  3. nRF5 action!
nRF5 action!
  • NeverDieN NeverDie
    @scalz
    Thanks for the explanation. I had been programming it as a "Generic nRF82832," and I don't know what that mapping is. However, I can just as easily pick one of the alternatives you listed, such as the D.K, to get a predictable pin mapping.
    @d00616
    Your idea of having the pin mapping be selectable within the sketch sounds great! A+. I'm really looking forward to that and hope that you can do it soon. It sounds much easier for noobs like me than having to futz about with finding/changing/installing other files, and maybe also making it easier to share with and/or borrow from other makers.
    d00616D
    d00616D
    d00616
    With merging this pull request the feature should be available: https://github.com/mysensors/ArduinoBoards/pull/13
    Documentation can be found at https://github.com/mysensors/ArduinoHwNRF5
    d00616D 1 Reply Last reply
    • d00616D d00616
      d00616D
      d00616D
      d00616
      Merged. Have fun with board definition in your sketch.
      NeverDieN 1 Reply Last reply
        In lieu of my breakout board, which hasn't yet arrived, I've been attaching wires directly to the module so that I can do more than just sit and wait for the BoB delivery. I'm now doing it this way:
        and although crude it's working much better than just soldering the wire to the module with no mechanical support. Doing it the way pictured, the connections stay connected and don't break loose. :) Ironically, by the time my breakout boards finally do arrive, I may have already learned everything I needed them for.
        I am curious: how are the rest of you handling this issue?
        [Edit: One other alternative: once my 1.27mm pitch generic protoboards arrive, I expect they'll offer up cleaner connection possibilities. At the moment, I'm also waiting for them to arrive from Aliexpress....]
        Nca78N
        Nca78N
        Not many solutions, I soldered wires directly to the modules too, I used thin&cheap wires from aliexpress. They are very convenient for this, easy to solder and very soft so not having any constraint on the solder joints when you manipulate them. Then I put module on the side of board with double sided tape and soldered other ends of the wires to a connector.
        Then I flip everything and only look at the beautiful side of things :D
        • d00616D d00616
          NeverDieN
          NeverDieN
          #404
          Thanks! By being "merged," does that mean it is now in the regular MySensors development release, and so I should reload a fresh copy of the MySensors development library?
          Also, is this the way I should enable P0.21 as nReset (to enable hardware resets on P0.21), or should I instead be writing 0xFFFF directly to both the PSELRESET[0] and PSELRESET[1] registers to enable that?
          mfalkviddM d00616D 2 Replies Last reply
            This post is deleted!
              d00616D
              d00616D
              d00616
              The Board definition is independed from MySensors core living at https://github.com/mysensors/ArduinoBoards You have to follow the instructions, then you can install the MySensors nRF5 Boards via Arduino Board Manager.
              Look into the Tools menu. For nRF52 MCU is a "Reset" menu. Switch it to "Enable"
              • d00616D d00616
                NeverDieN
                NeverDieN
                #407
                @d00616
                I got the pin mapping to work, but setting reset enable through the tool menu seems to have no effect. I subsequently drive P0.21 low (all the way to GND even), but no reset happens. Am I doing it wrong? Anyone gotten it to work?
                  @d00616
                  NeverDieN
                  NeverDieN
                  #408
                  @NeverDie
                  I also tried adding a 10K pullup resistor, and no change.
                  At the moment I'm unfamiliar with the nRF52 API. What would the code be to set both those reset registers to 0xFFFF? That by itself should enable the reset on P0.21. I could try inserting it into the demo script and see if reset then works.
                  • NeverDieN
                    NeverDieN
                    #409
                    I guess it wouldn't be that simple, because I just now read that it requires a system reset after writing to those registers: https://devzone.nordicsemi.com/question/157603/can-i-enable-and-disable-nrf52832-reset-pin-when-code-is-running/ for it to take effect.
                      By switching to a Windows 10 computer, I was able to get J-link working over USB from windows. Then I opened up J-Link Command, which mostly utiizes a command line interface. It turns out that for unlocking, the nRF52836 is not on the list of devices (see below), so I simply then issued a mass erase command, which looks as though it may have worked:
                      J-Link>unlock
                      Syntax: unlock <DeviceName>
                      ---Supported devices---
                        LM3Sxxx [<Auto>]
                        Kinetis
                        EFM32Gxxx
                        LPC5460x
                      J-Link>erase
                      Erasing device (nRF52832_xxAA)...
                      J-Link: Flash download: Total time needed: 0.336s (Prepare: 0.064s, Compare: 0.000s, Erase: 0.263s, Program: 0.000s, Verify: 0.000s, Restore: 0.008s)
                      Erasing done.
                      J-Link>mem 0 100
                      00000000 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      00000010 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      00000020 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      00000030 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      00000040 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      00000050 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      00000060 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      00000070 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      00000080 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      00000090 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      000000A0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      000000B0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      000000C0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      000000D0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      000000E0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      000000F0 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
                      J-Link>
                      Nca78N
                      Nca78N
                      Can you explain the steps you used for that ?
                      Did you use a jlink clone or the version included in the DK ?
                      Nca78N NeverDieN 2 Replies Last reply
                      • Nca78N Nca78
                        Nca78N
                        Nca78N
                        @Nca78 said in nRF5 Bluetooth action!:
                        Well you can forget about my questions.
