  3. OpenHAB
  4. Can't link rfid node item
13 Posts 3 Posters 5.1k Views 3 Watching
  • ben999B
    ben999B
    ben999
    wrote on last edited by ben999
    Hi guys,
    I am having trouble linking an RFID node. So i thought i would pop down here to tikkle the software guys :smiling_imp:
    Here is my setup:
    Raspberry 3 + nRF24 as controller, running openhabian
    Arduino nano + nRF24 + RC532 + relays + "basic" sketch as per https://www.mysensors.org/build/rfid
    Gateway works fine with other nodes (motion, temp and hum)
    Node works fine, relay opens and closes when presented to the right rfid tag.
    I use PaperUi to discover nodes. Works like a charm :)
    I managed to link "last update" and "battery level" items . Both items were then included within .item and .sitemap files and showed-up nicely in Paper UI as well as in iOS app.
    But I got an error when linking "lock" item : error message at the bottom right hand corner of Paper UI
    Here is what i get when logged into Karaf console:
    16:20:33.171 [WARN ] [thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at 'items/MySensorsDevice21_Lock' with an invalid item type 'Status'.
    Does it make any sense to you?
    "lock" item returns a status right?
    Child ID for that piece of kit is always "99" in sketches i have come accross... does it matter? (I have tried and didn't make a change in that particular case... will it matter later on? Is it like "battery level" that has to be 255?)
    Thanks for your help
    Regards
    Ben
    • pansenP
      pansenP
      pansen
      The ID shouldn't matter..
      What is the lock item? Showing the status of the lock?
      Interesting that those get added to your files, for me the items that I add through Paper UI are not reflected in the folder structure, which is quite annoying...
      Checking https://www.mysensors.org/controller and https://www.mysensors.org/download/serial_api_20 it looks like the lock stuff should be fully supported by OH, weird. Did you ask in their forums? It's superactive actually...
      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
      • ben999B
        ben999B
        ben999
        Hi @pansen
        Thanks a lot for your reply. Ok for ID number.
        Yes lock item is supposed to show status of the rfid lock device.
        Here is the way it works for me :
        • discovery of node via Paper UI
        • i then "link" every relevant item of that node within PaperUI
        • include these items in "home.items", "home.sitemap" and rules (as text files with editor, old fashioned way)
        My item file
        Contact salonMotion01 "Présence Salon" <motion2> (gMotion,gSalon) { channel="mysensors:motion:65885f11:Motion_1_1:tripped" }
        Number salonBatt01 "Batterie [%.1f %%]" <battery> (gBattery,gSalon) { channel="mysensors:motion:65885f11:Motion_1_1:battery" }
        DateTime salonUpdate01 "Dernière MAJ: [%1$ta %1$tR]" <calendar> (gUpdate,gSalon) {channel="mysensors:motion:65885f11:Motion_1_1:lastupdate" }
        Switch activateAlarm "Alarme activée" <switch>
        Contact hallLock01 "Verrou entrée" <door> (gLock,gHall) {channel="mysensors:lock:65885f11:Lock_2_99:lock" }
        DateTime hallUpdate01 "Dernière MAJ: [%1$ta %1$tR]" <calendar> (gUpdate,gHall) { channel="mysensors:lock:65885f11:Lock_2_99:lastupdate" }
        and sitemap file (for iOS)
        sitemap home label="Cheny" {
                Switch item=activateAlarm
                Frame label="Premier étage" {
                        Text label="Palier" icon="office" {
                                Text item=salonBatt01
                                Text item=salonMotion01
                                Text item=salonUpdate01
        Hope i got your question right...
        Thanks for links. Yes it does say that openhab fully support the "lock" device...
        I will have a go on openhab forum and report back here if success...
        Thank you again
        Best Regards
        Ben
        • ben999B
          ben999B
          ben999
          Hi
          I found this... :
          https://github.com/eclipse/smarthome/pull/2033/commits/008b4871ef308ae67400fe039e51e104fa061d83
          But what can i do with that?
          Seems to me that the file in question is some kind of install file that doesn't exist on my gateway as it is, right?
          T 1 Reply Last reply
          • ben999B ben999
            Hi
            I found this... :
            TimO
            Hi @ben999 !
            The fix you've mentioned was already merged into ESH and because of the date (23. Aug 2016) I'm pretty sure it is already merged into OpenHAB. So I suppose we need to search somewhere else.
            Please dump the complete log (in DEBUG mode) of the karaf console starting from the presentation messages arriving at the gateway till the message in your first post. I'll then try to reproduce the behaviour.
            Greetings
            Tim
            ben999B 1 Reply Last reply
            • T TimO
              Hi @ben999 !
