  3. nRF5 action!
nRF5 action!
  • Nca78N Nca78
    @NeverDie it would also make sense to make at least the "basic" decoupling capacitors/pullups/...
    @Nca78
    You're right. So, I think this will probably be it then: 0_1496760742368_Schematic_for_SAMD21_TQFP32_Pro_Mini _v003.pdf
    It's the guts of the sparkfun design, but with just one LED, and minus the usb, and with a 4 pin SWD connection, and the easiest possible mapping of chip pins to external pins.
    What do you think?
      On the other hand, at least during development, it seems a shame to lose the USB connection. I suppose maybe (?) the USB could be pumped through some kind of external 5v to 3.3v level shifter, and then I wouldn't need to put voltage converters on the board itself. It wouldn't any longer meet the official USB spec, but maybe it would work just the same. That in turn would help reduce the size and costs. Never tried that before with USB though, so it's an unknown to me as to whether it would work or not.
        I can probably make it a bit more compact, but without the USB, this will be the approximate shape of it: 0_1496774768997_SAMD21_TQFP32_Breakout_v003.pdf
          The whole thing is less than one square inch in size, so I went ahead and ordered the non-usb version from osh-park:
          The silkscreen could be better, but it's good enough to test whether or not it's going to fly.
          It appears there's plenty of space at the bottom for adding a USB connector, so I guess that will be next....
            I don't see any decoupling capacitors or ferrite beads on the USB data circuit. According to the schematic ( https://cdn.sparkfun.com/datasheets/Dev/Arduino/Boards/sparkfun-samd21-mini-breakout-v10.pdf), USB_D- and USB_D+ just connect directly to pins PA24 and PA25 on the MCU.
            Nca78N 1 Reply Last reply
              What size pads are you guys using for your SAMD21 land pattern? Mine don't look right. The SAMD21 datasheet didn't actually give a land pattern. It just gave the size of the legs, and so I just made up a land pattern that was close to that. Looks too small compared to others that I'm seeing (e.g. on the Hackaday).
                @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
                Nevermind. I found the answer on page 10 of http://www.atmel.com/Images/Atmel-8826-SEEPROM-PCB-Mounting-Guidelines-Surface-Mount-Packages-ApplicationNote.pdf
                  I saw that on the Adafruit board I think, and on the SenseBender gateway.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    you should not add decoupling /ferite beads to the D+/D- lines.. At most, add a protection resistor of 30R (or there about) inline, to limit current flow. Also you can add a USB protection circuit with diodes externally..
                    The ferite bead / capacitors on the sensebender, is between the cable shield, and gnd on the device, to limit EMI on the cable shielding..
                      Just realizing that if I'm going to hand patch the 4 SWD wires onto the board anyway, then I really don't need an SWD block. Consequently, I'm now thinking the Hackaday guy had the right idea with making his entire node the width of a USB connector:
                      TerrenceT NeverDieN 2 Replies Last reply
                        TerrenceT
                        TerrenceT
                        Terrence
                        @NeverDie >> I'm now thinking the Hackaday guy had the right idea with making his entire node the width of a USB connector:
                        Really good idea. Just plug it into your box.
                        • TerrenceT Terrence
                          @Terrence
                          Yes, and by making the node the width of a USB connector, there's no wasted PCB that you'd get if the PCB were wider.
                          TerrenceT 1 Reply Last reply
                            @Terrence
                            TerrenceT
                            TerrenceT
                            Terrence
                            @NeverDie Event though there seem to be many benefits to going narrow, what about enclosure sizes, where longer may not be as good as a smaller square?
                              #24
                              I'll cross that bridge if I come to it. :)
                              Meanwhile, what I'm wondering is: just how wide should the PCB be? I tried looking up USB dimensions, but I get conflicting info:
                              alt textalt textalt text
                              I also tried measuring some with a micrometer. I think it's going to be something around 12mm. My PCB needs to be a minimum of 12.12mm wide in order to avoid pads of the SAMD21 being too close to the edge of the PCB. Is that too wide, or is it within tolerance?
                                Maybe you can file the pcb near the usb connector if it is too wide 😀
                                  #26
                                  i saw this board too, it's nice one ;) and we can see there is nothing for usb... no fuse, no esd protection, and you touch it and play with it when it's plugged.
                                  I know this works like this, i did it too for proto. i think maybe computers usb ports are perhaps better protected now, but who knows what can happen, so on my side i prefer to have some basic security to not fry my usb ports :grimacing:
                                  If you're doing a proto, this pcb size should be ok, but if it's for using with a radio, especially RFM, then the radio module is wider than the board. I know it because i made my atsam RFM dongle for serial gw.
                                  Last advice if i can :), it's a good practice, to route usb datalines in a // way, and like differential lines, meaning they should be almost the same length (with a few % error). That will work sure, without too much care on a small board like that, but still good to know. you should have a tool in your CAD software for this.
                                  • scalzS scalz
                                    #27
                                    @scalz said in Minimalist SAMD21 TQFP32 Pro Mini:
                                    Good point. That might make connecting it a bit difficult! I suppose this form factor is a better match for a surface mount NRF24.
                                      #28
                                      I notice that the Hackaday guy's labeling of D- and D+ as pins 28 and 29 conflicts with what Sparkfun has. Sparkfun has those as pins PA24 and PA25 respectively. Is he wrong? I know from direct experience that the Sparkfun board works, so for now I'm going with the Sparkfun pin mapping.
                                      I hear that the PIC MCU chips have a switching fabric that allows you to map any logical pin to any physical pin. I wish the Atmel chips had that. Do maybe these ARM chips have some of that as well?
                                        #29
                                        yes it depends what ARM mcu you use, some have more freedom regarding pin mapping and peripherals, but atsam can do that too. Very useful.
                                        There are some rules for atsam how to change the mapping for spi or other periph, versus arduino core files and datasheet. But if you don't want to dig in that, you can just follow a mapping from a board which already exists in Board manager.
                                          I finished the first pass, and it looks as though everything will fit:
                                          A bit more work to do, but this is the approximate form it would take.
