  3. Message is send twice
27 Posts 4 Posters 7.0k Views 4 Watching
    If it is a battery powered node you need to use the sleep function to put the node into low power mode.
    • E esawyja
      @core_c I'm sorry I do not understand, must I replace this in loop
      sleep(digitalPinToInterrupt(GENERATOR_PIN), CHANGE, sleep_time_left);
      With this in setup?
      attachInterrupt(digitalPinToInterrupt(GENERATOR_PIN), generator_pin_interrupt_handler, CHANGE);
      Sorry for all the questions!! This is sooo confusing to me, it also seems that the battery level is not sending, I left it running for 12 hours plus and never got a reading, the line
      #define BATTERY_REPORT_INTERVAL 60000
      Does this define that the battery level must be send ever 60000 milli seconds?
      core_cC
      core_cC
      core_c
      @esawyja i made the changes for you in my post made earlier^^
      E 1 Reply Last reply
      • core_cC core_c
        E
        E
        esawyja
        @core_c Thanks so much, I will try these changes!
        • core_cC
          core_cC
          core_c
          About your battery level send question, here's some explanation:
          The intention is to let your node sleep when nothing happens.
          Only when the generator pin changes, it interrupts the sleep cycle, and wakes up the node. It then checks the current generator pin state and sends the appropriate message. Then it goes to sleep again.
          However, it does not sleep forever. At regular intervals the battery level is send. So every BATTERY_REPORT_INTERVAL milliseconds the current sleep cycle ends (because the timer has counted down and reached its end), and the battery level is send.
          The program keeps doing this: Sleep, and wake up if the pin changed, and/or wake up when the battery level should be send.
          E 2 Replies Last reply
          • core_cC core_c
            E
            E
            esawyja
            @core_c Thanks, I will try all the changes, thanks again for the code!!
            • core_cC core_c
              E
              E
              esawyja
              @core_c I'm still having problems with this, the generator running or not works a treat, but if I just reboot the node and leave it, it goes through the sleep from what I can see, but then nothing happens after that, it does not send the battery level, it just hangs. Also the #define BATTERY_REPORT_INTERVAL 3000 does not work correctly, I've set it to 3000 as a test and it definitely took longer than 3000 MS, the complete serial log is pasted below, I did not trigger the generator during this period
              0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
              4 TSM:INIT
              4 TSF:WUR:MS=1000
              8 TSM:INIT:TSP OK
              10 TSM:INIT:STATID=11
              12 TSF:SID:OK,ID=11
              14 TSM:FPAR
              145 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              395 TSF:MSG:READ,0-0-11,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              401 TSF:MSG:FPAR OK,ID=0,D=1
              1007 MCO:BGN:STP
              1007 !MCO:SND:NODE NOT REG
              2152 TSM:FPAR:OK
              2152 TSM:ID
              2154 TSM:ID:OK
              2156 TSM:UPL
              2164 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2215 TSF:MSG:READ,0-0-11,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2222 TSF:MSG:PONG RECV,HP=1
              2224 TSM:UPL:OK
              2226 TSM:READY:ID=11,PAR=0,DIS=1
              2238 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2289 TSF:MSG:READ,0-0-11,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2304 TSF:MSG:SEND,11-11-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
              2320 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              4327 MCO:REG:REQ
              4335 TSF:MSG:SEND,11-11-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              4386 TSF:MSG:READ,0-0-11,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              4392 MCO:PIM:NODE REG=1
              11018 TSF:MSG:SEND,11-11-0-0,s=6,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
              Generator message sent
              11026 MCO:BGN:INIT OK,TSP=1
              11030 MCO:SLP:MS=2996,SMS=0,I1=1,M1=1,I2=255,M2=255
              11036 MCO:SLP:TPD
              11038 MCO:SLP:WUP=-1
              11042 MCO:SLP:MS=2984,SMS=0,I1=1,M1=1,I2=255,M2=255
              11046 MCO:SLP:TPD
              11051 MCO:SLP:WUP=-1
              11053 MCO:SLP:MS=2973,SMS=0,I1=1,M1=1,I2=255,M2=255
              11059 MCO:SLP:TPD
              11061 MCO:SLP:WUP=-1
              11063 MCO:SLP:MS=2963,SMS=0,I1=1,M1=1,I2=255,M2=255
              11069 MCO:SLP:TPD
              11071 MCO:SLP:WUP=-1
              11073 MCO:SLP:MS=2953,SMS=0,I1=1,M1=1,I2=255,M2=255
              11079 MCO:SLP:TPD
              11081 MCO:SLP:WUP=-1
              11085 MCO:SLP:MS=2941,SMS=0,I1=1,M1=1,I2=255,M2=255
              11089 MCO:SLP:TPD
              11094 MCO:SLP:WUP=-1
              11096 MCO:SLP:MS=2930,SMS=0,I1=1,M1=1,I2=255,M2=255
              11102 MCO:SLP:TPD
              11104 MCO:SLP:WUP=-1
              11106 MCO:SLP:MS=2920,SMS=0,I1=1,M1=1,I2=255,M2=255
              11112 MCO:SLP:TPD
              11114 MCO:SLP:WUP=-1
              11118 MCO:SLP:MS=2908,SMS=0,I1=1,M1=1,I2=255,M2=255
              11122 MCO:SLP:TPD
              11124 MCO:SLP:WUP=-1
              11128 MCO:SLP:MS=2898,SMS=0,I1=1,M1=1,I2=255,M2=255
              11134 MCO:SLP:TPD
              11137 MCO:SLP:WUP=-1
              11139 MCO:SLP:MS=2887,SMS=0,I1=1,M1=1,I2=255,M2=255
              11145 MCO:SLP:TPD
              11147 MCO:SLP:WUP=-1
              11149 MCO:SLP:MS=2877,SMS=0,I1=1,M1=1,I2=255,M2=255
              11155 MCO:SLP:TPD
              11157 MCO:SLP:WUP=-1
              11161 MCO:SLP:MS=2865,SMS=0,I1=1,M1=1,I2=255,M2=255
              11165 MCO:SLP:TPD
              11167 MCO:SLP:WUP=-1
              11171 MCO:SLP:MS=2855,SMS=0,I1=1,M1=1,I2=255,M2=255
              11177 MCO:SLP:TPD
              11180 MCO:SLP:WUP=-1
              11182 MCO:SLP:MS=2844,SMS=0,I1=1,M1=1,I2=255,M2=255
              11188 MCO:SLP:TPD
              11190 MCO:SLP:WUP=-1
              11192 MCO:SLP:MS=2834,SMS=0,I1=1,M1=1,I2=255,M2=255
              11198 MCO:SLP:TPD
              11200 MCO:SLP:WUP=-1
              11204 MCO:SLP:MS=2822,SMS=0,I1=1,M1=1,I2=255,M2=255
              11208 MCO:SLP:TPD
              11212 MCO:SLP:WUP=-1
              11214 MCO:SLP:MS=2812,SMS=0,I1=1,M1=1,I2=255,M2=255
              11220 MCO:SLP:TPD
              11223 MCO:SLP:WUP=-1
