  3. [SOLVED] Multiple source files & including MySensors.h problem
include mysensors.h
3 Posts 2 Posters 2.5k Views 4 Watching
  • T
    tlustoch
    I am trying to create a sketch with multiple source files (to keep my own classes definitions out of main sketch file), but I am not able to include MySensors.h.
    Lets consider the following GatewayESP8266 example (4 files) for NodeMCU 0.9 board:
    I have the main sketch file GatewayESP8266.ino
    // GatewayESP8266.ino
    #include "myownconfig.h"
    MySensor config file myownconfig.h
    // myownconfig.h
    #ifndef MYOWNCONFIG_H
    #define MYOWNCONFIG_H
    and my test class header and source files test.cpp and test.h
    // test.cpp
    #include "test.h"
    // test.h
    #ifndef TEST_H
    #define TEST_H
    class Test {
       MyMessage &message;
    Compiling (board NodeMCU 0.9) gives a bunch of errors:
    sketch/test.cpp.o: In function `__gdb_do_break': /Users/hynekbaran/Documents/Arduino-ESP/libraries/MySensors/core/MyGatewayTransport.cpp:69: multiple definition of `g_cont' sketch/GatewayESP8266.ino.cpp.o:/Users/hynekbaran/Documents/Arduino-ESP/libraries/MySensors/core/MySensorsCore.h:428: first defined here sketch/test.cpp.o: In function `__gdb_do_break': /Users/hynekbaran/Documents/Arduino-ESP/libraries/MySensors/core/MyGatewayTransport.cpp:69: multiple definition of `_ethernetServer' sketch/GatewayESP8266.ino.cpp.o:/Users/hynekbaran/Documents/Arduino-ESP/libraries/MySensors/core/MySensorsCore.h:428: first defined here sketch/test.cpp.o: In function `hwInit()': /Users/hynekbaran/Documents/Arduino-ESP/libraries/MySensors/core/MyGatewayTransport.cpp:69: multiple definition of `hwInit()' sketch/GatewayESP8266.ino.cpp.o:/Users/hynekbaran/Documents/Arduino-ESP/libraries/MySensors/core/MyHwESP8266.cpp:24: first defined here sketch/test.cpp.o: ... collect2: error: ld returned 1 exit status exit status 1 Error compiling for board NodeMCU 0.9 (ESP-12 Module).
    The same problem appears with ArduinoPro DimmableLigth test project.
    Thanks for help!
    • U
      U
      user2684
      Hi, I think you have a similar issue to mine at https://forum.mysensors.org/topic/6084/including-mysensors-h-in-multiple-files. You don't want to include MySensors.h in the other header files but individual MySensors headers containing the functions you need e.g.
      #include <core/MySensorsCore.h>
      T 1 Reply Last reply
      • U user2684
        tlustoch
        @user2684 Yes, that is the solution. Thanks a lot!
