  3. nRF5 action!
nRF5 action!
  • NeverDieN NeverDie
    @Nca78
    Did you ever figure out how to reset the MCU on the Ebyte module?
    Nca78N
    Nca78N
    @Nca78
    Sorry didn't touch my NRF5 in the last weeks. A bit busy on other things...
    • NeverDieN
      NeverDieN
      #642
      What's the best way to make a "receive only" gateway? i.e. one that cannot transmit? Then I wouldn't need to worry about whether the gateway is turned on before powering up a MY_PASSIVE_NODE sensor mote. Is there a way to do it simply in hardware, or do I have to sabotage the gateway library code?
      • NeverDieN
        NeverDieN
        #643
        It's getting too baroque. What I'd really like to have is a short nRF5 library of just the bare essentials (like the MIRF library is for the RF24).
        d00616D 1 Reply Last reply
        • NeverDieN
          NeverDieN
          Hmmm... it looks like radiohead may be such a library: http://www.airspayce.com/mikem/arduino/RadioHead/classRH__NRF52.html
            d00616D
            d00616D
            d00616
            You can take a look into the actual Nordic NRF SDK. There are the ESB library for nRF24 compatible communication.
            NeverDieN 1 Reply Last reply
            • d00616D d00616
              NeverDieN
              NeverDieN
              The RadioHead library seems very easy to pickup and start using. Maybe it's me, but I can't say the same for the Nordic SDK.
              Interestingly, it looks as though @Yveaux may (?) have written the nRF51 part of the RadioHead library.
              • NeverDieN
                NeverDieN
                I was able to program the tiny nRF51822 (earlier photograph above) by programming it as an xxaa Generic nRF51 with an RC oscillator.
                Nice!
                • NeverDieN
                  NeverDieN
                  Here's a close-up photo:
                  • NeverDieN
                    NeverDieN
                    FWIW, range on the tiny nRF51822 does seem compromised when compared against larger sized nRF52832 modules. Not really surprising, but I had hoped it might be a little better than it is.
                      d00616D
                      d00616D
                      d00616
                      This is an idea, I don't know if this helps. The two pins near the antenna are GND. Try to solder an 3cm isolated wire to the pin near your PCB and route it parallel of your pcb away from the nRF51 board. The extends the GND pane size.
                      • rmtuckerR
                        rmtuckerR
                        rmtucker
                        Just in case anyone uses the waveshare ble400 board.
                        The board was consuming 150uA when fed with 3.3v bypassing the regulator.
                        I have cut through one of the tracks and now it is only consuming 4-5uA and it can still be used normally with the usb lead 5v as long as i place a dupont link across 2 pins.
                        If anyone needs photo's let me know.
                        • d00616D d00616
                          NeverDieN
                          NeverDieN
                          I'll give it a try. Is your idea to make it like a dipole antenna?
                          • NeverDieN
                            NeverDieN
                            @d00616
                            Is this what you had in mind?
                            • NeverDieN
                              NeverDieN
                              #654
                              Also, there are a couple of what look like large solder pads on the back of the PCB. I have no idea what they're for. Anyone know or care to guess?
                              • scalzS scalz
                                I don't think sendSignalStrength function is implemented yet, but you should be able to get this info with:
                                int16_t transportGetSendingRSSI(void)
                                int16_t transportGetReceivingRSSI(void)
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                @scalz said in nRF5 Bluetooth action!:
                                Just wondering what both of these mean?
                                I assumed the transportGetReceivingRSSI(void) was the strength of signal from my Gateway ?
                                But what is the transportGetSendingRSSI(void)?
                                • rmtuckerR rmtucker
                                  d00616D
                                  d00616D
                                  d00616
                                  @rmtucker said in nRF5 Bluetooth action!:
                                  This is the RSSI of the receiver. With nRF5 it's part of the ACK payload.
                                  • rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    wrote on last edited by rmtucker
                                    #657
                                    Out of curiosity i stuck a cake tin over the top of the node and it just carried on transmitting,so i put it behind 4 walls and 1 floor down then behind the fuse box and consumer unit and eventually got it to drop to -68dB for received rssi but send rssi stayed at -45dB so it seems to be booming out and in.😉
                                      @d00616
                                      NeverDieN
                                      NeverDieN
                                      #658
                                      Results: I don't think it made the link worse, but it's not obvious that it made the link better either. Range seems about the same.
                                      Even more surprising: prior to adding this piece of wire, I didn't notice much improvement when I went from 2Mbps at Tx 0db to 250kbps at Tx 4db either. I had really thought it would be a tangible improvement in range, but if there was any improvement (and I'm not sure that there was), it seemed like only a modest amount.
                                      Conclusions/recommendations/suggestions/comments?
                                        @NeverDie I don't know how much work is needed to make this work with nrf5, but @Yveaux has created a range tester that might be useful. https://github.com/Yveaux/MySensorsRangeTest
                                        It does use MySensors though, so it might provide more overhead than the bare-bone functionality you are looking for.
                                        • scalzS
                                          scalzS
                                          wrote on last edited by scalz
                                          #660
                                          @NeverDie is your wire soldered to gnd?? if so, i would have soldered it to the antenna transmission line, as a monopole, with taking care of disabling the pcb antenna. i guess you're trying sort of dipole, but one branch is meandered/"coiled" so not sure if that would improve a lot like you noticed..