              11225 MCO:SLP:MS=2801,SMS=0,I1=1,M1=1,I2=255,M2=255
              11231 MCO:SLP:TPD
              11233 MCO:SLP:WUP=-1
              11235 MCO:SLP:MS=2791,SMS=0,I1=1,M1=1,I2=255,M2=255
              11241 MCO:SLP:TPD
              11243 MCO:SLP:WUP=-1
              11247 MCO:SLP:MS=2779,SMS=0,I1=1,M1=1,I2=255,M2=255
              11251 MCO:SLP:TPD
              11255 MCO:SLP:WUP=-1
              11257 MCO:SLP:MS=2769,SMS=0,I1=1,M1=1,I2=255,M2=255
              11264 MCO:SLP:TPD
              11266 MCO:SLP:WUP=-1
              11268 MCO:SLP:MS=2758,SMS=0,I1=1,M1=1,I2=255,M2=255
              11274 MCO:SLP:TPD
              11276 MCO:SLP:WUP=-1
              11278 MCO:SLP:MS=2748,SMS=0,I1=1,M1=1,I2=255,M2=255
              11284 MCO:SLP:TPD
              11286 MCO:SLP:WUP=-1
              11290 MCO:SLP:MS=2736,SMS=0,I1=1,M1=1,I2=255,M2=255
              11294 MCO:SLP:TPD
              11298 MCO:SLP:WUP=-1
              11300 MCO:SLP:MS=2726,SMS=0,I1=1,M1=1,I2=255,M2=255
              11307 MCO:SLP:TPD
              11309 MCO:SLP:WUP=-1
              11311 MCO:SLP:MS=2715,SMS=0,I1=1,M1=1,I2=255,M2=255
              11317 MCO:SLP:TPD
              11319 MCO:SLP:WUP=-1
              11323 MCO:SLP:MS=2703,SMS=0,I1=1,M1=1,I2=255,M2=255
              11327 MCO:SLP:TPD
              11329 MCO:SLP:WUP=-1
              11333 MCO:SLP:MS=2693,SMS=0,I1=1,M1=1,I2=255,M2=255
              11339 MCO:SLP:TPD
              11341 MCO:SLP:WUP=-1
              11343 MCO:SLP:MS=2683,SMS=0,I1=1,M1=1,I2=255,M2=255
              11350 MCO:SLP:TPD
              11352 MCO:SLP:WUP=-1
              11354 MCO:SLP:MS=2672,SMS=0,I1=1,M1=1,I2=255,M2=255
              11360 MCO:SLP:TPD
              11362 MCO:SLP:WUP=-1
              11366 MCO:SLP:MS=2660,SMS=0,I1=1,M1=1,I2=255,M2=255
              11370 MCO:SLP:TPD
              11372 MCO:SLP:WUP=-1
              11376 MCO:SLP:MS=2650,SMS=0,I1=1,M1=1,I2=255,M2=255
              11382 MCO:SLP:TPD
              11384 MCO:SLP:WUP=-1
              11386 MCO:SLP:MS=2640,SMS=0,I1=1,M1=1,I2=255,M2=255
              11393 MCO:SLP:TPD
              11395 MCO:SLP:WUP=-1
              11397 MCO:SLP:MS=2629,SMS=0,I1=1,M1=1,I2=255,M2=255
              11403 MCO:SLP:TPD
              11405 MCO:SLP:WUP=-1
              11409 MCO:SLP:MS=2617,SMS=0,I1=1,M1=1,I2=255,M2=255
              11413 MCO:SLP:TPD
              11415 MCO:SLP:WUP=-1
              11419 MCO:SLP:MS=2607,SMS=0,I1=1,M1=1,I2=255,M2=255
              11425 MCO:SLP:TPD
              11427 MCO:SLP:WUP=-1
              11429 MCO:SLP:MS=2597,SMS=0,I1=1,M1=1,I2=255,M2=255
              11436 MCO:SLP:TPD
              11438 MCO:SLP:WUP=-1
              11440 MCO:SLP:MS=2586,SMS=0,I1=1,M1=1,I2=255,M2=255
              11446 MCO:SLP:TPD
              11448 MCO:SLP:WUP=-1
              11452 MCO:SLP:MS=2574,SMS=0,I1=1,M1=1,I2=255,M2=255
              11456 MCO:SLP:TPD
              11458 MCO:SLP:WUP=-1
              11462 MCO:SLP:MS=2564,SMS=0,I1=1,M1=1,I2=255,M2=255
              11468 MCO:SLP:TPD
              11470 MCO:SLP:WUP=-1
              11472 MCO:SLP:MS=2554,SMS=0,I1=1,M1=1,I2=255,M2=255
              11479 MCO:SLP:TPD
              11481 MCO:SLP:WUP=-1
              11483 MCO:SLP:MS=2543,SMS=0,I1=1,M1=1,I2=255,M2=255
              11489 MCO:SLP:TPD
              11491 MCO:SLP:WUP=-1
              11495 MCO:SLP:MS=2531,SMS=0,I1=1,M1=1,I2=255,M2=255
              11499 MCO:SLP:TPD
              11503 MCO:SLP:WUP=-1
              11505 MCO:SLP:MS=2521,SMS=0,I1=1,M1=1,I2=255,M2=255
              11511 MCO:SLP:TPD
              11513 MCO:SLP:WUP=-1
              11515 MCO:SLP:MS=2511,SMS=0,I1=1,M1=1,I2=255,M2=255
              11522 MCO:SLP:TPD
              11524 MCO:SLP:WUP=-1
              11526 MCO:SLP:MS=2500,SMS=0,I1=1,M1=1,I2=255,M2=255
              11532 MCO:SLP:TPD
              11534 MCO:SLP:WUP=-1
              11538 MCO:SLP:MS=2488,SMS=0,I1=1,M1=1,I2=255,M2=255
              11542 MCO:SLP:TPD
              11544 MCO:SLP:WUP=-1
              11548 MCO:SLP:MS=2478,SMS=0,I1=1,M1=1,I2=255,M2=255
              11554 MCO:SLP:TPD
              11556 MCO:SLP:WUP=-1
              11558 MCO:SLP:MS=2468,SMS=0,I1=1,M1=1,I2=255,M2=255
              11565 MCO:SLP:TPD
              11567 MCO:SLP:WUP=-1
              11569 MCO:SLP:MS=2457,SMS=0,I1=1,M1=1,I2=255,M2=255
              11575 MCO:SLP:TPD
              11577 MCO:SLP:WUP=-1
              11581 MCO:SLP:MS=2445,SMS=0,I1=1,M1=1,I2=255,M2=255
              11585 MCO:SLP:TPD
              11589 MCO:SLP:WUP=-1
              11591 MCO:SLP:MS=2435,SMS=0,I1=1,M1=1,I2=255,M2=255
              11597 MCO:SLP:TPD
              11599 MCO:SLP:WUP=-1
              11601 MCO:SLP:MS=2425,SMS=0,I1=1,M1=1,I2=255,M2=255
              11608 MCO:SLP:TPD
              11610 MCO:SLP:WUP=-1
              11612 MCO:SLP:MS=2414,SMS=0,I1=1,M1=1,I2=255,M2=255
              11618 MCO:SLP:TPD
              11620 MCO:SLP:WUP=-1
              11624 MCO:SLP:MS=2402,SMS=0,I1=1,M1=1,I2=255,M2=255
              11628 MCO:SLP:TPD
              11632 MCO:SLP:WUP=-1
              11634 MCO:SLP:MS=2392,SMS=0,I1=1,M1=1,I2=255,M2=255
              11640 MCO:SLP:TPD
              11642 MCO:SLP:WUP=-1
              11644 MCO:SLP:MS=2382,SMS=0,I1=1,M1=1,I2=255,M2=255
              11651 MCO:SLP:TPD
              11653 MCO:SLP:WUP=-1
              11655 MCO:SLP:MS=2371,SMS=0,I1=1,M1=1,I2=255,M2=255
              11661 MCO:SLP:TPD
              11663 MCO:SLP:WUP=-1
              11667 MCO:SLP:MS=2359,SMS=0,I1=1,M1=1,I2=255,M2=255
              11671 MCO:SLP:TPD
              11675 MCO:SLP:WUP=-1
              11677 MCO:SLP:MS=2349,SMS=0,I1=1,M1=1,I2=255,M2=255
              11683 MCO:SLP:TPD
              11685 MCO:SLP:WUP=-1
              11687 MCO:SLP:MS=2339,SMS=0,I1=1,M1=1,I2=255,M2=255
              11694 MCO:SLP:TPD
              11696 MCO:SLP:WUP=-1
              11698 MCO:SLP:MS=2328,SMS=0,I1=1,M1=1,I2=255,M2=255
              11704 MCO:SLP:TPD
              11706 MCO:SLP:WUP=-1
              11710 MCO:SLP:MS=2316,SMS=0,I1=1,M1=1,I2=255,M2=255
              11714 MCO:SLP:TPD
              11716 MCO:SLP:WUP=-1
              11720 MCO:SLP:MS=2306,SMS=0,I1=1,M1=1,I2=255,M2=255
              11726 MCO:SLP:TPD
              11728 MCO:SLP:WUP=-1
              11730 MCO:SLP:MS=2296,SMS=0,I1=1,M1=1,I2=255,M2=255
              11737 MCO:SLP:TPD
              11739 MCO:SLP:WUP=-1
              11741 MCO:SLP:MS=2285,SMS=0,I1=1,M1=1,I2=255,M2=255
              11747 MCO:SLP:TPD
              11749 MCO:SLP:WUP=-1
              11753 MCO:SLP:MS=2273,SMS=0,I1=1,M1=1,I2=255,M2=255
              11757 MCO:SLP:TPD
              11759 MCO:SLP:WUP=-1
              11763 MCO:SLP:MS=2263,SMS=0,I1=1,M1=1,I2=255,M2=255
