  3. nRF5 action!
nRF5 action!
  • scalzS scalz
    @neverdie said in nRF5 Bluetooth action!:
    @scalz Well, what do you think he should use instead? Bare chips? That's not as easy to solder.
    Frankly, I'm lazy answering to this question, same for technical stuff. sometimes I feel people miss what I'm trying to explain even if they haven't xp, and I keep repeating it... And the same for my designs, I'm wondering if it's worth the effort when i hear people trying to save 2-5bucks (not rewarding for time&money spent, not asking money btw), or want to reinvent cheaper&less quality variants (why not teamworking, not interested in infinite challenge, waste money&time) or complaining it's too hard to solder, did you read my many redondant advice in the forum, I don't handsolder tiny dfn, I reflow them, far far easier&quicker.
    So that's settled, this is why I delayed my releases, until i change my mind, and I'm playing with software.
    Sorry I don't want to look pedantic, not targeted against you especially, just tired ;)
    @Nca78 cool
    Nca78N
    Nca78N
    wrote on last edited by Nca78
    #1441
    @nca78 said in nRF5 Bluetooth action!:
    you need to buy solder paste and keep it fresh in a separate fridge if you don't want to intoxicate your family when putting it in the kitchen fridge
    Yikes! I didn't know there was a risk of that happening.
    Well it's probably not a real problem, but I don't want to take risks with my 4yo chidren.
    • NeverDieN
      NeverDieN
      #1442
      I do think a lot of people really underestimate the toxicity of getting solder paste onto their hands. I always use disposable neoprene gloves when handling it, and try to throw away anything that comes into contact with it. You definitely don't want to run the risk of unintentionally ingesting that stuff. AFAIK, the neurotoxicity is permanent damage.
      • NeverDieN
        NeverDieN
        #1443
        By the way, I never got to the point where reflow was "nice and easy" with tiny pad chips. But that's just me. Operator error, I'm sure. It ended up taking so long to get a good outcome that I just decided it wasn't worth the time. Maybe I'll revisit it at a future date.
        Anyway, everyone has their limits. I mean reflowing the gazillion tiny components on a HopeRF module, for instance. That doesn't look easy to me, even if I knew what I was doing.
        @scalz Anyway, it's great that you are doing it. You're an inspiration for us all.
        • NeverDieN
          NeverDieN
          @Nca78
          Here's the board settings that I use:
          Nca78N 1 Reply Last reply
          • korttomaK
            korttomaK
            korttoma
            #1445
            Like NeverDie I am also having some trouble getting started with the NRF5 programming.
            Here is my setup:
            The problem "No valid JTAG Interface Configured":
            Did I miss some step to configure the J-Link somewhere?
            • Tomas
            • NeverDieN
              NeverDieN
              I've always used the IDC connector. I'm not sure that it works if you don't.
              NeverDieN 1 Reply Last reply
              • korttomaK korttoma
                Here is my setup:
                Nca78N
                Nca78N
                @korttoma I have the same problem with the official jlink drivers. So I drag/drop the hex file from output directory to the Jlink drive at the moment.
                korttomaK 1 Reply Last reply
                • Nca78N Nca78
                  korttomaK
                  korttomaK
                  korttoma
                  #1448
                  @nca78 :D that worked! thank you thank you thank you!
                  My first NFR5 node is ALIVE!
                  • Tomas
                  • NeverDieN NeverDie
                    NeverDieN
                    NeverDieN
                    #1449
                    i.e. the 10-pin connector.
                      @Nca78
                      Nca78N
                      Nca78N
                      @neverdie thank you for pointing to the power problem. I had one jumper left for my adapter to connect GND to GND and "as usual" it had a contact problem, I just replaced it and I can see the module in nRFgo Studio, even without external power.
                      • O
                        O
                        Omemanti
                        Question;
                        I've been using the Ebyte modules and I'm making progress. But somehow the energy consumption is far too much. 11,7 mA when I use a clean sketch with hwSleep().
                        When I change to "Normal" Sleep() I get 0.1mA.
                        which one should be the right one to use, keeping in mind, I would like to wake up from an interrupt.
                        • O Omemanti
                          Question;
                          @omemanti sleep. See https://www.mysensors.org/download/sensor_api_20#sleeping for details.
                            @toyman sure do LINK
                            korttomaK
                            korttomaK
                            korttoma
                            @Mika what is your experience regarding battery consumption on these?
                            LINK
                            I put together a sketch witch seems to work fine but one CR2032 just lasts a couple of days.
