  3. nRF5 action!
nRF5 action!
  • Nca78N Nca78
    Has anyone succeeded in programming the WT51822-S4AT module (the cheapest and tiny nrf51822 module on AliExpress) using NRF52 DK ?
    I pulled a lot of hair trying to find out what I did wrong with my board, I soldered an adapter to make sure I didn't have problems with faulty jumper wires etc, I reinstalled JLink and Nordic software, in the end I desoldered everything on my board, then the module itself to program it independantly. It always failed and JLink couldn't connect to it. I tried the other spare one I had, same result. I tried the one I'm sure I managed to program long ago with a jlink clone, always the same result.
    Then I tried with an old nrf51822 module I bought long ago on AliExpress, and no problem !
    Has anyone had similar problems ? Is there something special hardware wise that I should check ?
    NeverDieN
    NeverDieN
    #1421
    @nca78 said in nRF5 Bluetooth action!:
    Yes. Haven't had a problem.
    A couple things:
    1. Are you powering the nRF51 module externally (separate from the nRF52DK)? It's highly advisable that you do, even though by random luck, you can sometimes succeed without it.
    2. Especially for new, unprogrammed modules, you need to do a bulk erase at the beginning. I do this by the d00616 trick of saying "Burn bootloader" with a null bootloader. The burning bootloader process fails, as expected, but the side-effect is that it does a bulk-erase before failing.
    I know you know these things, but sometimes we forget to do what we know.
    scalzS Nca78N 2 Replies Last reply
    • S
      Sarg666
      @Nca78
      Do you have the J-Link with only 4 pins? And if so, is the module a QFAAH0? In this konstalation I have the same problem, but with the J-Link V8 and ST-Link V2, the module can be programmed without any problem.
      • NeverDieN
        NeverDieN
        #1423
        @Nca78
        Also, what board type in the arduino IDE are you using to program it? That could be throwing you off as well.
        • NeverDieN NeverDie
          A couple things:
          scalzS
          scalzS
          wrote on last edited by scalz
          #1424
          @neverdie said in nRF5 Bluetooth action!:
          1. Especially for new, unprogrammed modules, you need to do a bulk erase at the beginning. I do this by the d00616 trick of saying "Burn bootloader" with a null bootloader. The burning bootloader process fails, as expected, but the side-effect is that it does a bulk-erase before failing.
          if bulk erase is needed, then it means it was programmed ;) a fresh new mcu is usually not programmed unless you ask for it to the manufacturer..
          Like said above, it could be a problem with module, power issue, usb & cable, dupont cable, jlink, jlink setup, arduino core etc.
          NeverDieN Nca78N 2 Replies Last reply
            A couple things:
            Nca78N
            Nca78N
            I was at the beginning, but after that I tried with power from the DK. I will try again with external power.
            I can't even reach that step, JLink can't establish the SWD connection so there's no way to erase the chip.
            • Nca78N Nca78
              NeverDieN
              NeverDieN
              I use a battery pack with a 3.3v regulator as the external power source. Don't just use 2xAA. If the voltage is too low, it will fail to program.
              • scalzS scalz
                NeverDieN
                NeverDieN
                #1427
                @scalz said in nRF5 Bluetooth action!:
                if bulk erase is needed, then it means it was programmed a fresh new mcu is usually not programmed unless you ask for it to the manufacturer..
                Well, you would think so, and yet it seems I always need to do it anyway on a new module. Go figure.
                • scalzS scalz
                  Nca78N
                  Nca78N
                  @sarg666 said in nRF5 Bluetooth action!:
                  I use the JLink included on the NRF52DK.
                  No because the <3$ modules are made to be controlled with an external MCU using serial commands, the same way than ESP8266 for Wifi, so they have a firmware installed.
                  • Nca78N
                    Nca78N
                    wrote on last edited by Nca78
                    #1429
                    For those interested, only 2.55$ for the CDEByte NRF52832 modules :o
                    https://www.aliexpress.com/store/product/nRF52832-2-4GHz-Wireless-rf-Module-CDSENET-E73-2G4M04S-SPI-SMD-rf-Receiver-transmitter-Bluetooth-Module/2798183_32819293925.html
                    [edit] Limited to 2 / customer, but you can buy 2 more in the other CDEByte store here :)
                    https://www.aliexpress.com/store/product/CDEBYTE-E73-2G4M04S-BLE-4-2-5-0-long-distance-100m-2-4GHz-SMD-ARM-Core/2077046_32820692238.html
                    • scalzS
                      scalzS
                      #1430
                      @NeverDie @Nca78
                      then buy a fresh mcu on Mouser and you'll see by yourself ;)
                      You don't get what I meant, I'm not talking about a specific module design, but in general. the mcu can be accessed by jlink no matter, else how would you program it in first place ..
                      Nca78N 1 Reply Last reply
                      • scalzS scalz
                        @NeverDie @Nca78
                        Nca78N
                        Nca78N
                        @NeverDie @Nca78
                        then buy a fresh mcu on Mouser and you'll see by yourself etc ;)
                        Yes, but when there's a firmware it can be locked, so you must unlock it and erase it to remove softdevice and be able to write something.
                        scalzS 1 Reply Last reply
                        • Nca78N Nca78
                          NeverDieN
                          NeverDieN
                          #1432
                          I don't know why, but I seem to recollect that doing it that way may confuse it. Otherwise, I don't know how I would have ended up using a battery pack instead.
                          • Nca78N Nca78
                            @NeverDie @Nca78
                            scalzS
                            scalzS
                            @NeverDie @Nca78
                            are you sure it's locked? I thought neverdie suggested to erase it with jlink.
