  3. nRF5 action!
nRF5 action!
    I tried my nrf24l01 pa lna sma but it seemed to be only working every now and again so waiting on a new one being delivered.
    According to hackaday, there's a certain very common model which doesn't perform well unless you wrap it first in saran wrap (as an electrical insulator) and then in aluminum foil (except for the antenna, obviously).
    rmtuckerR
    rmtuckerR
    rmtucker
    I connected a new amplified nrf24 to the gateway with the tin foil as mentioned and it is reading -60dB compared to -89dB with the non amplified version.
    Now lets see how far it goes past the original test.😉
    rmtuckerR NeverDieN 2 Replies Last reply
    • rmtuckerR rmtucker
      rmtuckerR
      rmtuckerR
      rmtucker
      @rmtucker
      Well outside of the garden now no problem.😊
      On to supercaps now i think.😉
        #638
        Did the tin foil make a difference? Hackaday seemed to think it made a big difference. I haven't tried it yet.
        rmtuckerR 1 Reply Last reply
          rmtuckerR
          rmtuckerR
          rmtucker
          I think it did but what do you have to lose😉
            Here's the Hackaday article: http://hackaday.com/2016/05/31/fixing-the-terrible-range-of-your-cheap-nrf24l01-palna-module/
              @Nca78
              Did you ever figure out how to reset the MCU on the Ebyte module?
              @Nca78
              Sorry didn't touch my NRF5 in the last weeks. A bit busy on other things...
                #642
                What's the best way to make a "receive only" gateway? i.e. one that cannot transmit? Then I wouldn't need to worry about whether the gateway is turned on before powering up a MY_PASSIVE_NODE sensor mote. Is there a way to do it simply in hardware, or do I have to sabotage the gateway library code?
                  #643
                  It's getting too baroque. What I'd really like to have is a short nRF5 library of just the bare essentials (like the MIRF library is for the RF24).
                  d00616D 1 Reply Last reply
                    Hmmm... it looks like radiohead may be such a library: http://www.airspayce.com/mikem/arduino/RadioHead/classRH__NRF52.html
                      d00616D
                      d00616D
                      d00616
                      You can take a look into the actual Nordic NRF SDK. There are the ESB library for nRF24 compatible communication.
                      • d00616D d00616
                        The RadioHead library seems very easy to pickup and start using. Maybe it's me, but I can't say the same for the Nordic SDK.
                        Interestingly, it looks as though @Yveaux may (?) have written the nRF51 part of the RadioHead library.
                          I was able to program the tiny nRF51822 (earlier photograph above) by programming it as an xxaa Generic nRF51 with an RC oscillator.
                          Nice!
                            Here's a close-up photo:
                              FWIW, range on the tiny nRF51822 does seem compromised when compared against larger sized nRF52832 modules. Not really surprising, but I had hoped it might be a little better than it is.
                                d00616D
                                d00616D
                                d00616
                                This is an idea, I don't know if this helps. The two pins near the antenna are GND. Try to solder an 3cm isolated wire to the pin near your PCB and route it parallel of your pcb away from the nRF51 board. The extends the GND pane size.
                                • rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  Just in case anyone uses the waveshare ble400 board.
                                  The board was consuming 150uA when fed with 3.3v bypassing the regulator.
                                  I have cut through one of the tracks and now it is only consuming 4-5uA and it can still be used normally with the usb lead 5v as long as i place a dupont link across 2 pins.
                                  If anyone needs photo's let me know.
                                  • d00616D d00616
                                    I'll give it a try. Is your idea to make it like a dipole antenna?
                                      @d00616
                                      Is this what you had in mind?
                                        #654
                                        Also, there are a couple of what look like large solder pads on the back of the PCB. I have no idea what they're for. Anyone know or care to guess?
                                        • scalzS scalz
                                          I don't think sendSignalStrength function is implemented yet, but you should be able to get this info with:
                                          int16_t transportGetSendingRSSI(void)
                                          int16_t transportGetReceivingRSSI(void)
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          Just wondering what both of these mean?
                                          I assumed the transportGetReceivingRSSI(void) was the strength of signal from my Gateway ?
                                          But what is the transportGetSendingRSSI(void)?
