  3. DHT22 - switched sensor types?
5 Posts 3 Posters 1.8k Views 3 Watching
  • simonszuS
    simonszuS
    simonszu
    i am trying to set up a DHT22 node. This is my first step with mysensors ever. After figuring out some hardware issues, all connection is working, at least for a distance of around 1 meters.
    However, i'd like to ask how big can a temperature offset of a DHT22 sensor be? I have a room temperature of around 22°C, however, this sensor shows around 28°C - and a humiditiy of 23%. So, either the measurement tolerance is quite big, or i have somehow switched both readings.
    This is the code i have flashed on the node: https://pastebin.com/E2XWu3F3
    And this is how it appears in Home Assistant: https://pastebin.com/rLWn91ws
    Is my code correct? I think i have some weird errors, e.g. only increasing temperature is registered, when decreasing temperature, the value isn't decreasing as well.
    Boots33B 1 Reply Last reply
    • simonszuS simonszu
      Boots33B
      Boots33B
      Boots33
      wrote on last edited by Boots33
      @simonszu Looks like you have the temp and humidity swapped around in the send message part
      here is a direct copy of your sketch. you are sending the temperature in the humidity message and humidity in the temp message
        send(msgHum.set(temperature, 1));    // this should be humidity
        #ifdef My_DEBUG
        Serial.print("T: ")
        Serial.println(temperature);
        send(msgTemp.set(humidity, 1));   // this should be temperature
      • simonszuS
        simonszuS
        simonszu
        Ah. Yeah. Thanks. Sometimes one can be really blind when debugging own code. :D
          Boots33B
          Boots33B
          Boots33
          @simonszu Yes I know the feeling well !! Hope it all works as expected now
            dht sensors are not very accurate anyway 😅