              11769 MCO:SLP:TPD
              11771 MCO:SLP:WUP=-1
              11773 MCO:SLP:MS=2253,SMS=0,I1=1,M1=1,I2=255,M2=255
              11780 MCO:SLP:TPD
              11782 MCO:SLP:WUP=-1
              11784 MCO:SLP:MS=2242,SMS=0,I1=1,M1=1,I2=255,M2=255
              11790 MCO:SLP:TPD
              11792 MCO:SLP:WUP=-1
              11796 MCO:SLP:MS=2230,SMS=0,I1=1,M1=1,I2=255,M2=255
              11800 MCO:SLP:TPD
              11802 MCO:SLP:WUP=-1
              11806 MCO:SLP:MS=2220,SMS=0,I1=1,M1=1,I2=255,M2=255
              11812 MCO:SLP:TPD
              11814 MCO:SLP:WUP=-1
              11816 MCO:SLP:MS=2210,SMS=0,I1=1,M1=1,I2=255,M2=255
              11823 MCO:SLP:TPD
              11825 MCO:SLP:WUP=-1
              11827 MCO:SLP:MS=2199,SMS=0,I1=1,M1=1,I2=255,M2=255
              11833 MCO:SLP:TPD
              11835 MCO:SLP:WUP=-1
              11839 MCO:SLP:MS=2187,SMS=0,I1=1,M1=1,I2=255,M2=255
              11843 MCO:SLP:TPD
              11845 MCO:SLP:WUP=-1
              11849 MCO:SLP:MS=2177,SMS=0,I1=1,M1=1,I2=255,M2=255
              11855 MCO:SLP:TPD
              11857 MCO:SLP:WUP=-1
              11859 MCO:SLP:MS=2167,SMS=0,I1=1,M1=1,I2=255,M2=255
              11866 MCO:SLP:TPD
              11868 MCO:SLP:WUP=-1
              11870 MCO:SLP:MS=2156,SMS=0,I1=1,M1=1,I2=255,M2=255
              11876 MCO:SLP:TPD
              11878 MCO:SLP:WUP=-1
              11882 MCO:SLP:MS=2146,SMS=0,I1=1,M1=1,I2=255,M2=255
              11886 MCO:SLP:TPD
              11888 MCO:SLP:WUP=-1
              11892 MCO:SLP:MS=2134,SMS=0,I1=1,M1=1,I2=255,M2=255
              11898 MCO:SLP:TPD
              11900 MCO:SLP:WUP=-1
              11902 MCO:SLP:MS=2124,SMS=0,I1=1,M1=1,I2=255,M2=255
              11909 MCO:SLP:TPD
              11911 MCO:SLP:WUP=-1
              11913 MCO:SLP:MS=2113,SMS=0,I1=1,M1=1,I2=255,M2=255
              11919 MCO:SLP:TPD
              11921 MCO:SLP:WUP=-1
              11923 MCO:SLP:MS=2103,SMS=0,I1=1,M1=1,I2=255,M2=255
              11929 MCO:SLP:TPD
              11931 MCO:SLP:WUP=-1
              11935 MCO:SLP:MS=2091,SMS=0,I1=1,M1=1,I2=255,M2=255
              11939 MCO:SLP:TPD
              11943 MCO:SLP:WUP=-1
              11945 MCO:SLP:MS=2081,SMS=0,I1=1,M1=1,I2=255,M2=255
              11952 MCO:SLP:TPD
              11954 MCO:SLP:WUP=-1
              11956 MCO:SLP:MS=2070,SMS=0,I1=1,M1=1,I2=255,M2=255
              11962 MCO:SLP:TPD
              11964 MCO:SLP:WUP=-1
              11966 MCO:SLP:MS=2060,SMS=0,I1=1,M1=1,I2=255,M2=255
              11972 MCO:SLP:TPD
              11974 MCO:SLP:WUP=-1
              11978 MCO:SLP:MS=2048,SMS=0,I1=1,M1=1,I2=255,M2=255
              11982 MCO:SLP:TPD
              11984 MCO:SLP:WUP=-1
              11988 MCO:SLP:MS=2038,SMS=0,I1=1,M1=1,I2=255,M2=255
              11995 MCO:SLP:TPD
              11997 MCO:SLP:WUP=-1
              11999 MCO:SLP:MS=2027,SMS=0,I1=1,M1=1,I2=255,M2=255
              12005 MCO:SLP:TPD
              12007 MCO:SLP:WUP=-1
              12009 MCO:SLP:MS=2017,SMS=0,I1=1,M1=1,I2=255,M2=255
              12015 MCO:SLP:TPD
              12017 MCO:SLP:WUP=-1
              12019 MCO:SLP:MS=2007,SMS=0,I1=1,M1=1,I2=255,M2=255
              12025 MCO:SLP:TPD
              12027 MCO:SLP:WUP=-1
              12032 MCO:SLP:MS=1994,SMS=0,I1=1,M1=1,I2=255,M2=255
              12036 MCO:SLP:TPD
              12040 MCO:SLP:WUP=-1
              12042 MCO:SLP:MS=1984,SMS=0,I1=1,M1=1,I2=255,M2=255
              12048 MCO:SLP:TPD
              12050 MCO:SLP:WUP=-1
              12052 MCO:SLP:MS=1974,SMS=0,I1=1,M1=1,I2=255,M2=255
              12058 MCO:SLP:TPD
              12060 MCO:SLP:WUP=-1
              12062 MCO:SLP:MS=1964,SMS=0,I1=1,M1=1,I2=255,M2=255
              12068 MCO:SLP:TPD
              12070 MCO:SLP:WUP=-1
              12075 MCO:SLP:MS=1951,SMS=0,I1=1,M1=1,I2=255,M2=255
              12079 MCO:SLP:TPD
              12083 MCO:SLP:WUP=-1
              12085 MCO:SLP:MS=1941,SMS=0,I1=1,M1=1,I2=255,M2=255
              12091 MCO:SLP:TPD
              12093 MCO:SLP:WUP=-1
              12095 MCO:SLP:MS=1931,SMS=0,I1=1,M1=1,I2=255,M2=255
              12101 MCO:SLP:TPD
              12103 MCO:SLP:WUP=-1
              12105 MCO:SLP:MS=1921,SMS=0,I1=1,M1=1,I2=255,M2=255
              12111 MCO:SLP:TPD
              12113 MCO:SLP:WUP=-1
              12118 MCO:SLP:MS=1908,SMS=0,I1=1,M1=1,I2=255,M2=255
              12122 MCO:SLP:TPD
              12126 MCO:SLP:WUP=-1
              12128 MCO:SLP:MS=1898,SMS=0,I1=1,M1=1,I2=255,M2=255
              12134 MCO:SLP:TPD
              12136 MCO:SLP:WUP=-1
              12138 MCO:SLP:MS=1888,SMS=0,I1=1,M1=1,I2=255,M2=255
              12144 MCO:SLP:TPD
              12146 MCO:SLP:WUP=-1
              12148 MCO:SLP:MS=1878,SMS=0,I1=1,M1=1,I2=255,M2=255
              12154 MCO:SLP:TPD
              12156 MCO:SLP:WUP=-1
              12161 MCO:SLP:MS=1865,SMS=0,I1=1,M1=1,I2=255,M2=255
              12165 MCO:SLP:TPD
              12169 MCO:SLP:WUP=-1
              12171 MCO:SLP:MS=1855,SMS=0,I1=1,M1=1,I2=255,M2=255
              12177 MCO:SLP:TPD
              12179 MCO:SLP:WUP=-1
              12181 MCO:SLP:MS=1845,SMS=0,I1=1,M1=1,I2=255,M2=255
              12187 MCO:SLP:TPD
              12189 MCO:SLP:WUP=-1
              12191 MCO:SLP:MS=1835,SMS=0,I1=1,M1=1,I2=255,M2=255
              12197 MCO:SLP:TPD
              12199 MCO:SLP:WUP=-1
              12204 MCO:SLP:MS=1822,SMS=0,I1=1,M1=1,I2=255,M2=255
              12208 MCO:SLP:TPD
              12210 MCO:SLP:WUP=-1
              12214 MCO:SLP:MS=1812,SMS=0,I1=1,M1=1,I2=255,M2=255
              12220 MCO:SLP:TPD
              12222 MCO:SLP:WUP=-1
              12224 MCO:SLP:MS=1802,SMS=0,I1=1,M1=1,I2=255,M2=255
              12230 MCO:SLP:TPD
              12232 MCO:SLP:WUP=-1
              12234 MCO:SLP:MS=1792,SMS=0,I1=1,M1=1,I2=255,M2=255
              12240 MCO:SLP:TPD
              12242 MCO:SLP:WUP=-1
              12247 MCO:SLP:MS=1779,SMS=0,I1=1,M1=1,I2=255,M2=255
              12251 MCO:SLP:TPD
              12253 MCO:SLP:WUP=-1
              12257 MCO:SLP:MS=1769,SMS=0,I1=1,M1=1,I2=255,M2=255
              12263 MCO:SLP:TPD
              12265 MCO:SLP:WUP=-1
              12267 MCO:SLP:MS=1759,SMS=0,I1=1,M1=1,I2=255,M2=255
              12273 MCO:SLP:TPD
              12275 MCO:SLP:WUP=-1
              12277 MCO:SLP:MS=1749,SMS=0,I1=1,M1=1,I2=255,M2=255
              12283 MCO:SLP:TPD
              12285 MCO:SLP:WUP=-1
              12290 MCO:SLP:MS=1736,SMS=0,I1=1,M1=1,I2=255,M2=255
              12294 MCO:SLP:TPD
              12296 MCO:SLP:WUP=-1
              12300 MCO:SLP:MS=1726,SMS=0,I1=1,M1=1,I2=255,M2=255