                            Sketch:
                            //#define MY_DEBUG
                            // Define a static node address, remove if you want auto address assignment
                            //#define MY_NODE_ID 26                                                          // Kök
                            #define MY_NODE_ID 27                                                          // Test device
                            #define MY_RADIO_NRF5_ESB
                            #define SN "NRF5 Scene"
                            #define SV "1.0"
                            #define CHILD_ID_SCENE 1
                            // PIN for the buttons
                            byte buttonOne = 28;
                            //Bounce debouncer[NUMBUTTONS];
                            int buttonOneoldValue;
                            // Pin definitions
                            #define DIGITAL_INPUT_INT 28   // The digital input you attached your interrupt  (Only 2 and 3 generates interrupt!)
                            // Sensor messages
                            MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
                            // Global settings
                            uint16_t SceneOne = 0;
                            uint16_t SceneTwo = 1;
                            void blinkityBlink(uint8_t repetitions) {
                              for (int x=0;x<repetitions;x++) {
                                digitalWrite(LED_BUILTIN,HIGH);
                                wait(20);
                                digitalWrite(LED_BUILTIN,LOW);
                                wait(100);
                                wait(20);
                                if (x<(repetitions-1)) {  //skip waiting at the end of the final repetition
                                  wait(500);
                             * Setup code
                              hwPinMode(LED_BUILTIN,OUTPUT_D0H1);
                              blinkityBlink(2);  //signify power-up and start of operations
                              NRF_CLOCK->INTENSET=B11;  //enable interrupts for EVENTS_HFCLKSTARTED and  EVENTS_LFCLKSTARTED
                              NRF_CLOCK->TASKS_HFCLKSTART=1;  //start the high frequency crystal oscillator clock
                              while (!(NRF_CLOCK->EVENTS_HFCLKSTARTED)) {} //wait until high frequency crystal oscillator clock is up to speed and working
                              hwPinMode(DIGITAL_INPUT_INT, INPUT_PULLUP);
                                /// Make input & enable pull-up resistors on switch pins
                              hwPinMode(buttonOne, INPUT_PULLUP);
                              buttonOneoldValue = -1;
                              sendBattLevel();
                            void presentation()  {
                              sendSketchInfo(SN, SV);
                              //present the scene controller to gateway
                              wait(10);
                              present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
                              wait(10);
                             *  Main loop function
                              // Check for button activity
                              int value = digitalRead(buttonOne);
                              if (value != buttonOneoldValue)
                                  // Send in the new value
                                  if (value == LOW)
                                    send(msgOn.set(SceneOne));
                                    wait(20);
                                    send(msgOn.set(SceneTwo));
                                    sendBattLevel();
                                  buttonOneoldValue = value;
                              sleep(digitalPinToInterrupt(DIGITAL_INPUT_INT), CHANGE, 0);
                             * Sends battery information (battery percentage)
                             * Parameters
                             * - force : Forces transmission of a value
                            void sendBattLevel()
                                long vcc = hwCPUVoltage();
                                // Calculate percentage
                                vcc = vcc - 1800; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
                                long percent = vcc / 14.0;
                                sendBatteryLevel(percent);
                            I noticed that the chip sais:
                            N51822
                            QFABC0
                            1646UU
                            QFAB translates to 16kB RAM, 128kB flash and I can not even select this option in the arduino IDE. Can this be the problem?
                            @d00616 refer to his document for some high current consumption issue but I'm not sure what to do with the info.
                            Is there something wrong with my sketch or is there just an old crappy chip on the device??
                            • Tomas
                            • MiKaM
                              MiKaM
                              MiKa
                              Same result, battery out within few days, I want to do a check of current consumption, but not yet free time...
                              I want to try this:
                              https://github.com/ThingPulse/ESP8266PowerMonitor
                              https://thingpulse.com/2018/02/25/esp8266-monitoring-power-consumption/
                              • Nca78N
                                Nca78N
                                #1455
                                @korttoma have you tried the code @NeverDie put together using the LPCOMP ? With a QFAAH0 (which I believe is the same version than QFABC0, but with 256K flash) he went down to something like 4µA.
                                From the document you link, anomaly 70, it will be necessary to add an extra wait of 36us after that line, it's strange that @NeverDie never had any problem with it. Or maybe I misunderstand the document :)
                                void activateLpComp() {
                                  while (!(NRF_LPCOMP->EVENTS_READY)) {}  //wait until ready
                                Test code from @NeverDie using LPCOMP is here:
                                https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1307
                                I will try it on my board (using a module with QFAAH0) tomorrow, if power consumption is as low as expected I'll try on the beacon board.
                                [Edit] Just checked quickly my "beacon" board and it's using a QFAAH1 chip (made in 2017), so the test might not be relevant...
                                korttomaK Nca78N 2 Replies Last reply
                                • NeverDieN
                                  NeverDieN
                                  #1456
                                  I don't remember. I've lately been using LoRa modules, plus getting distracted by CNC, so my nRF5 work has been on hold. I'm hoping that d00616 continues to work on the software though so that more than one nRF5 interrupt can be active at a time.