              Greetings
              Tim
              ben999B
              ben999B
              ben999
              Hi @TimO
              My digital Knight coming (once again) to save me :blush:
              I logged into karaf (mysensors debug).
              That is when powering my rfid node (nano 328+nRF+RC532+relays)
              21:37:09.617 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              21:37:19.543 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;0;0;17;2.1.1
              21:37:19.566 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2017-05-09T21:37:19.554+0200
              21:37:19.567 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;6;0
              21:37:19.570 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - I_CONFIG request received from M, answering: (is imperial?)false
              21:37:19.573 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 2;255;3;0;6;M
              21:37:19.589 [INFO ] [marthome.event.ItemStateChangedEvent] - MySensorsDevice21_LastUpdate changed from NULL to 2017-05-09T21:37:19.554+0200
              21:37:19.595 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;11;RFID Lock
              21:37:19.609 [INFO ] [marthome.event.ItemStateChangedEvent] - hallUpdate01 changed from NULL to 2017-05-09T21:37:19.554+0200
              21:37:19.618 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              21:37:19.627 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;12;07.05.2017
              21:37:19.629 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;1;0;0;19;
              21:37:22.698 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;1;1;0;36;0
              21:37:29.619 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              That is when playing with a valid tag :
              21:37:49.622 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              21:37:58.475 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;1;1;0;36;1
              21:37:59.624 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              21:38:02.988 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;1;1;0;36;0
              21:38:09.625 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              And this is when i am in paperUI trying to link the "lock" item:
              21:38:49.631 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              21:38:59.360 [WARN ] [thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at 'items/MySensorsDevice21_Lock' with an invalid item type 'Status'.
              21:38:59.633 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              And lastly this is when i "unlink" the "lastupdate" item and link it again. Dunno if relevant...
              21:45:09.706 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              21:45:14.418 [INFO ] [smarthome.event.ItemRemovedEvent    ] - Item 'MySensorsDevice21_LastUpdate' has been removed.
              21:45:19.708 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              21:45:39.711 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              21:45:41.713 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'MySensorsDevice21_LastUpdate' has been added.
              21:45:42.396 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'MySensorsDevice21_LastUpdate-mysensors:lock:65885f11:Lock_2_1:lastupdate' has been added.
              21:45:49.713 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
              Once again, thanks a lot Tim for taking the time to look at that :)
              • ben999B ben999
                Hi @TimO
                TimO
                Hey @ben999 !
                Thanks for reporting and your patience!
                There was a bug in the binding. Please update your binding via IoT Marketplace or by replacing the jar with THIS version.
                • T TimO
                  Hey @ben999 !
                  ben999B
                  ben999B
                  ben999
                  @TimO
                  Smashing !!! You're an ace!
                  How did you manage to spot the bug? Was it just applying to "Lock"?
                  Anyway thank you very very much
                  • ben999B ben999
                    @TimO
                    TimO
                    @ben999
                    It was a bug in the description of the lock thing. You seem to be the first one that is using this thing type. ;-)
                    Here is the commit, I only had to change one word.
                    It was easy to spot with your help!
                    ben999B 2 Replies Last reply
                    • T TimO
                      @ben999
                      ben999B
                      ben999B
                      ben999
                      @TimO
                      Great job, thanks again :smiley:
                      I'm sure we all have weird setups :stuck_out_tongue_winking_eye:
                      • T TimO
                        @ben999
                        ben999B
                        ben999B
                        ben999
                        @TimO
                        Dude, it's awesome :)
                        I even get a slider in paperUI to control the lock as well !!!
                        BUT... (there's alway's a "but")
                        Auto-discovery doesn't work anymore :cry:
                        Here is what i get from Karaf when clicking on "refresh" (in Inbox > MySensors Binding > Search )
                        21:50:27.220 [DEBUG] [.discovery.MySensorsDiscoveryService] - Stopping MySensors discovery scan
                        21:50:27.227 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                        No more hourglass... no searching...
                        Doc, i think we've lost it...
                        • ben999B ben999
                          @TimO
                          TimO
                          @ben999 :D
                          Well thank you again! That's an old bug and was totally overdue.
                          An internal cache that was only cleaned up on a restart of the binding was preventing a (re)discovery after a removal.
                          https://github.com/tobof/openhab2-addons/issues/39
                          • T TimO
                            @ben999 :D
                            ben999B
                            ben999B
                            ben999
                            @TimO
                            Thanks a lot :)
                            Having grown-up together with Windows got me used to reboot many time a day :laughing:
                            I think i did reboot a few times last night but not sure about the timing though... might have done so for other reasons. I just gave up on discovery and went on with "manual mode"
                            I will check tonight.
                            Thanks @TimO for looking after us so well ;)
