  3. 8Bit or 32Bit processors
86 Posts 11 Posters 37.4k Views 8 Watching
  • tbowmoT tbowmo
    @NeverDie
    There is a "BOSA" compatible bootloader, I have still on my todo list to verify that this is working (will be before makerfaire in Eindhoven, as I have promised to bring the new sensebender micro mk2 with me)
    I have created the sensebender micro mk2, which still needs verification.. (For my part, activity have been low due to other work related projects..)
    Software should be possible in arduino IDE (the core is the same as in atsamd21, which is used by the Sensebender Gateway.. Only difference is that it misses USB interface.
    Nca78N
    Nca78N
    wrote on last edited by Nca78
    #41
    @tbowmo said in 8Bit or 32Bit processors:
    Any reason to use D20 instead of D21 except saving 0.3 - 0.5$ per unit ?
    As the D21G18 is used in Arduino Zero it makes sure there's some stable support for that version.
    @NeverDie you can check that for "pro mini" style board: https://www.sparkfun.com/products/13664
    NeverDieN 1 Reply Last reply
    • tbowmoT
      tbowmoT
      tbowmo
      @Nca78
      It won't incorporate USB anyways, so I do not see a benefit of using D21.. And even 0.5$ could become a lot of money, when we start producing a million sensebender micro mk2 :)
      Nca78N 1 Reply Last reply
      • scalzS
        scalzS
        @NeverDie i'm using atsamd21 with mysensors since last year, no problem too with VS Studio ;)
        • tbowmoT tbowmo
          @Nca78
          Nca78N
          Nca78N
          @Nca78
          Yes yes I'm not talking about the sensebender micro for which saving money for a feature you don't use makes sense. But for small scale production like in my appartment ? :D
          • scalzS
            scalzS
            wrote on last edited by scalz
            #45
            @Nca78
            depends what you need, but what i like with usb (d21) is i just connect the cable and i can program it easily and at same time can have serial monitor (no ftdi needed). You need to burn a bootloader for that by using a swd programmer first.
            or then use the cheaper version, program it through swd, but then need an ftdi for uart
            depends.
            perhaps i should release some design for it, but i think there are already a lot on internet
            • scalzS scalz
              Nca78N
              Nca78N
              @scalz said in 8Bit or 32Bit processors:
              And do you have to put a bootloader on it ? If yes what do you use for programming ?
              • scalzS
                scalzS
                #47
                using d21e, so i burn a bootloader like i said above with a Segger OB j-link, clone i guess. Then you just need usb
                Nca78N alexsh1A 2 Replies Last reply
                • scalzS scalz
                  Nca78N
                  Nca78N
                  Any chance you have a link for purchase of the j-link ? There are a bunch on Ali but you never know what you get.
                  • scalzS
                    scalzS
                    #49
                    those at ali are the same. i bought it at the french Ebay because wasn't patient and the few bucks were worth it :)
                    • Nca78N Nca78
                      NeverDieN
                      NeverDieN
                      #50
                      @Nca78 said in 8Bit or 32Bit processors:
                      Awesome! That greatly lowers the barriers to trying it. I just ordered one from Amazon: https://www.amazon.com/SparkFun-LYSB018RKKRVG-ELECTRNCS-SAMD21-Mini-Breakout/dp/B018RKKRVG/ref=sr_1_1?s=electronics&ie=UTF8&qid=1496436449&sr=1-1&keywords=samd21
                      There's a good chance I'll receive it this Sunday.
                      It looks as though the Adafruit Feather is more or less the same type of SAMD21 board: https://www.amazon.com/Adafruit-Feather-M0-Basic-Proto/dp/B019MGQE8Y/ref=sr_1_6?ie=UTF8&qid=1496437154&sr=8-6&keywords=adafruit+feather
                      • NeverDieN
                        NeverDieN
                        #51
                        Took a closer look at the Sparkfun SAMD21 PCB. It's actually a four layer PCB, not the more ordinary two layer PCB. On the other hand, the Adafruit SAMD21 is a two layer PCB. The four layers explains why the Chinese knock-ffs look different from the Sparkfun version: https://www.aliexpress.com/item/SAMD21-M0-Mini-32-bit-ARM-Cortex-M0-core-Pins-soldered-Compatible-with-Arduino-Zero-Arduino/32779698644.html?spm=2114.01010208.3.10.0u636X&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10130_10068_5010013_10136_10137_10060_10138_10155_10062_437_10154_10056_10055_10054_10059_303_100031_10099_10103_10102_10096_10052_10053_10107_10050_10142_10051_5030014_10084_10083_10119_10080_10082_10081_10178_10110_519_10111_10112_10113_10114_10182_10185_10078_10079_10073_10123_10120_10189_142-10050,searchweb201603_9,ppcSwitch_4&btsid=36be8280-4e44-474b-b3e4-2c9eef009d58&algo_expid=09284286-c141-4a88-bce8-2d8bb9d233d6-1&algo_pvid=09284286-c141-4a88-bce8-2d8bb9d233d6
                        • NeverDieN
                          NeverDieN
                          #52
                          I think it will be important to see how big a minimalist SAMD21 board needs to be while still remaining 2-layer. I'm guessing about half the size of the Adafruit board, since a lot of that board real estate is just prototyping area plus pinouts from the SAMD21.
