  3. nRF5 action!
nRF5 action!
  • rmtuckerR
    rmtuckerR
    rmtucker
    Just wondering what the prescaler etc would have to be set to for ms accuracy and how long before overflow.(aint got my maths head on today):blush:
    • NeverDieN NeverDie
      What more can be done to reduce current consumption on an nRF52832 when the MySensors "sleep" function is being used with RTC wakeup. I've measured a 300mv drop on a 10F capacitor over a 12 hour time period. Of that 300mv, perhaps 20mv was lost due to self-discharge of the supercap. So, that still leaves 280mv of loss due to the nRF52832 . That is too high a rate of loss.
      d00616D
      d00616D
      d00616
      wrote on last edited by d00616
      #702
      Wh = 0.5 * 10F * 280mV = 0.392 Wh = 0.0326667 W
      I=0.0326667/2.56V = 12.76mA
      Looks like the node is most time fully active.
      • rmtuckerR rmtucker
        @d00616
        My initial thoughts were how the nrf51822 could be used for energy meters (counting pulses and the gap between them),But unlike the arduino's which can not run timers when in sleep mode,The nrf5 can of course do this.
        So the nrf5 would be able to report watts and usage while still using sleep mode.
        But seeing the inaccuracy of the timer has put the brakes on that.
        Yes being able to change the prescaler dynamically would help a great deal as 125ms / 582.542 hours is not really useful for most applications with a 250ms overrun.
        d00616D
        d00616D
        d00616
        @rmtucker said in nRF5 Bluetooth action!:
        @d00616
        If you have the idea to store the results into the EEPROM like storage the nRF5, then read the hints about this: https://github.com/d00616/arduino-NVM/#nvramh
        The virtual EEPROM, the radio or debugging output are adding latency to the main loop. You will see more timing errors in long term run when you trust the sleep() time.
        The nRF5 can help you to count without adding latency by the cpu. You can use a timer in counter mode which TASK_COUNT and TASKS_CAPTURE[0] are triggered by PPI. Then you can compare the hwMillis() with the last seen CC[0] content and do precise calculation of events.
        With nRF52 there is an unused RTC wich can trigger TASKS_CAPTURE[0] at a specific time. One RTC is used for millis() in arduino-nrf5 and one RTC is used for sleep.
        I will change this.
          @NeverDie
          Seeing Your sketch would help?
          NeverDieN
          NeverDieN
          #704
          @rmtucker
          Here it is, though it's rather messy. Nonetheless, all it does is measure the supercap and solar panel voltages, send them, then sleep for 12 hours. Then repeats:
          // nrf51_client.pde
          // -*- mode: C++ -*-
          // Example sketch showing how to create a simple messageing client
          // with the RH_NRF51 class. RH_NRF51 class does not provide for addressing or
          // reliability, so you should only use RH_NRF51 if you do not need the higher
          // level messaging abilities.
          // It is designed to work with the other example nrf51_server.
          // Tested on RedBearLabs nRF51822 and BLE Nano kit, built with Arduino 1.6.4.
          // See http://redbearlab.com/getting-started-nrf51822/
          // for how to set up your Arduino build environment
          // Also tested with Sparkfun nRF52832 breakout board, witth Arduino 1.6.13 and
          // Sparkfun nRF52 boards manager 0.2.3
          #include <RH_NRF51.h>
          unsigned long SLEEP_TIME = 43200000; // 12 hour sleep time between measurements (in milliseconds)
          //unsigned long SLEEP_TIME = 3600000; // 1 hour sleep time between measurements (in milliseconds)
          //unsigned long SLEEP_TIME = 300000; // 5 minute sleep time between measurements (in milliseconds)
          //unsigned long SLEEP_TIME = 1000; // 1 second sleep time between measurements (in milliseconds)
          #define SUPERCAP_PIN A2  //input pin for reading the supercap's voltage
          #define SOLAR_PANEL_PIN A4  //input pin for reading the solar panel's voltage
          #define LDO_ENABLE_PIN 8  //D8 (P0.19) is output pin for enabling (HIGH) or disabling (LOW) the LDO
          #define NUM_MEASUREMENTS_TO_AVERAGE 3  //number of measurements to collect and then average
          #define MAX_MEASUREMENTS 10 //Maximum number of voltage measurements before returning a result.
