIT OK,TSP=1
    19:45:45debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;MCO:BGN:STP
    19:45:45debug [pimatic-mysensors]: <- Presented Node  [ '0', '255', '0', '0', '18', '2.1.1' ]
    19:45:45debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;MCO:REG:NOT NEEDED
    19:45:45debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSM:READY:ID=0,PAR=0,DIS=0
    19:45:45debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSM:INIT:GW MODE
    19:45:45debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSM:INIT:TSP OK
    19:45:45debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSF:WUR:MS=0
    19:45:45debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    19:45:45debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSF:MSG:SEND,0-0-5-5,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
    19:45:44debug [pimatic-mysensors]: -> Sending  5;1;1;1;2;1
    if it starts reacting i get this output.
    debug [pimatic-mysensors]: <- MySensorDHT  { sender: 5, sensor: 1, type: 2, value: '1' }
    19:45:04debug [pimatic-mysensors]: <- MySensorSwitch  { sender: 5, sensor: 1, type: 2, value: '1' }
    19:45:04debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSF:MSG:ACK
    19:45:04debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSF:MSG:READ,5-5-0,s=1,c=1,t=2,pt=0,l=1,sg=0:1
    19:45:04debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSF:MSG:SEND,0-0-5-5,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
    19:45:04debug [pimatic-mysensors]: -> Sending  5;1;1;1;2;1```
    This is the sketch i am using
    ```#define MY_NODE_ID 5
    // Enable debug prints
    #include <DHT.h>
    #define CHILD_ID_HUM 1
    #define CHILD_ID_TEMP 2
    #define HUMIDITY_SENSOR_DIGITAL_PIN 6
    unsigned long WAIT_TIME = 30000; // Sleep time between reads (in milliseconds)
    unsigned long lastRefreshTime = 0; // Use this to implement a non-blocking delay function
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
      metric = getConfig().isMetric;
        pinMode(pin, OUTPUT);
        // Request the latest relay status from the gateway
      Serial.println("Requesting initial value from controller");
      request(RELAY_1, V_STATUS);
      sendSketchInfo("Badkamer", "1.3");
      present(CHILD_ID_HUM, S_HUM);
        present(sensor, S_LIGHT);
      boolean needRefresh = (millis() - lastRefreshTime) > WAIT_TIME;
      if (needRefresh)
          lastRefreshTime = millis();
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            Serial.print("T: ");
            Serial.println(temperature);
          if (isnan(humidity)) {
              lastHum = humidity;
              Serial.print("H: ");
              Serial.println(humidity);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         Serial.print(message.sensor);
    rejoe2R 1 Reply Last reply
    • derksuhD derksuh
      Hello all,
      #include <DHT.h>
      DHT dht;
      float lastTemp;
      float lastHum;
        if (needRefresh)
              if (!metric) {
                lastHum = humidity;
      rejoe2R Offline
      rejoe2R Offline
      rejoe2
      @derksuh Could you check, if your GW is rebooting all the time?
      The debug message
      looks like a reboot to me.
      Root cause could be a faulty AVR board definition (should be latest (1.6.18+) or <=1.6.11). Affected: Serial GWs and Ethernet-GW's.
      • derksuhD Offline
        derksuhD Offline
        derksuh
        @rejoe2 said in Relay not reacting first 3 seconds:
        If this is the problem then could i do something about it?
        • derksuhD derksuh
          rejoe2R Offline
          rejoe2R Offline
          rejoe2
          @derksuh For information which version of the board defs you use (and for up- and downgrading also): Within the Arduino IDE you can just use the boardmanager (Tools menue, as far as I remember) to do this...