              12306 MCO:SLP:TPD
              12308 MCO:SLP:WUP=-1
              12310 MCO:SLP:MS=1716,SMS=0,I1=1,M1=1,I2=255,M2=255
              12316 MCO:SLP:TPD
              12318 MCO:SLP:WUP=-1
              12320 MCO:SLP:MS=1706,SMS=0,I1=1,M1=1,I2=255,M2=255
              12326 MCO:SLP:TPD
              12328 MCO:SLP:WUP=-1
              12333 MCO:SLP:MS=1693,SMS=0,I1=1,M1=1,I2=255,M2=255
              12337 MCO:SLP:TPD
              12339 MCO:SLP:WUP=-1
              12343 MCO:SLP:MS=1683,SMS=0,I1=1,M1=1,I2=255,M2=255
              12349 MCO:SLP:TPD
              12351 MCO:SLP:WUP=-1
              12353 MCO:SLP:MS=1673,SMS=0,I1=1,M1=1,I2=255,M2=255
              12359 MCO:SLP:TPD
              12361 MCO:SLP:WUP=-1
              12363 MCO:SLP:MS=1663,SMS=0,I1=1,M1=1,I2=255,M2=255
              12369 MCO:SLP:TPD
              12371 MCO:SLP:WUP=-1
              12374 MCO:SLP:MS=1652,SMS=0,I1=1,M1=1,I2=255,M2=255
              12380 MCO:SLP:TPD
              12382 MCO:SLP:WUP=-1
              12386 MCO:SLP:MS=1640,SMS=0,I1=1,M1=1,I2=255,M2=255
              12390 MCO:SLP:TPD
              12394 MCO:SLP:WUP=-1
              12396 MCO:SLP:MS=1630,SMS=0,I1=1,M1=1,I2=255,M2=255
              12402 MCO:SLP:TPD
              12404 MCO:SLP:WUP=-1
              12406 MCO:SLP:MS=1620,SMS=0,I1=1,M1=1,I2=255,M2=255
              12412 MCO:SLP:TPD
              12414 MCO:SLP:WUP=-1
              12417 MCO:SLP:MS=1609,SMS=0,I1=1,M1=1,I2=255,M2=255
              12423 MCO:SLP:TPD
              12425 MCO:SLP:WUP=-1
              12429 MCO:SLP:MS=1597,SMS=0,I1=1,M1=1,I2=255,M2=255
              12433 MCO:SLP:TPD
              12437 MCO:SLP:WUP=-1
              12439 MCO:SLP:MS=1587,SMS=0,I1=1,M1=1,I2=255,M2=255
              12445 MCO:SLP:TPD
              12447 MCO:SLP:WUP=-1
              12449 MCO:SLP:MS=1577,SMS=0,I1=1,M1=1,I2=255,M2=255
              12455 MCO:SLP:TPD
              12457 MCO:SLP:WUP=-1
              12460 MCO:SLP:MS=1566,SMS=0,I1=1,M1=1,I2=255,M2=255
              12466 MCO:SLP:TPD
              12468 MCO:SLP:WUP=-1
              12472 MCO:SLP:MS=1554,SMS=0,I1=1,M1=1,I2=255,M2=255
              12476 MCO:SLP:TPD
              12478 MCO:SLP:WUP=-1
              12482 MCO:SLP:MS=1544,SMS=0,I1=1,M1=1,I2=255,M2=255
              12488 MCO:SLP:TPD
              12490 MCO:SLP:WUP=-1
              12492 MCO:SLP:MS=1534,SMS=0,I1=1,M1=1,I2=255,M2=255
              12498 MCO:SLP:TPD
              12500 MCO:SLP:WUP=-1
              12503 MCO:SLP:MS=1523,SMS=0,I1=1,M1=1,I2=255,M2=255
              12509 MCO:SLP:TPD
              12511 MCO:SLP:WUP=-1
              12515 MCO:SLP:MS=1511,SMS=0,I1=1,M1=1,I2=255,M2=255
              12519 MCO:SLP:TPD
              12521 MCO:SLP:WUP=-1
              12525 MCO:SLP:MS=1501,SMS=0,I1=1,M1=1,I2=255,M2=255
              12531 MCO:SLP:TPD
              12533 MCO:SLP:WUP=-1
              12535 MCO:SLP:MS=1491,SMS=0,I1=1,M1=1,I2=255,M2=255
              12541 MCO:SLP:TPD
              12544 MCO:SLP:WUP=-1
              12546 MCO:SLP:MS=1480,SMS=0,I1=1,M1=1,I2=255,M2=255
              12552 MCO:SLP:TPD
              12554 MCO:SLP:WUP=-1
              12558 MCO:SLP:MS=1468,SMS=0,I1=1,M1=1,I2=255,M2=255
              12562 MCO:SLP:TPD
              12564 MCO:SLP:WUP=-1
              12568 MCO:SLP:MS=1458,SMS=0,I1=1,M1=1,I2=255,M2=255
              12574 MCO:SLP:TPD
              12576 MCO:SLP:WUP=-1
              12578 MCO:SLP:MS=1448,SMS=0,I1=1,M1=1,I2=255,M2=255
              12584 MCO:SLP:TPD
              12587 MCO:SLP:WUP=-1
              12589 MCO:SLP:MS=1437,SMS=0,I1=1,M1=1,I2=255,M2=255
              12595 MCO:SLP:TPD
              12597 MCO:SLP:WUP=-1
              12601 MCO:SLP:MS=1425,SMS=0,I1=1,M1=1,I2=255,M2=255
              12605 MCO:SLP:TPD
              12607 MCO:SLP:WUP=-1
              12611 MCO:SLP:MS=1415,SMS=0,I1=1,M1=1,I2=255,M2=255
              12617 MCO:SLP:TPD
              12619 MCO:SLP:WUP=-1
              12621 MCO:SLP:MS=1405,SMS=0,I1=1,M1=1,I2=255,M2=255
              12627 MCO:SLP:TPD
              12630 MCO:SLP:WUP=-1
              12632 MCO:SLP:MS=1394,SMS=0,I1=1,M1=1,I2=255,M2=255
              12638 MCO:SLP:TPD
              12640 MCO:SLP:WUP=-1
              12644 MCO:SLP:MS=1382,SMS=0,I1=1,M1=1,I2=255,M2=255
              12648 MCO:SLP:TPD
              12650 MCO:SLP:WUP=-1
              12654 MCO:SLP:MS=1372,SMS=0,I1=1,M1=1,I2=255,M2=255
              12658 MCO:SLP:TPD
              12662 MCO:SLP:WUP=-1
              12664 MCO:SLP:MS=1362,SMS=0,I1=1,M1=1,I2=255,M2=255
              12670 MCO:SLP:TPD
              12673 MCO:SLP:WUP=-1
              12675 MCO:SLP:MS=1351,SMS=0,I1=1,M1=1,I2=255,M2=255
              12681 MCO:SLP:TPD
              12683 MCO:SLP:WUP=-1
              12685 MCO:SLP:MS=1341,SMS=0,I1=1,M1=1,I2=255,M2=255
              12691 MCO:SLP:TPD
              12693 MCO:SLP:WUP=-1
              12697 MCO:SLP:MS=1329,SMS=0,I1=1,M1=1,I2=255,M2=255
              12701 MCO:SLP:TPD
              12705 MCO:SLP:WUP=-1
              12707 MCO:SLP:MS=1319,SMS=0,I1=1,M1=1,I2=255,M2=255
              12713 MCO:SLP:TPD
              12716 MCO:SLP:WUP=-1
              12718 MCO:SLP:MS=1308,SMS=0,I1=1,M1=1,I2=255,M2=255
              12724 MCO:SLP:TPD
              12726 MCO:SLP:WUP=-1
              12728 MCO:SLP:MS=1298,SMS=0,I1=1,M1=1,I2=255,M2=255
              12734 MCO:SLP:TPD
              12736 MCO:SLP:WUP=-1
              12740 MCO:SLP:MS=1286,SMS=0,I1=1,M1=1,I2=255,M2=255
              12744 MCO:SLP:TPD
              12748 MCO:SLP:WUP=-1
              12750 MCO:SLP:MS=1276,SMS=0,I1=1,M1=1,I2=255,M2=255
              12756 MCO:SLP:TPD
              12759 MCO:SLP:WUP=-1
              12761 MCO:SLP:MS=1265,SMS=0,I1=1,M1=1,I2=255,M2=255
              12767 MCO:SLP:TPD
              12769 MCO:SLP:WUP=-1
              12771 MCO:SLP:MS=1255,SMS=0,I1=1,M1=1,I2=255,M2=255
              12777 MCO:SLP:TPD
              12779 MCO:SLP:WUP=-1
              12783 MCO:SLP:MS=1243,SMS=0,I1=1,M1=1,I2=255,M2=255
              12787 MCO:SLP:TPD
              12791 MCO:SLP:WUP=-1
              12793 MCO:SLP:MS=1233,SMS=0,I1=1,M1=1,I2=255,M2=255
              12800 MCO:SLP:TPD
              12802 MCO:SLP:WUP=-1
              12804 MCO:SLP:MS=1222,SMS=0,I1=1,M1=1,I2=255,M2=255
              12810 MCO:SLP:TPD
              12812 MCO:SLP:WUP=-1
              12814 MCO:SLP:MS=1212,SMS=0,I1=1,M1=1,I2=255,M2=255
              12820 MCO:SLP:TPD
              12822 MCO:SLP:WUP=-1
              12826 MCO:SLP:MS=1200,SMS=0,I1=1,M1=1,I2=255,M2=255
              12830 MCO:SLP:TPD
              12832 MCO:SLP:WUP=-1
              12836 MCO:SLP:MS=1190,SMS=0,I1=1,M1=1,I2=255,M2=255
              12843 MCO:SLP:TPD