          // Singleton instance of the radio driver
          RH_NRF51 nrf51;
          uint8_t data[10];
          uint16_t batteryVoltage() {
            uint16_t lastRawVoltage, newRawVoltage;
            //uint16_t counter=0;
            //lastRawVoltage = hwCPUVoltage();  //throw away the first voltage measurement
            newRawVoltage = hwCPUVoltage();
            return newRawVoltage;
          uint16_t readRawVoltageOnPin(uint8_t thePin) {
            uint16_t counter=0;
            lastRawVoltage = analogRead(thePin);
            newRawVoltage = analogRead(thePin);
            while (((newRawVoltage != lastRawVoltage)) && (counter<MAX_MEASUREMENTS)) {  //measure until two consecutive measurements match
              lastRawVoltage=newRawVoltage;
              newRawVoltage=analogRead(thePin);
              counter++;
            uint32_t sumOfMeasurements=0;
            for (int i=0;i<NUM_MEASUREMENTS_TO_AVERAGE;i++) {
              sumOfMeasurements=sumOfMeasurements+analogRead(thePin);
            return (sumOfMeasurements/NUM_MEASUREMENTS_TO_AVERAGE);
          void myBaro()
            uint32_t superCapVoltage=0;
            uint32_t solarPanelVoltage=0;
            uint32_t superCapRawVoltage=0;
            uint32_t solarPanelRawVoltage=0;
            digitalWrite(LDO_ENABLE_PIN, LOW);  //disconnect solar panel
            superCapRawVoltage = readRawVoltageOnPin(SUPERCAP_PIN);
            superCapVoltage = (3048*(((superCapRawVoltage)*3127)/4095))/1591;
            //Serial.print("SuperCap voltage=");
            //Serial.println(superCapVoltage);
            //send(msg1_S_BARO_P.set(superCapVoltage));  //superCap's raw voltage
          //  wait(500);
          //  wait(500);
            //delayMicroseconds(1000);  //wait for voltage to adjust after LDO disabled.  Necessary???
            solarPanelRawVoltage=readRawVoltageOnPin(SOLAR_PANEL_PIN);
            digitalWrite(LDO_ENABLE_PIN, HIGH);  //re-connect solar panel
            solarPanelVoltage=(5500*(((solarPanelRawVoltage)*3181)/4095))/1289;
            //Serial.print("Solar Panel Voltage=");
            //Serial.println(solarPanelVoltage);
            //superCapVoltage=1234;
            data[0]= (superCapVoltage/1000)+'0';
            data[1]= ((superCapVoltage%1000)/100)+'0';
            data[2]= ((superCapVoltage%100)/10)+'0';
            data[3]= (superCapVoltage%10)+'0';
            data[4]=',';
            data[5]= (solarPanelVoltage/1000)+'0';
            data[6]= ((solarPanelVoltage%1000)/100)+'0';
            data[7]= ((solarPanelVoltage%100)/10)+'0';
            data[8]= (solarPanelVoltage%10)+'0';
            data[9]='\0';
            nrf51.send(data, sizeof(data));
            nrf51.waitPacketSent();
            pinMode(LDO_ENABLE_PIN, OUTPUT);  // Enable/Disable pin for the LDO
            digitalWrite(LDO_ENABLE_PIN, HIGH);  //enable the LDO.
            analogReadResolution(12);  //use 12-bit ADC resolution
            pinMode(SUPERCAP_PIN,INPUT);  //Supercap voltage measurement pin
            pinMode(SOLAR_PANEL_PIN,INPUT);  //Solar panel voltage measurement pin
            //delay(1000); // Wait for serial port etc to be ready
            Serial.begin(250000);
            //while (!Serial)
              ; // wait for serial port to connect.