                            well, you should choose a better module than funky design modules.. just my opinion, for saving?? 2bucks!
                            • scalzS scalz
                              @NeverDie @Nca78
                              NeverDieN
                              NeverDieN
                              #1434
                              @scalz Well, what do you think he should use instead? Bare chips? That's not as easy to solder.
                              • NeverDieN
                                NeverDieN
                                #1435
                                By the way, any update as to when Nordic will be shipping final silicon on the nRF52840? Seems overdue. I just checked Digikey, and still all they have are the ancient PDK's.
                                • scalzS scalz
                                  @NeverDie @Nca78
                                  Nca78N
                                  Nca78N
                                  Well I was about to complain about my limited choice on Arrow (others ask 75$ shipping :o ), but after checking (again) I see that Arrow now has the Fanstel modules, so I have no reason to complain anymore :D
                                  Too bad the BT832F is not in stock, but BT832 at 4.6$ is great, with the XE version in the gateway to compensate the lower range.
                                    scalzS
                                    scalzS
                                    #1437
                                    Frankly, I'm lazy answering to this question, same for technical stuff. sometimes I feel people miss what I'm trying to explain even if they haven't xp, and I keep repeating it... And the same for my designs, I'm wondering if it's worth the effort when i hear people trying to save 2-5bucks (not rewarding for time&money spent, not asking money btw), or want to reinvent cheaper&less quality variants (why not teamworking, not interested in infinite challenge, waste money&time) or complaining it's too hard to solder, did you read my many redondant advice in the forum, I don't handsolder tiny dfn, I reflow them, far far easier&quicker.
                                    So that's settled, this is why I delayed my releases, until i change my mind, and I'm playing with software.
                                    Sorry I don't want to look pedantic, not targeted against you especially, just tired ;)
                                    @Nca78 cool
                                    • scalzS scalz
                                      @Nca78 cool
                                      NeverDieN
                                      NeverDieN
                                      #1438
                                      @scalz For comparison, I feel like the nRF24L01 is also pretty much a waste of time, given that better performing alternatives exist, and yet it's the most popular radio on the mysensors forum, possibly because it's so cheap and easy to wire up.
                                      You have unusually high skills. A lot of people on this forum just want a list of throughole parts from Aliexpress that they can connect together using dupont wires. So, there's quite a range of skill levels. The biggest barrier I see is people not wanting to hand solder (let alone reflow) SMD parts onto a custom PCB. I think that's partly why the openhardware thing hasn't gotten much traction.
                                      • Nca78N
                                        Nca78N
                                        #1439
                                        Reflow is nice and easy when you know how to do it, but not everyone has the space and money for it, and is willing to spend the necessary time to learn how to do it well. You need oven (that you usually need to modify), you need to buy stencils, you need to buy solder paste and keep it fresh in a separate fridge if you don't want to intoxicate your family when putting it in the kitchen fridge, you need to test/tune the process etc etc It's not for everyone. I tried, I have bought a hotplate (oven is too big and too expensive) and hot air gun, I ordered stencils to make some tests, but I can't get decent quality solder paste. Local shops sold me stuff that was way too old, when it comes from AliExpress it's low quality and it spent weeks at 30+ degrees, at Arrows it's either 50-100$ (that will end mostly wasted because I have no space for dedicated fridge), unavailable (maker paste) or "hazmat" so only sent by ground meaning not available for me. Life is hard :D
                                        About the price I dont think everyone is ready to sacrifice quality to save a few $, I see people buying NModule PCBs at 25$ or more through openhardware.io for example, when they could buy much cheaper when ordering directly. I don't think those people will cry if components on a board cost 15-20$ instead of 10-15 but offer better range or reliability, lower power consumption etc.
                                        About the "funky modules", yes they are not high quality but they still do the job (and way better than atmega + nrf24 clone), and when I first bought them I had no good alternative to get such a compact module, I would have bought them even if more expensive because compact modules on AliExpress or Ebay were either much bigger or with chip antenna, Arrow only had a Rigado module with LGA pins and other reputable shops have rip off shipping costs. Now I see Fanstel modules nearly as small, with better quality, FCC registration, low EMI etc etc at Arrow it would be stupid to continue, so of course I will not buy them anymore and redesign my board for the Fanstel. And if I make it public then I can provide a reliable source for the module, everyone can order from them with no shipping costs and 100% reliability. Way worth the few extra $.
                                        And it's not always about reinventing things, it's about making things yourself and learning, too. I want to learn about ARM processors, bluetooth etc so to avoid having to learn anything at the same time I leave the reflowing, antenna tuning etc aside at the moment and use modules. If in the middle of this process I make a board that people with basic soldering skills can make themselves then how is it negative ? Those who take the MySensors hobby seriously will still favor your board because of the top notch quality and components used, there will also be a bunch of people interested in the complete board, but I think it's also great if people with lower technical skills but thirst for DIY can have something, too, even if "lower quality". Of course that won't be my "22" board, that's why I was thinking about a "33" version with more space to put bigger components (big SMDs or sensor breakout boards) and extension via MySX connector. Not sure if I will ever make it, and I hope it's not part of what is making you lose your motivation to release AEOS, because I'm waiting for it and it would be a good occasion to retry reflow soldering ;)
                                        NeverDieN 1 Reply Last reply
                                        • Nca78N Nca78
                                          NeverDieN
                                          NeverDieN
                                          Yikes! I didn't know there was a risk of that happening.
