  3. fody weather station, wind sensor
windwinddirectiongusthyt221weatherwindspeedfodyhytht01dweather station
36 Posts 7 Posters 15.6k Views 7 Watching
    I haven't done anything yet, I'm just trying to apply some cheap physics 😀
    I'd start from the outside and see what happens
    F 1 Reply Last reply
      F Offline
      F Offline
      flopp
      @gohan
      Ok, thanks.
      I will try it tomorrow
      • F Offline
        F Offline
        flopp
        wrote on last edited by flopp
        #23
        New code again :frowning:
        Wind speed: it compare between two interrupts if it is too quick, if more than 100000 micros it will not use it
        #include <Wire.h>
        #define WIND_CHILD 0
        #define TEMP_CHILD 1
        #define HUM_CHILD 2
        #define RAIN_CHILD 3
        MyMessage WSMsg(WIND_CHILD, V_WIND);
        MyMessage WGMsg(WIND_CHILD, V_GUST);
        MyMessage WDMsg(WIND_CHILD, V_DIRECTION);
        MyMessage TempMsg(TEMP_CHILD, V_TEMP);
        MyMessage HumMsg(HUM_CHILD, V_HUM);
        MyMessage RainMsg(RAIN_CHILD, V_RAIN);
        MyMessage RainCounterMsg(RAIN_CHILD,V_VAR1);
        //Wind Speed
        volatile unsigned long lastPulse = 0;
        volatile unsigned long intervalSum;
        unsigned long lastInterval = 0;
        unsigned long looptime;
        float WS = 0;
        float WG = 0;
        int WScount = 0;
        //Wind Direction
        int WDarray[8] = {0,45,90,135,180,225,270,315};
        int WD;
        //Rain
        volatile float hwRainVolume = 0;   // Current rainvolume calculated in hardware.
        float bucketSize = 0.4;   // mm per tip
        boolean pcReceived = false;
        volatile unsigned long lastSend = 0;
        // Temperature/Humidity
        double hum = 0;
        double temp = 0;
          Wire.begin();   //start i2c
          gw.begin(incomingMessage, AUTO, false);
          gw.sendSketchInfo("WeatherMast", "170427");
          gw.present(WIND_CHILD, S_WIND);
          gw.present(TEMP_CHILD, S_TEMP);
          gw.present(HUM_CHILD, S_HUM);
          gw.present(RAIN_CHILD, S_RAIN);
          gw.request(RAIN_CHILD, V_VAR1);
          gw.wait(5000);
          //pin 2 is rain, pin 3 is wind speed
          //pin 4-8, 14-16 is wind direction
          //configure pin 2-8 as an input and enable the internal pull-up resistor
          for (int i=2 ; i < 9 ; i++) {
            pinMode(i, INPUT_PULLUP);
          //configure pin 14-16(A0-A2) as an input and enable the internal pull-up resistor
          for (int i=14 ; i < 17 ; i++) {
          attachInterrupt(0, Rain, FALLING);    //rain
          attachInterrupt(1, WindSpeed, FALLING);   //wind speed
          gw.wait(60000);
          detachInterrupt(1);
          looptime = micros();
          readTempHum();    //read temperature and humidity
          readWindDirection();    //read wind direction
          resend((WSMsg.set(WS, 1)),3);
          WS = 0;  //reset wind speed, useful if there is no wind otherwise old value will be sent to Controller
          resend((WGMsg.set(WG, 1)),3);
          WG = 0;   //reset gust
          resend((WDMsg.set(WD, 1)),3);
          resend((RainMsg.set((float)hwRainVolume,2)),3);
          resend((TempMsg.set(temp, 1)),3);
          resend((HumMsg.set(hum, 1)),3);
          lastPulse += micros() - looptime;
        void readWindDirection()
          //check in what direction the wind is. First sensor that have light will be the direction
          int i = 4;
          for (i; i < 9 ; i++){
            if (!digitalRead(i)){
              WD = WDarray[i-4];
              return;
          i = 14;
          for (i; i < 17 ; i++){
              WD = WDarray[i-9];
              return;
        void Rain()
          unsigned long currentTime = millis();
          if (!pcReceived) {
            Serial.println("Request rainCount");
            gw.process();
            return;
          if (currentTime - lastSend > 5000) {
          hwRainVolume = hwRainVolume + bucketSize;
          resend((RainCounterMsg.set(hwRainVolume,2)),3);
          lastSend=currentTime;
        void WindSpeed()
          detachInterrupt(1);
          volatile unsigned long newPulse = micros();
          unsigned long interval = newPulse-lastPulse;
          if (interval<16000L) { // Sometimes we get wrong interrupt. 16000L = ~30 m/s
            lastPulse = newPulse;
            return;
          long a = interval-lastInterval;
          a = abs(a);
          lastInterval = interval;
          if (a > 100000) {
            return;
          else {
            WS = (0.4775/(interval/1000000.0));
            if (WS > WG) {
              WG = WS;
        void readTempHum()
          Wire.beginTransmission(0x28);   // Begin transmission with given device on I2C bus
          Wire.requestFrom(0x28, 4);      // Request 4 bytes
          if(Wire.available() == 4) {
            int b1 = Wire.read();
            int b2 = Wire.read();
            int b3 = Wire.read();
            int b4 = Wire.read();
            Wire.endTransmission();           // End transmission and release I2C bus
            // combine humidity bytes and calculate humidity
            int rawHumidity = b1 << 8 | b2;