                          Anyhow, I'm looking forward to not worrying about how many libraries I can load before running out of memory! Even that alone--at least during development--is worth spending some extra money. :)
                          • NeverDieN
                            NeverDieN
                            #53
                            What kind of hardware have people here had success in using for burning a bootloader and changing fuses on a SAMD21? For instance, will I need Atmel's ICE, or do these work just as well:
                            https://www.aliexpress.com/item/1PCS-AVR-JTAG-USB-Emulator-Debugger-download-AVR-JTAG-ICE-Download-Programmer-Atmega/32789255835.html?spm=2114.01010208.3.26.iO9ONh&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10130_10068_5010014_10136_10137_10060_10138_10155_10062_437_10154_10056_10055_10054_10059_303_100031_10099_10103_10102_10096_10052_10053_10107_10050_10142_10051_5030014_10084_10083_10119_10080_10082_10081_10178_10110_519_10111_10112_10113_10114_10182_10185_10078_10079_10073_10123_10120_10189_142-10052_10152_10113_10120,searchweb201603_16,ppcSwitch_4&btsid=f5ac2ded-aae9-478c-a52d-08f2e72cc936&algo_expid=44d9bdb3-4da4-4810-a84b-23ba1337c57b-3&algo_pvid=44d9bdb3-4da4-4810-a84b-23ba1337c57b
                            or https://www.amazon.com/Microcontroller-circuit-Debugger-Programmer-Emulator/dp/B00C7W4IWA/ref=sr_1_2?ie=UTF8&qid=1496575267&sr=8-2&keywords=swd+jtag
                            • scalzS
                              scalzS
                              @NeverDie you need SWD interface for burning a bootloader to them.
                              ST-link v2 should be ok and you can find cheaper clone, no idea for your other link.
                              Otherwise, like i said above, i'm using a Segger Jlink OB like this one http://www.ebay.com/itm/New-J-Link-OB-ARM-Debugger-Programmer-Downloader-replace-v8-SWD/141854905580?_trksid=p2047675.c100623.m-1&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D41375%26meid%3D188c2e52c5484de68b250d6f7dfb4d72%26pid%3D100623%26rk%3D2%26rkt%3D6%26sd%3D400943523132
                              Again you can find them cheaper at aliexpress, on my side i keep the insulating plastic cover in place
                              • NeverDieN
                                NeverDieN
                                #55
                                A bit off topic, but I like what this guy did with putting an OLED onto his SAMD21 board. Not sure where to get them, but they must be cheap, because his whole board costs $15 on Tindie.
                                https://www.tindie.com/products/microwavemont/ultra-zero-a-successor-of-sduino-zero/?pt=full_prod_search
                                gohanG 1 Reply Last reply
                                • NeverDieN NeverDie
                                  @NeverDie don't they have something similar on adafruit?
                                    #57
                                    http://www.ebay.com/itm/0-96-I2C-IIC-SPI-Serial-128X64-White-OLED-LCD-LED-Display-Module-fr-Arduino-NEW-/232314247092
                                    https://www.aliexpress.com/item/Hot-Selling-0-96-inch-128X64-Blue-OLED-Display-128-64-LCD-Screen-Board-30pin-SSD1306/32806209969.html
                                      NeverDieN
                                      NeverDieN
                                      #58
                                      @gohan
                                      This is the most "similar" one I've found on Adafruit:
                                      https://www.adafruit.com/product/2900
                                      That and the one that mfalkvidd just posted look a lot bigger to me.
                                        well it is similar :D
                                        maybe I confused another one that has a different processor, I remember they had one with a small LCD and processor together
                                          The Adafruit one is 128x32. From the picture, it looks to be about twice the width of the one on the tindie board. So maybe it is 64x32? Like this one
                                          https://www.aliexpress.com/item/White-0-49-inch-OLED-Display-Module-64x32-0-49-Screen-IIC-for-Arduino-AVR-STM32/32779893498.html
