  3. Browser-based firmware generator
108 Posts 14 Posters 54.2k Views 18 Watching
  • U user2684
    @rakeshpai FYI I'm making some good progress with the new version of NodeManager (https://github.com/mysensors/NodeManager/milestones) thanks also to the many users contributing :-) However, the list of things to do is still pretty long and last thing I want to do is to keep your amazing project on hold depending on mine. So whenever you are almost ready, just let me know so that I can push some of the less critical requests I have on the list to another release and hurry up to finalize the current one I'm working on. Whenever you will tell me "I'm ready", I expect at least a couple of weeks for me to finalize the current code and test the release before will be made available. Thanks
    rakeshpaiR
    rakeshpaiR
    rakeshpai
    @user2684 Thanks for the update. Much appreciated.
    The thing is, I think it'll be really great if this project can come to a point where I can confidently tell people that they can flash the output code to their devices, at least in a test setup, so that I can start to get some usage-based feedback. So far, I've very vocally said that the output isn't ready, and that's definitely limiting usage.
    So, I wouldn't say it's urgent, but user-feedback is important, so I'd like to start making releases that I can ask people to try.
    U 1 Reply Last reply
    • rakeshpaiR rakeshpai
      U
      U
      user2684
      @rakeshpai fully agree with you. I'll start working in order to push those changes which are not a priority or too complex to implement to a future release in order to finalize v1.6 asap and give you the time to start working with something stable. Mean while I'll let you know once the development code will be good enough to start working on it. I can probably target a final v1.6 by end of August and a stable version in a couple of weeks if it fits your plans. I've also created a specific thread we can use to discuss about the integration (https://forum.mysensors.org/topic/7212/integrating-nodemanager-with-sketch-generator) so to keep this as clean as possible from implementation details. Thanks!
      • rakeshpaiR
        rakeshpaiR
        rakeshpai
        Sorry for the long silence. it might look like I've been slacking off (and that's mostly true), but I've also been rolling out some updates:
        • Code can now either be downloaded for the Arduino IDE or for the PlatformIO IDE. The PlatformIO code generates additional config files to use their dependency manager automatically. This means, you don't have to download and install libraries manually. Just open in PlatformIO and build the project. It's magical.
        • Also, you can now download a backup zip of everything. It contains code for the entire network and all it's nodes, and a network.json file. I haven't implemented a 'restore' functionality yet (coming soon), but the network.json file contains everything needed for a restore. The network.json is the internal state data-structure used by the app.
        • Couple of minor performance improvements, especially to help with the first-ever-visit scenario. (All subsequent user actions are blazing fast anyway.)
        To clarify, while backups are a great idea, you don't need to save anything. Stuff is still automatically saved in the browser's storage anyway during regular use, and is persisted even if you close the browser. Backups are for the assurance of having a neat little zip containing everything on your hard drive, just in case things go horribly wrong.
        Very little has changed visually. To find these new features, launch the app, and click the 'hamburger menu' at the top right of the page.
        https://rakeshpai.github.io/mysensors-network-manager/
        • rakeshpaiR
          rakeshpaiR
          rakeshpai
          wrote on last edited by rakeshpai
          #104
          Pretty big update: Added the ability to select the board that the node/gateway is based on. Supported boards are: Pro Mini (5v and 3.3v), Nano and Uno for the atmega328 boards, and NodeMCU and D1 Mini for the esp8266 boards. Please let me know if your favourite board isn't listed here.
          The selection of the board effects the list of available pins for sensors. The sense pin dropdown for sensors now shows the appropriate pins (analog/digital/interrupt pins) based on the board selected for the node and the type of sensor being configured.
          The selected board also affects the platformio.ini file generated, which makes PlatformIO integration even more enjoyable to use. No need to specify the board during the build.
          This was a pretty big update, including changes to the underlying internal datastructure itself, so it's also an acid test for the data migration and versioning system implemented before. If you don't see any errors when you refresh after the update, it means everything worked transparently, and that's great news! (The migration mechanism hasn't been tested so far, so please let me know if you see errors when you get the update.)
          Also implemented a reporting interval setting for analog sensors, to bring it in line with the latest changes in NodeManager.
          We're getting closer to being release-ready!
          EDIT: Also, this project crossed 100 commits in GitHub already! Wow!
          • alowhumA
            alowhumA
            alowhum
            @rakeshpai , is this project still being developed? The Github page seems to indicate the last development was a year ago. Is there more development in secret? I really like it.
            My dream solution for beginners usability would be a web interface where you can manage the network and the Arduino code. Users then connect an Arduino Nano or Micro:bit to the Raspberry Pi, and press the 'upload code' button for a specific device.
            That way they don't need to install the Arduino IDE on their own laptops, but it can be incorporated into a smart home disk image instead.
            *dreams on
            bjacobseB 1 Reply Last reply
            • alowhumA alowhum
              *dreams on
              bjacobseB
              bjacobseB
              bjacobse
              @alowhum
              If you take a look at the gitpage:
              Quote: "mysensors-network-manager
              A web-based tool to generate firmware for MySensors nodes.
              It buggy, incomplete, it doesn't even work. Don't use this for anything important."
              https://github.com/rakeshpai/mysensors-network-manager
              alowhumA 1 Reply Last reply
              • bjacobseB bjacobse
                @alowhum
                alowhumA
                alowhumA
                alowhum
                @bjacobse Yes I know, but I was hoping that the latest code hadn't reached Github. And that there could be some explanation of that claim. It seemed to work ok when I tried it, and the interface looks really good.
                rakeshpaiR 1 Reply Last reply
                • alowhumA alowhum
                  rakeshpaiR
                  rakeshpaiR
                  rakeshpai
                  @alowhum Sorry, I have abandoned this project. It didn't garner the interest I hoped it would, and I’ve moved on to other microcontrollers/radios/networks since then. This is hosted on GitHub’s free static hosting, so it should continue to work as long as they are in business, and it should work on devices as it was 5-6 years ago. But I won’t be supporting it and won’t continue to build on it. Glad to hear that you like it!