            // compound bitwise to get 14 bit measurement first two bits
            // are status/stall bit (see intro text)
            rawHumidity =  (rawHumidity &= 0x3FFF);
            hum = 100.0 / pow(2,14) * rawHumidity;
            // combine temperature bytes and calculate temperature
            b4 = (b4 >> 2); // Mask away 2 least significant bits see HYT 221 doc
            int rawTemperature = b3 << 6 | b4;
            temp = 165.0 / pow(2,14) * rawTemperature - 40;
          if (message.type==V_VAR1) {
            hwRainVolume = message.getFloat();
            pcReceived = true;
            Serial.print("Received last pulse count from gw: ");
            Serial.println(hwRainVolume,2);
        void resend(MyMessage &msg, int repeats)
          int repeat = 1;
          int repeatdelay = 0;
          boolean sendOK = false;
          while ((sendOK == false) and (repeat < repeats)) {
            if (gw.send(msg)) {
              sendOK = true;
            else {
              sendOK = false;
              Serial.print("Error ");
              Serial.println(repeat);
              repeatdelay += 500;
            repeat++; delay(repeatdelay);
        EDIT: added
        WS = 0;
        in loop
          So, how is the hacking going? :)
            F Offline
            F Offline
            flopp
            @gohan
            Thanks for asking :)
            It is working good, but I don't trust the wind speed. I have lots of "ghost" indications from the reed
            switch, I tried to remove it with code in two different ways but anyway I get some high values. I will order a wind speed meter and check against that one. I also record a slow-mo video when it spins in front of a fan(2.5m/s) and it is correct but it is difficult to test it with 10 m/s,
            If anyone are inreseted what's inside the receiver that was included from Fody. It look like this
            • F Offline
              F Offline
              flopp
              suddenly it stopped sending data, after power-off-power-on it started to work again
              gohanG 1 Reply Last reply
                I got an Uno as ethernet gateway with a DHT sensors and sometimes it hangs too after several days
                • F flopp
                  @flopp I'll need to look at the watchdog timers and see if it may help
                  • F Offline
                    F Offline
                    flopp
                    it stopped working again, this morning. This time it started to work again just after opening Serial monitoring in Arduino IDE
                      That's normal, upon serial connection the Arduino resets. Try adding the watchdog function. You could also try the newer mysensors library that's in the development branch
                        F Offline
                        F Offline
                        flopp
                        @gohan said in fody weather station, wind sensor:
                        That's something new for me. What is this and how do you add it?
                        Anyone with a link?
                          Search "Arduino watchdog examples" lots of stuff comes out
                            F Offline
                            F Offline
                            flopp
                            #33
                            thanks :+1:
                            I did some search and I never heard of this function before.
                            I will test it in my sketch and see if I get rid of the freezing stuff
                            • F Offline
                              F Offline
                              flopp
                              I read about watchdog now and as normal way, without extra code, it can check that our code is alive less then 8 seconds.
                              I want it to send data every 60 seconds so I need to loop watchdog code a couple of times.
                              I will look at this later
                              • K Offline
                                K Offline
                                karl-ove
                                Hi Flopp
                                I bought the Fody some time ago with the intention to connect it via Blue Tooth to a RPI for awnings control. The idea was that all the calibrating then should be handled by the indoor unit.
                                Whats your opinion about this?
                                I'm really new to BLE and Python programming and have so far only been able to make a succesful CONNECT. Is there anybody made something similar? Any help would be appreciated
                                • D Offline
                                  Dan_n_e
                                  Hello, I have followed your build and are about to to a similar reverse engineering of a weather station but my winddirection look different and Ineed some input on how I can fix it.
                                  On my there are 8 IR leds on the perimiter and 4 IR sensitiv transistors in the middle. The outer leds are wired 2 and 2 with all the odds having common GND and all the even have common GND. So i have problem on how to turn the led on 1 by 1. Any inputs?