            if (!nrf51.init())
              Serial.println("init failed");
            // Defaults after init are 2.402 GHz (channel 123), 2Mbps, 0dBm
            if (!nrf51.setChannel(123))
              Serial.println("setChannel failed");
            if (!nrf51.setRF(RH_NRF51::DataRate2Mbps, RH_NRF51::TransmitPower4dBm))
              Serial.println("setRF failed");
            // AES encryption can be enabled by setting the same key in the sender and receiver
          //  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
          //                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
          //  nrf51.setEncryptionKey(key);
          //  nrf51.printRegisters();
            Serial.println("Setup of nr51 client completed.");
            Serial.println("Sending to nrf51_server...");
            Serial.flush();
          uint32_t sentCounter=0;
          uint32_t replyCounter=0;
            //uint16_t theBatteryVoltage;
            //theBatteryVoltage=batteryVoltage();
           // Serial.print("Battery voltage = ");
            //Serial.print(theBatteryVoltage);
            //Serial.println(" millivolts.");
            // Send a message to nrf51_server
            //uint8_t data[] = "Hello World!";
            data[0]= (theBatteryVoltage/1000)+'0';
            data[1]= ((theBatteryVoltage%1000)/100)+'0';
            data[2]= ((theBatteryVoltage%100)/10)+'0';
            data[3]= (theBatteryVoltage%10)+'0';
            data[4]='\0';
            sentCounter++;
            myBaro();
            // Now wait for a reply
            uint8_t buf[RH_NRF51_MAX_MESSAGE_LEN];
            uint8_t len = sizeof(buf);
            if (nrf51.waitAvailableTimeout(500))
              // Should be a reply message for us now
              if (nrf51.recv(buf, &len))
                Serial.print("got reply: ");
                Serial.println((char*)buf);
                replyCounter++;
              else
                Serial.println("recv failed");
            else
              Serial.println("No reply, is nrf51_server running?");
            Serial.print("sentCounter=");
            Serial.print(sentCounter);
            Serial.print(", replyCounter=");
            Serial.println(replyCounter);
            Serial.flush();
            sleep(SLEEP_TIME); // Sleeps for 12 hours in deep sleep
          Using Termite to timestamp the output received, what I got was:
          2017/08/25 17:04:13: got request: 2684,0085
          2017/08/26 05:04:12: got request: 2396,0076
          You can ignore the solar panel measurements, because I disconnected it so as to not interfere.
          On the bright side, it woke up and reported within 1 second of when it was supposed to, after a 12 hour sleep.
          d00616D rmtuckerR 2 Replies Last reply
            @rmtucker
            // nrf51_client.pde
            RH_NRF51 nrf51;
            uint8_t data[10];
              uint16_t counter=0;
                counter++;
            void myBaro()
            //  wait(500);
            //  wait(500);
              data[4]=',';
              data[9]='\0';
              //while (!Serial)
              if (!nrf51.init())
              Serial.flush();
              data[4]='\0';
              sentCounter++;
              myBaro();
                  replyCounter++;
                else
              else
              Serial.flush();
            d00616D
            d00616D
            d00616
            RadioHead sets the radio into the Idle state. The radio isn't powered off. There is no call in RadioHead to power off the radio.
              @rmtucker
              // nrf51_client.pde
              RH_NRF51 nrf51;
              uint8_t data[10];
                uint16_t counter=0;
                  counter++;
              void myBaro()
              //  wait(500);
              //  wait(500);
                data[4]=',';
                data[9]='\0';
                //while (!Serial)
                if (!nrf51.init())
                Serial.flush();
                data[4]='\0';
                sentCounter++;
                myBaro();
                    replyCounter++;
                  else
                else
                Serial.flush();
              rmtuckerR
              rmtuckerR
              rmtucker
              @NeverDie
              So your sketch only wakes up every 12hours.
              What current is it drawing using the radiohead library vs mysensors for an equivalent 12 hour sleep because in past discussions with you i remember you saying 5-6uA while sleeping,is this still correct?
              I dont see much advantage to the radiohead library if only sending at 12hour intervals.
              NeverDieN 1 Reply Last reply
                @NeverDie
                NeverDieN
                NeverDieN
                #707
                @NeverDie
                The 6ua was measured with it in deep sleep, where it relied on an external interrupt to wakeup. This measurement was intended to see what it would be if it woke-up using the RTC. So, the 12 hour interval is artificial, for measurement purposes.
