  3. nRF5 action!
nRF5 action!
  • nagelcN
    nagelcN
    nagelc
    wrote on last edited by nagelc
    #1401
    Any suggestions how can I get serial debug messages out of the NRF52832 (Fanstel BT832)? I can upload the program over the SWD interface. I'm using a black magic probe with the Arduino NRF5 package on Windows 10. I know it works because the node shows up in my controller.
    NeverDieN 1 Reply Last reply
    • nagelcN nagelc
      NeverDieN
      NeverDieN
      #1402
      @nagelc said in nRF5 Bluetooth action!:
      Define one of the pins as serial TXO. Then connect it to RXI on an FTDI TTL-USB converter and read it that way. That's what I do, and it works.
      nagelcN 1 Reply Last reply
      • NeverDieN NeverDie
        nagelcN
        nagelcN
        nagelc
        @neverdie
        Do you define the pins in MyBoardNRF5? In MyBoadNRF5.cpp, I replaced the 0 in the first line with10, thinking this will map Arduino TX0 to P010. This did not seem to work. How do you map the TX0 pin?
        • nagelcN nagelc
          @neverdie
          NeverDieN
          NeverDieN
          #1404
          @nagelc No, you want to change the values in the MyBoardNRF5.h file instead. For an example, see the source code in: https://www.openhardware.io/view/499/10-years-wireless-PIR-Sensor-on-just-one-set-of-3-AAs#tabs-source
          So, in your case, you'd want:
          #define PIN_SERIAL_TX       (10)
          and, to avoid conflicts, make sure that pin P0.10 isn't defined anywhere in the same .h file as something else already. If it is, you may need to change that as well.
          • nagelcN
            nagelcN
            nagelc
            Thanks. I'll give that a try.
            • T
              Toyman
              Yesterday, I 've got a mailing from my components' supplier featuring new type of cells, Li-MnO2. The cell has all the features needed for nRF5:
              • 1200mah capacity
              • 1.8-3.0v range
              • low cost (ca. $3)
              • 41,0 x 24,5 x 5,2 dimensions and, importantly
              • up to 120mah peak discharge current.
              The link to manufacturer:
              http://www.fanso-battery.com/Ultra-thin-Li-MnO2-battery-CP502440-3V1200mAh-pd1905.html
              Nca78N NeverDieN 2 Replies Last reply
              • T Toyman
                • 1200mah capacity
                • 1.8-3.0v range
                • low cost (ca. $3)
                Nca78N
                Nca78N
                @toyman said in nRF5 Bluetooth action!:
                • 1200mah capacity
                • 1.8-3.0v range
                • low cost (ca. $3)
                Mhmhmh, a disposable battery that you have to solder I can't see it as a good idea for a node...
                T 1 Reply Last reply
                • Nca78N Nca78
                  • 1200mah capacity
                  • 1.8-3.0v range
                  • low cost (ca. $3)
                  Toyman
                  @nca78 said in nRF5 Bluetooth action!:
                  • 1200mah capacity
                  • 1.8-3.0v range
                  • low cost (ca. $3)
                  well, 1200mah will last AT LEAST for a year (two in real life). I have no issues resoldering 2 joints once a year, given it gives AAA capacity in a much smaller package
                  • NeverDieN
                    NeverDieN
                    Speaking of batteries, I found only one proper holder for holding two CR2032's in series:
                    It turns out you pretty much need the plastic carrier to guarantee that the edge of the button cell doesn't short out against the side of the metal holding bracket.
                    d00616D 1 Reply Last reply
                      d00616D
                      d00616D
                      d00616
                      @neverdie said in nRF5 Bluetooth action!:
                      There are CR2477 (560mAh) or CR2450 (950mAh) 3V cells. Maybe its's better to handle.
                      • T Toyman
                        • 1200mah capacity
                        • 1.8-3.0v range
                        • low cost (ca. $3)
                        NeverDieN
                        NeverDieN
                        #1411
                        Footprint seems kinda large, at least for nodes intended to be small. It trades off length in order to get thin. In contrast, a CR123 is shorter (34.5mm), but thicker (17mm), but can deliver 1.5a continuous (which makes it very tempting for powering a PA):
                        https://www.batteryjunction.com/energizer-cr123a.html
                        On the other hand, when you add the CR123 holder, the length may be comparable.
                        If you decide to try out the fanso, please do let us know how you like it.
                        • d00616D d00616
                          NeverDieN
                          NeverDieN
                          Good point. I think maybe the only actual justified use of two CR2032's in series is to power the AM612, which requires a voltage of at least 2.7v.
                          • O
                            O
                            Omemanti
                            Did someone get an NRF52 working with an ESP8266(ESP32) and successfully connected it to a controller?
                            Since my controller is something stuffed away in a closet, Id like to have a gateway that's positioned more centralized. An ESP+NRF52832 would be a lovely cost-efficient solution.
                            • O Omemanti
                              NeverDieN
                              NeverDieN
                              #1414
                              @omemanti said in nRF5 Bluetooth action!:
                              Yes: https://www.openhardware.io/view/491/PA-LNA-nRF52832-ESP-LINK-Shield-for-Wemos-D1-Mini-ESP8266
                              Works great! :)
                              O 1 Reply Last reply
                                Works great! :)
                                O
                                O
                                Omemanti
                                @neverdie ah thnx. I'll try it out with my nodemcu+ebyte
                                  nagelcN
                                  nagelcN
                                  nagelc
                                  @neverdie
                                  It worked! I used pin 26 as in your example and now can get the debug messages. Also thanks for the many other NRF5 routines you had in the example.
                                  • O
                                    O
                                    Omemanti
                                    wrote on last edited by Omemanti
                                    #1417
                                    How can I connect to DEC5 as an I/O when using MyBoardNRF5?
                                    The Ebyte Module Datasheet says: 14 DEC5 Input/Output MCU GPIO to it should be possible?
                                    • O Omemanti
                                      NeverDieN
                                      NeverDieN
                                      #1418
                                      @omemanti Suggest you check the Nordic datasheet on that rather than rely on the Ebyte documentation. IIRC, the DECT pins are not GPIO, but it's worth your double checking the nRF52 datasheet if it's important to you.
                                        O
                                        O
                                        Omemanti
                                        #1419
                                        @neverdie, Indeed, I checked and it was false. well goes to show that late-night prototyping has some disadvantages, my bad, :)
                                        Deleted Following up question..
                                        DK =>Ebyte module
                                        GND(detect) => GND
                                        SWDIO => SWDIO
                                        SWDCLK => SWCLK
                                        VTG => 3,3V
                                        3,3V => 3,3V
                                        GND =>GND
                                        • Nca78N
                                          Nca78N
                                          Has anyone succeeded in programming the WT51822-S4AT module (the cheapest and tiny nrf51822 module on AliExpress) using NRF52 DK ?
                                          I pulled a lot of hair trying to find out what I did wrong with my board, I soldered an adapter to make sure I didn't have problems with faulty jumper wires etc, I reinstalled JLink and Nordic software, in the end I desoldered everything on my board, then the module itself to program it independantly. It always failed and JLink couldn't connect to it. I tried the other spare one I had, same result. I tried the one I'm sure I managed to program long ago with a jlink clone, always the same result.
                                          Then I tried with an old nrf51822 module I bought long ago on AliExpress, and no problem !
                                          Has anyone had similar problems ? Is there something special hardware wise that I should check ?