              12845 MCO:SLP:WUP=-1
              12847 MCO:SLP:MS=1179,SMS=0,I1=1,M1=1,I2=255,M2=255
              12853 MCO:SLP:TPD
              12855 MCO:SLP:WUP=-1
              12857 MCO:SLP:MS=1169,SMS=0,I1=1,M1=1,I2=255,M2=255
              12863 MCO:SLP:TPD
              12865 MCO:SLP:WUP=-1
              12869 MCO:SLP:MS=1157,SMS=0,I1=1,M1=1,I2=255,M2=255
              12873 MCO:SLP:TPD
              12875 MCO:SLP:WUP=-1
              12879 MCO:SLP:MS=1147,SMS=0,I1=1,M1=1,I2=255,M2=255
              12886 MCO:SLP:TPD
              12888 MCO:SLP:WUP=-1
              12890 MCO:SLP:MS=1136,SMS=0,I1=1,M1=1,I2=255,M2=255
              12896 MCO:SLP:TPD
              12898 MCO:SLP:WUP=-1
              12900 MCO:SLP:MS=1126,SMS=0,I1=1,M1=1,I2=255,M2=255
              12906 MCO:SLP:TPD
              12908 MCO:SLP:WUP=-1
              12912 MCO:SLP:MS=1114,SMS=0,I1=1,M1=1,I2=255,M2=255
              12916 MCO:SLP:TPD
              12918 MCO:SLP:WUP=-1
              12922 MCO:SLP:MS=1104,SMS=0,I1=1,M1=1,I2=255,M2=255
              12929 MCO:SLP:TPD
              12931 MCO:SLP:WUP=-1
              12933 MCO:SLP:MS=1093,SMS=0,I1=1,M1=1,I2=255,M2=255
              12939 MCO:SLP:TPD
              12941 MCO:SLP:WUP=-1
              12943 MCO:SLP:MS=1083,SMS=0,I1=1,M1=1,I2=255,M2=255
              12949 MCO:SLP:TPD
              12951 MCO:SLP:WUP=-1
              12955 MCO:SLP:MS=1071,SMS=0,I1=1,M1=1,I2=255,M2=255
              12959 MCO:SLP:TPD
              12961 MCO:SLP:WUP=-1
              12965 MCO:SLP:MS=1061,SMS=0,I1=1,M1=1,I2=255,M2=255
              12972 MCO:SLP:TPD
              12974 MCO:SLP:WUP=-1
              12976 MCO:SLP:MS=1050,SMS=0,I1=1,M1=1,I2=255,M2=255
              12982 MCO:SLP:TPD
              12984 MCO:SLP:WUP=-1
              12986 MCO:SLP:MS=1040,SMS=0,I1=1,M1=1,I2=255,M2=255
              12992 MCO:SLP:TPD
              12994 MCO:SLP:WUP=-1
              12998 MCO:SLP:MS=1028,SMS=0,I1=1,M1=1,I2=255,M2=255
              13002 MCO:SLP:TPD
              13004 MCO:SLP:WUP=-1
              13008 MCO:SLP:MS=1018,SMS=0,I1=1,M1=1,I2=255,M2=255
              13015 MCO:SLP:TPD
              13017 MCO:SLP:WUP=-1
              13019 MCO:SLP:MS=1007,SMS=0,I1=1,M1=1,I2=255,M2=255
              13025 MCO:SLP:TPD
              13027 MCO:SLP:WUP=-1
              13029 MCO:SLP:MS=997,SMS=0,I1=1,M1=1,I2=255,M2=255
              13035 MCO:SLP:TPD
              13037 MCO:SLP:WUP=-1
              13039 MCO:SLP:MS=987,SMS=0,I1=1,M1=1,I2=255,M2=255
              13045 MCO:SLP:TPD
              13047 MCO:SLP:WUP=-1
              13051 MCO:SLP:MS=975,SMS=0,I1=1,M1=1,I2=255,M2=255
              13056 MCO:SLP:TPD
              13058 MCO:SLP:WUP=-1
              13062 MCO:SLP:MS=964,SMS=0,I1=1,M1=1,I2=255,M2=255
              13068 MCO:SLP:TPD
              13070 MCO:SLP:WUP=-1
              13072 MCO:SLP:MS=954,SMS=0,I1=1,M1=1,I2=255,M2=255
              13078 MCO:SLP:TPD
              13080 MCO:SLP:WUP=-1
              13082 MCO:SLP:MS=944,SMS=0,I1=1,M1=1,I2=255,M2=255
              13088 MCO:SLP:TPD
              13090 MCO:SLP:WUP=-1
              13092 MCO:SLP:MS=934,SMS=0,I1=1,M1=1,I2=255,M2=255
              13099 MCO:SLP:TPD
              13101 MCO:SLP:WUP=-1
              13105 MCO:SLP:MS=921,SMS=0,I1=1,M1=1,I2=255,M2=255
              13109 MCO:SLP:TPD
              13111 MCO:SLP:WUP=-1
              13115 MCO:SLP:MS=911,SMS=0,I1=1,M1=1,I2=255,M2=255
              13121 MCO:SLP:TPD
              13123 MCO:SLP:WUP=-1
              13125 MCO:SLP:MS=901,SMS=0,I1=1,M1=1,I2=255,M2=255
              13131 MCO:SLP:TPD
              13133 MCO:SLP:WUP=-1
              13135 MCO:SLP:MS=891,SMS=0,I1=1,M1=1,I2=255,M2=255
              13142 MCO:SLP:TPD
              13144 MCO:SLP:WUP=-1
              13146 MCO:SLP:MS=880,SMS=0,I1=1,M1=1,I2=255,M2=255
              13152 MCO:SLP:TPD
              13154 MCO:SLP:WUP=-1
              13158 MCO:SLP:MS=868,SMS=0,I1=1,M1=1,I2=255,M2=255
              13162 MCO:SLP:TPD
              13164 MCO:SLP:WUP=-1
              13168 MCO:SLP:MS=858,SMS=0,I1=1,M1=1,I2=255,M2=255
              13174 MCO:SLP:TPD
              13176 MCO:SLP:WUP=-1
              13178 MCO:SLP:MS=848,SMS=0,I1=1,M1=1,I2=255,M2=255
              13185 MCO:SLP:TPD
              13187 MCO:SLP:WUP=-1
              13189 MCO:SLP:MS=837,SMS=0,I1=1,M1=1,I2=255,M2=255
              13195 MCO:SLP:TPD
              13197 MCO:SLP:WUP=-1
              13199 MCO:SLP:MS=827,SMS=0,I1=1,M1=1,I2=255,M2=255
              13205 MCO:SLP:TPD
              13207 MCO:SLP:WUP=-1
              13211 MCO:SLP:MS=815,SMS=0,I1=1,M1=1,I2=255,M2=255
              13215 MCO:SLP:TPD
              13217 MCO:SLP:WUP=-1
              13221 MCO:SLP:MS=805,SMS=0,I1=1,M1=1,I2=255,M2=255
              13228 MCO:SLP:TPD
              13230 MCO:SLP:WUP=-1
              13232 MCO:SLP:MS=794,SMS=0,I1=1,M1=1,I2=255,M2=255
              13238 MCO:SLP:TPD
              13240 MCO:SLP:WUP=-1
              13242 MCO:SLP:MS=784,SMS=0,I1=1,M1=1,I2=255,M2=255
              13248 MCO:SLP:TPD
              13250 MCO:SLP:WUP=-1
              13252 MCO:SLP:MS=774,SMS=0,I1=1,M1=1,I2=255,M2=255
              13258 MCO:SLP:TPD
              13260 MCO:SLP:WUP=-1
              13264 MCO:SLP:MS=762,SMS=0,I1=1,M1=1,I2=255,M2=255
              13268 MCO:SLP:TPD
              13271 MCO:SLP:WUP=-1
              13275 MCO:SLP:MS=751,SMS=0,I1=1,M1=1,I2=255,M2=255
              13279 MCO:SLP:TPD
              13283 MCO:SLP:WUP=-1
              13285 MCO:SLP:MS=741,SMS=0,I1=1,M1=1,I2=255,M2=255
              13291 MCO:SLP:TPD
              13293 MCO:SLP:WUP=-1
              13295 MCO:SLP:MS=731,SMS=0,I1=1,M1=1,I2=255,M2=255
              13301 MCO:SLP:TPD
              13303 MCO:SLP:WUP=-1
              13305 MCO:SLP:MS=721,SMS=0,I1=1,M1=1,I2=255,M2=255
              13312 MCO:SLP:TPD
              13314 MCO:SLP:WUP=-1
              13318 MCO:SLP:MS=708,SMS=0,I1=1,M1=1,I2=255,M2=255
              13322 MCO:SLP:TPD
              13324 MCO:SLP:WUP=-1
              13328 MCO:SLP:MS=698,SMS=0,I1=1,M1=1,I2=255,M2=255
              13332 MCO:SLP:TPD
              13336 MCO:SLP:WUP=-1
              13338 MCO:SLP:MS=688,SMS=0,I1=1,M1=1,I2=255,M2=255
              13344 MCO:SLP:TPD
              13346 MCO:SLP:WUP=-1
              13348 MCO:SLP:MS=678,SMS=0,I1=1,M1=1,I2=255,M2=255
              13355 MCO:SLP:TPD
              13357 MCO:SLP:WUP=-1
              13359 MCO:SLP:MS=667,SMS=0,I1=1,M1=1,I2=255,M2=255
              13365 MCO:SLP:TPD
              13367 MCO:SLP:WUP=-1
              13371 MCO:SLP:MS=655,SMS=0,I1=1,M1=1,I2=255,M2=255
              13375 MCO:SLP:TPD
              13377 MCO:SLP:WUP=-1
              13381 MCO:SLP:MS=645,SMS=0,I1=1,M1=1,I2=255,M2=255