                        I tried to use the JLink tools to make the mass erase but it didn't want to connect to the module.
                        But then I have replaced the driver with Zadig and configured Arduino for NRF5 and it uploaded the LightSensor sketch, I can see it in the log of the controller. No mass erase needed, nor any unlock or related command.
                        Just plug and program for me :D
                        I have some strange error messages but I guess they come from (very) dated firmware on my Segger clone
                        ** Programming Started **
                        auto erase enabled
                        Info : nRF51822-QFN48(build code: B00) 512kB Flash
                        Warn : not enough working area available(requested 32)
                        Warn : no working area available, falling back to slow memory writes
                        wrote 28672 bytes from file C:\Users\Nicolas\AppData\Local\Temp\arduino_build_723618/LightSensor.ino.hex in 6.715397s (4.170 KiB/s)
                        ** Programming Finished **
                        ** Verify Started **
                        Warn : not enough working area available(requested 52)
                        verified 27432 bytes in 0.279278s (95.923 KiB/s)
                        ** Verified OK **
                        ** Resetting Target **
                        shutdown command invoked
                        • Nca78N Nca78
                          NeverDieN
                          NeverDieN
                          #412
                          I used the j-link Segger clone to do the mass erase, and then I switched to the DK to do the programming. However, today I was able to do the programming from the Segger clone on the Windows 10 computer, and the setup is less arduous than for programming an external chip using the DK (because with the Segger I didn't have to power the target chip independently during the programming).
                            NeverDieN
                            NeverDieN
                            #413
                            So, I guess the way the code would read is:
                            1. First check if the reset registers are already properly set.
                            2. If so, then just move on to whatever is next.
                              If not, then properly set the reset registers and invoke the system reset.
                            Apparently a system reset doesn't change the values in the reset registers.
                            Of course, none of this would be needed if the reset enable from the tools menu worked, so I'd still prefer to do it that way if at all possible.
                            As I indicated earlier, the pin mapping on Rx and Tx did work using @d00616 new technique, so hurray for that. That much was an important victory in itself that's worth celebrating. :)
                            • Nca78N
                              Nca78N
                              wrote on last edited by Nca78
                              #414
                              First nrf51822 module arrived already.
                              It's really small, here between an nrf24 SMD and the cdebyte 52832.
                              Soldering quality looks better than the pictures on AliExpress.
                                d00616D
                                d00616D
                                d00616
                                The "Reset" menu was from my first approach creating user manageable boards for arduino-nrf5. I haven' tested it. With the reset menu I set the "-DCONFIG_GPIO_AS_PINRESET" option. This option should be processed in "cores/nRF5/SDK/components/toolchain/system_nrf52.c". If not the SystemInit() function is not processed in the startup code. This is a problem handling the chip errata. I have not time to check this at the moment.
                                Here is a PR which want to enable reset as default: https://github.com/sandeepmistry/arduino-nRF5/pull/91
                                • NeverDieN
                                  NeverDieN
                                  #416
                                  Maybe the reset pin problem is hardware related? I say that because if I program the Ebyte module as a Nordic nRF52832 DK board, it still has the same issue. In contrast, the reset button on the actual nRF52832 DK board does work as expected.
                                  • NeverDieN
                                    NeverDieN
                                    #417
                                    I've confirmed that connecting P0.21 to GND and then removing it again on the Nordic nRF52832 DK does act as a reset. So, at the moment I have no idea why doing so on the Ebyte nRF52832 that's been programmed to think it's an Nordic nRF52832 DK doesn't do the same. There must be some hardware difference, right?
                                    • NeverDieN
                                      NeverDieN
                                      #418
                                      I've confirmed that on both the Ebyte Module and on the Nordic nRF52832 DK, there is continuity between the P0.21 pin on the chip and the P0.21 pin on the board pinout. So, there must be some other factor that accounts for the difference.
                                      • NeverDieN
                                        NeverDieN
                                        Making no headway on the reset topic, so for now I'm going to punt and move on to other things.
                                        • NeverDieN
                                          NeverDieN
                                          #420
                                          Success! I received some of these modules:
                                          https://www.aliexpress.com/item/nRF52832-Bluetooth-4-1-BLE-Module-M4-Transparent-Transmission-SMA-512K-FLASH-64K-RAM-pass-through/32798522093.html?spm=2114.search0104.3.10.osbQHP&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_10130_10084_10083_10119_10080_10307_10082_10081_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_10056_10055_10054_10310_10312_10059_100031_10099_10078_10079_10103_10073_10102_10120_10052_10053_10142_10107_10050_10051-10120,searchweb201603_2,ppcSwitch_5&btsid=b9a0c3cb-cc2a-4254-b24f-94136c73def6&algo_expid=2a71f70b-4929-43a5-887a-2f7263250568-1&algo_pvid=2a71f70b-4929-43a5-887a-2f7263250568
                                          which I immediately programmed using the nRF52832 DK. This time, there was no need to first mass erase. Furthermore, this time P0.21 does indeed reset the module after it is pulled to ground and then released.
                                          So, from this I conclude there must be something peculiar to the Ebyte modules which prevents their resetting using P0.21.
                                          It's nice to have different modules to compare amongst. :)