                @d00616
                I had wrongly assumed that the "sleep(...)" command would sleep the radio. Thanks for pointing out my error. How/when is it that Mysensors puts the radio to sleep? Does it just happen automatically at the end of every sending/receiving?
                d00616D 1 Reply Last reply
                  @NeverDie
                  @d00616
                  d00616D
                  d00616D
                  d00616
                  #708
                  We are both not 100% correct ;-) The hwSleep() function doesn't disable the radio, but the sleep() function does it, when MY_SENSOR_NETWORK is defined.
                  After Sleep transportReInitialise() is called. Then you have to initialize RadioHead again.
                  • d00616D d00616
                    NeverDieN
                    NeverDieN
                    So, even with RAM retention active while sleeping, each time the radio is awoken, it needs to be re-initialized?
                      d00616D
                      d00616D
                      d00616
                      The Radio has to be initialized after power down. This doesn't depend on RAM retention.
                      • NeverDieN
                        NeverDieN
                        #711
                        According to Table 39 of the mRF52832 datasheet, there is only one radio state resembling sleep, and that is the DISABLED radio state where "No operations are going on inside the radio and the power consumption is at a minimum."
                        Apparently the radio is disabled through register TASKS_DISABLE, offset 0x010, Disable RADIO, as indicated by Table 41 register overview.
                        • NeverDieN
                          NeverDieN
                          #712
                          But how exactly does one read or write to these registers? It looks like a quite different arrangement than writing to registers for an nRF24 or an RFM69 or a LoRa chip.
                            d00616D
                            d00616D
                            d00616
                            You have to include nrf.h. To disable the radio, you can do this:
                            https://github.com/mysensors/MySensors/blob/development/drivers/NRF5/Radio_ESB.cpp#L264
                            If your transmitting power is 0dbm, then "TX only run current PRF = 0dBm" with 11.6 mA is near the calculated current, when the radio stays in TX mode after sending the data.
                            • d00616D d00616
                              NeverDieN
                              NeverDieN
                              #714
                              @d00616
                              Will this block of code guarantee that the radio is disabled?
                                Serial.println("Testing whether radio is disabled...");
                                Serial.print("NRF_RADIO->EVENTS_DISABLED=");
                                Serial.println(NRF_RADIO->EVENTS_DISABLED);
                                while (!(NRF_RADIO->EVENTS_DISABLED)) {
                                  NRF_RADIO->TASKS_DISABLE = 1;  //sleep the radio
                                Serial.println("Radio disabled.");
                                @d00616
                                d00616D
                                d00616D
                                d00616
                                This one is better:
                                if (NRF_RADIO->STATE != RADIO_STATE_STATE_Disabled) {
                                  @d00616
                                  d00616D
                                  d00616D
                                  d00616
                                  The sleep() function is now more precise for sleeping <512s:
                                  https://github.com/mysensors/MySensors/pull/909
                                  The PR is waiting for merge.
                                  rmtuckerR 1 Reply Last reply
                                  • d00616D d00616
                                    This one is better:
                                    NeverDieN
                                    NeverDieN
                                    @d00616
                                    That works. Thanks!
                                    What's the best way to awaken the radio after sleeping it though? I've tried:
                                        NRF_RADIO->TASKS_START  = 1;  //awaken the radio
                                    and
                                        NRF_RADIO->TASKS_TXEN  = 1;  //awaken the radio
                                    and neither seems to have an effect. The radio stays disabled.
                                    d00616D 2 Replies Last reply
                                      @d00616
                                      That works. Thanks!
                                      and
                                      d00616D
                                      d00616D
                                      d00616
                                      This depends on the implementation. Sorry, at the moment I have not time to look into the RadioHead code in that detail. You can try to initialize the library again.
                                        @d00616
                                        That works. Thanks!