              13385 MCO:SLP:TPD
              13389 MCO:SLP:WUP=-1
              13391 MCO:SLP:MS=635,SMS=0,I1=1,M1=1,I2=255,M2=255
              13398 MCO:SLP:TPD
              13400 MCO:SLP:WUP=-1
              13402 MCO:SLP:MS=624,SMS=0,I1=1,M1=1,I2=255,M2=255
              13408 MCO:SLP:TPD
              13410 MCO:SLP:WUP=-1
              13412 MCO:SLP:MS=614,SMS=0,I1=1,M1=1,I2=255,M2=255
              13418 MCO:SLP:TPD
              13420 MCO:SLP:WUP=-1
              13424 MCO:SLP:MS=602,SMS=0,I1=1,M1=1,I2=255,M2=255
              13428 MCO:SLP:TPD
              13430 MCO:SLP:WUP=-1
              13434 MCO:SLP:MS=592,SMS=0,I1=1,M1=1,I2=255,M2=255
              13438 MCO:SLP:TPD
              13441 MCO:SLP:WUP=-1
              13445 MCO:SLP:MS=581,SMS=0,I1=1,M1=1,I2=255,M2=255
              13451 MCO:SLP:TPD
              13453 MCO:SLP:WUP=-1
              13455 MCO:SLP:MS=571,SMS=0,I1=1,M1=1,I2=255,M2=255
              13461 MCO:SLP:TPD
              13463 MCO:SLP:WUP=-1
              13465 MCO:SLP:MS=561,SMS=0,I1=1,M1=1,I2=255,M2=255
              13471 MCO:SLP:TPD
              13473 MCO:SLP:WUP=-1
              13475 MCO:SLP:MS=551,SMS=0,I1=1,M1=1,I2=255,M2=255
              13481 MCO:SLP:TPD
              13484 MCO:SLP:WUP=-1
              13488 MCO:SLP:MS=538,SMS=0,I1=1,M1=1,I2=255,M2=255
              13492 MCO:SLP:TPD
              13494 MCO:SLP:WUP=-1
              13498 MCO:SLP:MS=528,SMS=0,I1=1,M1=1,I2=255,M2=255
              13504 MCO:SLP:TPD
              13506 MCO:SLP:WUP=-1
              13508 MCO:SLP:MS=518,SMS=0,I1=1,M1=1,I2=255,M2=255
              13514 MCO:SLP:TPD
              13516 MCO:SLP:WUP=-1
              13518 MCO:SLP:MS=508,SMS=0,I1=1,M1=1,I2=255,M2=255
              13524 MCO:SLP:TPD
              13527 MCO:SLP:WUP=-1
              13529 MCO:SLP:MS=497,SMS=0,I1=1,M1=1,I2=255,M2=255
              13535 MCO:SLP:TPD
              13537 MCO:SLP:WUP=-1
              13541 MCO:SLP:MS=485,SMS=0,I1=1,M1=1,I2=255,M2=255
              13545 MCO:SLP:TPD
              13547 MCO:SLP:WUP=-1
              13551 MCO:SLP:MS=475,SMS=0,I1=1,M1=1,I2=255,M2=255
              13555 MCO:SLP:TPD
              13559 MCO:SLP:WUP=-1
              13561 MCO:SLP:MS=465,SMS=0,I1=1,M1=1,I2=255,M2=255
              13568 MCO:SLP:TPD
              13570 MCO:SLP:WUP=-1
              13572 MCO:SLP:MS=454,SMS=0,I1=1,M1=1,I2=255,M2=255
              13578 MCO:SLP:TPD
              13580 MCO:SLP:WUP=-1
              13582 MCO:SLP:MS=444,SMS=0,I1=1,M1=1,I2=255,M2=255
              13588 MCO:SLP:TPD
              13590 MCO:SLP:WUP=-1
              13594 MCO:SLP:MS=432,SMS=0,I1=1,M1=1,I2=255,M2=255
              13598 MCO:SLP:TPD
              13600 MCO:SLP:WUP=-1
              13604 MCO:SLP:MS=422,SMS=0,I1=1,M1=1,I2=255,M2=255
              13608 MCO:SLP:TPD
              13613 MCO:SLP:WUP=-1
              13615 MCO:SLP:MS=411,SMS=0,I1=1,M1=1,I2=255,M2=255
              13621 MCO:SLP:TPD
              13623 MCO:SLP:WUP=-1
              13625 MCO:SLP:MS=401,SMS=0,I1=1,M1=1,I2=255,M2=255
              13631 MCO:SLP:TPD
              13633 MCO:SLP:WUP=-1
              13635 MCO:SLP:MS=391,SMS=0,I1=1,M1=1,I2=255,M2=255
              13641 MCO:SLP:TPD
              13643 MCO:SLP:WUP=-1
              13647 MCO:SLP:MS=379,SMS=0,I1=1,M1=1,I2=255,M2=255
              13651 MCO:SLP:TPD
              13654 MCO:SLP:WUP=-1
              13658 MCO:SLP:MS=368,SMS=0,I1=1,M1=1,I2=255,M2=255
              13662 MCO:SLP:TPD
              13664 MCO:SLP:WUP=-1
              13668 MCO:SLP:MS=358,SMS=0,I1=1,M1=1,I2=255,M2=255
              13674 MCO:SLP:TPD
              13676 MCO:SLP:WUP=-1
              13678 MCO:SLP:MS=348,SMS=0,I1=1,M1=1,I2=255,M2=255
              13684 MCO:SLP:TPD
              13686 MCO:SLP:WUP=-1
              13688 MCO:SLP:MS=338,SMS=0,I1=1,M1=1,I2=255,M2=255
              13694 MCO:SLP:TPD
              13697 MCO:SLP:WUP=-1
              13699 MCO:SLP:MS=327,SMS=0,I1=1,M1=1,I2=255,M2=255
              13705 MCO:SLP:TPD
              13707 MCO:SLP:WUP=-1
              13711 MCO:SLP:MS=315,SMS=0,I1=1,M1=1,I2=255,M2=255
              13715 MCO:SLP:TPD
              13717 MCO:SLP:WUP=-1
              13721 MCO:SLP:MS=305,SMS=0,I1=1,M1=1,I2=255,M2=255
              13727 MCO:SLP:TPD
              13729 MCO:SLP:WUP=-1
              13731 MCO:SLP:MS=295,SMS=0,I1=1,M1=1,I2=255,M2=255
              13737 MCO:SLP:TPD
              13740 MCO:SLP:WUP=-1
              13742 MCO:SLP:MS=284,SMS=0,I1=1,M1=1,I2=255,M2=255
              13748 MCO:SLP:TPD
              13750 MCO:SLP:WUP=-1
              13752 MCO:SLP:MS=274,SMS=0,I1=1,M1=1,I2=255,M2=255
              13758 MCO:SLP:TPD
              13760 MCO:SLP:WUP=-1
              13764 MCO:SLP:MS=262,SMS=0,I1=1,M1=1,I2=255,M2=255
              13768 MCO:SLP:TPD
              13770 MCO:SLP:WUP=-1
              13774 MCO:SLP:MS=252,SMS=0,I1=1,M1=1,I2=255,M2=255
              13778 MCO:SLP:TPD
              13783 MCO:SLP:WUP=-1
              13785 MCO:SLP:MS=241,SMS=0,I1=1,M1=1,I2=255,M2=255
              13791 MCO:SLP:TPD
              13793 MCO:SLP:WUP=-1
              13795 MCO:SLP:MS=231,SMS=0,I1=1,M1=1,I2=255,M2=255
              13801 MCO:SLP:TPD
              13803 MCO:SLP:WUP=-1
              13805 MCO:SLP:MS=221,SMS=0,I1=1,M1=1,I2=255,M2=255
              13811 MCO:SLP:TPD
              13813 MCO:SLP:WUP=-1
              13817 MCO:SLP:MS=209,SMS=0,I1=1,M1=1,I2=255,M2=255
              13821 MCO:SLP:TPD
              13824 MCO:SLP:WUP=-1
              13828 MCO:SLP:MS=198,SMS=0,I1=1,M1=1,I2=255,M2=255
              13832 MCO:SLP:TPD
              13836 MCO:SLP:WUP=-1
              13838 MCO:SLP:MS=188,SMS=0,I1=1,M1=1,I2=255,M2=255
              13844 MCO:SLP:TPD
              13846 MCO:SLP:WUP=-1
              13848 MCO:SLP:MS=178,SMS=0,I1=1,M1=1,I2=255,M2=255
              13854 MCO:SLP:TPD
              13856 MCO:SLP:WUP=-1
              13858 MCO:SLP:MS=168,SMS=0,I1=1,M1=1,I2=255,M2=255
              13864 MCO:SLP:TPD
              13867 MCO:SLP:WUP=-1
              13869 MCO:SLP:MS=157,SMS=0,I1=1,M1=1,I2=255,M2=255
              13875 MCO:SLP:TPD
              13877 MCO:SLP:WUP=-1
              13881 MCO:SLP:MS=145,SMS=0,I1=1,M1=1,I2=255,M2=255
              13885 MCO:SLP:TPD
              13887 MCO:SLP:WUP=-1
              13891 MCO:SLP:MS=135,SMS=0,I1=1,M1=1,I2=255,M2=255
              13895 MCO:SLP:TPD
              13899 MCO:SLP:WUP=-1
              13901 MCO:SLP:MS=125,SMS=0,I1=1,M1=1,I2=255,M2=255
              13907 MCO:SLP:TPD
              13910 MCO:SLP:WUP=-1
              13912 MCO:SLP:MS=114,SMS=0,I1=1,M1=1,I2=255,M2=255
              13918 MCO:SLP:TPD
              13920 MCO:SLP:WUP=-1
