  3. fody weather station, wind sensor
windwinddirectiongusthyt221weatherwindspeedfodyhytht01dweather station
36 Posts 7 Posters 16.5k Views 7 Watching
  • F
    F
    flopp
    some pictures
    0_1493054883191_20170424_160412832_iOS.jpg 0_1493054891231_20170424_160402858_iOS.jpg 0_1493054901570_20170424_160025939_iOS.jpg 0_1493054908764_20170424_160020368_iOS.jpg
    • F
      F
      flopp
      wrote on last edited by flopp
      I am using this water proof connector for USB connection.
      https://www.aliexpress.com/item/Free-Shipping-3-Sets-All-New-4-Pin-Waterproof-Electrical-Wire-Connector-Plug-HID-Male-female/32264045957.html
      in sweden you can buy it at Biltema
      • F
        F
        flopp
        I have not verify all the code yet.
        Wind direction is correct.
        Temp is little bit higher then another temp that I have on shadow so maybe the radiation shield is not working 100%
        Hum: my other sensor that I have outdoor broke a few weeks ago, so nothing to compare with
        Wind Speed: I want to verify with an RPM tool. I get some extra indication from reeed switch.
        Every second indication is below 1000 micros which is 1 millisecond, which is 1000m/s
        Rain: lucky or unlucky I have not had any rain when the mast was up and running
          Maybe you need a better heat shield, did you try some aluminum foil?
          F 1 Reply Last reply
            F
            F
            flopp
            @gohan said in fody weather station, wind sensor:
            Good idea :)
            Should I have the foil inside the shield or outside?
            Any pics if you done it yourself?
            I think I need some air through the shield so it can cool down.
              I haven't done anything yet, I'm just trying to apply some cheap physics 😀
              I'd start from the outside and see what happens
                F
                F
                flopp
                @gohan
                Ok, thanks.
                I will try it tomorrow
                • F
                  F
                  flopp
                  #23
                  New code again :frowning:
                  Wind speed: it compare between two interrupts if it is too quick, if more than 100000 micros it will not use it
                  #define WIND_CHILD 0
                  #define TEMP_CHILD 1
                  #define HUM_CHILD 2
                  #define RAIN_CHILD 3
                  MyMessage WSMsg(WIND_CHILD, V_WIND);
                  MyMessage WGMsg(WIND_CHILD, V_GUST);
                  MyMessage WDMsg(WIND_CHILD, V_DIRECTION);
                  MyMessage TempMsg(TEMP_CHILD, V_TEMP);
                  MyMessage HumMsg(HUM_CHILD, V_HUM);
                  MyMessage RainMsg(RAIN_CHILD, V_RAIN);
                  MyMessage RainCounterMsg(RAIN_CHILD,V_VAR1);
                  //Wind Speed
                  volatile unsigned long lastPulse = 0;
                  volatile unsigned long intervalSum;
                  unsigned long lastInterval = 0;
                  unsigned long looptime;
                  float WS = 0;
                  float WG = 0;
                  int WScount = 0;
                  //Wind Direction
                  int WDarray[8] = {0,45,90,135,180,225,270,315};
                  int WD;
                  //Rain
                  volatile float hwRainVolume = 0;   // Current rainvolume calculated in hardware.
                  float bucketSize = 0.4;   // mm per tip
                  boolean pcReceived = false;
                  volatile unsigned long lastSend = 0;
                  // Temperature/Humidity
                  double hum = 0;
                  double temp = 0;
                    Wire.begin();   //start i2c
                    gw.begin(incomingMessage, AUTO, false);
                    gw.sendSketchInfo("WeatherMast", "170427");
                    gw.present(WIND_CHILD, S_WIND);
                    gw.present(TEMP_CHILD, S_TEMP);
                    gw.present(HUM_CHILD, S_HUM);
                    gw.present(RAIN_CHILD, S_RAIN);
                    gw.request(RAIN_CHILD, V_VAR1);
                    gw.wait(5000);
                    //pin 2 is rain, pin 3 is wind speed
                    //pin 4-8, 14-16 is wind direction
                    //configure pin 2-8 as an input and enable the internal pull-up resistor
                    for (int i=2 ; i < 9 ; i++) {
                      pinMode(i, INPUT_PULLUP);
                    //configure pin 14-16(A0-A2) as an input and enable the internal pull-up resistor
                    for (int i=14 ; i < 17 ; i++) {
                    attachInterrupt(0, Rain, FALLING);    //rain
                    attachInterrupt(1, WindSpeed, FALLING);   //wind speed
                    gw.wait(60000);
                    detachInterrupt(1);
                    looptime = micros();
                    readTempHum();    //read temperature and humidity
                    readWindDirection();    //read wind direction
                    resend((WSMsg.set(WS, 1)),3);
                    WS = 0;  //reset wind speed, useful if there is no wind otherwise old value will be sent to Controller
                    resend((WGMsg.set(WG, 1)),3);
                    WG = 0;   //reset gust
                    resend((WDMsg.set(WD, 1)),3);
                    resend((RainMsg.set((float)hwRainVolume,2)),3);
                    resend((TempMsg.set(temp, 1)),3);
                    resend((HumMsg.set(hum, 1)),3);
                    lastPulse += micros() - looptime;
                  void readWindDirection()
                    //check in what direction the wind is. First sensor that have light will be the direction
                    int i = 4;
                    for (i; i < 9 ; i++){
                      if (!digitalRead(i)){
                        WD = WDarray[i-4];
                        return;
                    i = 14;
                    for (i; i < 17 ; i++){
                        WD = WDarray[i-9];
                        return;
                  void Rain()
                    unsigned long currentTime = millis();
                    if (!pcReceived) {
                      Serial.println("Request rainCount");
                      return;
                    if (currentTime - lastSend > 5000) {
                    hwRainVolume = hwRainVolume + bucketSize;
                    resend((RainCounterMsg.set(hwRainVolume,2)),3);
                    lastSend=currentTime;
                  void WindSpeed()
                    detachInterrupt(1);