                                  • Nca78N Nca78
                                    korttomaK
                                    korttomaK
                                    korttoma
                                    @nca78 thanks for the hint.
                                    I tried to merge my sketch with the code provided by @NeverDie but I can not seem to get it to detect my button and I don't quite understand where I should attach my button that is on pin 28 to the interrupt thingie.
                                    Here is my code now:
                                    //This sketch is applicable to Coincell Multisensor nRF51822, version 10
                                    #define SV "1.0"
                                    //#define MY_CORE_ONLY
                                    #define IS_NRF51  //true iff the target is an nRF51.  If an nRF52, then comment this line out!
                                    // Pin definitions
                                    //#define DIGITAL_INPUT_INT 28   // The digital input you attached your interrupt  (Only 2 and 3 generates interrupt!)
                                    //#define I2C_INTERRUPT_PIN PIN_BUTTON1
                                    //#define LEAK_DETECTION_PIN PIN_BUTTON1
                                    #include <nrf.h>
                                    volatile bool button_pressed=false;
                                    // Sensor messages
                                    // Global settings
                                    void blinkityBlink(uint8_t pulses, uint8_t repetitions) {
                                        for (int i=0;i<pulses;i++) {
                                          wait(20);
                                          wait(100);
                                          wait(500);
                                    void disableNfc() {  //only applied to nRF52
                                    #ifndef IS_NRF51
                                      //Make pins 9 and 10 usable as GPIO pins.
                                      NRF_NFCT->TASKS_DISABLE=1;  //disable NFC
                                      NRF_NVMC->CONFIG=1;  // Write enable the UICR
                                      NRF_UICR->NFCPINS=0; //Make pins 9 and 10 usable as GPIO pins.
                                      NRF_NVMC->CONFIG=0;  // Put the UICR back into read-only mode.
                                    void turnOffRadio() {
                                      NRF_RADIO->TASKS_DISABLE=1;
                                      while (!(NRF_RADIO->EVENTS_DISABLED)) {}  //until radio is confirmed disabled
                                    void turnOffUarte0() {
                                    #ifndef IS_NRF51
                                      NRF_UARTE0->TASKS_STOPRX = 1;
                                      NRF_UARTE0->TASKS_STOPTX = 1;
                                      NRF_UARTE0->TASKS_SUSPEND = 1;
                                      NRF_UARTE0->ENABLE=0;  //disable UART0
                                      while (NRF_UARTE0->ENABLE!=0) {};  //wait until UART0 is confirmed disabled.
                                    #ifdef IS_NRF51
                                      NRF_UART0->TASKS_STOPRX = 1;
                                      NRF_UART0->TASKS_STOPTX = 1;
                                      NRF_UART0->TASKS_SUSPEND = 1;
                                      NRF_UART0->ENABLE=0;  //disable UART0
                                      while (NRF_UART0->ENABLE!=0) {};  //wait until UART0 is confirmed disabled.
                                    void turnOffAdc() {
                                    #ifndef IS_NRF51
                                      if (NRF_SAADC->ENABLE) { //if enabled, then disable the SAADC
                                        NRF_SAADC->TASKS_STOP=1;
                                        while (NRF_SAADC->EVENTS_STOPPED) {} //wait until stopping of SAADC is confirmed
                                        NRF_SAADC->ENABLE=0;  //disable the SAADC
                                        while (NRF_SAADC->ENABLE) {} //wait until the disable is confirmed
                                    void turnOffHighFrequencyClock() {
                                        NRF_CLOCK->TASKS_HFCLKSTOP = 1;
                                        while ((NRF_CLOCK->HFCLKSTAT) & 0x0100) {}  //wait as long as HF clock is still running.
                                    void mySleepPrepare()
                                      turnOffHighFrequencyClock();
                                      turnOffRadio();
                                      turnOffUarte0();
                                      //NRF_LPCOMP->PSEL=1; // monitor AIN1 (pin P0.03 on nRF52832 test board).
                                      //while (!(NRF_LPCOMP->PSEL==1)) {} //wait until confirmed
                                      NRF_LPCOMP->PSEL=3; // monitor AIN3 (pin P0.02 on nRF51822 for coincell_multisensor_v10)
                                      while (!(NRF_LPCOMP->PSEL==3)) {} //wait until confirmed
                                      NRF_LPCOMP->REFSEL=1;  // choose 1/4 VDD as the reference voltage
                                      while (!(NRF_LPCOMP->REFSEL==1)) {} //wait until confirmed
                                      NRF_LPCOMP->ANADETECT=1;  //detect UP events.
