  3. nRF5 action!
nRF5 action!
    Mike_Lemo
    you should follow this schematic design if you want to get this module working.
    NeverDieN 1 Reply Last reply
    • M Mike_Lemo
      @NeverDie
      Oh yeah and forgot to mention I used the generic NRF52 settings.
      d00616D
      d00616D
      d00616
      @Mike_Lemo said in nRF5 Bluetooth action!:
      The "generic" settings haven't a good pin assignment. Pins P0.00 and P0.01 are reserved for the 32KHz crystal and defined as TX/RX pins. That's an conflict.
      • d00616D d00616
        NeverDieN
        NeverDieN
        What should we use instead?
        • d00616D
          d00616D
          d00616
          @NeverDie The "Taida Century nRF52 minidev" has a lot of pins mapped out:
          https://github.com/RIOT-OS/RIOT/wiki/Board%3A-nRF52-minidev you can select the programmer like your needs. The RedBear BLE Blend 2 has also a lot of pins mapped out, but the CMSIS-DAP is preselected.
          M 1 Reply Last reply
          • d00616D d00616
            Mike_Lemo
            @d00616 It says there NFC is not useable but what if my board is NFC hardware ready? how would I use that?
            • d00616D
              d00616D
              d00616
              It's simple. Use that. NFC isn't enabled or disabled by the board definition. Without SoftDevice, you have to enable the NFC functionality by flashing into the UICR.
              You can define your own Board. Look into the "boards.txt" file and the "variants" folder in ~/.arduino15/packages/sandeepmistry/hardware/nRF5/0.3.0/ Most pins can be assigned to roles like SPI, I2C, UART.... Pins like NFC, RESET are fixed and analog Pins an be ordered like your needs.
              • NeverDieN NeverDie
                I'm tring to blink an led on a PCB I made not realy knowing how to program the IC before other than connection the SWD pins.
                I've followed the startup guide at github flashed the soft device probably successful using the ST link V2(while flashing the soft device it blinked the on board st link V2 led and at the end the blue led on my PCB stopped being on.)
                So I've got an RGB led connected to my PCB to pins:
                #define RGBL_RED_PIN P0.16
                #define RGBL_GREEN_PIN P0.15
                #define RGBL_BLUE_PIN P0.17
                now for a test to see if I got it right I want to blink each of them how would I do it?
                What is the arduino pin mapping?
                Isn't the arduino mapping generally handled by the boards.txt file? Which board that you're using are you telling the compiler that it is? i.e. which board under the board manager in the Arduino IDE are you selecting?
                Mike_Lemo
                @NeverDie where can that boards.txt file of the NRF52 thing be found?
                • d00616D d00616
                  Mike_Lemo
                  @d00616 I meant is there a library or something for that? how do I approach it I'm relatively new for this 3rd party arduino programming thing and I'ts necessary for me sins I already made a PCB for a micro controller I want to use.
                  • M Mike_Lemo
                    NeverDieN
                    NeverDieN
                    On the Windows platform it's located in this directory: Program Files/Arduino/hardware/arduino/avr
                      Mike_Lemo
                      @NeverDie I can't see the Generic nrf52 board setting
                      • NeverDieN
                        NeverDieN
                        #291
                        I added the two caps that Scalz suggested for DEC1 and DEC2, but I'm still getting the same error message as before when I try to program it using the DK. Unless someone has further ideas, I may have to wait two weeks for my breakout board to arrive before I do more, as right now I'm just deadbugging this by soldering wires directly to the module.
                        • M Mike_Lemo
                          NeverDieN
                          NeverDieN
                          #292
                          That's all I know, so hopefully someone who knows more can chime in and offer you guidance.
                          • NeverDieN
                            NeverDieN
                            BTW, here's a picture of how the silkscreen looks and which shows DEC1 in the "DEC5" location:
                              NeverDieN
                              NeverDieN
                              #294
                              Oh, I see now that @d00616 already has. Sorry, my browser didn't refresh, so I missed seeing his post.
                                Mike_Lemo
                                Yeah he did I just preformed a local search for that arduino15 on my PC
                                  Mike_Lemo
                                  Also If I want to change the UART pins to other pins would it work without errors or If I want to use 2 or more UARTS? same with I2C
                                  Also what are the debugging options available sins the RS232 is not connected to the MCU like in an arduino how would I set stop points or peek at variables values to see if the code runs as expected?
                                  d00616D 1 Reply Last reply
                                  • M Mike_Lemo
                                    NeverDieN
                                    NeverDieN
                                    #297
                                    There's a bunch of similar looking schematics in the nRF52832 datasheet for the nRF52832 chip itself, but I'm not sure which of them, if any, is applicable to the Ebyte module. I guess maybe Ebyte needs a demo board schematic like Raytac has. Either that, or we need a schematic of what's on the Ebyte module itself. As it stands, I think maybe there's no enough info with which to move ahead on wiring up the Ebyte module. Am I wrong? Come to think of it, I think some of the other Chinese modules I ordered from Aliexpress may also be similar "mystery" modules. :(
                                    • M Mike_Lemo
                                      d00616D
                                      d00616D
                                      d00616
                                      The Chip has a lot of periphery on it. You can connect most components to pins. There is only one hardware UART, which can be connected. Please look at the Infocenter The arduino-nrf5 port is limited to things are implemented with arduino-samd by the author. This is the reason I have implemented an extension for hwPinMode() in MySensors.
                                      Another fine thing is the implementation of Shortcuts and the PPI. You can do a lot without using the CPU.
                                      Debugging depends on your programmer and flashing tool. I think you can start by search for "openocd gdb". OpenOCD is the flashing tool in arduino-nrf5 for all supported programmers.
                                      • NeverDieN
                                        NeverDieN
                                        #299
                                        It looks as though raytec does make two modules for the nRF52832 that has a PCB antenna rather than a chip antenna: the MDBT42Q-P and the MDBT-42V-P:
                                        http://statics3.seeedstudio.com/assets/file/bazaar/product/MDBT42Q-Version_B.pdf
                                        The MDBT-42V-P looks nice because of its small size. Anyone know where it can be purchased? All of a sudden, buying a module that comes with a proper datasheet seems appealing.
                                          Mike_Lemo
                                          @NeverDie I had mine from seeed studio