                    volatile unsigned long newPulse = micros();
                    unsigned long interval = newPulse-lastPulse;
                    if (interval<16000L) { // Sometimes we get wrong interrupt. 16000L = ~30 m/s
                      lastPulse = newPulse;
                      return;
                    long a = interval-lastInterval;
                    a = abs(a);
                    lastInterval = interval;
                    if (a > 100000) {
                      return;
                    else {
                      WS = (0.4775/(interval/1000000.0));
                      if (WS > WG) {
                        WG = WS;
                  void readTempHum()
                    Wire.beginTransmission(0x28);   // Begin transmission with given device on I2C bus
                    Wire.requestFrom(0x28, 4);      // Request 4 bytes
                    if(Wire.available() == 4) {
                      int b1 = Wire.read();
                      int b2 = Wire.read();
                      int b3 = Wire.read();
                      int b4 = Wire.read();
                      Wire.endTransmission();           // End transmission and release I2C bus
                      // combine humidity bytes and calculate humidity
                      int rawHumidity = b1 << 8 | b2;
                      // compound bitwise to get 14 bit measurement first two bits
                      // are status/stall bit (see intro text)
                      rawHumidity =  (rawHumidity &= 0x3FFF);
                      hum = 100.0 / pow(2,14) * rawHumidity;
                      // combine temperature bytes and calculate temperature
                      b4 = (b4 >> 2); // Mask away 2 least significant bits see HYT 221 doc
                      int rawTemperature = b3 << 6 | b4;
                      temp = 165.0 / pow(2,14) * rawTemperature - 40;
                  void incomingMessage(const MyMessage &message)
                    if (message.type==V_VAR1) {
                      hwRainVolume = message.getFloat();
                      pcReceived = true;
                      Serial.print("Received last pulse count from gw: ");
                      Serial.println(hwRainVolume,2);
                  void resend(MyMessage &msg, int repeats)
                    int repeat = 1;
                    int repeatdelay = 0;
                    boolean sendOK = false;
                    while ((sendOK == false) and (repeat < repeats)) {
                      if (gw.send(msg)) {
                        sendOK = true;
                      else {
                        sendOK = false;
                        Serial.print("Error ");
                        Serial.println(repeat);
                        repeatdelay += 500;
                      repeat++; delay(repeatdelay);
                  EDIT: added
                  WS = 0;
                  in loop
                    So, how is the hacking going? :)
                      F
                      F
                      flopp
                      @gohan
                      Thanks for asking :)
                      It is working good, but I don't trust the wind speed. I have lots of "ghost" indications from the reed
                      switch, I tried to remove it with code in two different ways but anyway I get some high values. I will order a wind speed meter and check against that one. I also record a slow-mo video when it spins in front of a fan(2.5m/s) and it is correct but it is difficult to test it with 10 m/s,
                      If anyone are inreseted what's inside the receiver that was included from Fody. It look like this
                      • F
                        F
                        flopp
                        suddenly it stopped sending data, after power-off-power-on it started to work again
                        gohanG 1 Reply Last reply
                          I got an Uno as ethernet gateway with a DHT sensors and sometimes it hangs too after several days
                          • F flopp
                            @flopp I'll need to look at the watchdog timers and see if it may help
                            • F
                              F
                              flopp
                              it stopped working again, this morning. This time it started to work again just after opening Serial monitoring in Arduino IDE
                                That's normal, upon serial connection the Arduino resets. Try adding the watchdog function. You could also try the newer mysensors library that's in the development branch
                                  F
                                  F
                                  flopp
                                  That's something new for me. What is this and how do you add it?
                                  Anyone with a link?
                                    Search "Arduino watchdog examples" lots of stuff comes out
                                      F
                                      F
                                      flopp
                                      #33
                                      thanks :+1:
                                      I did some search and I never heard of this function before.
                                      I will test it in my sketch and see if I get rid of the freezing stuff
                                      • F
                                        F
                                        flopp
                                        I read about watchdog now and as normal way, without extra code, it can check that our code is alive less then 8 seconds.
                                        I want it to send data every 60 seconds so I need to loop watchdog code a couple of times.
                                        I will look at this later
                                        • K
                                          K
                                          karl-ove
                                          Hi Flopp
                                          I bought the Fody some time ago with the intention to connect it via Blue Tooth to a RPI for awnings control. The idea was that all the calibrating then should be handled by the indoor unit.
                                          Whats your opinion about this?
                                          I'm really new to BLE and Python programming and have so far only been able to make a succesful CONNECT. Is there anybody made something similar? Any help would be appreciated