                                      while (NRF_LPCOMP->ANADETECT!=1) {} //wait until confirmed
                                      NRF_LPCOMP->INTENSET=B0100;  //Enable interrupt for UP event
                                      while (!(NRF_LPCOMP->INTENSET==B0100)) {} //wait until confirmed
                                      NRF_LPCOMP->ENABLE=1;  //Enable LPCOMP
                                      while (!(NRF_LPCOMP->ENABLE==1)) {} //wait until confirmed
                                      NRF_LPCOMP->TASKS_START=1;  //start the LPCOMP
                                      NVIC_SetPriority(LPCOMP_IRQn, 15);
                                      NVIC_ClearPendingIRQ(LPCOMP_IRQn);
                                      NVIC_EnableIRQ(LPCOMP_IRQn);
                                    void suspendLpComp() { //suspend getting more interrupts from LPCOMP before the first interrupt can be handled
                                      if ((NRF_LPCOMP->ENABLE) && (NRF_LPCOMP->EVENTS_READY)) {  //if LPCOMP is enabled
                                        NRF_LPCOMP->INTENCLR=B0100;  //disable interrupt from LPCOMP
                                        while (NRF_LPCOMP->INTENCLR==B0100) {} //wait until confirmed
                                    void resumeLpComp() { //suspend getting interrupts from LPCOMP
                                     * Setup code
                                      hwInit();
                                      disableNfc();
                                      turnOffAdc();
                                      activateLpComp();
                                      blinkityBlink(2,1);  //Signify end of setup with two quick pulses.
                                      mySleepPrepare();
                                      //NRF_CLOCK->INTENSET=B11;  //enable interrupts for EVENTS_HFCLKSTARTED and  EVENTS_LFCLKSTARTED
                                     // NRF_CLOCK->TASKS_HFCLKSTART=1;  //start the high frequency crystal oscillator clock
                                     // while (!(NRF_CLOCK->EVENTS_HFCLKSTARTED)) {} //wait until high frequency crystal oscillator clock is up to speed and working
                                      //hwPinMode(DIGITAL_INPUT_INT, INPUT_PULLUP);
                                      //buttonOneoldValue = -1;
                                      //sendBattLevel();
                                      wait(10);
                                      wait(10);
                                      sendBattLevel();
                                      sleep(10000);  //sleep for 5 seconds.
                                      mySleepPrepare();  //An ounce of prevention: Turn-off HF clock, etc, ASAP to save power, just in case the library's sleep() routine resumed them.
                                      if (button_pressed) {   //if a leak is detected
                                        suspendLpComp(); //suspend LPCOMP to prevent multiple interrupts
                                        //blinkityBlink(10,3);  //blink a lot to show that a leak was detected.
                                            wait(20);
                                            sendBattLevel();
                                        button_pressed=false;  //Clear the semaphore
                                        NRF_LPCOMP->EVENTS_UP=0;  //Clear the semaphore
                                        resumeLpComp();  //operations of LPCOMP were suspended after detecting the LPCOMP iterrupt
                                      else {
                                        blinkityBlink(1,1);  //otherwise, just one short blink to indicate the wakeup was scheduled by the RTC
                                    // * Reset events and read back on nRF52
                                    //* http://infocenter.nordicsemi.com/pdf/nRF52_Series_Migration_v1.0.pdf
                                    #if __CORTEX_M == 0x04
                                    #define NRF5_RESET_EVENT(event)                                                 \
                                            event = 0;        \
                                            (void)event
                                    #else
                                    #define NRF5_RESET_EVENT(event) event = 0
                                    // This must be in one line
                                    extern "C" { void LPCOMP_IRQHandler(void) {button_pressed=true; NRF5_RESET_EVENT(NRF_LPCOMP->EVENTS_UP); NRF_LPCOMP->EVENTS_UP=0; MY_HW_RTC->CC[0]=(MY_HW_RTC->COUNTER+2);}}
                                    I thought that I should do it like this:
                                       NRF_LPCOMP->PSEL=28; // monitor AIN3 (pin P0.02 on nRF51822 for coincell_multisensor_v10)
                                      while (!(NRF_LPCOMP->PSEL==28)) {} //wait until confirmed
                                    But then it does not seem to run the loop anymore because I do not get the 10s blink.
                                    • Tomas
                                    • T
                                      Toyman
                                      Guys, help me understand: when do I need to enable DC-DC?
                                      My breakout board consists of Ebyte module and a couple of buttons. Battery is CR2450 directly connected to the module.
                                      Do I need DC-DC?
                                      • T Toyman
                                        Do I need DC-DC?
                                        NeverDieN
                                        NeverDieN
                                        #1459
                                        @toyman With DC-DC, it uses roughly half the current during Tx and Rx. Seems like a no brainer to me, but you don't literally "need" to have it. I'm not aware of any downsides to it.
                                        T 1 Reply Last reply
                                          Toyman
                                          @neverdie thx. What is needed hardware-wise? Two inductors between dc and dec4? Like in your breakout board?
