  3. 💬 LoRa Ra-01 ATmega328P Node
15 Posts 6 Posters 6.1k Views 5 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/395/LoRa-Ra-01-ATmega328P-Node
    • NeverDieN
      NeverDieN
      I just now posted the files for Version 2.
      • NeverDieN
        NeverDieN
        I just now posted the files for Version 3, which allows for an 0805 cap across the Ra-01's 3v3 and GND pads. I just now sent Version 3 to the PCB fabricator.
        • NeverDieN
          NeverDieN
          Project completed. It works.
          It runs the RadioHead RH95 library and examples without any need for modification. :)
          • miljumeM
            miljumeM
            miljume
            Nice work! Any chance you can post some code samples to interact with MySensors gateway?
            NeverDieN 1 Reply Last reply
            • miljumeM miljume
              NeverDieN
              NeverDieN
              @miljume
              Not anytime soon. Probably better if someone else did.
              • pansenP
                pansenP
                pansen
                Out of curiousity: Why did you use a through-hole AVR and not a SMD one?
                Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                • pansenP pansen
                  NeverDieN
                  NeverDieN
                  @pansen
                  Easier/faster to solder.
                  pansenP 1 Reply Last reply
                  • NeverDieN NeverDie
                    @pansen
                    pansenP
                    pansenP
                    pansen
                    @NeverDie
                    I understand but tend to disagree ;)
                    • nitroburnN
                      nitroburnN
                      nitroburn
                      any ideal value for the radio decoupling cap? It is the only thing I don't see listed.
                      • nitroburnN nitroburn
                        NeverDieN
                        NeverDieN
                        @nitroburn said in 💬 LoRa Ra-01 ATmega328P Node:
                        I'm not sure that it's even needed. I added pads for it in case it might later prove necessary or beneficial, but for now it's optional (unless/until proven otherwise).
                        • giridhararmG
                          giridhararmG
                          giridhararm
                          Is it working ? How to upload sketch using FTDI right
                          • giridhararmG
                            giridhararmG
                            giridhararm
                            Is it working can I use FTDI to post rfm libraries
                            • giridhararmG giridhararm
                              NeverDieN
                              NeverDieN
                              @giridhararm yes
                              • NeverDieN
                                NeverDieN
                                Starting with MySensors Release 2.1.1, it appears this module is now supported by MySensors:
                                "New transport layer: RFM95 (LoRa mode)"