                                        and
                                        d00616D
                                        d00616D
                                        d00616
                                        @NeverDie Here is a snippet to dump all registers, hope it's help to analyze whats going wrong with RadioHead:
                                        Serial.print("NRF_RADIO->EVENTS_READY  ");
                                        Serial.println(NRF_RADIO->EVENTS_READY, HEX);
                                        Serial.print("NRF_RADIO->EVENTS_ADDRESS  ");
                                        Serial.println(NRF_RADIO->EVENTS_ADDRESS, HEX);
                                        Serial.print("NRF_RADIO->EVENTS_PAYLOAD  ");
                                        Serial.println(NRF_RADIO->EVENTS_PAYLOAD, HEX);
                                        Serial.print("NRF_RADIO->EVENTS_END  ");
                                        Serial.println(NRF_RADIO->EVENTS_END, HEX);
                                        Serial.print("NRF_RADIO->EVENTS_DISABLED  ");
                                        Serial.println(NRF_RADIO->EVENTS_DISABLED, HEX);
                                        Serial.print("NRF_RADIO->EVENTS_DEVMATCH  ");
                                        Serial.println(NRF_RADIO->EVENTS_DEVMATCH, HEX);
                                        Serial.print("NRF_RADIO->EVENTS_DEVMISS  ");
                                        Serial.println(NRF_RADIO->EVENTS_DEVMISS, HEX);
                                        Serial.print("NRF_RADIO->EVENTS_RSSIEND  ");
                                        Serial.println(NRF_RADIO->EVENTS_RSSIEND, HEX);
                                        Serial.print("NRF_RADIO->EVENTS_BCMATCH  ");
                                        Serial.println(NRF_RADIO->EVENTS_BCMATCH, HEX);
                                        Serial.print("NRF_RADIO->CRCSTATUS  ");
                                        Serial.println(NRF_RADIO->CRCSTATUS, HEX);
                                        Serial.print("NRF_RADIO->RXMATCH  ");
                                        Serial.println(NRF_RADIO->RXMATCH, HEX);
                                        Serial.print("NRF_RADIO->RXCRC  ");
                                        Serial.println(NRF_RADIO->RXCRC, HEX);
                                        Serial.print("NRF_RADIO->DAI  ");
                                        Serial.println(NRF_RADIO->DAI, HEX);
                                        Serial.print("NRF_RADIO->PACKETPTR  ");
                                        Serial.println(NRF_RADIO->PACKETPTR, HEX);
                                        Serial.print("NRF_RADIO->FREQUENCY  ");
                                        Serial.println(NRF_RADIO->FREQUENCY, HEX);
                                        Serial.print("NRF_RADIO->TXPOWER  ");
                                        Serial.println(NRF_RADIO->TXPOWER, HEX);
                                        Serial.print("NRF_RADIO->MODE  ");
                                        Serial.println(NRF_RADIO->MODE, HEX);
                                        Serial.print("NRF_RADIO->PCNF0  ");
                                        Serial.println(NRF_RADIO->PCNF0, HEX);
                                        Serial.print("NRF_RADIO->PCNF1  ");
                                        Serial.println(NRF_RADIO->PCNF1, HEX);
                                        Serial.print("NRF_RADIO->BASE0  ");
                                        Serial.println(NRF_RADIO->BASE0, HEX);
                                        Serial.print("NRF_RADIO->BASE1  ");
                                        Serial.println(NRF_RADIO->BASE1, HEX);
                                        Serial.print("NRF_RADIO->PREFIX0  ");
                                        Serial.println(NRF_RADIO->PREFIX0, HEX);
                                        Serial.print("NRF_RADIO->PREFIX1  ");
                                        Serial.println(NRF_RADIO->PREFIX1, HEX);
                                        Serial.print("NRF_RADIO->TXADDRESS  ");
                                        Serial.println(NRF_RADIO->TXADDRESS, HEX);
                                        Serial.print("NRF_RADIO->RXADDRESSES  ");
                                        Serial.println(NRF_RADIO->RXADDRESSES, HEX);
                                        Serial.print("NRF_RADIO->CRCCNF  ");
                                        Serial.println(NRF_RADIO->CRCCNF, HEX);
                                        Serial.print("NRF_RADIO->SHORTS  ");
                                        Serial.println(NRF_RADIO->SHORTS, HEX);
                                        • d00616D d00616
                                          NeverDieN
                                          NeverDieN
                                          @d00616
                                          I did a bit more poking around, and I've confirmed that there's no need to re-enable the radio before transmitting. Apparently doing the transmission and returning to disabled mode happens automatically. In fact, I think this is the expected behavior, as indicated by Figure 35 of the datasheet.