              13922 MCO:SLP:MS=104,SMS=0,I1=1,M1=1,I2=255,M2=255
              13928 MCO:SLP:TPD
              13930 MCO:SLP:WUP=-1
              13932 MCO:SLP:MS=94,SMS=0,I1=1,M1=1,I2=255,M2=255
              13938 MCO:SLP:TPD
              13940 MCO:SLP:WUP=-1
              13944 MCO:SLP:MS=82,SMS=0,I1=1,M1=1,I2=255,M2=255
              13948 MCO:SLP:TPD
              13950 MCO:SLP:WUP=-1
              13955 MCO:SLP:MS=71,SMS=0,I1=1,M1=1,I2=255,M2=255
              13959 MCO:SLP:TPD
              13961 MCO:SLP:WUP=-1
              13965 MCO:SLP:MS=61,SMS=0,I1=1,M1=1,I2=255,M2=255
              13969 MCO:SLP:TPD
              13971 MCO:SLP:WUP=-1
              13975 MCO:SLP:MS=51,SMS=0,I1=1,M1=1,I2=255,M2=255
              13979 MCO:SLP:TPD
              13983 MCO:SLP:WUP=-1
              13985 MCO:SLP:MS=41,SMS=0,I1=1,M1=1,I2=255,M2=255
              13991 MCO:SLP:TPD
              13993 MCO:SLP:WUP=-1
              13996 MCO:SLP:MS=30,SMS=0,I1=1,M1=1,I2=255,M2=255
              14002 MCO:SLP:TPD
              14004 MCO:SLP:WUP=-1
              14006 MCO:SLP:MS=20,SMS=0,I1=1,M1=1,I2=255,M2=255
              14012 MCO:SLP:TPD
              14014 MCO:SLP:WUP=-1
              14016 MCO:SLP:MS=10,SMS=0,I1=1,M1=1,I2=255,M2=255
              14022 MCO:SLP:TPD
              14024 MCO:SLP:WUP=-1
              14026 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
              14032 MCO:SLP:TPD
              I'm sorry for asking for help again @core_c but I have no idea what I'm doing wrong....
              • E esawyja
                4 TSM:INIT
                4 TSF:WUR:MS=1000
                8 TSM:INIT:TSP OK
                12 TSF:SID:OK,ID=11
                14 TSM:FPAR
                1007 MCO:BGN:STP
                2152 TSM:FPAR:OK
                2152 TSM:ID
                2154 TSM:ID:OK
                2156 TSM:UPL
                2224 TSM:UPL:OK
                4327 MCO:REG:REQ
                11036 MCO:SLP:TPD
                11046 MCO:SLP:TPD
                11059 MCO:SLP:TPD
                11069 MCO:SLP:TPD
                11079 MCO:SLP:TPD
                11089 MCO:SLP:TPD
                11102 MCO:SLP:TPD
                11112 MCO:SLP:TPD
                11122 MCO:SLP:TPD
                11134 MCO:SLP:TPD
                11145 MCO:SLP:TPD
                11155 MCO:SLP:TPD
                11165 MCO:SLP:TPD
                11177 MCO:SLP:TPD
                11188 MCO:SLP:TPD
                11198 MCO:SLP:TPD
                11208 MCO:SLP:TPD
                11220 MCO:SLP:TPD
                11231 MCO:SLP:TPD
                11241 MCO:SLP:TPD
                11251 MCO:SLP:TPD
                11264 MCO:SLP:TPD
                11274 MCO:SLP:TPD
                11284 MCO:SLP:TPD
                11294 MCO:SLP:TPD
                11307 MCO:SLP:TPD
                11317 MCO:SLP:TPD
                11327 MCO:SLP:TPD
                11339 MCO:SLP:TPD
                11350 MCO:SLP:TPD
                11360 MCO:SLP:TPD
                11370 MCO:SLP:TPD
                11382 MCO:SLP:TPD
                11393 MCO:SLP:TPD
                11403 MCO:SLP:TPD
                11413 MCO:SLP:TPD
                11425 MCO:SLP:TPD
                11436 MCO:SLP:TPD
                11446 MCO:SLP:TPD
                11456 MCO:SLP:TPD
                11468 MCO:SLP:TPD
                11479 MCO:SLP:TPD
                11489 MCO:SLP:TPD
                11499 MCO:SLP:TPD
                11511 MCO:SLP:TPD
                11522 MCO:SLP:TPD
                11532 MCO:SLP:TPD
                11542 MCO:SLP:TPD
                11554 MCO:SLP:TPD
                11565 MCO:SLP:TPD
                11575 MCO:SLP:TPD
                11585 MCO:SLP:TPD
                11597 MCO:SLP:TPD
                11608 MCO:SLP:TPD
                11618 MCO:SLP:TPD
                11628 MCO:SLP:TPD
                11640 MCO:SLP:TPD
                11651 MCO:SLP:TPD
                11661 MCO:SLP:TPD
                11671 MCO:SLP:TPD
                11683 MCO:SLP:TPD
                11694 MCO:SLP:TPD
                11704 MCO:SLP:TPD
                11714 MCO:SLP:TPD
                11726 MCO:SLP:TPD
                11737 MCO:SLP:TPD
                11747 MCO:SLP:TPD
                11757 MCO:SLP:TPD
                11769 MCO:SLP:TPD
                11780 MCO:SLP:TPD
                11790 MCO:SLP:TPD
                11800 MCO:SLP:TPD
                11812 MCO:SLP:TPD
                11823 MCO:SLP:TPD
                11833 MCO:SLP:TPD
                11843 MCO:SLP:TPD
                11855 MCO:SLP:TPD
                11866 MCO:SLP:TPD
                11876 MCO:SLP:TPD
                11886 MCO:SLP:TPD
                11898 MCO:SLP:TPD
                11909 MCO:SLP:TPD
                11919 MCO:SLP:TPD
                11929 MCO:SLP:TPD
                11939 MCO:SLP:TPD
                11952 MCO:SLP:TPD
                11962 MCO:SLP:TPD
                11972 MCO:SLP:TPD
                11982 MCO:SLP:TPD
                11995 MCO:SLP:TPD
                12005 MCO:SLP:TPD
                12015 MCO:SLP:TPD
                12025 MCO:SLP:TPD
                12036 MCO:SLP:TPD
                12048 MCO:SLP:TPD
                12058 MCO:SLP:TPD
                12068 MCO:SLP:TPD
                12079 MCO:SLP:TPD
                12091 MCO:SLP:TPD
                12101 MCO:SLP:TPD
                12111 MCO:SLP:TPD
                12122 MCO:SLP:TPD
                12134 MCO:SLP:TPD
                12144 MCO:SLP:TPD
                12154 MCO:SLP:TPD
                12165 MCO:SLP:TPD
                12177 MCO:SLP:TPD
                12187 MCO:SLP:TPD
                12197 MCO:SLP:TPD
                12208 MCO:SLP:TPD
                12220 MCO:SLP:TPD
                12230 MCO:SLP:TPD
                12240 MCO:SLP:TPD
                12251 MCO:SLP:TPD
                12263 MCO:SLP:TPD
                12273 MCO:SLP:TPD
                12283 MCO:SLP:TPD
                12294 MCO:SLP:TPD
                12306 MCO:SLP:TPD
                12316 MCO:SLP:TPD
                12326 MCO:SLP:TPD
                12337 MCO:SLP:TPD
                12349 MCO:SLP:TPD
                12359 MCO:SLP:TPD
                12369 MCO:SLP:TPD
                12380 MCO:SLP:TPD
                12390 MCO:SLP:TPD
                12402 MCO:SLP:TPD
                12412 MCO:SLP:TPD
                12423 MCO:SLP:TPD
                12433 MCO:SLP:TPD
                12445 MCO:SLP:TPD
                12455 MCO:SLP:TPD
                12466 MCO:SLP:TPD
                12476 MCO:SLP:TPD
                12488 MCO:SLP:TPD
                12498 MCO:SLP:TPD
                12509 MCO:SLP:TPD
                12519 MCO:SLP:TPD
