  3. [SOLVED] How to detect power current with Arduino Pro Mini in a doorbell?
3 Posts 2 Posters 1.4k Views 2 Watching
  • ronnyandreR
    ronnyandreR
    ronnyandre
    wrote on last edited by ronnyandre
    I have a very simple wireless doorbell in my house, and I was thinking of making it notify me when someone rings in Domoticz.
    I have minimal with electronic components, but I do have the basics with resistors, wires, NRF24 etc.
    What I found out, is that when the doorbell button is clicked, it sends a wireless signal to the other unit, containing the speaker. This unit has a LED that lights up when it receives a signal, aka when someone rings the bell.
    I was thinking of connecting the Arduino to this LED, detecting when the LED is turned on. I connected the cathode on the LED to ground on the Pro Mini, and the LED's anode to an analog pin on the Pro Mini. Now I can read values around ~740 in standby mode, and around ~860 when the LED lights up.
    Is this a basic and "fail safe" method to check for power? Or is it varying too much? I want to use the door magnet sensor example to detect the doorbell, but not sure if I should use the Bounce library with analog signals.
    Thanks in advance!
    Newbie with RPi and Domoticz, trying to automate my home.
      You could use the analog input and measure the voltage going to the led: if it goes over a certain value within 0-5v you send the ring to domoticz. If voltage is sufficiently high you can use a digital pin too instead of analog.
      • ronnyandreR
        ronnyandreR
        ronnyandre
        Thanks @gohan it works perfectly using a digital pin and the door sensor example.
