nRF5 action!
@d00616
Thanks! I just now ordered one of your boards so that in the future we can share a common platform for comparing numbers. :)
https://www.aliexpress.com/item/NRF52832-Mini-Development-Board-Gold-Core-board-Wireless-Bluetooth-Transceiver-Module/32798618219.html?spm=2114.search0204.3.1.GUmybP&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10130_5490020_10068_5430020_5410020_10307_10137_10060_10155_10154_10333_10334_10056_5370011_10335_10055_10336_10054_10059_10332_100031_10099_5400020_10103_10102_10052_10053_10107_10050_10142_10051_10324_10325_5380020_10326_5390020_10084_10083_10080_10082_10081_10178_10110_10111_10112_10113_10114_10312_10313_10314_10316_10078_10079_10073_5420011-10332_10333,searchweb201603_5,ppcSwitch_4_ppcChannel&btsid=78a27a2f-4aa5-49a0-a538-502a2c86d8f2&algo_expid=598ae4bb-6401-4529-89ad-6e8d8a90af12-0&algo_pvid=598ae4bb-6401-4529-89ad-6e8d8a90af12&transAbTest=ae803_3[By the way, I did my measurements on an Ebyte nRF52832 module]
Ok. I have measured my Ebyte with the same sketch and in the µA range of my VC165 multimeter. Sleep current is 9.9µA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode. (b.t.w. this module costs actually 3,82€)
@scalz said in nRF5 Bluetooth action!:
in that case, you need to set it as a floating input i think, like it's generally at reset.
In datasheet, section 20 (p111), is explained how works the GPIO. You have a Bit for disconnecting it. See the PIN_CNF[n] registers. For instance, p.140, you can see how it looks for the P0.10, and the Bit 1.
This should do the job..Should I add a DISCONNECTED mode to hwPinMode()?
Sleep current is 9.9µA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode....
Ah, maybe that's part of the difference. I was doing just:
pinMode(ALPHA_PIN, INPUT) pinMode(BETA_PIN, OUTPUT)because that's how I would have done it on an Arduino. Should we instead always use INPUT_PULLUP and OUTPUT_H0H1 instead?
Thanks! Somehow didn't remember that.
So, as suggested by @scalz what is some example code that can be used to "disconnect" the pin later?
@NeverDie
He has not added that facility yet,i think he asked you if you wanted it adding to the code? -
for unused pins, it should be floating, not pullup. set the pin register you need to 0x02.
Something like that
NRF_GPIO->PIN_CNF[ulPin] = 0x02;
that will put pin in same state like it's on reset. Everything disabled/default, floating, with disconnect bit set.
(see datasheet gpio).@d00616 said in nRF5 Bluetooth action!:
make sense to have it for input too.. i agree :simple_smile:
Maybe add:
OUTPUT_D0D1 -> Disconnected 0, Disconnected 1
or similar to your list as another easy way to effectuate the disconnect? -
It finally makes sense now as to why there were all those "disconnected" choices among the various OUTPUT options. In my case, for controlling whether the solar panel is connected or disconnected, choosing OUTPUT_S0D1 works perfectly. :)
So, I suppose another way to disconnect an input pin would be to redefine it as an OUTPUT pin with a disconnect state, and then immediately put it into the disconnected state.
@rmtucker said in nRF5 Bluetooth action!:
Yes being able to change the prescaler dynamically would help a great deal as 125ms / 582.542 hours is not really useful for most applications with a 250ms overrun.
The sleep() function is now more precise for sleeping <512s:
https://github.com/mysensors/MySensors/pull/909
The PR is waiting for merge.
Hmm just tried the latest commit and it is giving me 306ms for sleep(10000).
Something not quite right. -
@rmtucker
How are you measuring how long it's sleeping?Just using hwMillis() before and after sleep and subtracting one from the other.
It was just reading + 250ms until @d00616 commited some changes a few hours ago.something wrong in here:-
// Calculate sleep time and prescaler if (ms<512000) { // prescaler 0, 30.517 μs resolution -> max 512 s sleep MY_HW_RTC->PRESCALER = 0; // Set compare register to 1/30.517 µs to garantee event triggering // A minimum of 2 ticks must be guaranteed // (1000/32768)<<12 == 125 MY_HW_RTC->CC[0] = max((ms<<12 / 125), 2); } else { // 8 Hz -> max 582.542 hours sleep. MY_HW_RTC->PRESCALER = 4095; // Set compare register to 1/125ms // A minimum of 2 ticks must be guaranteed MY_HW_RTC->CC[0] = max((ms / 125), 2); } -
@rmtucker
It was just reading + 250ms until @d00616 commited some changes a few hours ago.@rmtucker said in nRF5 Bluetooth action!:
@rmtucker
It was just reading + 250ms until @d00616 commited some changes a few hours ago.I thought so. The point being: doesn't millis stop when you're deep sleeping? Well, at least on an Arduino it does. Not sure what it does on the nRF5.
@rmtucker
@NeverDie
No the nrf5 has a rtc.(Real time Counter)
It can even keep time while sleeping.(just found this out myself!).
That is a great leap forward on the arduino. -
Try it just print the time out then put it to sleep for a minute then print the time out again.
The problem must be this line but i don't speak nrf5.:frowning:
// (1000/32768)<<12 == 125 MY_HW_RTC->CC[0] = max((ms<<12 / 125), 2);``` -
Should be:-
MY_HW_RTC->CC[0] = max(((ms << 12) / 125), 2));