                12531 MCO:SLP:TPD
                12541 MCO:SLP:TPD
                12552 MCO:SLP:TPD
                12562 MCO:SLP:TPD
                12574 MCO:SLP:TPD
                12584 MCO:SLP:TPD
                12595 MCO:SLP:TPD
                12605 MCO:SLP:TPD
                12617 MCO:SLP:TPD
                12627 MCO:SLP:TPD
                12638 MCO:SLP:TPD
                12648 MCO:SLP:TPD
                12658 MCO:SLP:TPD
                12670 MCO:SLP:TPD
                12681 MCO:SLP:TPD
                12691 MCO:SLP:TPD
                12701 MCO:SLP:TPD
                12713 MCO:SLP:TPD
                12724 MCO:SLP:TPD
                12734 MCO:SLP:TPD
                12744 MCO:SLP:TPD
                12756 MCO:SLP:TPD
                12767 MCO:SLP:TPD
                12777 MCO:SLP:TPD
                12787 MCO:SLP:TPD
                12800 MCO:SLP:TPD
                12810 MCO:SLP:TPD
                12820 MCO:SLP:TPD
                12830 MCO:SLP:TPD
                12843 MCO:SLP:TPD
                12853 MCO:SLP:TPD
                12863 MCO:SLP:TPD
                12873 MCO:SLP:TPD
                12886 MCO:SLP:TPD
                12896 MCO:SLP:TPD
                12906 MCO:SLP:TPD
                12916 MCO:SLP:TPD
                12929 MCO:SLP:TPD
                12939 MCO:SLP:TPD
                12949 MCO:SLP:TPD
                12959 MCO:SLP:TPD
                12972 MCO:SLP:TPD
                12982 MCO:SLP:TPD
                12992 MCO:SLP:TPD
                13002 MCO:SLP:TPD
                13015 MCO:SLP:TPD
                13025 MCO:SLP:TPD
                13035 MCO:SLP:TPD
                13045 MCO:SLP:TPD
                13056 MCO:SLP:TPD
                13068 MCO:SLP:TPD
                13078 MCO:SLP:TPD
                13088 MCO:SLP:TPD
                13099 MCO:SLP:TPD
                13109 MCO:SLP:TPD
                13121 MCO:SLP:TPD
                13131 MCO:SLP:TPD
                13142 MCO:SLP:TPD
                13152 MCO:SLP:TPD
                13162 MCO:SLP:TPD
                13174 MCO:SLP:TPD
                13185 MCO:SLP:TPD
                13195 MCO:SLP:TPD
                13205 MCO:SLP:TPD
                13215 MCO:SLP:TPD
                13228 MCO:SLP:TPD
                13238 MCO:SLP:TPD
                13248 MCO:SLP:TPD
                13258 MCO:SLP:TPD
                13268 MCO:SLP:TPD
                13279 MCO:SLP:TPD
                13291 MCO:SLP:TPD
                13301 MCO:SLP:TPD
                13312 MCO:SLP:TPD
                13322 MCO:SLP:TPD
                13332 MCO:SLP:TPD
                13344 MCO:SLP:TPD
                13355 MCO:SLP:TPD
                13365 MCO:SLP:TPD
                13375 MCO:SLP:TPD
                13385 MCO:SLP:TPD
                13398 MCO:SLP:TPD
                13408 MCO:SLP:TPD
                13418 MCO:SLP:TPD
                13428 MCO:SLP:TPD
                13438 MCO:SLP:TPD
                13451 MCO:SLP:TPD
                13461 MCO:SLP:TPD
                13471 MCO:SLP:TPD
                13481 MCO:SLP:TPD
                13492 MCO:SLP:TPD
                13504 MCO:SLP:TPD
                13514 MCO:SLP:TPD
                13524 MCO:SLP:TPD
                13535 MCO:SLP:TPD
                13545 MCO:SLP:TPD
                13555 MCO:SLP:TPD
                13568 MCO:SLP:TPD
                13578 MCO:SLP:TPD
                13588 MCO:SLP:TPD
                13598 MCO:SLP:TPD
                13608 MCO:SLP:TPD
                13621 MCO:SLP:TPD
                13631 MCO:SLP:TPD
                13641 MCO:SLP:TPD
                13651 MCO:SLP:TPD
                13662 MCO:SLP:TPD
                13674 MCO:SLP:TPD
                13684 MCO:SLP:TPD
                13694 MCO:SLP:TPD
                13705 MCO:SLP:TPD
                13715 MCO:SLP:TPD
                13727 MCO:SLP:TPD
                13737 MCO:SLP:TPD
                13748 MCO:SLP:TPD
                13758 MCO:SLP:TPD
                13768 MCO:SLP:TPD
                13778 MCO:SLP:TPD
                13791 MCO:SLP:TPD
                13801 MCO:SLP:TPD
                13811 MCO:SLP:TPD
                13821 MCO:SLP:TPD
                13832 MCO:SLP:TPD
                13844 MCO:SLP:TPD
                13854 MCO:SLP:TPD
                13864 MCO:SLP:TPD
                13875 MCO:SLP:TPD
                13885 MCO:SLP:TPD
                13895 MCO:SLP:TPD
                13907 MCO:SLP:TPD
                13918 MCO:SLP:TPD
                13928 MCO:SLP:TPD
                13938 MCO:SLP:TPD
                13948 MCO:SLP:TPD
                13959 MCO:SLP:TPD
                13969 MCO:SLP:TPD
                13979 MCO:SLP:TPD
                13991 MCO:SLP:TPD
                14002 MCO:SLP:TPD
                14012 MCO:SLP:TPD
                14022 MCO:SLP:TPD
                14032 MCO:SLP:TPD
                E
                E
                esawyja
                @core_c correction, after I typed and posted this, the serial log started again and it did send the message, this is weird
                14032 MCO:SLP:TPD
                14034 MCO:SLP:WUP=1
                14047 TSF:MSG:SEND,11-11-0-0,s=7,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:0.85
                14055 MCO:SLP:MS=3000,SMS=0,I1=1,M1=1,I2=255,M2=255
                14059 MCO:SLP:TPD
                14061 MCO:SLP:WUP=-1
                14065 MCO:SLP:MS=2990,SMS=0,I1=1,M1=1,I2=255,M2=255
                14071 MCO:SLP:TPD
                14073 MCO:SLP:WUP=-1
                14075 MCO:SLP:MS=2980,SMS=0,I1=1,M1=1,I2=255,M2=255
                14082 MCO:SLP:TPD
                14084 MCO:SLP:WUP=-1
                14086 MCO:SLP:MS=2969,SMS=0,I1=1,M1=1,I2=255,M2=255
                14092 MCO:SLP:TPD
                14094 MCO:SLP:WUP=-1
                14098 MCO:SLP:MS=2957,SMS=0,I1=1,M1=1,I2=255,M2=255
                14102 MCO:SLP:TPD
                14104 MCO:SLP:WUP=-1
                14108 MCO:SLP:MS=2947,SMS=0,I1=1,M1=1,I2=255,M2=255
                14114 MCO:SLP:TPD
                14116 MCO:SLP:WUP=-1
                14118 MCO:SLP:MS=2937,SMS=0,I1=1,M1=1,I2=255,M2=255
                14125 MCO:SLP:TPD
                14127 MCO:SLP:WUP=-1
                14129 MCO:SLP:MS=2926,SMS=0,I1=1,M1=1,I2=255,M2=255
                14135 MCO:SLP:TPD
                14137 MCO:SLP:WUP=-1
                14141 MCO:SLP:MS=2914,SMS=0,I1=1,M1=1,I2=255,M2=255
                14145 MCO:SLP:TPD
                14147 MCO:SLP:WUP=-1
                14151 MCO:SLP:MS=2904,SMS=0,I1=1,M1=1,I2=255,M2=255
                14157 MCO:SLP:TPD
                14159 MCO:SLP:WUP=-1
                14161 MCO:SLP:MS=2894,SMS=0,I1=1,M1=1,I2=255,M2=255
                14168 MCO:SLP:TPD
