  3. 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors
mysensoreasynewbiepcbmysx
106 Posts 20 Posters 56.8k Views 19 Watching
    mickecarlsson
    I have just finished soldering my last four easypcb with BME280:
    • M mickecarlsson
      @mickecarlsson - Woao - looks great!
      If you do that many with Ic2 i can understand you want extra area to be extended ;) I will think about it or maybe I can do a MysX daugherboard to you instead.
      Can I use your pic as a good example on the openhardware page?
      gohanG 1 Reply Last reply
        mickecarlsson
        Yes, you can use the pictures. If you need better pictues I can provide it to you.
        • sundberg84S sundberg84
          @sundberg84 are you going to test the SPI Flash with FOTA? at least to get an idea of the compatible chips that can be used.
            #65
            @gohan that was my plan. What is your thought s about this ? I have never used fota or spi flash.
            I'm not a software guy though... I can test hardware.
              The hardest part of fota is to wire the spi flash, the rest it is quite easy once you have the mycontroller installed. I can help you out if you want
                Everything is going fine so im taking this to the next level... from test to produktion.
                This sensor might be my most important summer sensor from now on ;)
                A couple of days ago I had some friends over which gave me a beer cooler, garden edition.
                Its pretty much a barrel in the ground which cools the beer down... (a bit atleast).
                I must say Im very impressed with the RFM69 so far... except the price, there has been no trouble at all. No repeaters, no capacitors, no fine tuning... nothing. Pretty much solder 'n' play!
                This node is burried in the far end on the garden (25m) and has to penetrate 3 concrete + 1brick wall to reach the GW in the celler... no problems, first try and bang!
                So far... the temperature in the cooler isnt very impressive, and I have only tried the first layer. I was afraid I would loose radio coverage if I put the sensors far down... but I will try.
                Cheers mates!
                Mr_sensor
                @sundberg84 said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
                Cheers mates!
                Hi, nice set-up. I have been reading this and havong a "newbie" question. I have a Newbie PCB build with the Nrf24l01+ which seems to give (me) a poor range.
                So would that improve having a rfm69 instead? Or will just adding an antenna improve the reach (I have more or less the same outside distance and concrete wall/ flooring I'd liek to cross). Now I just have a reach for approx 8 meters and one concrete floor (inside the house)? Which is not very good (even my z-wave devices are preforming much better - outside at 20 mtr from the house.
                Can the nrf240 be improved or do I need teh rfm69 (or even using a LORA ?).
                  wrote on last edited by gohan
                  #68
                  I would get better quality nrf24 modules and using a PA LNA one on the gateway may also help. Sure the rfm69 at 433MHz can have a better wall penetration, but I think you can do with better radios. Look for CDEByte store on aliexpress, they have good radio modules. Also a poor quality power supply can reduce the effective range.
                  If you want to try the RFM69 radios, you can "convert" the ones you have with this https://www.mysensors.org/hardware/nrf2rfm69
                  M 1 Reply Last reply
                    Mr_sensor
                    @gohan said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
                    So these would be better?
                    https://nl.aliexpress.com/item/E01-ML01DP5-Ebyte-2-4GHz-20dBm-2100m-nRF24L01-SPI-Wireless-transceiver-module/32638720689.html?spm=a2g0s.13010208.99999999.336.T3AfNk
                    https://nl.aliexpress.com/item/CDEBYTE-2PCS-Lot-E01-ML01D-Wireless-Transceiver-For-Arduino-nRF24L01-2-4GHz-Antenna-Module-For-Microcontroll/32803704874.html?spm=a2g0s.13010208.99999999.333.T3AfNk
                    https://nl.aliexpress.com/item/CDEBYTE-2PCS-Lot-Special-promotions-1800-meter-long-distance-nRF24L01-PA-LNA-wireless-modules-with-PCB/32803720600.html?spm=a2g0s.13010208.99999999.330.T3AfNk
                    If I use one with PA_LNA on my Gateway are the pin-out the same as for the nrf24l+ as in the mysensors gatweay example?
                    Also there are models with nrf24l+PA what is the difference with the nrf24l+ ones?
                      Yes those. Pa stands for power amplifier, lna stands for low noise amplifier and it is used to amplify incoming signal to boost low signals. For gateway it is better to use these with the higher gain antenna, on the node it is up to you according to the size constraints you may have.
                      • M Mr_sensor
                        #71
                        @mr_sensor I have the same experience. A good gateway radio is important. I also use a amplified version. Sometimes it has been poor radio clones that make the bad range as well. Even if you don't have a amplified radio 8m+ 1 wall should be possible.
                          Mr_sensor
                          @sundberg84 @gohan Ok thanks for the input I will order some of the extended ones :) and see if thing s will improve.
                          • M Mr_sensor
                            Mr_sensor
                            @mr_sensor said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
                            The parts mentioned above arrived. I thought just swapping the radio's and see if there is any improvement. But it seems my devices are not happy with there new radio :) ? So are these new devices coming with the same pin-out and are they using the same library as the non amplified radio"s ? Or do I need to alter my sketches or wiring for it to work?
                            • M Mr_sensor
                              #74
                              @mr_sensor i think it should be the same pin out. Gohan might now better on the amplified version. As I said I don't use those much.
                              What kind of error do you have now?
                                they both work fine for me, just define in code wether is HW version
                                  Mr_sensor
                                  wrote on last edited by Mr_sensor
                                  #76
                                  @gohan Ok, what do you mean by "define HW" in code" ? This in my code:
                                    but this is RFM69 radio pcb not NRF24
                                      Mr_sensor
                                      I know but I am using the nrf24 pcb.
                                      Do I need to add something like this when using the AP version?
                                      Or just #define MY_RADIO_NRF24
                                      • M Mr_sensor
                                        @mr_sensor correct. As I said I'm no expert with the amplified version but that looks ok. I suggest you try it out. If it's wrong you will get an error and you can post that .
                                          You should be able to swap a regular nrf24 with a PA version without changing code, given you have a stable 3.3v supply that can handle extra power
